Kubota Utility Vehicle RTV900R Homologated Version-EU Spare Parts Catalog EN FR
Language: French, English
Model: Kubota RTV900R Homologated Version-EU Utility Vehicle
Number of Pages: 235 Pages
Frequently Used Items / Frequently Used Items
Pieces De Maintenance / Maintenance Part S
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Di Pstick And Guide
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De P Ignon Fou / Camshaft And Idle Gear Shaft
Pistons Et Vilebrequin / Pi Ston And Crankshaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / Fuel Camshaft And Governor Sh Aft
Pompe D'injection / Injecti On Pump
Regulateur De Vitesses / Go Vernor
Porte-Injecteur [Parties Co Mposantes] / Nozzle Holder [Component Parts]
Pompe D'alimentation(Mecani Que) / Fuel Pump(Mechanical)
Contact A Huile Thermometre / Oil Switch/Thermometer
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Soupapes Et Culbuteurs / Va Lve And Rocker Arm
Collecteur D'admission / In Let Manifold
Collecter D'echappement / E Xhaust Manifold
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Super. / Uppe R Gasket Kit
Jeu De Joints Infer. / Lowe R Gasket Kit
Solenoide D'arret / Stop So Lenoid
Pedale D'ac Celerateur / Accelerator Pedal
Reservoir C Arb. / Fuel Tank
Tuyau A Car Burant / Fuel Pipe
Radiateur / Radiator
Reservoir Du Radiateur / Reserve Tank
Alt Ernateur Complet / Alternator
Alt Ernateur [Parties Composantes] / Alternator [Compon Ent Parts]
Lan Ceur / Starter
Dem Arreur [Parties Composantes] / Starter [Component P Arts]
Bat Terie / Battery
Com Mutateur/Detecteur / Switch/Sensor
Tab Leau De Commutateur / Panel Switch
Fre In De Commutateur / Brake Switch
Pha Re / Head Light
Feu X Clignotanto Avant / Front Combination Light
Feu X Clignotanto Arriere / Rear Combination Light
Lam P Et Plaque D'immatriculation / License Lamp
Pri Se De Remorque / Trailer Socket
Fai Sceau Electrique / Electrical Wiring
Carter Avant / Front Case
Carter De Trans Mission / Transmission Case
Hst / Hst
Hst 1 [Parties Composantes] / Hst 1 [Component Parts]
Hst 2 [Parties Composantes] / Hst 2 [Component Parts]
Hst 3 [Parties Composantes] / Hst 3 [Component Parts]
Hst 4 [Parties Composantes] / Hst 4 [Component Parts]
Arbre D'entree / Input Shaft
Arbre De Transm Ission / Propeller Shaft
Arbre De Change Ment De Gamme / Range Gear Shaft
Arbre De Marche Arriere / Revarse Shaft
Arbre De Marche / Idle Shaft
Arbre D'entrain Ement Avant / Front Wheel Propeller Shaft
Pignon Conique / Spiral Bevel Pinion
Differentiel Ar Riere / Rear Differential
Arbre D'entrain Ement Arriere / Rear Wheel Propeller Shaft
Joint De Cardan / Universal Joint
Jeu De Transmis Sion / Transmission Kit
Fourche Tte De Changement De Gamme / Range Gear Shift Fork
Bras De Changement De Gamme / Range Gear Arm
Bras De Traction Avant / Front Wheel Drive Arm
Fourche Tte De Blocage Differentiel / Differential Lock Shi Ft Fork
Levier De Vittese-Changement / Speed Change Lever
Levier De Changement De Vitesses Principal / Main Gear Shi Ft Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive L Ever
Suspension Arrie Re / Rear Suspension
Pedale De Verrou Illage Du Differentiel / Differential Lock Pedal
Frein Avant / Front Brake
Frein Arriere / Rear Brake
Cylindre De Frein(Cauche) / B Rake Cylinder(Left)
Cylindre De Frein(Droite) / B Rake Cylinder(Right)
Maitre Cylindre De Frein / Br Ake Master Cylinder
Maitre Cylindre De Frein [Par Ties Composantes] / Brake Master Cylinder [Componen T Parts]
Circuit D'huile Frein(Avant) / Brake Oil Line(Front)
Circuit D'huile Frein(Arriere ) / Brake Oil Line(Rear)
Tige De Frein / Brake Rod
Levier De Frein De Stationnem Ent / Parking Brake Lever
Cable De Frein De Stationneme Nt / Parking Brake Wire
Pedale De Frien / Brake Pedal
Levi Er De Relevage / Lift Lever
Supp Ort Avant Droit / Hydraulic Pump
Pomp E Hydraulique [Parties Composantes] / Hydraulic Pum P [Component Parts]
Pomp E A Engrenages / Gear Pump
Rese Rvoir A Hydraulique / Hydraulic Tank
Circ Uit D'huile Hydraulique(Direction) / Hydraulic Oil Line(Steering)
Circ Uit D'huile Hydraulique(Hst) / Hydraulic Oil Line(H St)
