Kubota Utility Vehicles RTV1140CPX Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV1140CPX Utility Vehicles
Number of Pages: 419 Pages
Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Tapa Silenciador / Muffler Cover
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Agua Tubo (Radiador) / Water Pipe (Radiator)
Agua Tubo (Motor) / Water Pipe (Engine)
Tapa Del Radiador / Radiator Cover
Alternador / Alternator
Motor De Arranque / Starter
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Freno Conmutador / Brake Switch
Culata Luz / Head Light
Cola Luz / Tail Light
Electrico Cableado / Electrical Wiring
Adelante Caja / Front Case
Hst
Hst 1 (Carga Bomba) [Componente Piezas] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Piston) [Componente Piezas] / Hst 2 (Piston) [Component Parts]
Hst 3 (Regulador) [Componente Piezas] / Hst 3 (Regulator) [Component Parts]
Hst 4 (Motor Eje) [Componente Piezas] / Hst 4 (Motor Shaft) [Component Parts]
Hst 5 (Cubierta) [Componente Piezas] / Hst 5 (Cover) [Component Parts]
Hst 6 (Valvula) [Componente Piezas] / Hst 6 (Valve) [Component Parts]
Entrada Eje / Input Shaft
Helice Eje / Propeller Shaft
Punto Muerto Eje / Idle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Transmision Kit / Transmission Kit
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Velocidad Cambio Palanca / Speed Change Lever
Eje Trasero (Izquierda) / Rear Axle (Left)
Eje Trasero (Derecha) / Rear Axle (Right)
Árbol De Transmisión Trasero (Izquierda) / Rear Drive Shaft (Left)
Árbol De Transmisión Trasero (Derecha) / Rear Drive Shaft (Right)
Suspensión Trasera (Izquierda) / Rear Suspension (Left)
Suspensión Trasera (Derecha) / Rear Suspension (Right)
Freno Delantero (Izquierda) / Front Brake (Left)
Freno Delantero (Derecha) / Front Brake (Right)
Freno Trasero (Izquierda) / Rear Brake (Left)
Freno Trasero (Derecha) / Rear Brake (Right)
Freno Cilindro (Izquierda) / Brake Cylinder (Left)
Freno Cilindro (Derecha) / Brake Cylinder (Right)
Freno Aceite Linea (Adelante) / Brake Oil Line (Front)
Freno Aceite Linea (Trasero) / Brake Oil Line (Rear)
Freno Varilla / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Ascenso Palanca / Lift Lever
Acoplamiento De Descarga / Unload Link
Aceite Deposito / Hydraulic Tank
Hidraulico Aceite Linea (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (Deposito) / Hydraulic Oil Line (Tank)
Línea De Aceite Hidráulico (Válvula De Control) / Hydraulic Oil Line (Control Valve)
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Ascenso Cilindro [Componente Piezas] / Lift Cylinder [Component Parts]
Línea De Aceite Hidráulico (Cilindro De Elevación) / Hydraulic Oil Line (Lift Cylinder)
Transmision Bastidor / Transmission Frame
Bajo Custodia / Under Guard
Diferencial Engranaje Eje / Differential Gear Shaft
Árbol De Transmisión Delantero (Izquierda) / Front Drive Shaft (Left)
Árbol De Transmisión Delantero (Derecha) / Front Drive Shaft (Right)
Caja Del Eje Delantero (Izquierda) / Front Axle Case (Left)
Caja Del Eje Delantero (Derecha) / Front Axle Case (Right)
Adelante Eje (Izquierda) / Front Axle (Left)
Eje Delantero (Derecha) / Front Axle (Right)
