Kubota Utility Vehicles RTV900G-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV900G-EU Utility Vehicles
Number of Pages: 373 Pages
Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Combustible Bomba(Mecanico) / Fuel Pump (Mechanical)
Manocontacto De Aceite/Termometro / Oil Switch/Thermometer
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Freno Conmutador / Brake Switch
Culata Luz / Head Light
Cola Luz / Tail Light
Adelante Caja / Front Case
Hst
Hst 1[Componente Piezas] / Hst 1 [Component Parts]
Hst 2[Componente Piezas] / Hst 2 [Component Parts]
Hst 3[Componente Piezas] / Hst 3 [Component Parts]
Hst 4[Componente Piezas] / Hst 4 [Component Parts]
Entrada Eje / Input Shaft
Helice Eje / Propeller Shaft
Marcha Atras Eje / Revarse Shaft
Punto Muerto Eje / Idle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Universal Junta / Universal Joint
Transmision Kit / Transmission Kit
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Velocidad Cambio Palanca / Speed Change Lever
Velocidad Cambio Varilla / Speed Change Rod
Eje Trasero / Rear Axle
Trasero Suspension / Rear Suspension
Adelante Freno / Front Brake
Trasero Freno / Rear Brake
Freno Cilindro(Izquierdo) / Brake Cylinder (Left)
Freno Cilindro(Derecho) / Brake Cylinder (Right)
Freno Maestro Cilindro[Componente Piezas] / Brake Master Cylinder [Component Parts]
Freno Aceite Linea(Adelante) / Brake Oil Line (Front)
Freno Aceite Linea(Trasero) / Brake Oil Line (Rear)
Freno Varilla / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Transmision Bastidor / Transmission Frame
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Accionar Eje / Front Drive Shaft
Adelante Eje / Front Axle
Adelante Suspension / Front Suspension
Adelante Suspension[Componente Piezas] / Front Suspension [Component Parts]
Adelante Suspension Brazo / Front Suspension Arm
Direccion Cilindro / Steering Cylinder
Direccion Deposito / Steering Tank
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line (Steering)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line(Hst)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Caja Base / Box Base
Caja Placa / Box Plate
Caja Compuerta / Box Gate
Adelante Protector / Front Guard
Capo / Bonnet
Lado Cubierta / Side Cover
Panel Bastidor / Panel Frame
Guardabarros / Fender
Hoja / Seat
Peldano / Step
Rops
Adelante Rueda(25*10-12) / Front Wheel (25*10-12)
Trasero Rueda(25*10-12) / Rear Wheel (25*10-12)
Etiqueta(Adelante)[Ingles] / Label(Front) [English]
Etiqueta(Adelante)[Frances] / Label(Front) [French]
Etiqueta(Adelante)[Alemania] / Label(Front) [Germany]
Etiqueta(Trasero)[Ingles] / Label(Rear) [English]
Etiqueta(Trasero)[Frances] / Label(Rear) [French]
Etiqueta(Trasero)[Alemania] / Label(Rear) [Germany]
Alto Soporte Aire Limpiador Kit[Opcion] / High Mount Air Cleaner Kit [Option]
Combustible Filtro Kit[Opcion] / Fuel Filter Kit [Option]
Combustible Filtro[Componente Piezas][Opcion] / Fuel Filter [Component Parts] [Option]
Velocimetro Kit[Rtv900g-Eu/W-Eu][Opcion] / Speedometer Kit [Rtv900g-Eu/W-Eu] [Option]
Reserva Zumbador Kit[Opcion] / Backup Beeper Kit [Option]
Sobrecalentamiento Alarma Kit[Opcion] / Overheat Alarm Kit [Option]
Trabajo Luz Kit(Adelante)[Opcion] / Work Light Kit (Front) [Option]
Trabajo Luz Kit(Trasero)[Opcion] / Work Light Kit (Rear) [Option]
Mano Estrangulador Kit[Opcion] / Hand Throttle Kit [Option]
Adelante Pesado Carga Amortiguador Telescopico Kit[Opcion] / Front Heavy Load Strut Kit [Option]
Adelante Pesado Carga Resortes Kit[Opcion] / Front Heavy Load Springs Kit [Option]
Hidraulico Cama Ascenso Kit(Engranaje Bomba)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Gear Pump) [Rtv900g-Eu] [Option]
Hidraulico Cama Ascenso Kit(Deposito)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Tank) [Rtv900g-Eu] [Option]
Hidraulico Cama Ascenso Kit(Alejado)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Remote) [Rtv900g-Eu] [Option]
Kit Hid. Elevacion Caja(Remoto)[Despiece][Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Remote) [Component Parts] [Rtv900g-Eu] [Option]
Hidraulico Cama Ascenso Kit(Ascenso Palanca)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Lever) [Rtv900g-Eu] [Option]
Hidraulico Cama Ascenso Kit(Ascenso Cylindro)[Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Rtv900g-Eu] [Option]
Kit Hid. Elevacion Caja(Cyl. Elevacion)[Despiece][Rtv900g-Eu][Opcion] / Hyd. Bed Lift Kit (Lift Cyl.) [Comp.Parts] [Rtv900g-Eu] [Option]
Cama Camisa Kit[Opcion] / Bed Liner Kit [Option]
Barra De Remolque Kit(Adelante)[Rtv900r-Eu][Opcion] / Drawbar Kit (Front) [Rtv900g-Eu] [Option]
Barra De Remolque Kit(Adelante)[Rtv900w-Eu/R-Eu][Opcion] / Drawbar Kit (Front) [Rtv900w-Eu/R-Eu] [Option]
Barra De Remolque Kit(Trasero)[Opcion] / Drawbar Kit (Rear) [Option]
Cabrestante Soporte Kit[Rtv900g-Eu][Opcion] / Winch Mounting Kit [Rtv900g-Eu] [Option]
Cabrestante Soporte Kit[Rtv900w-Eu/R-Eu][Opcion] / Winch Mounting Kit [Rtv900w-Eu/R-Eu] [Option]
Adelante Protector Kit[Rtv900g-Eu][Opcion] / Front Guard Kit [Rtv900g-Eu] [Option]
Adelante Accesorio Caja Kit[Opcion] / Front Accessory Box Kit [Option]
Guante Caja Kit[Opcion] / Glove Box Kit [Option]
Adelante Fango Protector Kit[Opcion] / Front Mud Guard Kit [Option]
Reposacabezas Kit[Opcion] / Headrest Kit [Option]
Cola Lampara Protectores Kit[Opcion] / Tail Lamp Guards Kit [Option]
Techo De Lona Kit[Opcion] / Canopy Kit [Option]
Culata Luz [Opcion] / Head Light Kit [Option]
Maintenance Parts
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Ventilador / Fan
Hst
Capo / Bonnet
Hoja / Seat
Peldano / Step
Rops
