Kubota Zero Turn Mower GZD15-HD Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-HD Zero Turn Mower
Number of Pages: 155 Pages
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Platec
Resguardo / Cover
Interruptor E Termómetro Do Óleo / Oil Switch/Ther Mometer
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Acessorios / Water Pump
Radiador / Water Pipe
Válvula E Veio Do Balanceiro / Valve And Rocker Ar M
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Superior [Opção] / Upper Gasket Kit [ Option]
Kit De Junta Inferior [Opção / Lower Gasket Kit [O Ption]
Piston Kit [Option] / Piston Kit [Option]
Tubo Combustivel / Fuel Pipe
Ventilador / Fan
Placa À Pr Ova De Poeiras / Dustproof Plate
Deposito R Eserva / Reserve Tank
Filtro Gasoleo / Stop Solen Oid
Dínamo / Dynamo
Dinamo [Componenetes] / Dyn Amo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes ] / Starter [Component Parts]
Comutador / Switch
Interruptor/Controlador/Rel É / Switch/Controller
Cabalagem Eletrica(Cabine)[ Ec] [G] / Electrical Wiring
Compensador / Clutch
Carter Eixo Traseiro Drt (Tipo Arco) / Rear Axle Case Rh
Hst / Hst
Hst Direita 1 (Peças Componentes) / Hst Rh 1 [Component Parts]
Hst Direita 2 (Peças Componentes) / Hst Rh 2 [Component Parts]
Hst Esquerda 1 (Peça S Componentes) / Hst Lh 1 [Component Parts]
Hst Esquerda 2 (Peça S Componentes) / Hst Lh 2 [Component Parts]
Veio Embraiagem / Cl Utch Shaft
Veio Primario / Inpu T Shaft
Cardan Universal (Ve Io) / Universal Joint(Input)
Veio De União / Join T Shaft
Veio Tdf / Pto Count Er Shaft
Veio Tdf / Pto Shaft
Cardan Universal (Td F) / Universal Joint(Pto)
Eixo Traseiro / Rear Axle
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Alavanca Tdf / Pto Gear Shif T Lever
Alavanca De Controlo De Movi Mento Direita / Speed Control Lever Rh
Alavanca De Controlo De Movi Mento Esquerda / Speed Control Lever Lh
Tirante De Mudança De Veloci Dade / Speed Control Rod
Eixo Dianteiro / Front Axle
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico[Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic Oil Line(Suction)
Tubo Oleo / Hydraulic Oil L Ine(Delivery)
Tubo Oleo Hidraulico / Hydr Aulic Oil Line(Breather)
Radiador Oleo / Hydraulic O Il Line(Oil Cooler)
Braco Hidraulico / Lift Arm
Braco Hidraulico / Control Valve
Cilndro Eleveção / Lift Cyl Inder
Cilndro Eleveção[Peças Comp Onentes] / Lift Cylinder [Component Parts]
Braço De Elevação Do Cortad Or De Relva / Mower Lift Arm
Ligação Do Cortador De Relv A (Centro) / Mower Link(Center)
Ligação Do Cortador De Relv A (Lado Direito) / Mower Link(Right)
Ligação Do Cortador De Relv A (Lado Esquerdo) / Mower Link(Left)
Alavanca De Salto Do Cortad Or De Relva / Mower Jump Lever
Conductor / Duct
Peso / Weight
Estrutura / Main Frame
Capot / Hood(Bonnet)
Lubrificacao (Engrenagem De Passeio De Bomba Hidraulica) [Opção] / Side Cover Lower
Guarda Lamas / Fender
Acessorios / Seat
Degrau / Step
Roda Frente / Front Wheel(15*6.00-6)
Roda Traseira / Rear Wheel(20*10-8)
Etiqueta Frente / Label(Front)
Etiqueta Traseira / Label(Rear)
Acessorios / Accessories
Kit De Pesos / Weight Kit [Option]
