Kubota Zero Turn Mower GZD15-HD Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-HD Zero Turn Mower
Number of Pages: 148 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Vitesse-Controle / Speed Control Platec
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Couvercle / Cover
Contact A Huile Thermometre / Oil Switch/Thermome Ter
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket K It [Option]
Jeu De Piston [Option] / Piston Kit [Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Ventilateur / Fan
Plateall A Poussiere / Dustproof Plate
Reservoir Du Radiate Ur / Reserve Tank
Dynamo / Dynamo
Dynamo [Parties Composant Es] / Dynamo [Component Parts]
Lanceur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Interrupteur / Switch
Interrupteur/Controleur / Switch/Controller
Faisceau Electrique / Ele Ctrical Wiring
Embrayage / Clutch
Carter De Transmissi On / Transmission Case
Carter De Pont Arrie Re Droite / Rear Axle Case Rh
Carter De Pont Arrie Re Gauche / Rear Axle Case Lh
Hst / Hst
Hst Doroite 1 [Parti Es Composantes] / Hst Rh 1 [Component Parts]
Hst Doroite 2 [Parti Es Composantes] / Hst Rh 2 [Component Parts]
Hst Gauche 1 [Partie S Composantes] / Hst Lh 1 [Component Parts]
Hst Gauche 2 [Partie S Composantes] / Hst Lh 2 [Component Parts]
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Inp Ut Shaft
Joint De Cardan(Entr Ee) / Universal Joint(Input)
Arbre De Cardan / Jo Int Shaft
Arbre Pdf Interm / P To Counter Shaft
Arbre De Prise Force / Pto Shaft
Joint De Cardan(Pdf) / Universal Joint(Pto)
Axe Arriere / Rear Axle
Frein / Brake
Pedale De Frein Stationnement / Parking Brake Pedal
Levier De Chengement De Vites Se Pdf / Pto Gear Shift Lever
Levier De Commande De Vitesse Droite / Speed Control Lever Rh
Levier De Commande De Vitesse Gauche / Speed Control Lever Lh
Tige De Commande De Vittesse / Speed Control Rod
Pont Avant / Front Axle
Support Avant Droit / Hydr Aulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Circuit D'huile Hydrauliqu E(Aspirat) / Hydraulic Oil Line(Suction)
Circuit C'huile Hydrauliqu E (Retour) / Hydraulic Oil Line(Delivery)
Circuit D'huile Hydrauliqu E(Reniflard) / Hydraulic Oil Line(Breather)
Circuit D'huile Hydrauliqu E(Refoulement) / Hydraulic Oil Line(Oil Cooler)
Bras De Relevage / Lift Ar M
Distributeur Hydraulique / Control Valve
Cylindre De Relevage / Lif T Cylinder
Cylindre De Relevage [Part Ies Composantes] / Lift Cylinder [Component Parts]
Bras De Relevage De Tondeu Se / Mower Lift Arm
Relevage De Tondeuse(Centr E) / Mower Link(Center)
Relevage De Tondeuse(Droit E) / Mower Link(Right)
Relevage De Tondeuse(Gauch E) / Mower Link(Left)
Levier De Sauter De Tondeu Se / Mower Jump Lever
Conduit / Duct
Contrepoids / Weight
Capot Superieur / Hood(Bonnet)
Couvercle Lateral Inferieur / Side Cover Lowe R
Aile / Fender
Siege / Seat
Marchepied / Step
Roue Avant(15*6,00-6) / Front Wheel(15*6 .00-6)
Roue Arriere(20*10-8) / Rear Wheel(20*1 0-8)
Etiquette(Avant) / Label(Front)
Etiquette(Arriere) / Label(Rear)
Accessoires / Acce Ssories
Jeu De Contrepoids [Option] / Weight Kit [Option]
Couvercle / Cover
Ventilateur / Fan
Dynamo / Dynamo
Lanceur / Starter
Batterie / Battery
Embrayage / Clutch
Hst / Hst
Frein / Brake
Conduit / Duct
Aile / Fender
Siege / Seat
Marchepied / Step
