Kubota Utility Vehicle RTV900MG-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV900MG-EU Utility Vehicle
Number of Pages: 249 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Rolamento Principal / Main Bearing Case # # Note:Order By Ref.No.010 And 080 New Parts. / Not E:Order By Ref.No.010 And 080 New Parts.
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsh Aft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Plat E
Bomba Gasoleo (Mecânica) / Fuel Pump (Mec Hanical)
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Valvula E Veio Martelos / Valve And Rocke R Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Acelerador Pedal / Accelerat Or Pedal
Tubo Combustivel / Fuel Pipe
Ventoinha / F An
Resguardo Ven Toinha / Fan Cover
Tubo Agua / W Ater Pipe
Radiador / Ra Diator
Deposito Rese Rva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor E Termómetro / Oil Switch And Thermometer
Buzina / Horn
Interruptor/Sensor / Swi Tch/Sensor
Rele / Relay
Tampa Interruptor / Pane L Switch
Interruptor Travao / Bra Ke Switch
Luzes Frente / Head Ligh T
Farol Traseiro / Tail Li Ght
Cablagem Electrica / Ele Ctrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmission Cas E
Caixa Velocidades Resguardo / Transm Ission Case Cover
Hst 1 (Bomba) [Peças Componentes] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Regulador) [Peças Componentes ] / Hst 2 (Regulator) [Component Parts]
Hst 3 (Veio Motor) [Peças Componente S] / Hst 3 (Motor Shaft) [Component Parts]
Hst 4 (Valvula) [Peças Componentes] / Hst 4 (Valve) [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear Differen Tial
Kit Transmissao / Transmission Kit
Forqueta Velocidades / Range Gear Shift Fork
Braço Carreto Gamas / Range G Ear Arm
Braco Roda Frente / Front Whe El Drive Arm
Alavanca / Differential Lock Shift Fork
Caixa Velocidades / Speed Cha Nge Lever
Caixa Velocidades / Speed Cha Nge Rod
Alavanca Velocidades / Main G Ear Shift Lever
Alavanca Dupla Traccao / Fron T Wheel Drive Lever
Eixo Traseiro / Rear Axle
Veio De Transmissão Traseiro (Esquer Do) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro (Direit O) / Rear Drive Shaft (Right)
Suspensao Traseira / Rear Suspension
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao (Esq) / Brake Cylinder (Left)
Cilindro Travao (Drt) / Brake Cylinder (Right)
Cilindro Travao Principal / Brake Master Cylin Der
Cilnidro Principal Travao [Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Dianteira) / Brake Oil Line (Front)
Tubo Oleo Travoes (Traseiro) / Brake Oil Line (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Valvula Bypass / Bypass Valve Link
Bomba Hidraulico / Hydra Ulic Pump
Linha De Óleo Hidráulico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Hst) / Hydraulic Oil Line (Hst)
Linha De Óleo Hidráulico (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Transmissao Estrutura / Transmission Frame
Carter Eixo Frente / Front Axle Ca Se
Grupo Conico / Differential Gear S Haft
Diferencial Dianteiro / Front Diff Erential
Veio De Transmissão Dianteiro (Esq Uerdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Dir Eito) / Front Drive Shaft (Right)
Carter Eixo Frente (Esq) / Front A Xle Case (Left)
Carter Eixo Frente (Drt) / Front A Xle Case (Right)
Eixo Dianteiro (Esq) / Front Axle (Left)
Eixo Dianteiro (Drt) / Front Axle (Right)
Veio Eixo / Front Drive Shaft
Suspensao Frontal (Esq) / Front Su Spension (Left)
