Kubota Utility Vehicle RTV900MW-EU-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900MW-EU-EC Utility Vehicle
Number of Pages: 266 Pages
Itens Uso Frequ Ente / Frequently Used Items
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick And Gui De
Bomba Oleo / Oil Pump
Rolamento Principal / Main Bearing Cas E
Arvore Cames E Veio / Camshaft And Idl E Gear Shaft
Piston E Cambota / Piston And Cranksha Ft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Ca Mshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control P Late
Vela Pre Aquecimento / Nozzle Holder A Nd Glow Plug
Suporte Bico [Peças Componentes] / Noz Zle Holder [Component Parts]
Bomba Gasoleo (Mecânica) / Fuel Pump ( Mechanical)
Bomba Agua E Termostacto / Water Flang E And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Valvula E Veio Martelos / Valve And Ro Cker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Fu El Tank
Tubo Combustivel / Fuel P Ipe
Ventoinha / Fan
Resguardo Ventoinha / Fan Cover
Deposito R Eserva / Reserve Tank
Alternador / Alternat Or
Alternador [Peças Com Ponentes] / Alternator [Component Parts]
Motor Arranque / Star Ter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor E Termóme Tro / Oil Switch And Thermometer
Buzina / Horn
Interruptor/Sensor / Switch/Sensor
Rele / Relay
Tampa Interruptor / P Anel Switch
Interruptor Travao / Brake Switch
Luzes Frente / Head L Ight
Luzes Frontais / Fron T Combination Light
Braco Traseiro / Rear Combination Light
Farol Matricula / Lic Ense Lamp
Ficha Reboque / Trail Er Socket
Cablagem Electrica / Electrical Wiring
Carter Frontal / Front Case
Caixa Velocidades Resguardo / Tra Nsmission Case Cover
Hst / Hst
Hst 1 (Bomba) [Peças Componentes] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Regulador) [Peças Componen Tes] / Hst 2 (Regulator) [Component Parts]
Hst 3 (Veio Motor) [Peças Compone Ntes] / Hst 3 (Motor Shaft) [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Ge Ar Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Whe El Propeller Shaft
Pinhao Espiral / Spiral Bevel Pin Ion
Diferencial Traseiro / Rear Diffe Rential
Kit Transmissao / Transmission Ki T
Forqueta Velocidades / Ran Ge Gear Shift Fork
Braço Carreto Gamas / Rang E Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Alavanca / Differential Lo Ck Shift Fork
Caixa Velocidades / Speed Change Lever
Alavanca Velocidades / Mai N Gear Shift Lever
Alavanca Dupla Traccao / F Ront Wheel Drive Lever
Eixo Traseiro / Rear Axle
Veio De Transmissão Traseiro (Esq Uerdo) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro (Dir Eito) / Rear Drive Shaft (Right)
Suspensao Traseira / Rear Suspens Ion
Bloqueio Diferencial / Differenti Al Lock Pedal
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao (Esq) / Brake Cylinder (Lef T)
Cilindro Travao Principal / Brake Master Cy Linder
Cilnidro Principal Travao [Peças Componente S] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Dianteira) / Brake Oil L Ine (Front)
Tubo Oleo Travoes (Traseiro) / Brake Oil Li Ne (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lever
Valvula Bypass / Bypa Ss Valve Link
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Bomba Hidraulica / Ge Ar Pump
Deposito Oleo Hidraul Ico / Hydraulic Tank
Linha De Óleo Hidrául Ico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidrául Ico (Hst) / Hydraulic Oil Line (Hst)
Linha De Óleo Hidrául Ico (Radiador Oleo) / Hydraulic Oil Line (Oil Coole R)
Linha De Óleo Hidrául Ico (Deposito) / Hydraulic Oil Line (Tank)
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [Peças Componentes] / Remote Control Valve [Compon Ent Parts]
Cilndro Eleveção / Li Ft Cylinder
Cilndro Eleveção [Peç As Componentes] / Lift Cylinder [Component Parts]
