Kubota Utility Vehicle RTV900SR Homologated Verion-UK Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900SR Homologated Verion-UK Utility Vehicle
Number of Pages: 228 Pages
I Tens Uso Frequente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Gover Nor Shaft
Ponto Neutro / Idle Apparatus
Bomba Injectora / Injection Pu Mp
Regulador Velocidade / Speed C Ontrol Plate
Valvula Solenoide / Nozzle Hol Der And Glow Plug
Suporte Bico [Peças Componente S] / Nozzle Holder [Component Parts]
Bomba Gasoleo / Fuel Pump(Mech Anical)
Interruptor E Termómetro Do Ól Eo / Oil Switch/Thermometer
Bomba Agua E Termostacto / Wat Er Flange And Thermostat
Acessorios / Water Pump
Radiador / Water Pipe
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Colector Admissao / Inlet Mani Fold
Colector Escape / Exhaust Mani Fold
Escpae / Muffler
Deposito Combustivel / Lower G Asket Kit
Filtro Gasoleo / Stop Solenoid
Acelarad Or / Accelerator Pedal
Tubo Com Bustivel / Fuel Pipe
Alterna Dor / Alternator
Alterna Dor [Peças Componentes] / Alternator [Component Par Ts]
Motor A Rranque / Starter
Motor A Rranque [Componentes] / Starter [Component Parts]
Interru Ptor / Sensor (Motor) / Switch/Sensor
Tampa I Nterruptor / Panel Switch
Interru Ptor Travao / Brake Switch
Farol D Ianteiro / Head Light
Luzes F Rontais / Front Combination Light
Braco T Raseiro / Rear Combination Light
Farol M Atricula / License Lamp
Ficha R Eboque / Trailer Socket
Cabalag Em Eletrica(Cabine)[Ec] [G] / Electrical Wiring
Carter Frontal / F Ront Case
Hst / Hst
Hst 1 (Bomba)[Peça S Componentes] / Hst 1(Charge Pump) [Component Part S]
Hst 2 (Regulador)[ Peças Componentes] / Hst 2(Regulator) [Component Pa Rts]
Hst 3 (Veio Motor) [Peças Componentes] / Hst 3 (Motor Shaft) [Componen T Parts]
Hst 4 (Valvula)[Pe Ças Componentes] / Hst 4(Valve) [Component Parts] # # Note:Not For Sale,Order By New Part. / Note:Not F Or Sale,Order By New Part.
Veio Primario / In Put Shaft
Veio Primario / Pr Opeller Shaft
Veio Gamas Velocid Ades / Range Gear Shaft
Inversor / Revarse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Diante Ira / Front Wheel Propeller Shaft
Pinhao Espiral / S Piral Bevel Pinion
Diferencial Carter / Rear Differential
Veio Eixo Traseiro / Rear Wheel Propeller Shaft
Kit Transmissao / Transmission Kit
Forqueta Caixa / Creeper / Range Gear Shift Fork
Braço Ca Rreto Gamas / Range Gear Arm
Braco Ro Da Frente / Front Wheel Drive Arm
Alavanca / Differential Lock Shift Fork
Caixa Ve Locidades / Speed Change Lever
Caixa Ve Locidades / Speed Change Rod
Eixo Traseiro / Rea R Axle
Suspensao Traseira / Rear Suspension
Bloqueio Diferencia L / Differential Lock Pedal
Travao Frontal / Front Brake
Travao Traseiro / Rear Brake
Cilindro Travao (Esq) / Brake Cylinder(Left)
Cilindro Travao (Drt) / Brake Cylinder(Right)
Cilindro Travao Principal / Br Ake Master Cylinder
Cilindro Travao Principal[Peça S Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes / Brake Oil Line(Front)
Tubo Oleo Travoes / Brake Oil Line(Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brak E Wire
Pedal Travao / Brake Pedal
Alavanc A / Lift Lever
Valvula Bypass / Bypass Valve Link
Bomba H Idraulico / Hydraulic Pump
Deposit O Oleo Hidraulico / Hydraulic Tank
Circuit O Oleo (Direcção) / Hydraulic Oil Line(Steering)
Tubo Ol Eo / Hydraulic Oil Line(Hst)
