Kubota Utility Vehicle RTV900SR-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900SR-EU Utility Vehicle
Number of Pages: 259 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holde R [Component Parts]
Bomba Gasoleo / Fuel Pump(Mechanical)
Interruptor E Termómetro Do Óleo / Oil Switch/T Hermometer And Plug
Bomba Agua E Termostacto / Water Flange And The Rmostat
Acessorios / Water Pump
Radiador / Water Pipe
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Lower Gasket Kit
Filtro Gasoleo / Stop Solenoid
Deposito Combustivel / Fu El Tank
Ventila Dor / Fan
Radiado R / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componen Tes] / Starter [Component Parts]
Interruptor / Sensor (Mo Tor) / Switch/Sensor
Tampa Interruptor / Pane L Switch
Interruptor Travao / Bra Ke Switch
Farol Dianteiro / Head L Ight
Farol Traseiro / Tail Li Ght
Cabalagem Eletrica(Cabin E)[Ec] [G] / Electrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmission Ca Se
Hst / Hst
Hst (Bloco Do Cilindro) [Peças Comp Onentes] 1 / Hst 1 [Component Parts]
Hst (Fixador Do Neutro) [Peças Comp Onentes] 4 / Hst 4 [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Revarse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Pinhao Espiral / Spiral Bevel Pinio N
Diferencial Carter / Rear Different Ial
Veio Eixo Traseiro / Rear Wheel Pro Peller Shaft
Estrutura Principal / Universal Joi Nt
Kit Transmissao / Transmission Kit
Forqueta Caixa / Creeper / Range Gear Shift Fork
Braço Carreto Gamas / Ran Ge Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Alavanca / Differential L Ock Shift Fork
Caixa Velocidades / Speed Change Lever
Caixa Velocidades / Speed Change Rod
Alavanca Velocidades / Ma In Gear Shift Lever
Eixo Traseiro / Rear Axle
Suspensao Traseira / Rear Suspension
Travao Frontal / Front Brake
Travao Traseiro / Rear Brake
Cilindro Travao (Esq) / Brake Cylinder(Left)
Cilindro Travao (Drt) / Brake Cylinder(Right)
Cilindro Travao Principal / Brake Master Cylind Er
Cilindro Travao Principal[Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes / Brake Oil Line(Front)
Tubo Oleo Travoes / Brake Oil Line(Rear)
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lever
Valvula Bypass / Bypass Valve Link
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico[Peças C Omponentes] / Hydraulic Pump [Component Parts]
Bomba Hidraulica / Gear Pump
Deposito Oleo Hidraulico / Hydraulic Tank
Circuito Oleo (Direcção) / Hydraulic Oil Line(Steering)
Tubo Oleo / Hydraulic Oi L Line(Hst)
Radiador Oleo / Hydrauli C Oil Line(Oil Cooler)
Tubo Oleo (Deposito) / H Ydraulic Oil Line(Tank)
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar[Pe Ças Componentes] / Remote Control Valve [Component Parts]
Cilndro Eleveção[Peças C Omponentes] / Lift Cylinder [Component Parts]
Estrutura / Main Frame
Transmissao / Transmission Frame
Carter Eixo / Front Axle Case
Grupo Conico / Differential Gear S Haft
Diferencial Dianteiro / Front Diff Erential
Veio / Front Drive Shaft
Eixo Dianteiro / Front Axle
Suspensao Frontal / Front Suspensi On
Suspensao Frontal[Peças Componente S] / Front Suspension [Component Parts]
Braço Suspensao / Front Suspension Arm
Direcção Assistida / Direção Punho / Steer Ing Handle
Rotula / Cilindro Direcção / Steering Cyli Nder
Cilindro Direcção[Peças Componentes] / Ste Ering Cylinder [Component Parts]
Deposito Oleo Direccao / Steering Tank
Caixa / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Distribuidor Auxiliar / Front Guard
Grelha Frontal / Front Grille
Acessorios / Bonnet
Painel Lateral / Side Cover
Kit Limpa Vidro Traseiros (Opcao) / Panel Frame
Guarda Lamas / Fender
Acessorios / Seat
Degrau / Step
Alavanca Valvula Control Auxiliar 2º [Opcao] / Rops
Roda Frente / Front Wheel (25*10 -12)
Roda Traseira / Rear Wheel (25*1 1-12)
Etiqueta Frente / Label(Front) [Fre Nch]
Etiqueta Frente / Label(Front) [Ger Man]
Etiqueta Traseira / Label(Rear) [En Glish]
Etiqueta Traseira / Label(Rear) [Fr Ench]
Etiqueta Traseira / Label(Rear) [Ge Rman]
Acessorios / Access Ories And Service Parts
Kit Filtro Ar[Opcao] / High Mount Air Cleaner K It [Option]
Fuel Filter Kit [Option] / Fuel Filter Kit [Opt Ion]
Fuel Filter [Component Parts] [Option] / Fuel F Ilter [Component Parts] [Option]
Kit Sonoro Mancha Atras[Opcao] / Backup Beeper Kit [Option]
Alarme Sobreaquecimento[Opcao] / Overheat Alarm Kit [Option]
Panel Kit [Option] / Panel Kit [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit (Fro Nt) [Option]
Kit Luzes Trabalho[Opcao] / Work Light Kit (Rea R) [Option]
Propeller Shaft Kit [Option] / Propeller Shaft Kit [Option]
Kit Acelarador Mao / Hand Throttle Kit [Option]
Kit Estrutura Elevacao Frontal [Opcao] / Front Heavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opcao] / Front Heavy Lo Ad Springs Kit [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Tank) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Oil Cooler) [Rtv900sw-Eu/Sr-Eu] [Optio N]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit(Hyd.Oil Line) [Rtv900sw-Eu/Sr-Eu] [Opti On]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Remote) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Remote) [Component Parts] [Rtv900sw-Eu /Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Pto Lever) [Rtv900sw-Eu/Sr-Eu] [Option ]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Electrical Wiring) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Relay) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Switch) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Upgrade Hidraulico (Cablagem)[Opcao] / Hyd. Upgrade Kit (Label) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Camisa / Bed Liner Kit [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Front) [Rtv900sg-Eu] [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Front) [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Rear) [ Option]
Kit Guicho (Opção) / Winch Mounting Kit [V4251] [Rtv900sg-Eu] [Option]
Kit Guicho (Opção) / Winch Mounting Kit [V4251] [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Guicho (Opção) / Winch Mounting Kit [V4253] [Rtv900sw-Eu/Sr-Eu] [Option]
Kit Caixa Acessorios / Front Accessory Box Kit [Option]
Kit Porta Luvas[Opcao] / Glove Box Kit [Option]
Kit Guarda Lamas Frontais[Opcao] / Front Mud Gu Ard Kit [Option]
Kit Encosto Cabeça[Opcao] / Headrest Kit [Optio N]
Kitproteccaoluzes(Opcao) / Tail Lamp Guards Kit [Option]
Kit Tecto Lona[Opcao] / Canopy Kit [V4221] [Opt Ion]
Kit Tecto Lona[Opcao] / Canopy Kit (Camouflage) [V4255] [Rtv900sr-Eu] [Option]
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Ventila Dor / Fan
Hst / Hst
Caixa / Box Base
Acessorios / Bonnet
Acessorios / Seat
Degrau / Step
