Kubota Utility Vehicles RTV900SG-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV900SG-EU Utility Vehicles
Number of Pages: 403 Pages
Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Bomba De Combustible(Mecanica) / Fuel Pump(Mechanical)
Aceite Conmutador/Sensor / Oil Switch/Thermometer And Plug
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Freno Conmutador / Brake Switch
Culata Luz / Head Light
Piloto Trasero / Tail Light
Adelante Caja / Front Case
Hst
Hst[Componente Piezas]1 / Hst 1 [Component Parts]
Hst[Componente Piezas]2 / Hst 2 [Component Parts]
Hst 3[Componente Piezas] / Hst 3 [Component Parts]
Hst 4[Componente Piezas] / Hst 4 [Component Parts]
Eje De Entrada / Input Shaft
Helice Eje / Propeller Shaft
Eje De Cambio De Gama / Range Gear Shaft
Marcha Atras Eje / Revarse Shaft
Punto Muerto Eje / Idle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Universal Junta / Universal Joint
Transmision Kit / Transmission Kit
Horquilla De Cambio De Gama / Range Gear Shift Fork
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Velocidad Cambio Palanca / Speed Change Lever
Velocidad Cambio Varilla / Speed Change Rod
Palanca De Cambio Principal / Main Gear Shift Lever
Eje Trasero / Rear Axle
Trasero Suspension / Rear Suspension
Adelante Freno / Front Brake
Trasero Freno / Rear Brake
Freno Cilindro(Izquierdo) / Brake Cylinder(Left)
Freno Cilindro(Derecho) / Brake Cylinder(Right)
Freno Maestro Cilindro[Componente Piezas] / Brake Master Cylinder [Component Parts]
Freno Aceite Linea(Adelante) / Brake Oil Line(Front)
Freno Aceite Linea(Trasero) / Brake Oil Line(Rear)
Varilla De Freno / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Derivacion Valvula Vinculo / Bypass Valve Link
Hidraulico Aceite Linea (Potencia Direccion) [Se] [Uk] / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line(Hst)
Radiador De Aceite[Tipo Nuevo] / Hydraulic Oil Line(Oil Cooler)
Transmision Bastidor / Transmission Frame
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Accionar Eje / Front Drive Shaft
Adelante Eje / Front Axle
Adelante Suspension / Front Suspension
Adelante Suspension[Componente Piezas] / Front Suspension [Component Parts]
Adelante Suspension Brazo / Front Suspension Arm
Direccion Cilindro / Steering Cylinder
Direccion Deposito / Steering Tank
Caja Base / Box Base
Caja Placa / Box Plate
Caja Compuerta / Box Gate
Adelante Protector / Front Guard
Capo / Bonnet
Transmision Caja Lado Cubierta / Side Cover
Panel Bastidor / Panel Frame
Guardabarros / Fender
Hoja / Seat
Peldano / Step
Arco De Seguridad / Rops
Rueda Delantera(7-12) / Front Wheel (25*10-12)
Rueda Posterior(12,4-16) / Rear Wheel (25*10-12)
Etiqueta (Adelante) [Ingles] / Label(Front) [English]
Etiqueta (Adelante) [Frances] / Label(Front) [French]
Etiqueta (Adelante) [Alemania] / Label(Front) [German]
Etiqueta(Trasero) [Ingles] / Label(Rear) [English]
Etiqueta(Trasero) [Frances] / Label(Rear) [French]
Etiqueta(Trasero)[Alemania] / Label(Rear) [German]
Alto Soporte Aire Limpiador Kit[Opcion] / High Mount Air Cleaner Kit [Option]
Combustible Filtro Kit[Opcion] / Fuel Filter Kit [Option]
Combustible Filtro[Componente Piezas][Opcion] / Fuel Filter [Component Parts] [Option]
Velocimetro Kit[Rtv900g-Eu/W-Eu][Opcion] / Speedometer Kit [Rtv900sg-Eu/Sw-Eu] [Option]
Reserva Zumbador Kit[Opcion] / Backup Beeper Kit [Option]
Sobrecalentamiento Alarma Kit[Opcion] / Overheat Alarm Kit [Option]
Panel Kit[Opcion] / Panel Kit [Option]
Trabajo Luz Kit(Adelante)[Opcion] / Work Light Kit (Front) [Option]
Trabajo Luz Kit(Trasero)[Opcion] / Work Light Kit (Rear) [Option]
Helice Eje Kit [Opcion] / Propeller Shaft Kit [Option]
Mano Estrangulador Kit[Opcion] / Hand Throttle Kit [Option]
Adelante Pesado Carga Amortiguador Telescopico Kit[Opcion] / Front Heavy Load Strut Kit [Option]
Adelante Pesado Carga Resortes Kit[Opcion] / Front Heavy Load Springs Kit [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Gear Pump) [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900sg-Eu][Opcion] / Hyd. Bed Lift Kit (Tank) [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Alejado)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Remote) [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Remote) [Component Parts] [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Lever) [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Ascenso Cilindro)[Rtv900sg-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Rtv900sg-Eu] [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Comp. Parts] [Rtv900sg-Eu] [Option]
Cama Camisa Kit[Opcion] / Bed Liner Kit [Option]
Barra De Remolque Kit(Adelante)[Rtv900r-Eu][Opcion] / Drawbar Kit (Front) [Rtv900sg-Eu] [Option]
Barra De Remolque Kit(Adelante)[Rtv900r-Eu][Opcion] / Drawbar Kit (Front) [Rtv900sw-Eu/Sr-Eu] [Option]
Barra De Remolque Kit(Trasero)[Opcion] / Drawbar Kit (Rear) [Option]
Cabrestante Soporte Kit[Rtv900g-Eu][Opcion] / Winch Mounting Kit [V4251] [Rtv900sg-Eu] [Option]
Cabrestante Soporte Kit[Rtv900g-Eu][Opcion] / Winch Mounting Kit [V4251] [Rtv900sw-Eu/Sr-Eu] [Option]
Cabrestante Soporte Kit[Rtv900g-Eu][Opcion] / Winch Mounting Kit [V4253] [Rtv900sg-Eu] [Option]
Cabrestante Soporte Kit[Rtv900g-Eu][Opcion] / Winch Mounting Kit [V4253] [Rtv900sw-Eu/Sr-Eu] [Option]
Adelante Protector Kit[Rtv900g-Eu][Opcion] / Front Guard Kit [Rtv900sg-Eu] [Option]
Adelante Accesorio Caja Kit[Opcion] / Front Accessory Box Kit [Option]
Guante Caja Kit[Opcion] / Glove Box Kit [Option]
Adelante Fango Protector Kit[Opcion] / Front Mud Guard Kit [Option]
Reposacabezas Kit[Opcion] / Headrest Kit [Option]
Cola Lampara Protectores Kit[Opcion] / Tail Lamp Guards Kit [Option]
Techo De Lona Kit(Camuflaje)[Rtv900r][Opcion] / Canopy Kit [V4221] [Option]
Culata Luz [Opcion] / Head Light Kit [Option]
Maintenance Parts
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Ventilador / Fan
Hst
Capo / Bonnet
Hoja / Seat
Peldano / Step
