Kubota Utility Vehicles RTV-X900MWEU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Utility Vehicles
Model: Kubota RTV-X900MWEU Utility Vehicles
Number of Pages: 493 Pages
Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Tapa Silenciador / Muffler Cover
Kit Arbol De Levas 1 [Opcion] / Camshaft Kit 1 [Option]
Kit Arbol De Levas 2 [Opcion] / Camshaft Kit 2 [Option]
Combustible Bomba / Fuel Pump
Manguera Del Purgador De Aire / Air Bleeder Hose
Ventilador (Radiador) / Fan (Radiator)
Ventilador (Motor) / Fan (Engine)
Ventilador Cubierta / Fan Cover
Agua Tubo (Radiador) / Water Pipe (Radiator)
Agua Tubo (Motor) / Water Pipe (Engine)
Protector Del Radiador / Radiator Shield
Alternador / Alternator
Motor De Arranque / Starter
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Claxon/Zumbador / Horn/Buzzer
Conmutador/Rele / Switch/Relay
Freno Conmutador / Brake Switch
Culata Luz / Head Light
Cola Luz / Tail Light
Electrical Wiring
Adelante Caja / Front Case
Respiradero De La Transmisión / Transmission Breather
Hst
Hst 1 (Caja) [Componente Piezas] / Hst 1 (Case) [Component Parts]
Hst 2 (Bomba) [Componente Piezas] / Hst 2 (Pump) [Component Parts]
Hst 3 (Piston) [Componente Piezas] / Hst 3 (Piston) [Component Parts]
Hst 4 (Motor) [Componente Piezas] / Hst 4 (Motor) [Component Parts]
Hst 5 (Regulador) [Componente Piezas] / Hst 5 (Regulator) [Component Parts]
Hst 6 (Cargo Bomba) [Componente Piezas] / Hst 6 (Charge Pump) [Component Parts]
Hst 7 (Cubierta De Bloqueo De Puerto) [Componente Piezas] / Hst 7 (Port Block Cover) [Component Parts]
Hst 8 (Válvula De Bloqueo De Puerto) [Componente Piezas] / Hst 8 (Port Block Valve) [Component Parts]
Hst 9 (Bloqueo De Puerto) [Componente Piezas] / Hst 9 (Port Block) [Component Parts]
Entrada Eje / Input Shaft
Principal Engranaje Eje / Main Gear Shaft
Punto Muerto Eje / Idle Shaft
Eje 4wd / 4wd Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Diferencial Trasero / Rear Differential Gear
Motor De Eje Trasero (Izquierda) / Rear Axle Gear (Left)
Motor De Eje Trasero (Derecha) / Rear Axle Gear (Right)
Gama Engranaje Brazo / Range Gear Arm
Adelante Rueda Accionar Brazo / Front Wheel Drive Arm
Brazo De Válvula De Control / Control Valve Arm
Velocidad Cambio Palanca / Shift Lever
Cable De Cambio De Velocidad / Speed Change Cable
Eje Trasero (Izquierda) / Rear Axle (Left)
Eje Trasero (Derecha) / Rear Axle (Right)
Árbol De Transmisión Trasero (Izquierda) / Rear Drive Shaft (Left)
Árbol De Transmisión Trasero (Derecha) / Rear Drive Shaft (Right)
Eje De Tracción Trasera [Componente Piezas] / Rear Drive Shaft [Component Parts]
Suspensión Trasera (Izquierda) / Rear Suspension (Left)
Suspensión Trasera (Derecha) / Rear Suspension (Right)
Suspensión Trasera [Componente Piezas] / Rear Suspension [Component Parts]
Brazo De Suspensión Trasero (Izquierda Superior) / Rear Suspension Arm (Left Upper)
Brazo De Suspensión Trasero (Izquierda Inferior) / Rear Suspension Arm (Left Lower)
Brazo De Suspensión Trasero (Derecha Superior) / Rear Suspension Arm (Right Upper)
Brazo De Suspensión Trasero (Derecha Inferior) / Rear Suspension Arm (Right Lower)
Estabilizador Trasero / Rear Stabilizer
Freno Delantero (Izquierda) / Front Brake (Left)
Freno Delantero (Derecha) / Front Brake (Right)
Freno Trasero (Izquierda) / Rear Brake (Left)
