Kubota Utility Vehicle RTV400CIR-A RTV400CIR-H Spare Parts Catalog EN FR
Language: French, English
Model: Kubota RTV400CIR-A ; RTV400CIR-H Utility Vehicle
Number of Pages: 171 Pages
Frequently Use D Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter De Lanceur / Fan Cover
Pistons Et Vilebrequin / Piston And Cranksha Ft
Embrayage / Clutch
Embrayage / Clutch
Embrayage [Parties Composantes] / Clutch [Co Mponent Parts]
Volant Moteur Et Magneto / Flywheel And Magn Eto
Soupapes Et Culbuteurs / Valve And Rocker Ar M
Corps Accelerateur / Throttle Body
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Cle Aner [Component Parts]
Silencieux / Muffler
Tuyau D'echappement / Exhaust Pipe
Arbre À Cames [Option] / Camshaft Kit [Optio N]
Pedale D'accelerateur / Acce Lerator Pedal
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pip E
Filtlre A Essence / Fuel Fil Ter
Lanceur / Starter
Batterie / Battery
Interrupteur/Detecte Ur / Switch/Sensor
Interrupteur/Relais / Switch/Relay
Tableau De Commutate Ur / Panel Switch
Frein De Commutateur / Brake Switch
Phare / Head Light
Phare / Head Light
Feu D'arriere / Rear Lamp
Faisceau Electrique / Electrical Wiring
Carter De Transmission / Transmi Ssion Case
Reniflard De Transmission / Tran Smission Breather
Couverture De Cvt / Cvt Cover
Filtre A Air De Cvt / Cvt Air Cl Eaner
Filtre A Air De Cvt [Parties Com Posantes] / Cvt Air Cleaner [Component Parts]
Poulie De Roulement De Cvt / Cvt Drive Pulley
Poulie De Roulement De Cvt [Part Ies Composantes] / Cvt Drive Pulley [Component Part S]
Poulie De Entraine De Cvt / Cvt Driven Pulley
Poulie De Entraine De Cvt [Parti Es Composantes] / Cvt Driven Pulley [Component Part S]
Arbre D'entree / Input Shaft
Arbre De Regulateur / Governor S Haft
Arbre De Changement De Gamme / R Ange Gear Shaft
Essieu De Misston / Decelerating Shaft
Arbre De Marche Arriere / Revers E Shaft
Arbre De Changement / Change Sha Ft
Pignon Conique / Spiral Bevel Pi Nion
Differentiel Arriere / Rear Diff Erential
Fourchette De Blocage Di Fferentiel / Differential Lock Shift Fork
Levier De Vittese-Change Ment / Speed Change Lever
Vittese Levier De Comman De / Speed Control Lever
Levier De Changement De Vitesses Principal / Main Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Essieu Arriere (Gauche) / Rear Ax Le (Left)
Essieu Arriere (Droite) / Rear Ax Le (Right)
Suspension Arriere (Gauche) / Rea R Suspension (Left)
Suspension Arriere (Droite) / Rea R Suspension (Right)
Suspension Arriere [Parties Compo Santes] / Rear Suspension [Component Parts]
Tringle De La Suspension Arriere (Superieur) / Rear Suspension Rod (Upper)
Tringle De La Suspension Arriere (Inferieur) / Rear Suspension Rod (Lower)
Levier De Verrouillage Du Differe Ntiel / Differential Lock Lever
Frein Avant (Gauche) / Front Brake (Left)
Frein Avant (Gauche) [Parties Composantes] / F Ront Brake (Left) [Component Parts]
Frein Avant (Droite) / Front Brake (Right)
Frein Avant (Droite) [Parties Composantes] / F Ront Brake (Right) [Component Parts]
Frein Arriere (Gauche) / Rear Brake (Left)
Frein Arriere (Gauche) [Parties Composantes] / Rear Brake (Left) [Component Parts]
Frein Arriere (Droite) / Rear Brake (Right)
Frein Arriere (Droite) [Parties Composantes] / Rear Brake (Right) [Component Parts]
Maitre Cylindre De Frein [Parties Composantes] / Brake Master Cylinder [Component Parts]
Circuit D'huile Frein (Avant) / Brake Oil Line (Front)
