Kubota Utility Vehicle RTV1140CPXR Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV1140CPXR Utility Vehicle
Number of Pages: 250 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft An D Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug
Suporte Bico[Peças Componentes] / Nozzle Holder [Component Parts]
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Acelarador Pedal / Accelerat Or Pedal
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo (Mecânica) / F Uel Pump (Mechanical)
Tubo Agua (Ra Diador) / Water Pipe (Radiator)
Tubo Agua (Mo Tor) / Water Pipe (Engine)
Radiador / Ra Diator
Deposito Rese Rva / Reserve Tank
Tampa Do Radi Ador / Radiator Cover
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch And Thermometer
Interruptor/Sensor / Swi Tch/Sensor
Tampa Interruptor / Pane L Switch
Interruptor Travao / Bra Ke Switch
Luzes Frente / Head Ligh T
Farol Traseiro / Tail Li Ght
Cablagem Electrica / Ele Ctrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmission Cas E
Tampa Transmissao / Transmission Cas E Cover
Hst / Hst
Hst 1 (Bomba) [Peças Componentes] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Piston) [Peças Componentes] / Hst 2 (Piston) [Component Parts]
Hst 3 (Regulador) [Peças Componentes ] / Hst 3 (Regulator) [Component Parts]
Hst 4 (Veio Motor) [Peças Componente S] / Hst 4 (Motor Shaft) [Component Parts]
Hst 5 (Resguardo) [Peças Componentes ] / Hst 5 (Cover) [Component Parts]
Hst 6 (Valvula) [Peças Componentes] / Hst 6 (Valve) [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear Differen Tial
Kit Transmissao / Transmission Kit
Forqueta Velocidades / Range Gear Shift Fork
Braço Carreto Gamas / Range G Ear Arm
Alavanca / Differential Lock Shift Fork
Caixa Velocidades / Speed Cha Nge Lever
Tirante De Mudança De Velocid Ade / Speed Change Rod
Alavanca Velocidades / Main G Ear Shift Lever
Alavanca Dupla Traccao / Fron T Wheel Drive Lever
Eixo Traseiro (Esq) / Rear Axle (Lef T)
Eixo Traseiro (Drt) / Rear Axle (Rig Ht)
Veio De Transmissão Traseiro (Esq) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro (Drt) / Rear Drive Shaft (Right)
Suspensão Traseiro (Esq) / Rear Susp Ension (Left)
Suspensão Traseiro (Drt) / Rear Susp Ension (Right)
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao (Esq) / Brake Cylinder (Left)
Cilindro Travao (Drt) / Brake Cylinder (Right)
Cilnidro Principal Travao [Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Line (F Ront)
Tubo Oleo Travoes (Traseira) / Brake Oil Line (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lever
Elo De Descarregamento / Unload Link
Bomba Hidraulico / Hydra Ulic Pump
Deposito Oleo Hidraulico / Hydraulic Tank
Tubo Oleo (Hst) / Hydrau Lic Oil Line (Hst)
Tubo Oleo (Deposito) / H Ydraulic Oil Line (Tank)
Linha De Óleo Hidráulico (Válvula De Controlo) / Hydraulic Oil Line (Contro L Valve)
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [P Eças Componentes] / Remote Control Valve [Component Parts]
Cilndro Eleveção [Peças Componentes] / Lift Cylinder [Component Parts]
Linha De Óleo Hidráulico (Cilindro Esquerdo) / Hydraulic Oil Line (Lift Cyl Inder)
Estrutura Transmissao / Transmission Frame
Protecção Inferior / Under Guard
