Kubota Zero Turn Mower ZD28-EC Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota ZD28-EC Zero Turn Mower
Number of Pages: 161 Pages
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Couvercle / Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Component P Arts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compone Nt Parts]
Contact A Huile Et Thermometre / Oil Switch And Th Ermometer
Pompe A Eau / Water Pump
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Superieur [Option] / Upper Gasket Ki T [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket Ki T [Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Plateall A Poussiere / Dustproof Plate
Reservoir Du Radiateu R / Reserve Tank
Batterie / Battery
Interrupteur/Detecteur / S Witch/Sensor
Interrupteur/Controleur / Switch/Controller
Faisceau Electrique / Elec Trical Wiring
Embrayage / Clutch
Carter De Pompe Charge / Charge Pump Case
Carter De Pompe Charge [Option] / Charge Pump Cas E [Option]
Carter De Pont Arriere Droite / Rear Axle Case Rh
Carter De Pont Arriere Gauche / Rear Axle Case Lh
Hst / Hst
Hst Doroite 1 [Parties Composantes] / Hst Rh 1 [C Omponent Parts]
Hst Doroite 2 [Parties Composantes] / Hst Rh 2 [C Omponent Parts]
Hst Gauche 1 [Parties Composantes] / Hst Lh 1 [Co Mponent Parts]
Hst Gauche 2 [Parties Composantes] / Hst Lh 2 [Co Mponent Parts]
Arbre D'embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Joint De Cardan/Ventilateur / Universal Joint/Fan
Abbre De Cardan / Joint Shaft
Axe Arriere / Rear Axle
Arbre De Fre In / Brake Shaft
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Tige De Frei N / Brake Rod
Frein De Sta Tionnement / Hand Brake
Levier De Ch Engement De Vitesse Pdf / Pto Gear Shift Lever
Levier De Co Mmande De Vitesse Droite / Speed Control Lever Rh
Levier De Co Mmande De Vitesse Gauche / Speed Control Lever Lh
Tige De Comm Ande De Vittesse 1 / Speed Control Rod 1
Tige De Comm Ande De Vittesse 2 / Speed Control Rod 2
Pedale De Fr Ein Stationnement / Parking Brake Pedal
Pont Avant / Front Axle
Circuit D'huile Hydraulique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraulique (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydraulique (Pdf) / Hydraulic Oil Line (Pto)
Tuyau Hydraulique (Hst) / H Ydraulic Pipe (Hst)
Circuit D'huile Hydraulique (Refoulement) / Hydraulic Oil Line (Oil Cooler)
Levier De Relevage / Lift L Ever
Distributeur Hydraulique / Control Valve
Distributeur [Parties Compo Santes] / Control Valve [Component Parts]
Bras De Relevage De Tondeus E / Mower Lift Arm
Chassis Superieur / Upper Frame
Regleur De Relevage / Lift Up Adjuster
Protecteur Avant / Front Mask
Capot Superieur / Hood (Bonnet)
Aile / Fender
Siege / Seat
Suspension Du Siege 1 [Parties Composantes] / Seat Suspension 1 [Component Parts]
Suspension Du Siege 2 [Parties Composantes] / Seat Suspension 2 [Component Parts]
Marchepied / Step
Roue Avant (15* 6.00-6) / Front Wheel (15*6.00-6)
Roue Arriere (2 4*12.00-12) / Rear Wheel (24*12.00-12)
Etiquette(Avant) / Label(Front)
Etiquette(Arriere) / Label(Rear)
A Ccessoires / Accessories
Jeu De Contrepoids [Option] / Weight Kit [Option]
Jeu De Avertisseur [Option] / Horn Kit [Option]
Jeu De Essieu [Option] / Axle Kit [Option]
Reservoir De La Reserve De L'huile [Option] / Oil Reserve Tank [Option]
Jeu De Cadre Anti-Renversement 1 [Option] / Rops K It 1 [Option]
Jeu De Cadre Anti-Renversement 2 [Option] / Rops K It 2 [Option]
Jeu De Pompe Charge [Option] / Kit Charge Pump [Op Tion]
Couvercle / Cover
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Embrayage / Clutch
Hst / Hst
Aile / Fender
Siege / Seat
Marchepied / Step
