Kubota Utility Vehicles RTV900MG-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV900MG-EU Utility Vehicles
Number of Pages: 437 Pages
Frequently Used Items
Maintenance Parts
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Aceite Bomba / Oil Pump
Caja De Cambios Ppal / Main Bearing Case
Volante / Flywheel
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Valvulas Y Balancines / Valve And Rocker Arm
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Ventilador Cubierta / Fan Cover
Alternador / Alternator
Motor De Arranque / Starter
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Claxon / Horn
Rele / Relay
Freno Conmutador / Brake Switch
Faro Delantero / Head Light
Cola Luz / Tail Light
Instalacion Electrica / Electrical Wiring
Adelante Caja / Front Case
Hst
Hst 1 (Carga Bomba) [Componente Piezas] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Regulador) [Componente Piezas] / Hst 2 (Regulator) [Component Parts]
Hst 3 (Motor Eje) [Componente Piezas] / Hst 3 (Motor Shaft) [Component Parts]
Hst 4 (Valvula) [Componente Piezas] / Hst 4 (Valve) [Component Parts]
Entrada Eje / Input Shaft
Eje De Cambio De Gama / Range Gear Shaft
Punto Muerto Eje / Idle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Transmision Kit / Transmission Kit
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Velocidad Cambio Palanca / Speed Change Lever
Velocidad Cambio Varilla / Speed Change Rod
Eje Trasero / Rear Axle
Árbol De Transmisión Trasero (Izquierda) / Rear Drive Shaft (Left)
Árbol De Transmisión Trasero (Derecha) / Rear Drive Shaft (Right)
Trasero Suspension / Rear Suspension
Freno Delantero (Izquierda) / Front Brake (Left)
Freno Delantero (Derecha) / Front Brake (Right)
Freno Trasero (Izquierda) / Rear Brake (Left)
Freno Trasero (Derecha) / Rear Brake (Right)
Freno Cilindro (Izquierdo) / Brake Cylinder (Left)
Freno Cilindro (Derecho) / Brake Cylinder (Right)
Freno Aceite Linea (Adelante) / Brake Oil Line (Front)
Freno Aceite Linea (Trasero) / Brake Oil Line (Rear)
Freno Varilla / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Derivacion Valvula Vinculo / Bypass Valve Link
Linea De Aceite Hidraulico (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Transmision Bastidor / Transmission Frame
Diferencial Eje Del Engranaje / Differential Gear Shaft
Árbol De Transmisión Delantero (Izquierda) / Front Drive Shaft (Left)
Árbol De Transmisión Delantero (Derecha) / Front Drive Shaft (Right)
Caja Del Eje Delantero (Izquierda) / Front Axle Case (Left)
Caja Del Eje Delantero (Derecha) / Front Axle Case (Right)
Eje Delantero (Izquierda) / Front Axle (Left)
Eje Delantero (Derecha) / Front Axle (Right)
Adelante Accionar Eje / Front Drive Shaft
Suspensión Delantera (Izquierda) / Front Suspension (Left)
Suspensión Delantera (Derecha) / Front Suspension (Right)
Adelante Suspension [Componente Piezas] / Front Suspension [Component Parts]
Brazo Suspensión Delantera (Izquierda) / Front Suspension Arm (Left)
Brazo Suspensión Delantera (Derecha) / Front Suspension Arm (Right)
Orbitrol / Steering Controller
Direccion Deposito / Steering Tank
Caja Base / Box Base
Caja Placa / Box Plate
Caja Compuerta / Box Gate
