Kubota Zero Turn Mower GZD21-2HD Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota GZD21-2HD Zero Turn Mower
Number of Pages: 159 Pages
Frequently Used It Ems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Volant Du Moteur / Flywheel
Regulateur De Vitesses [Vieux] / Governor [Old]
Regulateur De Vitesses [Nouveau] / Governor [New ]
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Couvercle / Cover
Kit D'accouplements Rapides [Option] / Water Fla Nge And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Levier D'accelerateur / Accelera Tor Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Ventilateur / Fan
Tuyau D'eau (Moteur ) / Water Pipe (Engine )
Tuyau D'eau (Radiat Eur) / Water Pipe (Radiator)
Radiateur / Radiato R
Plateall A Poussier E / Dustproof Plate
Reservoir Du Radiat Eur / Reserve Tank
Contact A Huile Thermome Tre / Oil Switch And Thermo Sensor
Dynamo / Dynamo
Dynamo [Parties Composan Tes] / Dynamo [Component Parts]
Lanceur / Starter
Batterie / Battery
Commutateur / Switch
Interrupteur De Demarreu R/Metre / Starter Switch/Meter
Interrupteur/Controleur / Switch/Controller
Avertisseur/Relais / Hor N/Relay
Faisceau Electrique / El Ectrical Wiring
Embrayage / Clutch
Reniflard De Transmission / Transmission Brea Ther
Carter Pont Arriere (Droite) / Rear Axle Case (Right)
Carter Pont Arriere (Gauche) / Rear Axle Case (Left)
Support De Boîte D'essieu Arrière / Rear Axle Case Support
Hst / Hst
Hst Doroite (Bloc-Cylindres) [Parties Composa Ntes] / Hst Rh (Cylinder Block) [Component Parts]
Hst Doroite (Carter) [Parties Composantes] / Hst Rh (Housing) [Component Parts]
Hst Gauche (Bloc-Cylindres) [Parties Composan Tes] / Hst Lh (Cylinder Block) [Component Parts]
Hst Gauche (Carter) [Parties Composantes] / H St Lh (Housing) [Component Parts]
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Joint De Cardan (Entree) / Universal Joint (I Nput)
Arbre De Cardan / Joint Shaft
Arbre Pdf Interm / Pto Countershaft
Arbre De Prise De Force / Pto Shaft
Essieu Arriere (Droite) / Rear Axle (Right)
Arbre D'entraînement De La Roue Arrière (Droi Te) / Rear Wheel Drive Shaft (Right)
Arbre D'entraînement De La Roue Arrière (Gauc He) / Rear Wheel Drive Shaft (Left)
Frein / Brake
Levier De Frein / Brake Arm
Pedale De Frein De Stationnement / Parking Brake Pedal
Levier De Chengement De Vitesse Pdf / Pto Gear Shift Lever
Levier De Commande Du Mouvement (Gauche) / Motion Control Le Ver (Left)
Tige De C Ommande De Vittesse / Speed Control Rod
Pont Avant / Front Axle
Circuit D'huile Hydrauliq Ue (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrauliq Ue (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydrauliq Ue (Reniflard) / Hydraulic Oil Line (Breather)
Circuit D'huile Hydrauliq Ue (Refoulement) / Hydraulic Oil Line (Oil Cooler)
Bras De Relevage / Lift A Rm
Distributeur Hydraulique / Control Valve
Distributeur [Parties Com Posantes] / Control Valve [Component Parts]
Cylindre De Relevage / Li Ft Cylinder
Cylindre De Relevage [Par Ties Composantes] / Lift Cylinder [Component Parts]
Bras De Relevage De Tonde Use / Mower Lift Arm
Relevage De Tondeuse (Cen Tre) / Mower Link (Center)
Relevage De Tondeuse (Dro Ite) / Mower Link (Right)
Relevage De Tondeuse (Gau Che) / Mower Link (Left)
Levier De Sauter De Tonde Use / Mower Jump Lever
Conduit / Duct
Contrepoids / Weight
Couvercle D' Arbre / Shaft Cover
Capot Superieur / Hood (Bonnet) Upper
Couvercle Lateral Inferieur / Side Cover L Ower
Aile / Fender
Siege / Seat
Marchepied / Step
Cadre Anti-Renversment / Rops
Roue Avant (15* 6,00-6) / Front Wheel (15*6.00-6)
Roue Arriere (2 3*10,5-12) / Rear Wheel (23*10.5-12)
Accessoires / Accessories
Jeu De Contrepoids [Option] / Weight Kit [Option ]
Couvercle / Cover
Ventilateur / Fan
Dynamo / Dynamo
Lanceur / Starter
Batterie / Battery
Embrayage / Clutch
Hst / Hst
Frein / Brake
Conduit / Duct
Aile / Fender
Siege / Seat
Marchepied / Step
