Kubota Zero Turn Mower Z122RKW-EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota Z122RKW-EU Zero Turn Mower
Number of Pages: 60 Pages
Bloc Moteur / Crankcase
Filtre D'huile / Oil Filter
Carter De Lanceur / Fan Cover
Arbre A Cames / Camshaft
Piston Et Vilebrequin / Piston And Crankshaft
Volant Moteur Et Magneto / Flywheel And Magneto
Demarreur [Parties Composantes] / Starter [Comp Onent Parts]
Plaque De Vitesse-Controle / Speed Control Plat E
Pompe D'alimentation(Electrique) / Fuel Pump(El Ectrical)
Collecteur D'admission Et Carburateur / Inlet M Anifold And Carburettor
Filtre A Air / Air Cleaner
Silencieux / Muffler
Etiquettes / Labels
Levier D'accelerateur / Acceler Ator Lever
Reservoir A Carburant / Fuel Ta Nk
Tuyau A Carburant / Fuel Pipe
Batterie / Battery
Commutateur / Switch
Faisceau Electrique / E Lectrical Wiring
Hst / Hst
Hst Gauche 1 [Parties Composantes] / Hst Lh 1 (Component Parts)
Hst Gauche 2 [Parties Composantes] / Hst Lh 2 (Component Parts)
Hst Doroite 1 [Parties Composantes] / Hst Rh 1 (Component Parts)
Hst Doroite 2 [Parties Composantes] / Hst Rh 2 (Component Parts)
Hst Doroite 3 [Parties Composantes] / Hst Rh 3 (Component Parts)
Poulie De Hst / Hst Pulley
Levier De Frein De Stationnemen T / Parking Brake Lever
Levier D E Commande Du Mouvement Gauche / Motion Control Lev Er Lh
Levier D E Commande Du Mouvement Droite / Motion Control Lev Er Rh
Tige De Commande De Vittesse / Speed Control Rod
Support De Reducteur / Front Wheel Br Acket
Bras De Relevage De Tondeuse / Mower Lift Arm
Levier D E Relevage De Tondeuse / Mower Lift Lever
Relevage [Option] / Hitch [Option]
Chassis Avant / Front Frame
Chassis Superieur / Upper Frame
Siege / Seat
Base De Siège / Seat Base
Marche/Aile / Step/Fender
Roue Avant (11 *4-5) / Front Wheel (11*4-5)
Accessoires / Accessories
Accoudoir [Option] / Armrest Kit [Option]