Tubo Ol Eo (Deposito) / Hydraulic Oil Line(Tank)
Distrib Uidor Auxiliar / Remote Control Valve
Distrib Uidor Auxiliar[Peças Componentes] / Remote Control Valve [Component Parts]
Cilndro Eleveção[Peças Componentes] / Lift Cylinder [Compo Nent Parts]
Estrutura / Main Frame
Transmissao / Transmission Frame
Grupo Conico / Di Fferential Gear Shaft
Diferencial Diant Eiro / Front Differential
Veio / Front Driv E Shaft
Eixo Dianteiro / Front Axle
Suspensao Frontal / Front Suspension
Suspensao Frontal [Peças Componentes] / Front Suspension [Component Parts]
Braço Suspensao / Front Suspension Arm
Direcção Assistida / Dire Ção Punho / Steering Handle
Direcção / Steering Contr Oller
Rotula / Cilindro Direcçã O / Steering Cylinder
Cilindro Direcção[Peças C Omponentes] / Steering Cylinder [Component Parts] # # S.No.;>=20549 / S.No.;>=20549
Deposito Oleo Direccao / Steering Tank
Caixa / Box Base
Chapa Caixa / Box Plate
Distribuidor Auxiliar / F Ront Guard
Grelha Frontal / Front Gr Ille
Acessorios / Bonnet
Painel Lateral / Side Cov Er
Kit Limpa Vidro Traseiros (Opcao) / Panel Frame
Guarda Lamas / Fender
Suporte Assento / Seat Su Pport(Operator)
Suporte Assento / Seat Su Pport(Passenger)
Acessorios / Seat
Degrau / Step
Espelho Rectrovisor / Rea Rview Mirror
Alavanca Valvula Control Auxiliar 2º [Opcao] / Rops
Ba Rra Reboque / Drawbar
Ac Essorios / Accessories And Service Parts
Roda Frente / F Ront Wheel(25*10-12)
Roda Traseira / Rear Wheel(25*10-12)
Etiqueta Traseira / Label(Rear) [English]
Kit Filtro Ar[Opcao] / High Mo Unt Air Cleaner Kit [Option]
Fuel Filter Kit [Option] / Fue L Filter Kit [Option]
Fuel Filter [Component Parts] [Option] / Fuel Filter [Component Parts] [Option]
Kit Sonoro Mancha Atras[Opcao] / Backup Beeper Kit [Option]
Alarme Sobreaquecimento[Opcao] / Overheat Alarm Kit [Option]
Kit Luzes Trabalho[Opcao] / Wo Rk Light Kit(Front) [Option]
Kit Acelarador Mao / Hand Thro Ttle Kit [Option]
Kit Estrutura Elevacao Frontal [Opcao] / Front Heavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opcao] / Front Heavy Load Springs Kit [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Tank) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Oil Cooler) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Hyd.Oil Line) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Remote) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Remote) [Component Par Ts] [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Pto Lever) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Electrical Wiring) [Op Tion]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Relay) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Switch) [Option]
Kit Upgrade Hidraulico (Cablag Em)[Opcao] / Hyd.Upgrade Kit(Label) [Option]
Kit Camisa / Bed Liner Kit [Op Tion]
Kit Barra Reboque[Opcao] / Dra Wbar Kit [Option]
Kit Guicho (Opção) / Winch Mou Nting Kit [V4251] [Option]
Kit Guicho (Opção) / Winch Mou Nting Kit [V4253] [Option]
Kit Caixa Acessorios / Front A Ccessory Box Kit [Option]
Kit Porta Luvas[Opcao] / Glove Box Kit [Option]
Kit Guarda Lamas Frontais[Opca O] / Front Mud Guard Kit [Option]
Kitproteccaoluzes(Opcao) / Tai L Lamp Guards Kit [Option]
Kit Tecto Lona[Opcao] / Canopy Kit [V4221] [Option]
Kit Tecto Lona[Opcao] / Canopy Kit(Camouflage) [V4255] [Rtv900sr] [Option]
