Kubota Utility Vehicle RTV900W Homologated Verion-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900W Homologated Verion-EU Utility Vehicle
Number of Pages: 238 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipsti Ck And Guide
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camsha Ft And Idle Gear Shaft
Piston E Cambota / Piston An D Crankshaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Gov Ernor Shaft
Ponto Neutro / Idle Apparatu S
Valvula Solenoide / Nozzle H Older And Glow Plug
Suporte Bico [Peças Componen Tes] / Nozzle Holder [Component Parts]
Bomba Gasoleo / Fuel Pump(Me Chanical)
Interruptor E Termómetro Do Óleo / Oil Switch/Thermometer
Bomba Agua E Termostacto / W Ater Flange And Thermostat
Acessorios / Water Pump
Radiador / Water Pipe
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Colector Admissao / Inlet Ma Nifold
Colector Escape / Exhaust Ma Nifold
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Superior / Uppe R Gasket Kit
Deposito Combustivel / Lower Gasket Kit
Filtro Gasoleo / Stop Soleno Id
Acelar Ador / Accelerator Pedal
Deposi To Combustivel / Fuel Tank
Tubo C Ombustivel / Fuel Pipe
Ventilador / Fan
Alter Nador / Alternator
Alter Nador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Bater Ia / Battery
Inter Ruptor / Sensor (Motor) / Switch/Sensor
Tampa Interruptor / Panel Switch
Inter Ruptor Travao / Brake Switch
Farol Dianteiro / Head Light
Luzes Frontais / Front Combination Light
Braco Traseiro / Rear Combination Light
Cabal Agem Eletrica(Cabine)[Ec] [G] / Electrical Wiring
Carter Frontal / Front Case
Caixa Velocidade S / Transmission Case
Hst / Hst
Hst (Bloco Do Ci Lindro) [Peças Componentes] 1 / Hst 1 [Component Pa Rts]
Hst (Tampa Do Bl Oco De Abertura) [Peças Componentes] 2 / Hst 2 [Com Ponent Parts]
Hst (Junta) [Peç As Componentes] 3 / Hst 3 [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Veloc Idades / Range Gear Shaft
Inversor / Revar Se Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dian Teira / Front Wheel Propeller Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Cart Er / Rear Differential
Veio Eixo Trasei Ro / Rear Wheel Propeller Shaft
Estrutura Princi Pal / Universal Joint
Kit Transmissao / Transmission Kit
Forque Ta Caixa / Creeper / Range Gear Shift Fork
Braço Carreto Gamas / Range Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Alavan Ca / Differential Lock Shift Fork
Caixa Velocidades / Speed Change Lever
Caixa Velocidades / Speed Change Rod
Alavan Ca Velocidades / Main Gear Shift Lever
Eixo Traseiro / R Ear Axle
Suspensao Traseir A / Rear Suspension
Bloqueio Diferenc Ial / Differential Lock Pedal
Travao Frontal / Front Brake
Travao Traseiro / Rear Brake
Cilindro Travao (Esq) / Brak E Cylinder(Left)
Cilindro Travao (Drt) / Brak E Cylinder(Right)
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal[Pe Ças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes / Brake Oi L Line(Front)
Tubo Oleo Travoes / Brake Oi L Line(Rear)
Tirante Travao / Brake Rod
Alavanca Travao Mao / Parkin G Brake Lever
Pedal Travao / Brake Pedal
Bomba Hidraulico[Peças Componentes] / Hydraulic Pump [Co Mponent Parts]
Bomba Hidraulica / Gear Pump
Depos Ito Oleo Hidraulico / Hydraulic Tank
Circu Ito Oleo (Direcção) / Hydraulic Oil Line(Steering)
Tubo Oleo / Hydraulic Oil Line(Hst)
Radia Dor Oleo / Hydraulic Oil Line(Oil Cooler)
