Kubota Zero Turn Mower ZD1211R-EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota ZD1211R-EU Zero Turn Mower
Number of Pages: 122 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Piston Et Vilebrequin / Piston And Crankshaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle / Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Componen T Parts]
Demarreur / Starter
Demarreur [Parties Composantes] / Starter [Comp Onent Parts]
Contacteur A Huile Et Obturateur / Oil Switch A Nd Plug
Bride A Eau Et Thermostat / Water Flange And Th Ermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Soupapes Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Acceler Ator Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant 2 / Fuel Pipe 2
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Plateall A Poussie Re / Dustproof Plate
Reservoir Du Radia Teur / Reserve Tank
Batterie / Battery
Interrupteur De Demarre Ur/Metre/Detecteur / Starter Switch/Meter/Sensor
Interrupteur/Controleur /Relais / Switch/Controller/Relay
Faisceau Electrique / E Lectrical Wiring
Embrayage / Clutch
Couvercle Centre (Avant) / Center Cover (Fro Nt)
Couvercle De Centre (Arriere) / Center Cover (Rear)
Pompe De Charge / Charge Pump
Hst / Hst
Hst Gauche 1 [Parties Composantes] / Hst Lh 1 [Component Parts]
Hst Gauche 2 [Parties Composantes] / Hst Lh 2 [Component Parts]
Hst Gauche 3 [Parties Composantes] / Hst Lh 3 [Component Parts]
Hst Doroite 1 [Parties Composantes] / Hst Rh 1 [Component Parts]
Hst Doroite 2 [Parties Composantes] / Hst Rh 2 [Component Parts]
Hst Doroite 3 [Parties Composantes] / Hst Rh 3 [Component Parts]
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Joint De Cardan/Ventilateur / Universal Join T/Fan
Arbre De Cardan / Joint Shaft
Arbre De Trein / Brake Shaft
Tige De Frein / Brake Rod
Pedale De Frein De Stationnemen T / Parking Brake Pedal
Levier D E Chengement De Vitesse Pdf / Pto Gear Shift Lever
Levier D E Commande Du Mouvement Droite / Motion Control Lev Er Rh
Levier D E Commande Du Mouvement Gauche / Motion Control Lev Er Lh
Bras De Commande Du Mouvement / Motion Control Arm
Essieu Avant / Front Axle
Tuyau Hydraulique (Hst) / Hydraulic Pipe (Hst)
Tuyau Hydraulique/Refroi Dissement D'huile / Hydraulic Pipe/Oil Cooler
Levier De Relevage / Lif T Lever
Distributeur Hydraulique / Control Valve
Cylindre De Relevage / L Ift Cylinder
Bras De Relevage De Tondeuse / Mower Lift Arm
Couverle De Volant Moteur / Flywheel Cover
Manche De Reglage / Adjuster Handle
Regleur De Relevage / Lift Up Adjuster
Masque Avant / Front Mask
Capot Superieur / Hood (Bonnet) Upper
Capot (Arriere) / Bonnet (Rear)
Aile Droite / Fender Rh
Aile Gauche / Fender Lh
Siege / Seat
Base De Siege / Seat Base
Marchepied / Step
Plaque De Poussiere / Dust Plate
Cadre Anti-Renversment / Rops
Roue Avant (15 *6,5-8ff) / Front Wheel (15*6,5-8ff)
Roue Arriere ( 26*12,0-16) / Rear Wheel (26*12,0-16)
Etiquettes / Labels
Accessoires / Accessories
