Kubota Zero Turn Mower ZD326-EU-2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota ZD326-EU-2 Zero Turn Mower
Number of Pages: 130 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Piston Et Vilebrequin / Piston And Crank Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Porte-Injecteur (Parties Composantes) / Nozzle Holder (Component Parts)
Couvercle / Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo (Parties Composantes) / Dynamo (Componen T Parts)
Lanceur / Starter
Demarreur (Parties Composantes) / Starter (Comp Onent Parts)
Contact A Huile Et Thermometre / Oil Switch And Thermometer
Kit D'accouplements Rapides [Option] / Water Fl Ange And Thermostat
Pompe A Eau / Water Pump
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket Kit [Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant (Avant) / Fue L Hose (Front)
Tuyau A Carburant (Arriere) / F Uel Hose (Rear)
Tuyau D'eau / Wate R Hose
Radiateur / Radiat Or
Filet De Radiateur / Radiator Net
Reservoir Du Radia Teur / Reserve Tank
Batterie / Battery
Interrupteur De Demarre Ur/Metre/Detecteur / Starter Switch/Meter/Sensor
Interrupteur/Controleur /Relais / Switch/Controller/Relay
Faisceau Electrique / W Ire Harness
Embrayage / Clutch
Carter Centre / Center Case
Couvercle Centre (Avant) / Center Cover (Fro Nt)
Couvercle Centre (Arriere) / Center Cover (R Ear)
Pompe De Charge (Parties Composantes) / Char Ge Pump (Component Parts)
Hst / Hst
Hst Dr 1 (Parties Composantes) / Hst Rh 1 (C Omponent Parts)
Hst Dr 2 (Parties Composantes) / Hst Rh 2 (C Omponent Parts)
Hst Dr 3 (Parties Composantes) / Hst Rh 3 (C Omponent Parts)
Hst Ga 1 (Parties Composantes) / Hst Lh 1 (C Omponent Parts)
Hst Ga 2 (Parties Composantes) / Hst Lh 2 (C Omponent Parts)
Hst Ga 3 (Parties Composantes) / Hst Lh 3 (C Omponent Parts)
Arbre D'embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Arbre De Cardan / Joint Shaft
Essieu / Axle
Tige De Frein / Brake Rod
Pedale De Frein De Stationnemen T / Parking Brake Pedal
Levier D E Vitesses Pdf / Pto Gear Shift Lever
Levier D E Commande Du Mouvement Droite / Motion Control Lev Er Rh
Levier D E Commande Du Mouvement Gauche / Motion Control Lev Er Lh
Bras De Commande Du Mouvement / Motion Control Arm
Pont Avant / Front Axle
Tuyau Hydraulique (Hst) / Hydraulic Pipe (Hst)
Tuyau Hydraulique/Refroi Dissement D'huile / Hydraulic Pipe/Oil Cooler
Bielette De Relevage / L Ift Pedal
Distributeur Hydraulique / Control Valve
Distributeur (Parties Co Mposantes) / Control Valve (Component Parts)
Cylindre De Relevage De Tondeuse / Mower Lift Cylinder
Bras De Relevage De Tondeuse / Mower Lift Arm
Chassis Superieur / Upper Frame
Chassis Superieur [Option] / Upper Frame [Optio N]
Couverle De Volant Moteur / Flywheel Cover
Manche De Reglage / Adjuster Handle
Regleur De Relevage / Lift Up Adjuster
Masque Avant / Front Mask
Capot (Avant) / Bonnet (Front)
Capot (Arriere) / Bonnet (Rear)
Aile Dr / Fender Rh
Aile Ga / Fender Lh
Siege / Seat
Base De Siege / Seat Base
Marchepied / Step
Cadre Anti-Renversment / Rops
Roue Avant (1 5*6-6) / Front Wheel (15*6-6)
Roue Arriere (26*12-12) / Rear Wheel (26*12-12)
Etiquettes / Labels
Accessoires / Accessories
