Kubota Wheel Loader R410B Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Wheel Loader
Model: Kubota R410B Wheel Loader
Number of Pages: 169 Pages
Crank Case / Crank Case
Oil Pan / Oil Pan
Piston And Crank Shaft / Piston And Cran K Shaft
Main Bearing Case / Main Bearing Case
Cam Shaft / Cam Shaft
Cylinder Head / Cylinder Head
Valve Rocker Arm / Valve Rocker Arm
Cylinder Head Cover / Cylinder Head Cove R
Gear Case / Gear Case
Engine Bracket / Engine Bracke T
Inlet Manifold / Inlet Manifol D
Air Cleaner / Air Cleaner
Muffler Exhaust Manifold / Muffler E Xhaust Manifold
Nozzle Holder And Glow Plug / Nozzle Holde R And Glow Plug
Nozzle Holder (Component Parts) / Nozzle H Older (Component Parts)
Fuel Camshaft / Fuel Camshaft
Injection Pump / Injection Pump
Injection Pump (Component Parts) / Injecti On Pump (Component Parts)
Engine Stop Lever / Engine Stop Lever
Speed Control Plate / Speed Control Plate
Governor / Governor
Accel Pedal / Accel Pedal
Solenoid Support / Solenoid Support
Fuel Tank / Fuel Tank
Water Flange / Water Flange
Water Pump / Water Pump
Radiator / Radiator
Fan And Dynamo / Fan And Dynamo
Dynamo(Component Parts) / Dyna Mo(Component Parts)
Alternator(Component Parts) / Alternator(Component Parts)
Flywheel And Starter / Flywhee L And Starter
Starter(Component Parts) / Sta Rter(Component Parts)
Battery / Battery
Switch And Meter / Switch And Meter
Regulator And Horn / Regulator And Horn
Light / Light
Electrical Wiring / Electrical Wiring
Front Axle Case / Front Axle Case
Front Axle / Front Axle
Front Differential Case / Front Differential Case
Front Differential Case (No-Spin) / Front Differential C Ase (No-Spin)
Front Differential Case (Lsd) / Front Differential Case (Lsd)
Rear Axle Case / Rear Axle Case
Rear Axle / Rear Axle
Rear Differential Case / Rear Differential Case
Rear Differential Case (No-Spin) / Rear Differential Cas E (No-Spin)
Tire And Wheel / Tire And Wheel
Steering Controller / Steering Controller
Steering Controller(Component Parts) / Steering Controller(Component Parts)
Steering Handle / Steering Handle
Bra Ke / Brake
Bra Ke Pedal / Brake Pedal
Bra Ke Piping / Brake Piping
Lev Er / Lever
Pump Housing / Pump Housing
Lst Pump / Lst Pump
Lst Pump(Component Parts) / Lst Pump(Component Parts)
Hydraulic Lst Pump / Hydraulic L St Pump
Lst Control Valve / Lst Control Valve
Lst Control Valve(Component Part S) / Lst Control Valve(Component Parts)
Lst Motor / Lst Motor
Lst Motor(Component Parts) / Lst Motor(Component Parts)
Controlvalve(Component Parts)(S/ P) / Controlvalve(Component Parts)(S/P)
Control Valve Spool Section / Co Ntrol Valve Spool Section
Hydraulic Control Valve / Hydrau Lic Control Valve
Oil Tank / Oil Tank
Filter Flange / Filter Flange
Lift Cylinder(Component Parts) / Lift Cylinder(Component Parts)
Assy Pin Lift Cylinder / Assy Pi N Lift Cylinder
Tilt Cylinder(Component Parts) / Tilt Cylinder(Component Parts)
Assy Pin Tilt Cylinder / Assy Pi N Tilt Cylinder
[Kcl Kta Ke Ktc]
Assypin Steering Cylinder / Assy Pin Steering Cylinder
Control Lever / Control Lever
Oil Piping(1) Return / Oil Pipin G(1) Return
Oil Piping(2) Steering / Oil Pip Ing(2) Steering
Oil Piping Lift Cylinder / Oil P Iping Lift Cylinder
Oil Piping Tiltcylinder / Oil Pi Ping Tiltcylinder
Front Frame / Front Frame
Center Pin / Center Pin
Stand / Stand
Bonnet(1) / Bonnet(1)
Sponge / Sponge
Shovel Frame / Shovel Frame
Tilt Arm / Tilt Arm
Bucket / Bucket
Multi Coupler / Multi Coupler
Canopy / Canopy
Rops Canopy / Rops Canopy
Rops Cabin(1) / Rops Cabin (1)
Door / Door
Rear Door / Rear Door
Rops Cabin(2) / Rops Cabin (2)
Rops Cabin(3) / Rops Cabin (3)
Heater / Heater
Seal / Seal
Seat / Seat
Accel / Accel
Control Valve / Control Valve
Return Piping / Return Piping
Slide Frame / Slide Frame
Swing Bracket / Swing Bracket
Boom / Boom
Arm / Arm
Bucket Link / Bucket Link
Out Ligger Cylinder / Out Ligger Cylinder
Swing Cylinder / Swing Cylinder
Boom Cylinder / Boom Cylinder
Arm Cylinder / Arm Cylinder
Bucket Cylinder / Bucket Cylinde R
Slide Lock Cylinder / Slide Lock Cylinder
Oil Piping(Quick Coupler) / Oil Piping(Quick Coupler)
Oil Piping(Out Ligger) / Oil Pip Ing(Out Ligger)
Oil Piping(Slide Lock)(1) / Oil Piping(Slide Lock)(1)
Oil Piping(Boom) / Oil Piping(Bo Om)
Oil Piping(Arm) / Oil Piping(Arm )
Oil Piping(Bucket) / Oil Piping( Bucket)
Oil Piping(Swing) / Oil Piping(S Wing)
Oilpiping(S/P) / Oilpiping(S/P)
Control Valve(Component Parts) / Control Valve(Component Parts)
Control Lever(Outligger & Slide Lock) / Control Lever(Outligger & Slide Lock)
Valve Stand / Valve Stand
Control Lever(Operating) / Contr Ol Lever(Operating)
Control Lever(Safety Lock Lever) / Control Lever(Safety Lock Lever)
Label / Label
Accessories / Accessories