Circuit D'huile Frein (Arriere) / Brake Oil Li Ne (Rear)
Levier De Frein De Stationnement / Parking Bra Ke Lever
Cable De Frein De Stationnement / Parking Brak E Wire
Pedale De Frien / Brake Pedal
Chassis Transmission / Transmission Frame
Dessous Garde / Under Guard
Console De Moteur / Engine Bracket
Couvercle De Carter De Differentie L Avant / Front Axle Case Cover
Demi Arbre Pont Avant / Bevel Gear Shaft
Differentiel Avant / Front Differe Ntial
Demi Arbre Avant [Parties Composan Tes] / Front Drive Shaft [Component Parts]
Carter Reducteur (Gauche) / Front Axle (Left)
Essieu Avant (Droite) / Front Axle (Right)
Arbre D'entrainement Avant / Front Propeller Shaft
Suspension Avant (Gauche) / Front Suspension (Left)
Suspension Avant (Droite) / Front Suspension (Right)
Suspension Avant [Parties Composan Tes] / Front Suspension [Component Parts]
Bras De Suspension Avant (Gauche) / Front Suspension Arm (Left)
Bras De Suspension Avant (Droite) / Front Suspension Arm (Right)
Colonne De Direction / Steering Wheel
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direc Tion / Steering Cylinder
Cylindre De Direction [Parties Composan Tes] / Steering Cylinder [Component Parts]
Corps De Boite / Box Base
Plaque De Boite (Avant) / Bo X Plate (Front)
Plaque De Boite (Droite) / B Ox Plate (Right)
Grille De Boite / Box Gate
Couverture De Boite / Box Co Ver
Capot Superieur / Hood (Bonnet) Upper
Aile (Avant) / Fender (Front)
Aile (Arriere) / Fender (Rear)
Couvercle De Centre / Center Cover
Siege / Seat
Marchepied / Step
Plaque D'isolation / Insulation Plate
Cadre Anti-Renversment / Rops
Roue Avant (24*9-12) [R Tv400ci-A/Cir-A] / Front Wheel (24*9-12) [Rtv400ci- A/Cir-A]
Roue Arriere (24*11-12) [Rtv400ci-A/Cir-A] / Rear Wheel (24*11-12) [Rtv400 Ci-A/Cir-A]
Roue Arriere (24*11-12) [Rtv400ci-H/Cir-H] / Rear Wheel (24*11-12) [Rtv400 Ci-H/Cir-H]
Etiquettes (Panneau) / Label (Panel)
Accessories Et Piece De Service / Accessories And Service Parts
Indicateur De Vitesse (No.De M/E V4338) [Opt Ion] / Speedometer Kit (W/G No.V4338) [Option]
Alarme De Recul (No.De M/E V4336) [Option] / Backup Beeper Kit (W/G No.V4336) [Option]
Phares De Travail (Avant) (No.De M/E V4322a) [Option] / Work Light Kit (Front) (W/G No.V4322a) [Option]
Phares De Travail (Arriere) (No.De M/E V4323 A) [Option] / Work Light Kit(Rear) (W/G No.V4323a) [Option]
Support De Suspension Avant (No.De M/E V4309 ) [Option] / Front Heavy Load Strut Kit (W/G No.V43 09) [Option]
Repose Pied De Benne (No.De M/E V4352) [Opti On] / Bed Mat Kit (W/G No.V4352) [Option]
Garde De Protection Avant (No.De M/E V4325) [Option] / Front Guard Kit (W/G No. V4325) [Option]
Boite De Rangement Avant (No.De M/E V4335) [ Option] / Front Accessory Box Kit (W/G No. V4335) [ Option]
Support De Appui Tete (No. De M/E V4341) [Op Tion] / Headrest Stay Kit (W/G No. V4341) [Option]
Appui Tete (No.De M/E V4231xt) [Option] / He Adrest Kit (W/G No.V4231xt) [Option]
Filet De Cargaison (No. De M/E V4350) [Optio N] / Cargo Screen Kit (W/G No. V4350) [Option]
Kit De Auvent (No. De M/E V4321) [Option] / Canopy Kit (W/G No. V4321) [Option]
Pare-Brise (No. De M/E V4316) [Option] / Gla Ss Windshield Kit (W/G No. V4316) [Option]
Abaissez Le Pare-Brise (No. De M/E V4315) [O Ption] / Lower Windshield Kit (W/G No. V4315) [Opti On]
Embrayage / Clutch
Embrayage / Clutch
Lanceur / Starter
Batterie / Battery
Phare / Head Light
Phare / Head Light
Siege / Seat
Marchepied / Step
