Kubota Wheel Loader R520 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Wheel Loader
Model: Kubota R520 Wheel Loader
Number of Pages: 192 Pages
Bl Oc Moteur / Crankcase
Ca Rter D'huile / Oil Pan
Pi Stons/Vilebrequin / Piston/Crankshaft
Pa Liers De Principal / Main Bearing Case
Ar Bre A Cames / Camshaft
Cu Lasse / Cylinder Head
So Upapes Et Culbuteurs / Valve/Rocker Arm
Co Uvre-Culbuters / Cylinder Head Cover
Ki T D'accouplements Rapides [Option] / Gear Case
Co Llecteur D'admission / Inlet Manifold
Co Llecteur D'echappment / Exhaust Manifold
Po Rte/Injecteur / Nozzle Holder/Glow Plug
Ar Bre A Cames Dalimentation / Fuel Camshaft
Po Mpe D'injection / Injection Pump
Po Mpe D'injection [Parties Composantes] / Injection P Ump [Component Parts]
Le Vier D Arret Du Moteur / Engine Stop Lever
Pl Aque De Limiteur De Vitesse / Speed Control Plate
Re Gulateur De Vitesses / Governor
Po Mpe A Eau / Water Pump
Br Ide Et Thermostat / Water Flange/Thermostat
Ve Ntilateur/Alternateur / Fan/Alternator
Al Ternateur [Parties Composantes] / Alternator [Compo Nent Parts]
Vo Lant Moteur Demarreur / Flywheel/Starter
De Marreur [Parties Composantes] / Starter [Component Parts]
Co Nsole De Moteur / Engine Bracket
Fi Ltre A Air [Vieux Type] / Air Cleaner [Old Type]
Fi Ltre A Air [Nouveau Type] / Air Cleaner [New Type]
Si Lencieux / Muffler
Ra Diateur / Radiator
Tu Yau D'eau / Water Pipe
Solenoide / Solenoid
Reservoir Carb. / Fuel Tank
Carburant Tuyau / Fuel Pipe
Sedimenteur / Sedimenter
Batterie / Battery
Metre / Meter
Contacteur / Switch
Fuex / Light
Feu D'arriere / Tail Light
Harness De Fil / Wire Harness
Carter De Misston / Mission Case
Pont Avant / Front Axle
Avant Carter De Differentiel / Front Diff Erential Case
Embrayage Planetaire (Avant) / Planetary Gear (Front)
Differentiel Avant / Front Differential
Axe Arriere / Rear Axle
Arriere Carter De Differentiel / Rear Fro Nt Differential Case
Embrayage Planetaire (D'arriere) / Planet Ary Gear (Rear)
Jante/Pneu / Wheel/Tire
Circuit D'huile Hydrauliqe (Colonne) / Hydraulic Oil Line (Steering)
Accelerateur Assistance / Accelerator Support
Servo Direction [Parties Composantes] [Vieux Typ E] / Steering Controller [Component Parts] [Old Typ E]
Servo Direction [Parties Composantes][Nouveau Ty Pe] / Steering Controller [Component Parts] [New Ty Pe]
Peda Le De Frien / Brake Pedal
Mani Ement De Frein / Brake Operation
Cana Lisation De Frein / Brake Piping
Frei N / Brake
Carter De Pompe / Pump Housing
Pipe Expulsion / Drain Piping
Pompe Lst / Lst Pump
Pompe Lst [Parties Composantes ] / Lst Pump [Component Parts]
Piston Pompe [Parties Composan Tes] / Piston Pump [Component Parts]
Rotor [Parties Composantes] / Rotary [Component Parts]
Cylindre [Parties Composantes] / Cylinder [Component Parts]
Haute Pression Soupape [Partie S Composantes] / High Pressure Valve [Component Par Ts]
Decompression Soupape [Parties Composantes] / Low Pressure Valve [Component Parts ]
Lutte De Rouleau [Parties Comp Osantes] / Section Control [Component Parts]
Da Soupape [Parties Composante S] / Da Valve [Component Parts]
Engrenage Pompe [Parties Compo Santes] / Gear Pump [Component Parts]
Joint (Lst Pompe) [Parties Co Mposantes] / Seal Kit (Lst Pump) [Component Parts]
Lst Pompe / Lst Pump
Lst Pompe (Clapet De Decha) / Lst Pump (Relife Valve)
Lst Moteur / Lst Motor
Lst Moteur [Parties Composante S] / Lst Motor [Component Parts]
Controle [Parties Composantes] / Control [Component Parts]
Joint (Lst Moteur) / Seal Kit (Lst Motor)
Distributeur Hydraulique / Con Trol Valve
Soupape De Controle [Parties C Omposantes] / Control Valve [Component Parts]
Section De Tiroir (1) / Spool Section (1)
Section De Tiroir (3) / Spool Section (3)
Solenoide Clapet / Solenoid Va Lve
Reservoir D'huile / Oil Tank
D'huile Filter / Oil Filter
Refroidisseur / Oil Coller
Circuit D'huile Hydraulique (S Uction) / Hydraulic Oil Line (Suction)
Circuti D'huile Hydraulique (R Efroidisseur) / Hydraulic Oil Line (Oil Cooler)
Circuti D'huile Hydraulique (R Etour) / Hydraulic Oil Line (Return)
Tour Filtre / Return Filter
Haute Pression Circuit D'huile / High Pressure Oil Line
Canalisation D'huile Retour / Oil Piping Return
Levier De Commande (Delle) / C Ontrol Lever (Shovel)
Levier De Commande (Delle) [P Arties Composantes] / Control (Shovel) [Component Parts]
Levier De Commande (Sp) [Part Ies Composantes] / Control Lever (Sp) [Component P Arts]
Bras De Pelle / Shovel Arm
Bras D'inclinaison / Tilt Arm
Godet / Bucket
Verin De Levage / Lift Cylinder
Verin D'inclinaison Incliner / Tilt Cylinder
Automate Niveleuse / Auto Level Er
Barrd De Accouplement/Cylindre De Direction / Steering Cylinder
Circuit D'huile Hydraulique (Ga Uche) / Hydraulic Oil Line (Lift)
Circuit D'huile Hydraulique (In Cliner) / Hydraulic Oil Line (Tilt)
Circuit D'huile Hydraulique (Sp ) / Hydraulic Oil Line (Sp)
Ch Assis Avant / Front Frame
At Telage Avant / Frame Connection
Ch Assis D'arriere / Rear Frame
Pa Re-Choc Arriere / Rear Fender
Ga Rde-Boue / Mud Guad
Capot Superieur / Hood
Capot Superieur Serrure / Hood Lock
Garniture Interieure / Sound Absorber
Bequille Maniement / Operation Stand
Aile / Fender
Siege / Seat
Contre Poids / Weight
Accelerateur / Hand Accel
Etiquette / Label
Accessories Et Piece De Service / Accessori Es And Service Parts
Batterie / Battery
Metre / Meter
Contacteur / Switch
Fuex / Light
Frei N / Brake
Godet / Bucket
Aile / Fender
Siege / Seat
Etiquette / Label
