Kubota Zero Turn Mower GZD15-IIHD Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-IIHD Zero Turn Mower
Number of Pages: 166 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Cas E
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle / Cover
Contact A Huile Thermometre / Oil Switch/Thermo Meter
Kit D'accouplements Rapides [Option] / Water Fl Ange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Filter A Air / Air Cleaner
Tuyau D'admission (Filtre A Air) / Inlet Pipe ( Air Cleaner)
Silencieux / Muffler
Levier D'accelerateur / Acceler Ator Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Ventilateur / Fan
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Plateall A Poussie Re / Dustproof Plate
Reservoir Du Radia Teur / Reserve Tank
Solenoide D'arret / Sto P Solenoid
Dynamo / Dynamo
Dynamo [Parties Composa Ntes] / Dynamo [Component Parts]
Lanceur / Starter
Batterie / Battery
Interrupteur / Switch
Interrupteur/Controleur / Switch/Controller
Avertisseur/Relais / Ho Rn/Relay
Faisceau Electrique (Co Rps) / Electrical Wiring (Body)
Embrayage / Clutch
Carter De Transmis Sion / Transmission Case
Carter De Pont Arr Iere Droite / Rear Axle Case Rh
Hst / Hst
Hst Doroite(Bloc-C Ylindres) [Parties Composantes] / Hst Rh(Cylinder B Lock) [Component Parts]
Hst Gauche(Bloc-Cy Lindres) [Parties Composantes] / Hst Lh(Cylinder Bl Ock) [Component Parts]
Hst Gauche(Carter) [Parties Composantes] / Hst Lh(Housing) [Component Parts]
Arbre D'entree / I Nput Shaft
Joint De Cardan(En Tree) / Universal Joint(Input)
Arbre De Cardan / Joint Shaft
Arbre Pdf Interm / Pto Counter Shaft
Arbre De Prise For Ce / Pto Shaft
Joint De Cardan(Pd F) / Universal Joint(Pto)
Axe Arriere / Rear Axle
Frein / Brake
Pedale De Frein Stationnement / Parking Brake Ped Al
Levier De Chengement De Vit Esse Pdf / Pto Gear Shift Lever
Levier De Commande De Vites Se Droite / Speed Control Lever Rh
Levier De Commande De Vites Se Gauche / Speed Control Lever Lh
Tige De Commande De Vittess E / Speed Control Rod
Pont Avant / Front Axle
Support Avant Droit / Hy Draulic Pump
Circuit D'huile Hydrauli Que(Aspirat) / Hydraulic Oil Line(Suction)
Circuit C'huile Hydrauli Que (Retour) / Hydraulic Oil Line(Delivery)
Circuit D'huile Hydrauli Que(Reniflard) / Hydraulic Oil Line(Breather)
Circuit D'huile Hydrauli Que(Refoulement) / Hydraulic Oil Line(Oil Cooler)
Bras De Relevage / Lift Arm
Distributeur Hydraulique / Control Valve
Cylindre De Relevage / L Ift Cylinder
Cylindre De Relevage [Pa Rties Composantes] / Lift Cylinder [Component Parts ]
Relevage De Tondeuse(Cen Tre) / Mower Link(Center)
Relevage De Tondeuse(Dro Ite) / Mower Link(Right)
Relevage De Tondeuse(Gau Che) / Mower Link(Left)
Levier De Sauter De Tond Euse / Mower Jump Lever
Conduit / Duct
Contrepoids / Weight
Capot Superieur / Hood(Bonnet)
Couvercle Lateral Inferieur / Side Cover Lower
Aile / Fender
Siege / Seat
Marchepied / Step
Roue Avant(15* 6,00-6) / Front Wheel(15*6.00-6)
Roue Arriere(2 0*10-8) / Rear Wheel(20*10-8)
Etiquette(Avant) / Label(Front)
Etiquette(Arriere) / Label(Rear)
Jeu De Contrepoids [Option] / Weight Kit [Optio N]