Suspensao Frontal (Drt) / Front Su Spension (Right)
Suspensao Frontal [Peças Component Es] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Esqu Erdo) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (Dire Ito) / Front Suspension Arm (Right)
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Deposito Oleo Direccao / Steering Tank
Caixa / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Proteccao Frontal / Front Guard
Grelha Frontal / Front Grille
Painel Lateral / Side Cover
Painel / Panel Frame
Guarda Lamas / Fender
Cobertura Central / Center Cover
Banco / Seat
Degrau / Step
Arco / Rops
Roda Frente (25*10-1 2) / Front Wheel (25*10-12)
Roda Traseira (25*10 -12) / Rear Wheel (25*10-12)
Etiqueta (Frente) [Ingles] / Label (Front) [English]
Etiqueta (Frente) [Frances] / Label (Front) [French]
Etiqueta (Frente) [Alemao] / Label (Front) [German]
Etiqueta (Traseira) [Ingles] / Label (Rear) [English]
Etiqueta (Traseira) [Frances] / Label (Rear ) [French]
Kit Filtro Ar [Opção] / High Mount Air Cleaner Kit [Option]
Kit Velocimetro [Opção] / Speedmeter Kit [Optio N]
Kit Sonoro Mancha Atras [Opção] / Backup Beeper Kit [Option]
Kit Proteccao Radiador [Opção] / Radiator Guard Kit [Option]
Alarme Sobreaquecimento [Opção] / Overheat Alar M Kit [Option]
Kit Luzes Trabalho (Frente) [Opção] / Work Ligh T Kit (Front) [Option]
Kit Luzes Trabalho (Traseira) [Opção] / Work Li Ght Kit (Rear) [Option]
Veio [Opção] / Propeller Shaft With Nipple [Opt Ion]
Kit Acelarador Mao [Opção] / Hand Throttle Kit [Option]
Kit Estrutura Elevacao Frontal [Opção] / Front Heavy Load Strut Kit [Option]
Kit Estrutura Elevação [Opção] / Front Heavy Lo Ad Springs Kit [Option]
Kit Do Elevador Horizontal Hidraúlico (Bomba Da Engrenagem) [Opção] / Hyd. Bed Lift Kit (Gear Pump ) [Option]
Kit Do Elevador Horizontal Hidraúlico (Depósito ) [Opção] / Hyd. Bed Lift Kit (Tank) [Option]
Kit Do Elevador Horizontal Hidraúlico (Remoto) [Opção] / Hyd. Bed Lift Kit (Remote) [Option]
Kit Do Elevador Horizontal Hidraúlico (Remoto) [Peças Completas] [Opção] / Hyd. Bed Lift Kit (Remo Te) [Comp. Parts] [Option]
Kit Do Elevador Horizontal Hidraúlico (Alavanca De Elevação) [Opção] / Hyd. Bed Lift Kit (Lift Lev Er) [Option]
Kit Do Elevador Horizontal Hidraúlico (Cilindro De Elevação) [Opção] / Hyd. Bed Lift Kit (Lift Cyl .) [Option]
Kit Do Elevador Horizontal Hidraúlico (Cilindro De Elevação) [Peças Completas] [Opção] / Hyd. Bed Lift Kit (Lift Cyl.) [Comp. Parts] [Option]
Kit Camisa [Opção] / Bed Liner Kit [Option]
Kit Barra Reboque (Frente) [Opção] / Drawbar Ki T (Front) [Option]
Kit Barra Reboque (Traseira) [Opção] / Drawbar Kit (Rear) [Option]
Kit Barra Reboque (Traseira) [Opção] / Drawbar Kit (Rear) [Option]]
Kit Guicho [Opção] / Winch Mounting Kit [Option ]
Kit Proteccao Frontal [Opção] / Front Guard Kit [Option]
Kit Caixa Acessorios [Opção] / Front Accessory Box Kit [Option]
Kit Porta Luvas [Opção] / Glove Box Kit [Option ]
Kit Guarda Lamas Frontais [Opção] / Front Mud G Uard Kit [Option]
Kit Encosto Cabeça [Opção] / Headrest Kit [Opti On]
Kitproteccaoluzes [Opção] / Tail Lamp Guards Ki T [Option]
Kit Tecto Lona [Opção] / Canopy Kit [Option]
Kit Proteccao (Alternador) [Opção] / Shield Kit (Alternator) [Option]
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Ventoinha / F An
Buzina / Horn
Rele / Relay
Caixa / Box Base
Banco / Seat
Degrau / Step
Arco / Rops