Freno Trasero (Derecha) / Rear Brake (Right)
Freno Cilindro / Brake Cylinder
Cilindro De Frenos [Componente Piezas] / Brake Cylinder [Component Parts]
Freno Aceite Linea (Adelante) / Brake Oil Line (Front)
Freno Aceite Linea (Trasero) / Brake Oil Line (Rear)
Freno Varilla / Brake Rod
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Ascenso Palanca / Lift Lever
Acoplamiento De Descarga / Unload Link
Aceite Deposito / Hydraulic Tank
Línea De Aceite Hidráulico (Direccion) / Hydraulic Oil Line (Steering)
Línea De Aceite Hidráulico (Bomba) / Hydraulic Oil Line (Pump)
Línea De Aceite Hidráulico (Hst) / Hydraulic Oil Line (Hst)
Línea De Aceite Hidráulico (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Línea De Aceite Hidráulico (Deposito) / Hydraulic Oil Line (Tank)
Línea De Aceite Hidráulico (Válvula De Control) / Hydraulic Oil Line (Control Valve)
Descarga Valvula / Reief Valve
Línea De Aceite Hidráulico (Cilindro De Elevación) / Hydraulic Oil Line (Lift Cylinder)
Transmision Bastidor / Transmission Frame
Bajo Custodia / Under Guard
Soporte De Transmisión / Transmission Bracket
Diferencial Eje Del Engranaje / Differential Gear Shaft
Árbol De Transmisión Delantero (Izquierda) / Front Drive Shaft (Left)
Árbol De Transmisión Delantero (Derecha) / Front Drive Shaft (Right)
Árbol De Transmisión Delantero [Componente Piezas] / Front Drive Shaft [Component Parts]
Caja Del Eje Delantero (Izquierda) / Front Axle Case (Left)
Caja Del Eje Delantero (Derecha) / Front Axle Case (Right)
Tubo Del Respiradero / Breather Pipe
Adelante Eje (Izquierda) / Front Axle (Left)
Eje Delantero (Derecha) / Front Axle (Right)
Adelante Rueda Helice Eje [Componente Piezas] / Front Wheel Propeller Shaft [Component Parts]
Suspensión Delantera (Izquierda) / Front Suspension (Left)
Suspensión Delantera (Derecha) / Front Suspension (Right)
Adelante Suspension [Componente Piezas] / Front Suspension [Component Parts]
Brazo De Suspensión Delantero (Izquierda Superior) / Front Suspension Arm (Left Upper)
Brazo De Suspensión Delantero (Izquierda Inferior) / Front Suspension Arm (Left Lower)
Brazo De Suspensión Delantero (Derecha Superior) / Front Suspension Arm (Right Upper)
Brazo De Suspensión Delantero (Derecha Inferior) / Front Suspension Arm (Right Lower)
Estabilizador Delantero / Front Stabilizer
Direccion Poste / Steering Post
Atar Varilla / Tie Rod
Direccion Cilindro / Steering Cylinder
Caja Base / Box Base
Caja Placa / Box Plate
Caja Compuerta / Box Gate
Tapa De La Caja / Box Cover
Adelante Protector / Front Guard
Parachoques,Adelante / Front Bumper
Capo / Hood (Bonnet)
Lado Cubierta / Side Cover
Caja De Guantes / Glove Box
Panel Cubierta / Panel Cover
Panel Bastidor / Panel Frame
Guardabarros (Delantero) / Fender (Front)
Guardabarros (Trasero) / Fender (Rear)
Centro Cubierta (Lado) / Center Cover (Side)
Centro Cubierta (Trasero) / Center Cover (Rear)
Apoyo De Asiento (Funcionamiento) / Seat Support (Operation)
Asiento Soporte (Pasajero) / Seat Support (Passenger)
Hoja / Seat
Cinturón Del Asiento / Seat Belt
Peldano / Step
Placa De Aislacion / Insulation Plate
Caja De Asiento / Seat Box
Rueda Delantera (25*10-12) / Front Wheel (25*10-12)
Rueda Trasera (25*10-12) / Rear Wheel (25*10-12)
Etiqueta (Panel) / Label (Panel)
