Kubota Utility Vehicle RTV500S5G-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV500S5G-EU Utility Vehicle
Number of Pages: 177 Pages
Itens Uso Frequen Te / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Tampa Carter (Resguardo) / Crank Case Cover (C Over)
Tampa Carter (Resguardo) / Crankcase Cover (Be Lt)
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Cambota / Camshaft
Compensador / Balancer
Fio Do Motor / Engine Wire
Volante Motor / Magnetico / Flywheel And Magne To
Interruptor Ignição E Vela Incadescencia / Ign Ition Coil And Spark Plug
Bomba Agua / Water Pump
Correia / Poli Tensora / Belt And Tensionpulle Y
Corpo Acelarador / Throttle Body
Corpo Acelarador[Peças Componentes] / Throttle Body [Component Parts]
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [C Omponent Parts]
Escpae / Muffler
Tubo Escape / Exhaust Pipe
Acessorios (Ecu) / Accessories (Ecu)
Diagmaster / Diagmaster
Acelarador Pedal / Accelera Tor Pedal
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Ventoinha(Dr T) / Fan (Right)
Ventoinha (C Entral) / Fan (Center)
Tubo Agua (R Adiador) / Water Pipe (Radiator)
Tubo (Agua R Adiador Oleo) / Water Pipe (Oil Cooler)
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque[Peças Co Mponentes] / Starter [Component Parts]
Interruptor E Termómetr O Do Óleo / Oil Switch And Thermometer
Interruptor/Sensor / Sw Itch/Sensor
Tampa Interruptor / Pan El Switch
Interruptor Travao / Br Ake Switch
Farol Traseiro / Tail L Ight
Cablagem Electrica / El Ectrical Wiring
Caixa Velocidades / Transmission Ca Se
Respiro Transmissão / Transmission Breather
Caixa Da Transmissão Dianteira / Fr Ont Drive Case
Hst (Bomba) / Hst (Charge Pump)
Hst (Regulador) / Hst (Regulator)
Hst (Veio Motor) / Hst (Motor Shaft )
Hst (Valvula) / Hst (Valve)
Veio Primario / Input Shaft
Veio Saída / Output Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Forqueta / Main Gear Shift F Ork
Alavanca / Differential Lock Shift Fork
Caixa Velocidades / Speed Ch Ange Lever
Tirante De Mudança De Veloci Dade / Speed Change Rod
Alavanca Velocidades / Main Gear Shift Lever
Alavanca Dupla Traccao / Fro Nt Wheel Drive Lever
Valvula Bypass / Bypass Valv E Link
Eixo Traseiro(Esq) / Rear Axle (Lef T)
Eixo Traseiro(Drt) / Rear Axle (Rig Ht)
Suspensão Traseiro(Esq) / Rear Susp Ension (Left)
Suspensão Traseiro(Drt) / Rear Susp Ension (Right)
Suspensão Traseiro[Peças Componente S] / Rear Suspension [Component Parts]
Tirante Da Suspensão Traseira (Supe Rior) / Rear Suspension Rod (Upper)
Tirante Da Suspensão Traseira (Infe Rior) / Rear Suspension Rod (Lower)
Travao Frontal(Esq) / Front Brake (Left)
Travao Frontal(Drt) / Front Brake (Right)
Travao Traseiro(Esq) / Rear Brake (Left)
Travao Traseiro(Drt) / Rear Brake (Right)
Cilindro Travao Principal / Brake Master Cyli Nder
Cilnidro Principal Travao[Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Line ( Front)
Tubo Oleo Travoes (Traseira) / Brake Oil Line (Rear)
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Transmissao / Transmission Frame
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Carter Eixo Frente / Front Axle C Ase
Tampa Da Caixa Do Eixo Dianteiro / Front Axle Case Cover
Grupo Conico / Bevel Gear Shaft
Diferencial Dianteiro / Front Dif Ferential
Veio De Transmissão Dianteiro (Es Querdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Di Reito) / Front Drive Shaft (Right)
Veio De Accionamento Dianteiro [P Eças Componentes] / Front Drive Shaft [Component Pa Rts]
Eixo Dianteiro (Esquerdo) / Front Axle (Left)
Eixo Dianteiro (Direito) / Front Axle (Right)
Veio Tracao Dianteira / Front Pro Peller Shaft
Suspensao Frontal(Esq) / Front Su Spension (Left)
Suspensao Frontal(Drt) / Front Su Spension (Right)
Suspensao Frontal[Peças Component Es] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Esq Uerdo) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (Dir Eito) / Front Suspension Arm (Right)
Radiador Oleo / Oil Coo Ler
Caixa / Box Base
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Grelha Frontal / Front Grille
Capot / Bonnet
Tampa Painel / Panel Cover
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear)
Cobertura Central / Center Cover
Banco / Seat
Cinto Segurança / Seat Belt
Placa De Isolamento / Insulation Plate
Arco / Rops
Roda Frente (24*9-1 2) / Front Wheel (24*9-12)
Roda Frente (22*9-1 2) / Front Wheel (22*9-12)
Roda Traseira (24*1 1-12) / Rear Wheel (24*11-12)
Etiqueta (Frente) [Ingles] / Label (Front) [English]
Etiqueta (Frente) [Frances] / Label (Front ) [French]
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseira) [Ingles] / Label (Rear ) [English]
Etiqueta (Traseira) [Frances] / Label (Rea R) [French]
Ac Essorios E Peças Serviço / Accessories And Service Parts
Filtro Ar,Kit[Opcao] / High Land Air Cleaner K It [Option]
Kit Velocimetro (W/G No.V4333) [Opcao] / Speed Ometer Kit (W/G No.V4333) [Option]
Kit Sonoro Mancha Atras (W/G No.V4332) [Opcao] / Backup Beeper Kit (W/G No.V4332) [Option]
Kit Luzes Trabalho (W/G No.V4322) [Opcao] / Wo Rk Light Kit(Front) (W/G No. V4322) [Option]
Kit Luzes Trabalho (W/G No.V4323) [Opcao] / Wo Rk Light Kit(Rear) (W/G No. V4323) [Option]
Veio Propulsor Dianteiro Com Bocal [Opcao] / F Ront Propeller Shaft With Nipple [Option]
Kit Estrutura Elevacao Frontal (W/G No.V4309) [Opcao] / Front Heavy Load Strut Kit (W/G No.V4309) [Option]
Kit De Tapete Da Plataforma (W/G No. V4351) [O Pcao] / Bed Mat Kit (W/G No. V4351) [Option]
Kit Proteccao Frontal (W/G No.V4325) [Opcao] / Front Guard Kit (W/G No. V4325) [Option]
Kit Caixa Acessorios (W/G No.V4335) [Opcao] / Front Accessory Box Kit (W/G No. V4335) [Option]
Kit Do Suporte Do Encosto Para A Cabeça (W/G N O.V4341) [Opcao] / Headrest Stay Kit (W/G. No. V434 1) [Option]
Kit Encosto Cabeça (W/G No.V4231xt) [Opcao] / Headrest Kit (W/G No. V4231xt) [Option]
Kit Da Capa De Carga (W/G No.V4350) [Opcao] / Cargo Screen Kit (W/G. No. V4350) [Option]
Kit Tecto Lona (W/G No.V4321) [Opcao] / Canopy Kit (W/G No. V4321) [Option]
Kit De Pára-Brisas Em Policarbonato (W/G No.V4 316) [Opcao] / Glass Windshield Kit (W/G No. V4316) [Option]
Kit De Pára-Brisas Inferior (W/G No.V4315) [Op Cao] / Lower Windshield Kit (W/G No. V4315) [Option ]
