Kubota Utility Vehicle RTV900W-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900W-EU Utility Vehicle
Number of Pages: 226 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Bomba Gasoleo / Fuel Pump (Mechanical)
Interruptor E Termómetro Do Óleo / Oil Switch/Th Ermometer
Acessorios / Water Pump
Radiador / Water Pipe
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Lower Gasket Kit
Filtro Gasoleo / Stop Solenoid
Acelarador / Accelerator P Edal
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Ventilad Or / Fan
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Component Es] / Starter [Component Parts]
Interruptor / Sensor (Mot Or) / Switch/Sensor
Tampa Interruptor / Panel Switch
Interruptor Travao / Brak E Switch
Farol Dianteiro / Head Li Ght
Farol Traseiro / Tail Lig Ht
Cabalagem Eletrica(Cabine )[Ec] [G] / Electrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmission Cas E
Hst / Hst
Hst (Bloco Do Cilindro) [Peças Compo Nentes] 1 / Hst 1 [Component Parts]
Hst (Tampa Do Bloco De Abertura) [Pe Ças Componentes] 2 / Hst 2 [Component Parts]
Hst (Junta) [Peças Componentes] 3 / Hst 3 [Component Parts]
Hst (Fixador Do Neutro) [Peças Compo Nentes] 4 / Hst 4 [Component Parts]
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Revarse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Carter / Rear Differenti Al
Veio Eixo Traseiro / Rear Wheel Prop Eller Shaft
Estrutura Principal / Universal Join T
Kit Transmissao / Transmission Kit
Forqueta Caixa / Creeper / Range Gear Shift Fork
Braço Carreto Gamas / Rang E Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Alavanca / Differential Lo Ck Shift Fork
Caixa Velocidades / Speed Change Lever
Caixa Velocidades / Speed Change Rod
Alavanca Velocidades / Mai N Gear Shift Lever
Alavanca Dupla Traccao / F Ront Wheel Drive Lever
Eixo Traseiro / Rear Axle
Suspensao Traseira / Rear Suspension
Bloqueio Diferencial / Differential L Ock Pedal
Travao Frontal / Front Brake
Travao Traseiro / Rear Brake
Cilindro Travao (Esq) / Brake Cylinder (Left)
Cilindro Travao (Drt) / Brake Cylinder (Right)
Cilindro Travao Principal / Brake Master Cylinde R
Cilindro Travao Principal[Peças Componentes] / B Rake Master Cylinder [Component Parts]
Tubo Oleo Travoes / Brake Oil Line (Front)
Tubo Oleo Travoes / Brake Oil Line (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lever
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico[Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Bomba Hidraulica / Gear P Ump
Deposito Oleo Hidraulico / Hydraulic Tank
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Circuito Oleo Radiador / Hydraulic Oil Line (Oil Cooler)
Tubo Oleo (Deposito) / Hy Draulic Oil Line (Tank)
Distribuidor Auxiliar / R Emote Control Valve
Distribuidor Auxiliar[Peç As Componentes] / Remote Control Valve [Component Parts]
Cilndro Eleveção / Lift C Ylinder
Estrutura / Main Frame
Transmissao / Transmission Frame
Carter Eixo / Front Axle Case
Diferencial Dianteiro / Front Diffe Rential
Eixo Dianteiro / Front Axle
Suspensao Frontal / Front Suspensio N
Suspensao Frontal[Peças Componentes ] / Front Suspension [Component Parts]
Braço Suspensao / Front Suspension Arm
Direcção Assistida / Direção Punho / Steeri Ng Handle
Rotula / Cilindro Direcção / Steering Cylin Der
Cilindro Direcção[Peças Componentes] / Stee Ring Cylinder [Component Parts]
Deposito Oleo Direccao / Steering Tank
Caixa / Box Base
Estrutura Caixa / Box Gate
Distribuidor Auxiliar / Front Guard
Grelha Frontal / Front Grille
Acessorios / Bonnet
Painel Lateral / Side Cover
Kit Limpa Vidro Traseiros (Opcao) / Panel Frame
Guarda Lamas / Fender
Acessorios / Seat
Degrau / Step
Alavanca Valvula Control Auxiliar 2º [Opcao] / R Ops
Roda Frente / Front Wheel (25*10- 12)
Roda Traseira / Rear Wheel (25*10 -12)
Etiqueta Frente / Label(Front) [Engl Ish]
Etiqueta Frente / Label(Front) [Fren Ch]
Etiqueta Frente / Label(Front) [Germ Any]
Etiqueta Traseira / Label(Rear) [Eng Lish]
Etiqueta Traseira / Label(Rear) [Fre Nch]
Etiqueta Traseira / Label(Rear) [Ger Many]
Acessorios / Accesso Ries And Service Parts
Kit Filtro Ar[Opcao] / High Mount Air Cleaner Ki T [Option]
Fuel Filter Kit [Option] / Fuel Filter Kit [Opti On]
Fuel Filter [Component Parts] [Option] / Fuel Fi Lter [Component Parts] [Option]
Kit Velocimetro[Opcao] / Speedometer Kit [Rtv900 G-Eu/W-Eu] [Option]
Kit Sonoro Mancha Atras[Opcao] / Backup Beeper K It [Option]
Alarme Sobreaquecimento[Opcao] / Overheat Alarm Kit [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit (Fron T) [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit (Rear ) [Option]
Kit Acelarador Mao / Hand Throttle Kit [Option]
Kit Estrutura Elevacao Frontal [Opcao] / Front H Eavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opcao] / Front Heavy Loa D Springs Kit [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Tank) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Oil Cooler) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Hyd.Oil Line) [Rtv900w-Eu/R-Eu] [Option ]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Remote) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Remote) [Component Parts] [Rtv900w-Eu/R -Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Pto Lever) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Electrical Wiring) [Rtv900w-Eu/R-Eu] [O Ption]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Relay) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Switch) [Rtv900w-Eu/R-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd.U Pgrade Kit (Label) [Rtv900w-Eu/R-Eu] [Option]
Kit Camisa / Bed Liner Kit [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Front) [ Rtv900g-Eu] [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Front) [ Rtv900w-Eu/R-Eu] [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Rear) [O Ption]
Kit Guicho (Opção) / Winch Mounting Kit [Rtv900g -Eu] [Option]
Kit Guicho (Opção) / Winch Mounting Kit [Rtv900w -Eu/R-Eu] [Option]
Kit Caixa Acessorios / Front Accessory Box Kit [ Option]
Kit Porta Luvas[Opcao] / Glove Box Kit [Option]
Kit Guarda Lamas Frontais[Opcao] / Front Mud Gua Rd Kit [Option]
Kit Encosto Cabeça[Opcao] / Headrest Kit [Option ]
Kitproteccaoluzes(Opcao) / Tail Lamp Guards Kit [Option]
Kit Tecto Lona[Opcao] / Canopy Kit [Option]
Head Light Kit [Option] / Head Light Kit [Option ]