Árbol De Transmisión Delantero / Front Propeller Shaft
Suspensión Delantera (Izquierda) / Front Suspension (Left)
Suspensión Delantera (Derecha) / Front Suspension (Right)
Adelante Suspension [Componente Piezas] / Front Suspension [Component Parts]
Brazo Suspensión Delantera (Izquierda) / Front Suspension Arm (Left)
Brazo Suspensión Delantera (Derecha) / Front Suspension Arm (Right)
Direccion Cilindro / Steering Cylinder
Base De La Caja (Delantera) / Box Base (Front)
Base De La Caja (Trasera) / Box Base (Rear)
Placa De Caja (Delantera) / Box Plate (Front)
Placa De Caja (Trasera) / Box Plate (Rear)
Caja Compuerta / Box Gate
Adelante Protector / Front Guard
Capó (Superior) / Bonnet (Upper)
Capó (Inferior) / Bonnet (Lower)
Panel Cubierta / Panel Cover
Guardabarros (Delantera) / Fender (Front)
Guardabarros (Trasera) / Fender (Rear)
Centro Cubierta (Delantera) / Center Cover (Front)
Centro Cubierta (Lado) / Center Cover (Side)
Centro Cubierta (Trasera) / Center Cover (Rear)
Asiento Soporte (Trasera) / Seat Support (Rear)
Asiento (Delantero) / Seat (Front)
Asiento (Trasero) / Seat (Rear)
Cinturón Del Asiento (Delantero) / Seat Belt (Front)
Cinturón Del Asiento (Trasero) / Seat Belt (Rear)
Peldaño (Delantero) / Step (Front)
Peldaño (Trasero) / Step (Rear)
Arco De Seguridad (Delantero) / Rops (Front)
Arco De Seguridad (Trasero) / Rops (Rear)
Red (Rops) / Net (Rops)
Rueda Delantera (25*10-12) / Front Wheel (25*10-12)
Rueda Delantera (25*12-12) / Front Wheel (25*12-12)
Rueda Trasera (25*11-12) / Rear Wheel (25*11-12)
Rueda Trasera (25*10-12) / Rear Wheel (25*10-12)
Rueda Trasera (25*12-12) / Rear Wheel (25*12-12)
Juego Admisión De Aire Posición Elevada (W/G No. V4471) [Opcion] / High Position Air Intake Kit (W/G No. V4471) [Option]
Reserva Zumbador Kit (W/G No.V4232) [Opcion] / Backup Beeper Kit (W/G No.V4232) [Option]
Trabajo Luz Kit (Trasero)(W/G No.V4453) [Opcion] / Work Light Kit (Rear) (W/G No. V4453) [Option]
Juego Caja Motor Trasero [Opcion] / Rear Motor Case Kit [Option]
Helice Eje De Engrasador [Opcion] / Front Propeller Shaft With Nipple [Option]
Adelante Pesado Carga Resortes Kit (W/G No.V4219) [Opcion] / Front Heavy Load Springs Kit (W/G No.V4219) [Option]
Cama Camisa Kit (W/G No.V4451) [Opcion] / Bed Liner Kit (W/G No. V4451) [Option]
Adelante Accesorio Caja Kit (W/G No.V4235) [Opcion] / Front Accessory Box Kit (W/G No.V4235) [Option]
Juego Soporte De La Copa (W/G No. V4452) [Opcion] / Cup Holder Kit (W/G No. V4452) [Option]
Guante Caja Kit (W/G No.V4234) [Opcion] / Glove Box Kit (W/G No.V4234) [Option]
Adelante Fango Protector Kit (W/G No.V4236) [Opcion] / Front Mud Guard Kit (W/G No.V4236) [Option]
Juego De Protector (Asiento Trasero) [Opcion] / Shield Kit (Seat Rear) [Option]
Juego De Reposacabezas De Estancia (W/G No. V4443) [Opcion] / Headrest Stay Kit (W/G No. V4443) [Option]
Reposacabeza Kit (W/G No.V4231) [Opcion] / Headrest Kit (W/G No. V4231) [Option]
Techo De Lona Kit (W/G No.V4441) [Opcion] / Canopy Kit (W/G No. V4441) [Option]
Juego Parabrisas Policarbonato (W/G No.V4442) [Opcion] / Polycarbonate Windshield Kit (W/G No. V4442) [Option]
Maintenance Parts
Volante / Flywheel
Speed Control Plate
Hst