Tapa De La Caja / Box Cover
Adelante Protector / Front Guard
Parrilla Frontal / Front Grille
Capo / Bonnet
Lado Cubierta / Side Cover
Panel Bastidor / Panel Frame
Guardabarros / Fender
Centro Cubierta / Center Cover
Hoja / Seat
Capo / Bonnet
Peldano / Step
Rops
Adelante Rueda (25*10-12) / Front Wheel (25*10-12)
Trasero Rueda (25*10-12) / Rear Wheel (25*10-12)
Etiqueta (Adelante) [Ingles] / Label (Front) [English]
Etiqueta (Adelante) [Frances] / Label (Front) [French]
Etiqueta (Adelante) [Aleman] / Label (Front) [German]
Etiqueta (Trasero) [Ingles] / Label (Rear) [English]
Etiqueta (Trasero) [Frances] / Label (Rear) [French]
Etiqueta (Trasero) [Aleman] / Label (Rear) [German]
Alto Soporte Aire Limpiador Kit [Opcion] / High Mount Air Cleaner Kit [Option]
Velocimetro Kit [Opcion] / Speedmeter Kit [Option]
Reserva Zumbador Kit [Opcion] / Backup Beeper Kit [Option]
Kit Proteccion Radiador [Opcion] / Radiator Guard Kit [Option]
Sobrecalentamiento Alarma Kit [Opcion] / Overheat Alarm Kit [Option]
Trabajo Luz Kit (Adelante) [Opcion] / Work Light Kit (Front) [Option]
Trabajo Luz Kit (Trasero) [Opcion] / Work Light Kit (Rear) [Option]
Helice Eje De Engrasador [Opcion] / Propeller Shaft With Nipple [Option]
Mano Estrangulador Kit [Opcion] / Hand Throttle Kit [Option]
Adelante Pesado Carga Amortiguador Kit [Opcion] / Front Heavy Load Strut Kit [Option]
Adelante Pesado Carga Resortes Kit [Opcion] / Front Heavy Load Springs Kit [Option]
Hidraulico Cama Elevacion Kit (Engranaje Bomba) [Opcion] / Hyd. Bed Lift Kit (Gear Pump) [Option]
Hidraulico Cama Elevacion Kit (Deposit) [Opcion] / Hyd. Bed Lift Kit (Tank) [Option]
Hidraulico Cama Elevacion Kit (Alejado) [Opcion] / Hyd. Bed Lift Kit (Remote) [Option]
Hidraulico Cama Elevacion Kit (Alejado) [Comp. Piezas] [Opcion] / Hyd. Bed Lift Kit (Remote) [Comp. Parts] [Option]
Hidraulico Cama Elevacion Kit (Ascenso Palanca) [Opcion] / Hyd. Bed Lift Kit (Lift Lever) [Option]
Hidraulico Cama Elevacion Kit (Ascenso Cilindro) [Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Option]
Hidraulico Cama Elevacion Kit (Ascenso Cilindro) [Comp. Piezas] [Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Comp. Parts] [Option]
Cama Camisa Kit [Opcion] / Bed Liner Kit [Option]
Barra De Remolque Kit (Adelante) [Opcion] / Drawbar Kit (Front) [Option]
Barra De Remolque Kit (Trasero) [Opcion] / Drawbar Kit (Rear) [Option]
Barra De Remolque Kit (Trasero) [Opcion] / Drawbar Kit (Rear) [Option]]
Cabrestante Soporte Kit [Opcion] / Winch Mounting Kit [Option]
Adelante Protector Kit [Opcion] / Front Guard Kit [Option]
Adelante Accesorio Caja Kit [Opcion] / Front Accessory Box Kit [Option]
Guante Caja Kit [Opcion] / Glove Box Kit [Option]
Adelante Fango Protector Kit [Opcion] / Front Mud Guard Kit [Option]
Reposacabeza Kit [Opcion] / Headrest Kit [Option]
Cola Lampara Protectores Kit [Opcion] / Tail Lamp Guards Kit [Option]
Techo De Lona Kit [Opcion] / Canopy Kit [Option]
Protector Kit (Alternador) [Opcion] / Shield Kit (Alternator) [Option]
Maintenance Parts
Volante / Flywheel
Ventilador / Fan
Ventilador / Fan
Claxon / Horn
Rele / Relay
Hst
Capo / Bonnet
Hoja / Seat
Capo / Bonnet
Peldano / Step
Rops