Medidor,Aceite (W/G No.V5202) [Opcion] / Oil Gauge Kit (W/G No.V5202) [Option]
Reserva Zumbador Kit (W/G No.V5236) [Opcion] / Backup Beeper Kit (W/G No.V5236) [Option]
Mano Estrangulador Kit (W/G No.V5241) [Opcion] / Hand Throttle Kit (W/G No.V5241) [Option]
Adelante Pesado Carga Amortiguador Kit (W/G No.V5219) [Opcion] / Front Heavy Load Strut Kit (W/G No.V5219) [Option]
Adelante Pesado Carga Resortes Kit (W/G No.V5218) [Opcion] / Front Heavy Load Springs Kit (W/G No.V5218) [Option]
Kit Guardia Cv-J Adelante (W/G No.V5238) [Opcion] / Front Cv-J Guard Kit (W/G No.V5238) [Option]
Kit Guardia Cv-J Trasero (W/G No.V5239) [Opcion] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hidraulico Puerto Acoplador Kit (W/G No.V5276) [Opcion] / Hydraulic Outlet Coupler Kit (W/G No.V5276) [Option]
Kit Segundo Hidraulico De La Alta Capacidad (Bomba) (W/G No.V5271) [Opcion] / Double Hyd. Pump Kit (Pump) (W/G.No.V5271) [Option]
Bomba Hidraulica [Componente Piezas] (W/G No.V5271) [Opcion] / Hydraulic Pump [Component Parts] (W/G No.V5271) [Option]
Kit Segundo Hidraulico De La Alta Capacidad (Tubo) (W/G No.V5271) [Opcion] / Double Hyd. Pump Kit (Oil Line) (W/G.No.V5271) [Option]
Kit Primera Hidraulico Valvula (Palanca) (W/G No.V5273) [Opcion] / Hyd.Single Valve Kit (Lever) (W/G.No.V5273) [Option]
Kit Primera Hidraulico Valvula (Eje) (W/G No.V5273) [Opcion] / Hyd.Single Valve Kit (Shaft) (W/G.No.V5273) [Option]
Kit Primera Hidraulico Valvula (Valvula) (W/G No.V5273) [Opcion] / Hyd.Single Valve Kit (Valve) (W/G.No.V5273) [Option]
Primera Hidraulico Valvula [Componente Piezas] (W/G No.V5273) [Opcion] / Hyd.Single Valve [Comp.Parts] (W/G.No.V5273) [Option]
Kit Primera Hidraulico Valvula (Tubo) (W/G No.V5273) [Opcion] / Hyd.Single Valve Kit (Oil Line) (W/G.No.V5273) [Option]
Kit Segundo Hidraulico Valvula (Palanca) (W/G No.V5274) [Opcion] / Hyd.Double Valve Kit (Lever) (W/G.No.V5274) [Option]
Kit Segundo Hidraulico Valvula (Eje) (W/G No.V5274) [Opcion] / Hyd.Double Valve Kit (Shaft) (W/G.No.V5274) [Option]
Kit Segundo Hidraulico Valvula (Valvula) (W/G No.V5274) [Opcion] / Hyd.Double Valve Kit (Valve) (W/G.No.V5274) [Option]
Segundo Hidraulico Valvula [Componente Piezas] (W/G No.V5274) [Opcion] / Hyd.Double Valve [Comp.Parts] (W/G.No.V5274) [Option]
Kit Segundo Hidraulico Valvula (Tubo) 1 (W/G No.V5274) [Opcion] / Hyd.Double Valve Kit (Oil Line) 1 (W/G.No.V5274) [Option]
Kit Segundo Hidraulico Valvula (Tubo) 2 (W/G No.V5274) [Opcion] / Hyd.Double Valve Kit (Oil Line) 2 (W/G.No.V5274) [Option]
Cama Camisa Kit (W/G No.V5229) [Opcion] / Bed Liner Kit (W/G. No. V5229) [Option]
Barra De Remolque Kit Adelante [Opcion] / Drawbar Kit Front [Option]
Barra De Remolque Kit Trasero [Opcion] / Drawbar Kit Rear [Option]
Adelante Fango Protector Kit (W/G No.V5225) [Opcion] / Front Mud Guard Kit (W/G No.V5225) [Option]
Trasero Protector Kit (W/G No.V5226) [Opcion] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Cola Lampara Protectores Kit (W/G No.V5227) [Opcion] / Tail Lamp Guards Kit (W/G No.V5227) [Option]
Juego De Ruedas De Aluminio [Opcion] / Aluminum Alloy Wheel Kit [Option]
Juego De Ruedas De Aluminio (W/G No.Artv5213) [Opcion] / Aluminum Alloy Wheel Kit (W/G No.Artv5213) [Option]
Kit De Tornillos De Rueda De Aluminio (W/G No.V5205) [Opcion] / Alloy Wheel Hardware Kit (W/G No.V5205) [Option]