Circ Uit D'huile Hydraulique(Refroidisseur) / Hydraulic Oil Line(Oil Cooler)
Circ Uit D'huile Hydraulique(Reservoir) / Hydraulic Oil Line(Tank)
Dist Ributeur Auxiliaire / Remote Control Valve
Cont Role Des Valves Aux.[Parties Composantes] / Remote Control Valve [Component Parts]
Cyli Ndre De Relevage / Lift Cylinder
Cyli Ndre De Relevage [Parties Composantes] / Lift Cylin Der [Component Parts]
Chassis Principal / Main Fr Ame
Chassis Transmission / Tran Smission Frame
Demi Arbre De Pon T Avant / Differential Gear Shaft
Differentiel Avan T / Front Differential
Demi Arbre Avant / Front Drive Shaft
Pont Avant / Fron T Axle
Suspension Avant / Front Suspension
Suspension Avant [Parties Composantes] / Front Suspension [Component Parts]
Bras De Suspensio N Avant / Front Suspension Arm
Servo Direction / Stee Ring Controller
Barrd De Accouplement/ Cylindre De Direction / Steering Cylinder
Cylindre De Direction [Parties Composantes] / Steering Cylinder [Componen T Parts]
Reservoir A Direction / Steering Tank
Grille De B Oite / Box Gate
Protection Avant / Front Gua Rd
Phale De Travail / Front Gri Lle
Capot / Bonnet
Capot Lateral / Side Cover
Cadre De Panneau / Panel Fra Me
Aile / Fender
Support De Siege(Operateur) / Seat Support(Operator)
Support De Siege(Passager) / Seat Support(Passenger)
Siege / Seat
Marchepied / Step
Retroviseur / Rearview Mirro R
Cadre Anti-Renversement / Ro Ps
Barre D'attelage / Drawbar
Roue A Vant(25*10-12) / Front Wheel(25*10-12)
Roue A Rriere(25*10-12) / Rear Wheel(25*10-12)
Etiquette(Avant) [Franc Ais] / Label(Front) [French]
Etiquette(Avant) [Allem Agne] / Label(Front) [Germany]
Etiquette(Arriere) [Fra Ncais] / Label(Rear) [French]
Etiquette(Arriere) [All Emagne] / Label(Rear) [Germany]
Accessories Et Piece De Servi Ce / Accessories And Service Parts
Filtre A Air De Haute Monta Ge [Option] / High Mount Air Cleaner Kit [Option]
Filtre A Carburant [Option] / Fuel Filter Kit [Option]
Filtre A Carburant [Parties Composantes] [Option] / Fuel Filter [Component Par Ts] [Option]
Alarme De Recul [Option] / Backup Beeper Kit [Option]
Alarme De Surchauffer [Opti On] / Overheat Alarm Kit [Option]
Phares De Travail(Avant) [O Ption] / Work Light Kit(Front) [Option]
Phares De Travail(Arriere) [Option] / Work Light Kit(Rear) [Option]
Papillon A Main [Option] / Hand Throttle Kit [Option]
Support De Suspension Avant Renforce [Option] / Front Heavy Load Strut Kit [Op Tion]
Ressort De Suspension Avant Renforce [Option] / Front Heavy Load Springs Kit [ Option]
Kit Hyd.Amelioration(Reserv Oir) [Option] / Hyd.Upgrade Kit(Tank) [Option]
Kit Hyd.Amelioration(Refroi Disseur) [Option] / Hyd.Upgrade Kit(Oil Cooler) [Op Tion]
Kit Hyd.Amelioration(Circui T D'huile Hyd.) [Option] / Hyd.Upgrade Kit(Hyd.Oil Line) [Option]
Kit Hyd.Amelioration(Auxili Aire) [Option] / Hyd.Upgrade Kit(Remote) [Option]
Kit Hyd.Amelioration(Auxili Aire) [Parties Comp.] [Option] / Hyd.Upgrade Kit(Re Mote) [Component Parts] [Option]
Kit Hyd.Amelioration(Levier De Pdf) [Option] / Hyd.Upgrade Kit(Pto Lever) [Opt Ion]
Kit Hyd.Amelioration(Faisce Au Electrique) [Option] / Hyd.Upgrade Kit(Electrica L Wiring) [Option]
Kit Hyd.Amelioration(Relais ) [Option] / Hyd.Upgrade Kit(Relay) [Option]
Kit Hyd.Amelioration(Interr Upeur) [Option] / Hyd.Upgrade Kit(Switch) [Option]
Kit Hyd.Amelioration(Etique Tte) [Option] / Hyd.Upgrade Kit(Label) [Option]
Recouvrement De Benne [Opti On] / Bed Liner Kit [Option]
Barre D'attelage(Arriere) [ Option] / Drawbar Kit(Rear) [Option]
Kit Montage De Treuil [Opti On] / Winch Mounting Kit [Option]
Boite De Rangement Avant [O Ption] / Front Accessory Box Kit [Option]
Boite A Gant [Option] / Glo Ve Box Kit [Option]
Garde Boue Avant [Option] / Front Mud Guard Kit [Option]
Feux Stroboscopique [Option ] / Tail Lamp Guards Kit [Option]
Kit De Auvent [Option] / Ca Nopy Kit [Option]
Kit De Auvent(Camouflage) [ Rtv900r] [Option] / Canopy Kit(Camouflage) [Rtv900r ] [Option]
Ventilateur / Fan
Lan Ceur / Starter
Bat Terie / Battery
Pha Re / Head Light
Hst / Hst
Capot / Bonnet
Aile / Fender
Siege / Seat
Marchepied / Step
