Kubota Zero Turn Mower GZD15-IILD GZD15-IILDF Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-IILD ; GZD15-IILDF Zero Turn Mower
Number of Pages: 148 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediai Re / Camshaft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Cranksha Ft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Contro L Plate
Porte-Injecteur [Parties Composantes] / Nozz Le Holder [Component Parts]
Couvercle / Cover
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pip E (Air Cleaner)
Silencieux / Muffler
Levier D'accelerateur / Acce Lerator Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pip E
Filtlre A Essence / Fuel Fil Ter
Ventilateur / F An
Tuyau D'eau (Mo Teur) / Water Pipe (Engine)
Tuyau D'eau (Ra Diateur) / Water Pipe (Radiator)
Radiateur / Rad Iator
Plateall A Pous Siere / Dustproof Plate
Reservoir Du Ra Diateur / Reserve Tank
Contact A Huile Ther Mometre / Oil Switch And Thermo Sensor
Dynamo / Dynamo
Dynamo [Parties Comp Osantes] / Dynamo [Component Parts]
Demarreur / Starter
Demarreur [Parties C Omposantes] / Starter [Component Parts]
Batterie / Battery # # No.S.<=80014 S.No.;<=80014 / S.No.<=80014 S.No.;< =80014
Batterie / Battery # # No.S.>=80015 S.No.;>=80015 / S.No.>=80015 S.No.;> =80015
Commutateur / Switch
Interrupteur / Switc H
Interrupteur/Control Eur / Switch/Controller
Avertisseur/Relais / Horn/Relay
Faisceau Electrique / Electrical Wiring
Embrayage / Clutch
Reniflard De Transmission / Transmission Breather
Carter De Transmission / Transmission Cas E
Carter Pont Arriere Droite / Rear Axle Ca Se Rh
Carter Pont Arriere Gauche / Rear Axle Ca Se Lh
Support De Boîte D'essieu Arrière / Rear Axle Case Support
Hst / Hst
Hst Doroite(Bloc-Cylindres) [Parties Comp Osantes] / Hst Rh(Cylinder Block) [Component Parts]
Hst Doroite(Carter) [Parties Composantes] / Hst Rh(Housing) [Component Parts]
Hst Gauche(Bloc-Cylindres) [Parties Compo Santes] / Hst Lh(Cylinder Block) [Component Parts]
Hst Gauche(Carter) [Parties Composantes] / Hst Lh(Housing) [Component Parts]
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Joint De Cardan(Entree) / Universal Joint (Input)
Arbre De Cardan / Joint Shaft
Arbre Pdf Interm / Pto Countershaft
Arbre De Prise De Force / Pto Shaft
Couvercle De Joint De Cardan / Universal Joint Cover
Essieu Arriere (Droite) / Rear Axle (Righ T)
Essieu Arriere (Gauche) / Rear Axle (Left )
Arbre D'entraînement De La Roue Arrière ( Droite) / Rear Wheel Drive Shaft(Right)
Arbre D'entraînement De La Roue Arrière ( Gauche) / Rear Wheel Drive Shaft(Left)
Frein / Brake
Levier De Frein / Brake Arm
Levier De Vitesses Pdf / Pto Gear Shift Lever
Levier De Commande De Vi Tesse Droite / Speed Control Lever Rh
Levier De Commande De Vi Tesse Gauche / Speed Control Lever Lh
Tige De Commande De Vitt Esse / Speed Control Rod
Pont Avant / Front Axle
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Pa Rties Composantes] / Hydraulic Pump [Component Part S]
Circuit De Huile Hydr Aulique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydra Ulique(Reniflard) / Hydraulic Oil Line(Breather)
Circuit D'huile Hydra Ulique (Refoulement) / Hydraulic Oil Line(Oil Coole R)
Bras De Relevage / Li Ft Arm
Distributeur Hydrauli Que / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Cylindre De Relevage [Parties Composantes] / Lift Cylinder [Component Pa Rts]
Bras De Relevage De T Ondeuse / Mower Lift Arm
Relevage De Tondeuse (Centre) / Mower Link(Center)
Relevage De Tondeuse (Droite) / Mower Link(Right)
Relevage De Tondeuse (Gauche) / Mower Link(Left)
Conduit / Duct
Contrepoids / Weight
Chassis / Main Frame
Couvercle D' Arbre / Shaft Cover
Capot Superieur / Hood (Bonnet) Upper
Couvercle Lateral Inferieur / Side Cov Er Lower
Aile Droite / Fender
Siege / Seat
Marchepied / Step
Couvercle Inférieur / Under Cover
Avant Pneu (15*6,00-6) / Front Wheel (15*6.00-6)
Arriere Pne U (20*10-8) / Rear Wheel (20*10-8)
Accessoires / Accessories
Jeu De Contrepoids [Option] / Weight Kit [Op Tion]
Kit Du Reniflard [Option] / Breather Kit [Op Tion]
