Kubota Zero Turn Mower GZD15-IIHD Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-IIHD Zero Turn Mower
Number of Pages: 161 Pages
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
[Component Parts]
Resguardo / Cover
Interruptor E Termómetro Do Óleo / Oil Switch/Th Ermometer
Acessorios / Water Pump
Radiador / Water Pipe
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Deposito Combustivel / Lower Gasket Kit
Acelarador Mao / Accelerat Or Lever
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Ventilad Or / Fan
Placa À Prova De Poeiras / Dustproof Plate
Filtro Gasoleo / Stop Sol Enoid
Dínamo / Dynamo
Dinamo [Componenetes] / D Ynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Component Es] / Starter [Component Parts]
Comutador / Switch
Interruptor/Controlador/R Elé / Switch/Controller
Buzina/Relé / Horn/Relay
Cablagem Electrica / Elec Trical Wiring (Body)
Compensador / Clut Ch
Carter Eixo Trasei Ro Drt (Tipo Arco) / Rear Axle Case Rh
Carter Eixo Trasei Ro Esq (Tipo Arco) / Rear Axle Case Lh
Hst / Hst
Hst Direita 1 (Peç As Componentes) / Hst Rh(Cylinder Block) [Component Parts]
Hst Direita 2 (Peç As Componentes) / Hst Rh(Housing) [Component Parts]
Hst Esquerda 1 (Pe Ças Componentes) / Hst Lh(Cylinder Block) [Componen T Parts]
Hst Esquerda 2 (Pe Ças Componentes) / Hst Lh(Housing) [Component Parts ]
Veio Primario / In Put Shaft
Cardan Universal ( Veio) / Universal Joint(Input)
Veio De União / Jo Int Shaft
Veio Tdf / Pto Cou Nter Shaft
Veio Tdf / Pto Sha Ft
Cardan Universal ( Tdf) / Universal Joint(Pto)
Eixo Traseiro / Rear Axle
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brak E Pedal
Alavanca Tdf / Pto Gear Sh Ift Lever
Alavanca De Controlo De Mo Vimento Direita / Speed Control Lever Rh
Alavanca De Controlo De Mo Vimento Esquerda / Speed Control Lever Lh
Tirante De Mudança De Velo Cidade / Speed Control Rod
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico[Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraul Ic Oil Line(Suction)
Tubo Oleo / Hydraulic Oil Line(Delivery)
Radiador Oleo / Hydraulic Oil Line(Oil Cooler)
Braco Hidraulico / Lift A Rm
Braco Hidraulico / Contro L Valve
Cilndro Eleveção / Lift C Ylinder
Cilndro Eleveção[Peças Co Mponentes] / Lift Cylinder [Component Parts]
Braço De Elevação Do Cort Ador De Relva / Mower Lift Arm
Ligação Do Cortador De Re Lva (Centro) / Mower Link(Center)
Ligação Do Cortador De Re Lva (Lado Direito) / Mower Link(Right)
Ligação Do Cortador De Re Lva (Lado Esquerdo) / Mower Link(Left)
Alavanca De Salto Do Cort Ador De Relva / Mower Jump Lever
Conductor / Duct
Peso / Weight
Estrutura / Main Frame
Capot / Hood(Bonnet)
Lubrificacao (Engrenagem De Passeio De Bomba Hid Raulica) [Opção] / Side Cover Lower
Guarda Lamas / Fender
Acessorios / Seat
Degrau / Step
Roda Fren Te / Front Wheel(15*6.00-6)
Roda Tras Eira / Rear Wheel(20*10-8)
Etiqueta Frente / Label(Front)
Etiqueta Traseira / Label(Rear)
Acessorios / Accessories
Kit De Pesos / Weight Kit [Option]
