Kubota Utility Vehicles RTV900SR Homologated Verion EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV900SR Homologated Verion EU Utility Vehicles
Number of Pages: 421 Pages
Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Manocontacto De Aceite/Termometro / Oil Switch/Thermometer
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Freno Conmutador / Brake Switch
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Light
Trasero Combinacion Luz / Rear Combination Light
Licencia Lampara / License Lamp
Adelante Caja / Front Case
Hst
Hst 1(Carga Bomba) [Componente Piezas] / Hst 1(Charge Pump) [Component Parts]
Hst 2(Regulador) [Componente Piezas] / Hst 2(Regulator) [Component Parts]
Hst 3(Motor Eje) [Componente Piezas] / Hst 3 (Motor Shaft) [Component Parts]
Hst 4(Valvula) [Componente Piezas] / Hst 4(Valve) [Component Parts]
Entrada Eje / Input Shaft
Helice Eje / Propeller Shaft
Marcha Atras Eje / Revarse Shaft
Punto Muerto Eje / Idle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Transmision Kit / Transmission Kit
Gama Engranaje Cambio Bifuracacion / Range Gear Shift Fork
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Velocidad Cambio Palanca / Speed Change Lever
Velocidad Cambio Varilla / Speed Change Rod
Eje Trasero / Rear Axle
Trasero Suspension / Rear Suspension
Adelante Freno / Front Brake
Trasero Freno / Rear Brake
Freno Cilindro(Izquierdo) / Brake Cylinder(Left)
Freno Cilindro(Derecho) / Brake Cylinder(Right)
Freno Aceite Linea(Adelante) / Brake Oil Line(Front)
Freno Aceite Linea(Trasero) / Brake Oil Line(Rear)
Freno Varilla / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Ascenso Palanca / Lift Lever
Derivacion Valvula Vinculo / Bypass Valve Link
Engranaje Bomba / Gear Pump
Hidraulico Deposito / Hydraulic Tank
Hidraulico Aceite Linea (Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line(Hst)
Liinea De Aceite Hidraulico(Radiador De Aceite) / Hydraulic Oil Line(Oil Cooler)
Hidraulico Aceite Linea(Deposito) / Hydraulic Oil Line(Tank)
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Ascenso Cilindro [Componente Piezas] / Lift Cylinder [Component Parts]
Transmision Bastidor / Transmission Frame
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Accionar Eje / Front Drive Shaft
Adelante Eje / Front Axle
Adelante Suspension / Front Suspension
Adelante Suspension [Componente Piezas] / Front Suspension [Component Parts]
Adelante Suspension Brazo / Front Suspension Arm
Direccion Cilindro / Steering Cylinder
Direccion Deposito / Steering Tank
Caja Base / Box Base
Caja Placa / Box Plate
Caja Compuerta / Box Gate
Adelante Protector / Front Guard
Capo / Bonnet
Lado Cubierta / Side Cover
Panel Bastidor / Panel Frame
Guardabarros / Fender
Asiento Soporte(Operadore) / Seat Support(Operator)
Asiento Soporte(Operadore) / Seat Support(Passenger)
Hoja / Seat
Hoja / Seat
Peldano / Step
Rops
Barra De Remolque / Drawbar
Rueda Delantera(25*10-12) / Front Wheel(25*10-12)
Rueda Posterior(25*10-12) / Rear Wheel(25*10-12)
Etiqueta (Adelante) [Frances] / Label (Front) [French]
Etiqueta (Adelante) [Alemania] / Label (Front) [German]
Etiqueta(Trasero) [Frances] / Label(Rear) [French]
Etiqueta(Trasero) [Alemania] / Label(Rear) [German]
Alto Soporte Aire Limpiador Kit [Opcion] / High Mount Air Cleaner Kit [Option]
Combustible Filtro Kit [Opcion] / Fuel Filter Kit [Option]
Combustible Filtro [Componente Piezas] [Opcion] / Fuel Filter [Component Parts] [Option]
Reserva Zumbador Kit [Opcion] / Backup Beeper Kit [Option]
Sobrecalentamiento Alarma Kit [Opcion] / Overheat Alarm Kit [Option]
Panel Kit [Opcion] / Panel Kit [Option]
Trabajo Luz Kit(Adelante) [Opcion] / Work Light Kit(Front) [Option]
Trabajo Luz Kit(Trasero) [Opcion] / Work Light Kit(Rear) [Option]
Helice Eje Kit [Opcion] / Propeller Shaft Kit [Option]
Mano Estrangulador Kit [Opcion] / Hand Throttle Kit [Option]
Adelante Pesado Carga Amortiguador Telescopico Kit[Opcion] / Front Heavy Load Strut Kit [Option]
Adelante Pesado Carga Resortes Kit [Opcion] / Front Heavy Load Springs Kit [Option]
Hidraulico Mejorar Kit(Deposito) [Opcion] / Hyd.Upgrade Kit(Tank) [Option]
Hidraulico Mejorar Kit(Aceite Refrigerador) [Opcion] / Hyd.Upgrade Kit(Oil Cooler) [Option]
Hidraulico Mejorar Kit(Hidraulico Aceite Linea) [Opcion] / Hyd.Upgrade Kit(Hyd.Oil Line) [Option]
Hoja / Seat
Hidraulico Mejorar Kit(Alejado) [Opcion] / Hyd.Upgrade Kit(Remote) [Option]
Hidraulico Mejorar Kit(Alejado)[Componente Piezas] [Opcion] / Hyd.Upgrade Kit(Remote) [Component Parts] [Option]
Hidraulico Mejorar Kit(Pto Palanca) [Opcion] / Hyd.Upgrade Kit(Pto Lever) [Option]
Hidraulico Mejorar Kit(Electrico Cableado) [Opcion] / Hyd.Upgrade Kit(Electrical Wiring) [Option]
Hidraulico Mejorar Kit(Rele) [Opcion] / Hyd.Upgrade Kit(Relay) [Option]
Hidraulico Mejorar Kit(Commutador) [Opcion] / Hyd.Upgrade Kit(Switch) [Option]
Hidraulico Mejorar Kit(Etiqueta) [Opcion] / Hyd.Upgrade Kit(Label) [Option]
Cama Camisa Kit [Opcion] / Bed Liner Kit [Option]
Barra De Remolque Kit [Opcion] / Drawbar Kit [Option]
Cabrestante Soporte Kit [V4251] [Opcion] / Winch Mounting Kit [V4251] [Option]
Cabrestante Soporte Kit [V4253] [Opcion] / Winch Mounting Kit [V4253] [Option]
Adelante Accesorio Caja Kit [Opcion] / Front Accessory Box Kit [Option]
Guante Caja Kit [Opcion] / Glove Box Kit [Option]
Adelante Fango Protector Kit [Opcion] / Front Mud Guard Kit [Option]
Cola Lampara Protectores Kit [Opcion] / Tail Lamp Guards Kit [Option]
Techo De Lona Kit [V4221] [Opcion] / Canopy Kit [V4221] [Option]
Techo De Lona Kit(Camuflaje) [V4255] [Rtv900sr] [Opcion] / Canopy Kit(Camouflage) [V4255] [Rtv900sr] [Option]
Maintenance Parts
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Ventilador / Fan
Hst
Capo / Bonnet
Hoja / Seat
Hoja / Seat
Peldano / Step
Rops
Hoja / Seat
