Kubota Zero Turn Mower GZD15-3HD-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Zero Turn Mower
Model: Kubota GZD15-3HD-S5 Zero Turn Mower
Number of Pages: 159 Pages
Itens Uso Frequen Te / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Cams Haft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Pla Te
Suporte Bico [Peças Componentes] / Nozzl E Holder [Component Parts]
Tampa / Cover
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rock Er Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Kit De Junta Inferior / Lower Gasket Kit
Alavanca Acelarador / Ac Celerator Lever
Deposito Combustivel / F Uel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Fi Lter
Bomba Gasoleo / Fuel Pum P
Ventoi Nha / Fan
Tubo A Gua (Motor) / Water Pipe (Engine)
Tubo A Gua (Radiador) / Water Pipe (Radiator)
Radiad Or / Radiator
Placa À Prova De Poeiras / Dustproof Plate
Deposi To Reserva / Reserve Tank
Sensor Térmico E Interr Uptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Sto P Solenoid
Dínamo / Dynamo
Dínamo [Peças Component Es] / Dynamo [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Interruptor / Switch
Interruptor/Contador / Starter Switch/Meter
Interruptor/Controlador / Switch/Controller
Buzina/Relé / Horn/Rela Y
Cablagem Electrica / El Ectrical Wiring
Embraiagem / Clutch
Respiro Transmissão / Transmission Breather
Carter Eixo Traseiro (Drt) / Rear Axle Case (Right)
Carter Eixo Traseiro (Esq) / Rear Axle Case (Left)
Apoio Da Caixa Do Eixo Traseiro / Rear Axle Case Support
Hst / Hst
Hst Direito (Bloco,Conjunto) [Peças Compone Ntes] / Hst Rh (Cylinder Block) [Component Parts]
Hst Direito (Carter) [Peças Componentes] / Hst Rh (Housing) [Component Parts]
Hst Esquerado (Bloco,Conjunto) [Peças Compo Nentes] / Hst Lh (Cylinder Block) [Component Parts]
Hst Esquerado (Carter) [Peças Componentes] / Hst Lh (Housing) [Component Parts]
Junta Universal (Entrada) / Universal Joint (Input)
Veio Tdf / Pto Countershaft
Junta Universal (Tdf) / Universal Joint (Pt O)
Tampa Cardan / Universal Joint Cover
Veio Eixo Traseiro (Direito) / Rear Axle (R Ight)
Veio Eixo Traseiro (Esquerdo) / Rear Axle ( Left)
Veio De Transmissão Da Roda Traseira (Direi To) / Rear Wheel Drive Shaft (Right)
Veio De Transmissão Da Roda Traseira (Esque Rdo) / Rear Wheel Drive Shaft (Left)
Travão / Brake
Braço Do Travão / Brake Arm
Pedal Do Travão De Estaciona Mento / Parking Brake Pedal
Alav Anca Tdf / Pto Gear Shift Lever
Alav Anca De Controlo De Movimento (Direito) / Motion Co Ntrol Lever (Right)
Alav Anca De Controlo De Movimento (Esquerdo) / Motion C Ontrol Lever (Left)
Tira Nte De Controlo De Movimento / Speed Control Rod
Eixo Dianteiro / Front Axle
Bomba Hidraulico / Hydr Aulic Pump
Linha De Óleo Hidráulic O (Aspiração) / Hydraulic Oil Line (Suction)
Linha De Óleo Hidráulic O (Fornecimento) / Hydraulic Oil Line (Delivery)
Linha De Óleo Hidráulic O (Respiro) / Hydraulic Oil Line (Breather)
Linha De Óleo Hidráulic O (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Braco Hidraulico / Lift Arm
Valvula Control / Contr Ol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Cilndro Eleveção [Peças Componentes] / Lift Cylinder [Component Parts]
Braço De Elevação Do Co Rtador De Relva / Mower Lift Arm
Ligação Do Cortador De Relva (Centro) / Mower Link (Center)
Ligação Do Cortador De Relva (Direito) / Mower Link (Right)
Ligação Do Cortador De Relva (Esquerdo) / Mower Link (Left)
Conductor / Duct
Peso / Weight
Tampa Do Veio / Shaft Cover
Proteccao Frontal / Front Guard
Guarda Lamas / Fender
Cinto Segurança / Seat Belt
Banco / Seat
Degrau / Step
Cobertura Inferior / Under Cover
Arco / Rops
Roda Fr Ente (15*6,00-6) / Front Wheel (15*6.00-6)
Roda Tr Aseira (20*10-8) / Rear Wheel (20*10-8)
Etiqueta Frente (Dianteiro) / Body Label (Front)
Etiqueta Traseira (Traseiro) / Bod Y Label (Rear)
Acessorios / Accessories
Kit De Peso [Opção] / Weight Kit [Option]