Transmissao / Transmission Frame
Grupo Conico / Differential Gea R Shaft
Diferencial Dianteiro / Front D Ifferential
Veio De Transmissão Dianteiro ( Esquerdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro ( Direito) / Front Drive Shaft (Right)
Carter Eixo Frente (Drt) / Fron T Axle Case (Right)
Eixo Dianteiro (Esq) / Front Ax Le (Left)
Eixo Dianteiro (Drt) / Front Ax Le (Right)
Veio Eixo / Front Drive Shaft
Suspensao Frontal (Esq) / Front Suspension (Left)
Suspensao Frontal (Drt) / Front Suspension (Right)
Suspensao Frontal [Peças Compon Entes] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (E Squerdo) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (D Ireito) / Front Suspension Arm (Right)
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Deposito Oleo Direccao / Steering Tank
Caixa / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Proteccao Frontal / Front Guard
Grelha Frontal / Front Grille
Capot Superior / Bonnet
Painel Lateral / Side Cover
Painel / Panel Frame
Guarda Lamas / Fender
Cobertura Central / Center Cover
Suporte Assento (Operator) / Seat Suppo Rt (Operator)
Suporte Assento (Fahrgast) / Seat Suppo Rt (Passenger)
Banco / Seat
Degrau / Step
Roda Frente (25*1 0-12) / Front Wheel (25*10-12)
Roda Traseira (25 *10-12) / Rear Wheel (25*10-12)
Etiqueta (Frente) [Franes] / Label (Fron T) [French]
Etiqueta (Frente) [Alemao] / Label (Fron T) [German]
Etiqueta (Traseira) [Franes] / Label (Re Ar) [French]
Etiqueta (Traseira) [Alemao] / Label (Re Ar) [German]
Acessorios E Peças Serviço / Accessories And Servic E Parts
Kit Filtro Ar [Opção] / High Mount Air Clean Er Kit [Option]
Kit Sonoro Mancha Atras [Opção] / Backup Bee Per Kit [Option]
Kit Proteccao Radiador [Opção] / Radiator Gu Ard Kit [Option]
Alarme Sobreaquecimento [Opção] / Overheat A Larm Kit [Option]
Kit Luzes Trabalho (Frente) [Opção] / Work L Ight Kit (Front) [Option]
Kit Luzes Trabalho (Traseira) [Opção] / Work Light Kit (Rear) [Option]
Veio [Opção] / Propeller Shaft With Nipple [ Option]
Kit Acelarador Mao [Opção] / Hand Throttle K It [Option]
Kit Estrutura Elevacao Frontal [Opção] / Fro Nt Heavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opção] / Front Heavy Load Springs Kit [Option]
Kit De Atualização Hidráulico (Depósito) [Op Ção] / Hyd.Upgrade Kit (Tank) [Option]
Kit De Atualização Hidráulico (Radiador Do Ó Leo) [Opção] / Hyd.Upgrade Kit (Oil Cooler) [Option ]
Kit De Atualização Hidráulico (Remoto) [Opçã O] / Hyd.Upgrade Kit (Remote) [Option]
Kit De Atualização Hidráulico (Remoto) [Peça S Componentes] [Opção] / Hyd.Upgrade Kit (Remote) [ Component Parts] [Option]
Kit De Atualização Hidráulico (Esquema Elétr Ico) [Opção] / Hyd.Upgrade Kit (Electrical Wiring) [Option]
Kit De Atualização Hidráulico (Interruptor) [Opção] / Hyd.Upgrade Kit (Switch) [Option]
Kit De Atualização Hidráulico (Etiqueta) [Op Ção] / Hyd.Upgrade Kit (Label) [Option]
Kit Camisa [Opção] / Bed Liner Kit [Option]
Espelho [Opção] / Rearview Mirror [Option]
Arco Seguranca [Opção] / Rops [Option]
Kit Barra Reboque [Opção] / Drawbar Kit Fron T [Option]
Kit Barra Reboque [Opção] / Drawbar Kit Rear [Option]
Kit Guicho [Opção] / Winch Mounting Kit [Opt Ion]
Kit Caixa Acessorios [Opção] / Front Accesso Ry Box Kit [Option]
Kit Porta Luvas [Opção] / Glove Box Kit [Opt Ion]
Kit Guarda Lamas Frontais [Opção] / Front Mu D Guard Kit [Option]
Kitproteccaoluzes [Opção] / Tail Lamp Guards Kit [Option]
Kit Tecto Lona [Opção] / Canopy Kit [Option]
Kit Proteccao (Radiador) [Opção] / Shield Ki T (Alternator) [Option]
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Ventoinha / Fan
Buzina / Horn
Rele / Relay
Hst / Hst
Caixa / Box Base
Banco / Seat
Degrau / Step
