Kubota Utility Vehicle RTV500R-EU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV500R-EU Utility Vehicle
Number of Pages: 201 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Tampa Carter 1 (Resguardo) / Crank Case Cover 1 (Cover)
Tampa Carter 2 (Resguardo) / Crankcase Cover 2 ( Belt)
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Cambota / Camshaft
Compensador / Balancer
Fio Do Motor / Engine Wire
Volante Motor / Magnetico / Flywheel And Magneto
Interruptor Ignição E Vela Incadescencia / Ignit Ion Coil And Spark Plug
Bomba Agua / Water Pump
Correia / Poli Tensora / Belt And Tensionpulley
Corpo Acelarador / Throttle Body
Corpo Acelarador[Peças Componentes] / Throttle B Ody [Component Parts]
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Escpae / Muffler
Tubo Escape / Exhaust Pipe
Acessorios (Ecu) / Accessories (Ecu)
Diagmaster / Diagmaster
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Ventoinha(Drt) / Fan (Right)
Ventoinha (Cen Tral) / Fan (Center)
Tubo Agua (Rad Iador) / Water Pipe (Radiator)
Tubo (Agua Rad Iador Oleo) / Water Pipe (Oil Cooler)
Radiador / Rad Iator
Deposito Reser Va / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque[Peças Comp Onentes] / Starter [Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch And Thermometer
Tampa Interruptor / Panel Switch
Interruptor Travao / Brak E Switch
Luzes Frente / Head Light
Farol Traseiro / Rear Lam P
Cablagem Electrica / Elec Trical Wiring
Respiro Transmissão / Transmission Br Eather
Caixa Da Transmissão Dianteira / Fron T Drive Case
Hst 1 (Bomba) / Hst 1 (Charge Pump)
Hst 2 (Regulador) / Hst 2 (Regulator)
Hst 3 (Veio Motor) / Hst 3 (Motor Sha Ft)
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Gear S Haft
Inversor / Reverse Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear Different Ial
Forqueta / Main Gear Shift For K
Alavanca / Differential Lock S Hift Fork
Caixa Velocidades / Speed Chan Ge Lever
Tirante De Mudança De Velocida De / Speed Change Rod
Alavanca Velocidades / Main Ge Ar Shift Lever
Valvula Bypass / Bypass Valve Link
Eixo Traseiro(Esq) / Rear Axle (Left)
Eixo Traseiro(Drt) / Rear Axle (Right )
Suspensão Traseiro(Drt) / Rear Suspen Sion (Right)
Suspensão Traseiro[Peças Componentes] / Rear Suspension [Component Parts]
Tirante Da Suspensão Traseira (Superi Or) / Rear Suspension Rod (Upper)
Tirante Da Suspensão Traseira (Inferi Or) / Rear Suspension Rod (Lower)
Bloqueio Diferencial / Differential L Ock Pedal
Travao Frontal(Esq) / Front Brake (Left)
Travao Frontal(Drt) / Front Brake (Right)
Travao Traseiro(Esq) / Rear Brake (Left)
Travao Traseiro(Drt) / Rear Brake (Right)
Cilindro Travao Principal / Brake Master Cylind Er
Cilnidro Principal Travao[Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Line (Fr Ont)
Tubo Oleo Travoes (Traseira) / Brake Oil Line ( Rear)
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Carter Eixo Frente / Front Axle Cas E
Tampa Da Caixa Do Eixo Dianteiro / Front Axle Case Cover
Grupo Conico / Bevel Gear Shaft
Diferencial Dianteiro / Front Diffe Rential
Veio De Transmissão Dianteiro (Esqu Erdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Dire Ito) / Front Drive Shaft (Right)
Veio De Accionamento Dianteiro [Peç As Componentes] / Front Drive Shaft [Component Part S]
Eixo Dianteiro (Esquerdo) / Front A Xle (Left)
Eixo Dianteiro (Direito) / Front Ax Le (Right)
Veio Tracao Dianteira / Front Prope Ller Shaft
Suspensao Frontal(Esq) / Front Susp Ension (Left)
Suspensao Frontal(Drt) / Front Susp Ension (Right)
Suspensao Frontal[Peças Componentes ] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Esque Rdo) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (Direi To) / Front Suspension Arm (Right)
Cilindro Direcção[Peças Componentes] / Stee Ring Cylinder [Component Parts]
Radiador Oleo / Oil Coole R
Caixa / Box Base
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Grelha Frontal / Front Grille
Capot / Bonnet
Tampa Painel / Panel Cover
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear)
Cobertura Central / Center Cover
Cinto Segurança / Seat Belt
Degrau / Step
Placa De Isolamento / Insulation Plate
Arco / Rops
Roda Frente (24*9-12) / Front Wheel (24*9-12)
Roda Frente (22*9-12) / Front Wheel (22*9-12)
Roda Traseira (24*11- 12) / Rear Wheel (24*11-12)
Etiqueta (Frente) [English] / Label (Front) [English]
Etiqueta (Frente) [French] / Label (Front) [ French]
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseira) [English] / Label (Rear) [English]
Etiqueta (Traseira) [French] / Label (Rear) [French]
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Filtro Ar,Kit[Opcao] / High Land Air Cleaner Kit [Option]
Kit Velocimetro (W/G No.V4333) [Opcao] / Speedom Eter Kit (W/G No.V4333) [Option]
Kit Sonoro Mancha Atras (W/G No.V4332) [Opcao] / Backup Beeper Kit (W/G No.V4332) [Option]
Kit Luzes Trabalho (W/G No.V4322) [Opcao] / Work Light Kit(Front) (W/G No. V4322) [Option]
Kit Luzes Trabalho (W/G No.V4323) [Opcao] / Work Light Kit(Rear) (W/G No. V4323) [Option]
Veio Propulsor Dianteiro Com Bocal [Opcao] / Fro Nt Propeller Shaft With Nipple [Option]
Kit Estrutura Elevacao Frontal (W/G No.V4309) [O Pcao] / Front Heavy Load Strut Kit (W/G No.V4309) [ Option]
Kit De Tapete Da Plataforma (W/G No. V4351) [Opc Ao] / Bed Mat Kit (W/G No. V4351) [Option]
Kit Proteccao Frontal (W/G No.V4325) [Opcao] / F Ront Guard Kit (W/G No. V4325) [Option]
Kit Caixa Acessorios (W/G No.V4335) [Opcao] / Fr Ont Accessory Box Kit (W/G No. V4335) [Option]
Kit Do Suporte Do Encosto Para A Cabeça (W/G No. V4341) [Opcao] / Headrest Stay Kit (W/G No. V4341) [Option]
Kit Encosto Cabeça (W/G No.V4231xt) [Opcao] / He Adrest Kit (W/G No. V4231xt) [Option]
Kit Da Capa De Carga (W/G No.V4350) [Opcao] / Ca Rgo Screen Kit (W/G No. V4350) [Option]
Kit Tecto Lona (W/G No.V4321) [Opcao] / Canopy K It (W/G No. V4321) [Option]
Kit De Pára-Brisas Em Policarbonato (W/G No.V431 6) [Opcao] / Glass Windshield Kit (W/G No. V4316) [ Option]
Kit De Pára-Brisas Inferior (W/G No.V4315) [Opca O] / Lower Windshield Kit (W/G No. V4315) [Option]