Carter Eixo Frente / Front Axle Ca Se
Grupo Conico / Differential Gear S Haft
Veio De Transmissão Dianteiro (Esq ) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Drt ) / Front Drive Shaft (Right)
Carter Eixo Frente (Esq) / Front A Xle Case (Left)
Carter Eixo Frente (Drt) / Front A Xle Case (Right)
Eixo Dianteiro (Drt) / Front Axle (Right)
Veio Frontal / Front Propeller Sha Ft
Suspensao Frontal (Esq) / Front Su Spension (Left)
Suspensao Frontal (Drt) / Front Su Spension (Right)
Suspensao Frontal [Peças Component Es] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Esq) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (Drt) / Front Suspension Arm (Right)
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Base Caixa (Traseira) / Box Base (Rea R)
Chapa Caixa (Frente) / Box Plate (Fro Nt)
Estrutura Caixa / Box Gate
Proteccao Frontal / Front Guard
Grelha Frontal / Front Grille
Capot (Superior) / Bonnet (Upper)
Capot (Inferior) / Bonnet (Lower)
Tampa Painel / Panel Cover
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear)
Cobertura Central (Frente) / Center Cover (Front)
Cobertura Central (Lado) / Center Cover (S Ide)
Cobertura Central (Traseira) / Center Cove R (Rear)
Suporte Assento (Traseira) / Seat Support (Rear)
Banco (Frente) / Seat (Front)
Banco (Traseira) / Seat (Rear)
Cinto Segurança (Frente) / Seat Belt (Fron T)
Cinto Segurança (Traseira) / Seat Belt (Re Ar)
Degrau (Frente) / Step (Front)
Degrau (Traseira) / Step (Rear)
Arco (Frente) / Rops (Front)
Arco (Traseira) / Rops (Rear)
Rede (Arco) / Net (Rops)
Roda Frente (25*10-1 2) / Front Wheel (25*10-12)
Roda Traseira (25*11 -12) / Rear Wheel (25*11-12)
Roda Traseira (25*10 -12) / Rear Wheel (25*10-12)
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit De Admissão De Ar Em Posição Elevada (W/G N O. V4471) [Opcao] / High Position Air Intake Kit (W /G No. V4471) [Option]
Kit Sonoro Mancha Atras (W/G No.V4232) [Opcao] / Backup Beeper Kit (W/G No.V4232) [Option]
Kit Luzes Trabalho (W/G No. V4453) [Opcao] / Wo Rk Light Kit (Rear) (W/G No. V4453) [Option]
Kit Da Caixa Do Motor Traseiro [Opcao] / Rear M Otor Case Kit [Option]
Veio Frontal [Opcao] / Front Propeller Shaft Wi Th Nipple [Option]
Kit Estrutura Elevação (W/G No. V4219) [Opcao] / Front Heavy Load Springs Kit (W/G No.V4219) [Opti On]
Kit Camisa (W/G No. V4451) [Opcao] / Bed Liner Kit (W/G No. V4451) [Option]
Kit Caixa Acessorios (W/G No. V4235) [Opcao] / Front Accessory Box Kit (W/G No.V4235) [Option]
Kit Do Suporte Para Copos (W/G No. V4452) [Opca O] / Cup Holder Kit (W/G No. V4452) [Option]
Kit Porta Luvas (W/G No. V4234) [Opcao] / Glove Box Kit (W/G No.V4234) [Option]
Kit Guarda Lamas Frontais (W/G No. V4236) [Opca O] / Front Mud Guard Kit (W/G No.V4236) [Option]
Protecção,Kit (Banco Traseira) [Opcao] / Shield Kit (Seat Rear) [Option]
Kit Do Suporte Do Encosto Para A Cabeça (W/G No . V4443) [Opcao] / Headrest Stay Kit (W/G No. V4443 ) [Option]
Kit Encosto Cabeça (W/G No. V4231) [Opcao] / He Adrest Kit (W/G No. V4231) [Option]
Kit De Pára-Brisas Em Policarbonato (W/G No. V4 442) [Opcao] / Polycarbonate Windshield Kit (W/G No . V4442) [Option]
Carreto / Gear Case
Escpae / Muffler
Hst / Hst
