Kubota Zero Turn Mower GZD15-3LD-S5 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-3LD-S5 Zero Turn Mower
Number of Pages: 154 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Paliers De Vilebrequin / Main Bearing Case
Arbre A Cames Et Arbre De Pignon Fou / Camsha Ft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Crankshaf T
Arbre A Cames De Carburant Et Arbre Regulateu R / Fuel Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / N Ozzle Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzl E Holder [Component Parts]
Couvercle / Cover
Bride A Eau Et Thermostat / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Levier D'accelerateur / Accel Erator Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant / Fuel Fil Ter
Pompe D'alimentation / Fuel P Ump
Ventilateur / Fa N
Tuyau D'eau (Mot Eur) / Water Pipe (Engine)
Tuyau D'eau (Rad Iateur) / Water Pipe (Radiator)
Radiateur / Radi Ator
Plateall A Pouss Iere / Dustproof Plate
Reservoir Du Rad Iateur / Reserve Tank
Contact A Huile Therm Ometre / Oil Switch And Thermo Sensor
Solenoide D'arret / S Top Solenoid
Dynamo / Dynamo
Dynamo [Parties Compo Santes] / Dynamo [Component Parts]
Demarreur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Commutateur / Switch
Interrupteur De Demar Reur/Metre / Starter Switch/Meter
Interrupteur/Controle Ur / Switch/Controller
Avertisseur/Relais / Horn/Relay
Faisceau Electrique / Electrical Wiring
Embrayage / Clutch
Reniflard De Transmission / Transmission B Reather
Carter Pont Arriere (Droite) / Rear Axle C Ase (Right)
Carter Pont Arriere (Gauche) / Rear Axle C Ase (Left)
Support De Boîte D'essieu Arrière / Rear A Xle Case Support
Hst / Hst
Hst Doroite (Bloc-Cylindres) [Parties Comp Osantes] / Hst Rh (Cylinder Block) [Component Parts ]
Hst Doroite (Carter) [Parties Composantes] / Hst Rh (Housing) [Component Parts]
Hst Gauche (Bloc-Cylindres) [Parties Compo Santes] / Hst Lh (Cylinder Block) [Component Parts]
Hst Gauche (Carter) [Parties Composantes] / Hst Lh (Housing) [Component Parts]
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Joint De Cardan (Entree) / Universal Joint (Input)
Arbre De Cardan / Joint Shaft
Arbre Pdf Interm / Pto Countershaft
Arbre De Prise De Force / Pto Shaft
Joint De Cardan (Pdf) / Universal Joint (P To)
Couvercle De Joint Cardan / Universal Join T Cover
Essieu Arriere (Droite) / Rear Axle (Right )
Essieu Arriere (Gauche) / Rear Axle (Left)
Arbre D'entraînement De La Roue Arrière (D Roite) / Rear Wheel Drive Shaft (Right)
Arbre D'entraînement De La Roue Arrière (G Auche) / Rear Wheel Drive Shaft (Left)
Frein / Brake
Levier De Frein / Brake Arm
Pedale De Frein De Stationnem Ent / Parking Brake Pedal
Levier De Chengement De Vitesse Pdf / Pto Gear Shift Leve R
Levier De Commande Du Mouvement (Droite) / Motion Control Lever (Right)
Levier De Commande Du Mouvement (Gauche) / Motion Control Lever (Left)
Tige D E Commande De Vittesse / Speed Control Rod
Pont Avant / Front Axle
Pompe Hydraulique / Hy Draulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrau Lique (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydrau Lique (Reniflard) / Hydraulic Oil Line (Breather)
Circuit D'huile Hydrau Lique (Refoulement) / Hydraulic Oil Line (Oil Coole R)
Bras De Relevage / Lif T Arm
Distributeur Hydrauliq Ue / Control Valve
Distributeur Controle [Parties Composantes] / Control Valve [Component Pa Rts]
Cylindre De Relevage [ Parties Composantes] / Lift Cylinder [Component Par Ts]
Relevage De Tondeuse ( Centre) / Mower Link (Center)
Relevage De Tondeuse ( Droite) / Mower Link (Right)
Relevage De Tondeuse ( Gauche) / Mower Link (Left)
Levier De Sauter De To Ndeuse / Mower Jump Lever
Conduit / Duct
Contrepoids / Weight
Couvercle D' Arbre / Shaft Cover
Capot Superieur / Hood (Bonnet) Upper
Couvercle Lateral Inferieur / Side Cove R Lower
Aile / Fender
Siege / Seat
Marchepied / Step
Couvercle Inférieur / Under Cover
Cadre Anti-Renversment / Rops
Roue Avant ( 15*6,00-6) / Front Wheel (15*6.00-6)
Roue Arriere (20*10-8) / Rear Wheel (20*10-8)
Etiquette (Avant) / Body Label (Front)
Etiquette (Arriere) / Body Label (Rear)
Accessoires / Accessories
Jeu De Contrepoids [Option] / Weight Kit [Opt Ion]