Tubo Oleo (Deposito) / Hydraulic Oil Line(Tank)
Distr Ibuidor Auxiliar / Remote Control Valve
Distr Ibuidor Auxiliar[Peças Componentes] / Remote Contro L Valve [Component Parts]
Cilnd Ro Eleveção / Lift Cylinder
Cilnd Ro Eleveção[Peças Componentes] / Lift Cylinder [Com Ponent Parts]
Estrutura / Main Frame
Transmissao / Transmissio N Frame
Carter Eixo / F Ront Axle Case
Grupo Conico / Differential Gear Shaft
Diferencial Dia Nteiro / Front Differential
Veio / Front Dr Ive Shaft
Eixo Dianteiro / Front Axle
Suspensao Front Al / Front Suspension
Suspensao Front Al[Peças Componentes] / Front Suspension [Component Parts]
Braço Suspensao / Front Suspension Arm
Direcção Assistida / Di Reção Punho / Steering Handle
Direcção / Steering Con Troller
Rotula / Cilindro Direc Ção / Steering Cylinder
Cilindro Direcção[Peças Componentes] / Steering Cylinder [Component Parts]
Deposito Oleo Direccao / Steering Tank
Caixa / Box Bas E
Chapa Caixa / B Ox Plate
Estrutura Caixa / Box Gate
Distribuidor Auxiliar / Fron T Guard
Grelha Frontal / Front Grill E
Acessorios / Bonnet
Painel Lateral / Side Cover
Kit Limpa Vidro Traseiros (O Pcao) / Panel Frame
Guarda Lamas / Fender
Suporte Assento / Seat Suppo Rt(Operator)
Suporte Assento / Seat Suppo Rt(Passenger)
Acessorios / Seat
Degrau / Step
Espelho Rectrovisor / Rearvi Ew Mirror
Alavanca Valvula Control Aux Iliar 2º [Opcao] / Rops
Barra Reboque / Drawbar
Roda Frente / Front Wheel(25*10-12)
Roda Traseira / Rear Wheel(25*10-12)
Etiqueta Frente / Label(Front) [French]
Etiqueta Frente / Label(Front) [Germany]
Etiqueta Traseir A / Label(Rear) [French]
Etiqueta Traseir A / Label(Rear) [Germany]
Acessorios / Accessories And Service Parts
Kit Filtro Ar[Opcao] / High Mount Air Cleaner Kit [Option]
Fuel Filter Kit [Option] / F Uel Filter Kit [Option]
Fuel Filter [Component Parts ] [Option] / Fuel Filter [Component Parts] [Option]
Kit Sonoro Mancha Atras[Opca O] / Backup Beeper Kit [Option]
Alarme Sobreaquecimento[Opca O] / Overheat Alarm Kit [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit(Front) [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit(Rear) [Option]
Kit Acelarador Mao / Hand Th Rottle Kit [Option]
Kit Estrutura Elevacao Front Al [Opcao] / Front Heavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opca O] / Front Heavy Load Springs Kit [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Tank) [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Oil Cooler) [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Hyd.Oil Line) [Optio N]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Remote) [Component Parts] [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Pto Lever) [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Electrical Wiring) [ Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Switch) [Option]
Kit Upgrade Hidraulico (Cabl Agem)[Opcao] / Hyd.Upgrade Kit(Label) [Option]
Kit Camisa / Bed Liner Kit [ Option]
Kit Barra Reboque[Opcao] / D Rawbar Kit(Front) [Option]
Kit Barra Reboque[Opcao] / D Rawbar Kit(Rear) [Option]
Kit Guicho (Opção) / Winch M Ounting Kit [Option]
Kit Caixa Acessorios / Front Accessory Box Kit [Option]
Kit Porta Luvas[Opcao] / Glo Ve Box Kit [Option]
Kit Guarda Lamas Frontais[Op Cao] / Front Mud Guard Kit [Option]
Kitproteccaoluzes(Opcao) / T Ail Lamp Guards Kit [Option]
Kit Tecto Lona[Opcao] / Cano Py Kit [Option]
