Kubota Zero Turn Mower GZD15-IILD GZD15-IIHD GZD21-HD Operators Manual K2013-7121-7
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-IILD, GZD15-IIHD, GZD21-HD Zero Turn Mower
Part Number: K2013-7121-7
Number of Pages: 105 Pages
Safe Operation
Servicing Of Machine
Specifications
Instrument Panel And Controls
Mower Mounting
Setting Up The Mower
Mounting The Mower Deck
Adjusting The Mower
Dismounting The Mower Deck
Grass Catcher Mounting
Attaching The Grass Catcher
Mounting The Container
Dismounting The Container
Operating The Engine
Starting The Engine
Check During Operating
Immediately Stop The Engine If:
Easy Checker (Tm)
Engine Overheating Precautions
Fuel Gauge
Hour Meter
Cold Weather Starting
Block Heater (Option)
Warming Up
Warm-Up And Transmission Oil In The Low Temperature Range
Jump Starting
Stopping The Engine
Operating The Machine
Operating New Machine
Changing Lubricating Oil For New Machines
Engine Break-In
Machine Break-In
Starting
Stopping
Parking
Transporting
Front Wheel Bracket Lock
Operating The Mower
Making The Most Of Your Mower
Adjusting Cutting Height
Operating Mower
Pto Lever
Starting
Operating The Grass Catcher
Operating Performance
Emptying Grass Catcher (For Ld)
Emptying The Grass Catcher (For Hd)
Quick Clean Lever
Cleaning
Cleaning With Water
Cleaning The Mowing System
Cleaning The Grass Catching Container
Cleaning The Mowing System Using A Hose
Tires And Wheels
Tires
Inflation Pressure
Rear Ballast (Option)
Remove And Install Front Caster Wheels
Maintenance
Service Intervals
Lubricants, Fuel And Coolant
Periodic Service
How To Open The Hood
Hood
Engine Side Cover
How To Raise The Operator's Seat
How To Open The Boot
Lift-Up Point
Front Side:
Rear Side:
Daily Check
Checking Engine Oil Level
Checking Amount Of Fuel And Refueling
Checking And Cleaning Radiator To Prevent Overheating
Checking Tire Pressure
Checking Transmission Fluid Level
Checking Coolant Level
Cleaning Mower Deck
Checking Movable Parts
Every 50 Hours
Safety Devices
Cleaning Air Cleaner Element
Checking Gear Box Oil Level
Checking Front Pto Case Oil Level
Lubricating All Grease Fittings
Oiling
Checking Battery Condition
Every 100 Hours
Changing Engine Oil
Checking Fuel Lines And Fuel Filter
Checking Fan Drive Belt Tension
Checking Parking Brake
Every 150 Hours
Changing Gear Box Oil
Every 200 Hours
Replacing Engine Oil Filter Cartridge
Changing Transmission And Rear Axle Gear Case Fluid
Replacing Transmission Oil Filter Cartridge
Checking Radiator Hose And Clamp
Checking Hydraulic Hose
Adjusting Front Axle Pivot
Adjusting Front Caster
Checking Intake Air Line
Every 400 Hours
Replacing Fuel Filter
Every 1 Year
Replacing Air Cleaner Element
Flushing Cooling System And Changing Coolant
Anti-Freeze
Every 2 Years
Replacing Hydraulic Hose
Replacing Fuel Lines
Replacing Engine Breather Hose
Replacing Radiator Hose
Replacing Mower Gear Box Oil-Seal
Replacing Intake Air Line
Service As Required
Replacing Fuses
Checking And Replacing Blade
Mower Belt Replacement
Bleeding Fuel System
Adjustment
Motion Control Lever
Hst Neutral
Reverse Return Position
Maximum Speed (Forward)
Motion Control Lever Alignment
Mower Deck Level
Level Mower Deck (Side-To-Side)
Level Mower Deck (Front-To-Rear)
General Torque Specification
Tightening Torque Chart
Storage
Machine Storage
Removing The Machine From Storage
Troubleshooting
Engine Troubleshooting
Battery Troubleshooting
Machine Troubleshooting
Mower Troubleshooting
Grass Catcher Troubleshooting
Option
Sound And Vibration Measurements
Index
Safe Operation
Specifications
Mower Mounting
Adjusting The Mower
Starting The Engine
Easy Checker (Tm)
Fuel Gauge
Hour Meter
Warming Up
Jump Starting
Stopping The Engine
Engine Break-In
Machine Break-In
Starting
Stopping
Parking
Transporting
Operating The Mower
Operating Mower
Pto Lever
Starting
Quick Clean Lever
Cleaning
Cleaning With Water
Tires And Wheels
Tires
Inflation Pressure
Maintenance
Service Intervals
Periodic Service
Hood
Engine Side Cover
Lift-Up Point
Front Side:
Rear Side:
Daily Check
Cleaning Mower Deck
Every 50 Hours
Safety Devices
Oiling
Every 100 Hours
Changing Engine Oil
Every 150 Hours
Every 200 Hours
Every 400 Hours
Every 1 Year
Anti-Freeze
Every 2 Years
Service As Required
Replacing Fuses
Adjustment
Hst Neutral
Mower Deck Level
Storage
Machine Storage
Troubleshooting
Option
Index
