Kubota Wheel Loader R400 R400B Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Wheel Loader
Model: Kubota R400 ; R400B Wheel Loader
Number of Pages: 279 Pages
Crank Case
Oil Pan
Sub Oil Pan
Piston And Crank Shaft
Main Bearing Case
Cam Shaft
Valve And Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Inlet Manifold
Air Cleaner
Muffler And Exhaust Manifold
Nozzle Holder And Glow Plug
Nozzle Holder (Section Parts)
Fuel Camshaft
Injection Pump (Section Parts)
Engine Stop Lever
Speed Control Plate
Governor
Accel And Stop Rod [Ke Ktuk Kta]
Fuel Piping
Water Flange
Radiater & Water Pipe
Dynamo
Dynamo (Section Parts)
Flywheel And Starter
Battery
Switch (1) And Panel
Switch (2) And Regulator
Light
Electrical Wiring
Transmission Case (1)
Transmission Case (2)
Clutch [C1 C2]
Brake [B1 B2]
Clutch (C3) & Brake (B3)
Couplung
Planetary Carrier
Clutch Shaft (1)
Clutch Shaft (2)
Transfer (Drive Shaft)
Transfer (Hydraulic Pump)
Speed Change Lever
Speed Change Linkage System
Drive Shaft
Differential Case (Front)
Spiral Bevel Gear (Front)
Differential (Front)
Axle (Front)
Differential Case (Rear)
Spiral Bevel Gear (Rear)
Differential (Rear)
Axle (Rear)
Tire And Wheel
Clutch Shaft (2)
Steering Cylinder And Controller (New Type)
Steering Controller (Section Parts) >=20017 (New Type)
Steering Controller (Section Parts) <=20016 (Old Type)
Steering Cylinder (Section Parts)
Steering Handle
Brake
Brake Pedal
Inching Pedal
Brake Piping
Parking Lever
Hydraulic Pump (Section Parts)
Flow Priority Valve (Section Parts)
Control Valve & Section Parts
Control Valve Spool Section
Clutch Valve
Modulation Valve
Oil Tank
Tilt & Lift Cylinder
Tilt Cylinder (Section Parts)
Lift Cylinder (Section Parts)
Control Lever (Shovel)
Control Lever (S/P) / Control Lever (S/P)
Safety Rock Lever
Oil Piping (Suction Filter)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Rear Pto)
Oil Piping (Lift Cylinder)
Oil Piping (Lift Cylinder-Rh)
Oil Piping (Lift Cylinder-Lh)
Oil Piping (Tilt Cylinder)
Oil Piping (S/P-1) / Oil Piping (S/P-1)
Oil Piping (S/P-2) / Oil Piping (S/P-2)
Oil Piping (Transmission-1)
Oil Piping (Transmission-2)
Front Frame
Rear Frame (1)
Rear Frame (2)
Floor Board
Front Cover
Rear Cover (1)
Seat Frame
Rear Cover (2)
Bonnet Sponge [Ke Ktuk]
Weight
Axle (Front)
Shovel Frame
Tilt Arm
Canopy [Ke]
Label [Ke Ktuk Kta]
Slide Frame
Control Valve Stand
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Control Valve [Ke Ktuk Kta]
Control Valve Spool Section [Ke Ktuk Kta]
Boom Cylinder & Section Parts
Arm Cylinder & Section Parts
Bucket Cylinder & Section Parts
Swing Cylinder & Section Parts
Slide Lock Cylinder & Section Parts
Out Ligger Cylinder & Section Parts
Oil Piping (Quick Coupler)
Oil Piping (Out Ligger)
Oil Piping (Slide Lock)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Swing)
Control Lever (Out Ligger & Slide Lock)
Control Lever (Operating)
Control Lever (Safety Lock Lever)
Label
Accessory And Service Parts
Crank Case
Oil Pan
Sub Oil Pan
Main Bearing Case
Cam Shaft
Cylinder Head Cover
Gear Case
Engine Bracket
Inlet Manifold
Air Cleaner
Fuel Camshaft
Engine Stop Lever
Speed Control Plate
Governor
Fuel Piping
Water Flange
Dynamo
Battery
Light
Electrical Wiring
Clutch [C1 C2]
Brake [B1 B2]
Couplung
Planetary Carrier
Clutch Shaft (1)
Clutch Shaft (2)
Speed Change Lever
Drive Shaft
Axle (Front)
Differential (Rear)
Axle (Rear)
Tire And Wheel
Clutch Shaft (2)
Steering Handle
Brake
Brake Pedal
Inching Pedal
Brake Piping
Parking Lever
Clutch Valve
Modulation Valve
Oil Tank
Safety Rock Lever
Oil Piping (Return)
Front Frame
Rear Frame (1)
Rear Frame (2)
Floor Board
Front Cover
Rear Cover (1)
Seat Frame
Rear Cover (2)
Weight
Axle (Front)
Shovel Frame
Tilt Arm
Canopy [Ke]
Label [Ke Ktuk Kta]
Slide Frame
Control Valve Stand
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Swing)
Label
