Kubota Utility Vehicle RTV1140CPXR Spare Parts Catalog EN FR
Language: French, English
Model: Kubota RTV1140CPXR Utility Vehicle
Number of Pages: 249 Pages
Frequent Ly Used Items / Frequently Used Items
Pieces D E Maintenance / Maintenance Parts
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / No Zzle Holder And Glow Plug
Bride A Eau Et Thermostat / Water Flange And T Hermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Couvercle De Silencieux / Muffler Cover
Pedale D'accelerateur / Accele Rator Pedal
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtlre A Essence / Fuel Filte R
Pompe D'alimentation (Mecaniqu E) / Fuel Pump (Mechanical)
Tuyau D'eau (Radi Ateur) / Water Pipe (Radiator)
Tuyau D'eau (Mote Ur) / Water Pipe (Engine)
Radiateur / Radia Tor
Reservoir Du Radi Ateur / Reserve Tank
Covercle De Radia Teur / Radiator Cover
Alternateur / Alternat Or
Alternateur [Parties C Omposantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Parts]
Batterie / Battery
Contact A Huile Et The Rmometre / Oil Switch And Thermometer
Interrupteur/Detecteur / Switch/Sensor
Tableau De Commutateur / Panel Switch
Frein De Commutateur / Brake Switch
Phare / Head Light
Feu D'arriere / Tail L Ight
Carter Avant / Front Case
Carter De Transmission / Transmiss Ion Case
Couvercle De Carter De Transmissio N / Transmission Case Cover
Hst / Hst
Hst 1 (Pompe De Charge) [Parties C Omposantes] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Piston) [Parties Composante S] / Hst 2 (Piston) [Component Parts]
Hst 3 (Regulateur) [Parties Compos Antes] / Hst 3 (Regulator) [Component Parts]
Hst 4 (Arbre De Moteur) [Parties C Omposantes] / Hst 4 (Motor Shaft) [Component Parts]
Hst 5 (Couvercle) [Parties Composa Ntes] / Hst 5 (Cover) [Component Parts]
Hst 6 (Soupapes) [Parties Composan Tes] / Hst 6 (Valve) [Component Parts]
Arbre D'entree / Input Shaft
Arbre De Changement De Gamme / Ran Ge Gear Shaft
Arbre De Marche Arriere / Reverse Shaft
Arbre De Marche / Idle Shaft
Arbre D'entrainement Avant / Front Wheel Propeller Shaft
Pignon Conique / Spiral Bevel Pini On
Differentiel Arriere / Rear Differ Ential
Jeu De Transmission / Transmission Kit
Fourchette De Changement D E Gamme / Range Gear Shift Fork
Bras De Changement De Gamm E / Range Gear Arm
Bras De Traction Avant / F Ront Wheel Drive Arm
Fourchette De Blocage Diff Erentiel / Differential Lock Shift Fork
Levier De Vittese-Changeme Nt / Speed Change Lever
Tige De Commande De Vitess E / Speed Change Rod
Levier De Changement De Vi Tesses Principal / Main Gear Shift Lever
Levier De Tranission Aux R Oues Avant / Front Wheel Drive Lever
Essieu Arriere (Gauche) / Rear Axle (Left)
Essieu Arriere (Droite) / Rear Axle (Right)
Demi Arbre Arriere (Gauche) / Rear Drive Shaft (Left)
Demi Arbre Arriere (Droite) / Rear Drive Shaft (Right)
Suspension Arriere (Gauche) / Rear Suspension (Left)
Suspension Arriere (Droite) / Rear Suspension (Right)
Pedale De Verrouillage Du Different Iel / Differential Lock Pedal
Frein Avant (Gauche) / Front Brake (Left)
Frein Avant (Droite) / Front Brake (Right)
Frein Arriere (Gauche) / Rear Brake (Left)
Frein Arriere (Droite) / Rear Brake (Right)
Cylindre De Frein (Gauche) / Brake Cylinder (Lef T)
Cylindre De Frein (Droite) / Brake Cylinder (Rig Ht)
Maitre Cylindre De Frein [Parties Composantes] / Brake Master Cylinder [Component Parts]
Circuit D'huile Frein (Avant) / Brake Oil Line ( Front)
Circuit D'huile Frein (Arriere) / Brake Oil Line (Rear)
Tige De Frein / Brake Rod
Cable De Frein De Stationnement / Parking Brake Wire
Pedale De Frien / Brake Pedal
Levier De Relevage / Li Ft Lever
Dechargee De Maillon / Unload Link
Support Avant Droit / H Ydraulic Pump
Pompe Hydraulique [Part Ies Composantes] / Hydraulic Pump [Component Parts]
Reservoir A Hydraulique / Hydraulic Tank
Circuit D'huile Hydraul Ique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydraul Ique (Refroidisseur) / Hydraulic Oil Line (Oil Cool Er)
Circuit D'huile Hydraul Ique (Reservoir) / Hydraulic Oil Line (Tank)
Circuit D'huile Hydraul Ique (Distributeur) / Hydraulic Oil Line (Control V Alve)
Distributeur Auxiliaire / Remote Control Valve
Controle Des Valves Aux . [Parties Composantes] / Remote Control Valve [Com Ponent Parts]
Cylindre De Relevage [P Arties Composantes] / Lift Cylinder [Component Part S]
Circuit D'huile Hydraul Ique (Cylindre De Relevage) / Hydraulic Oil Line (L Ift Cylinder)
Chassis Transmission / Transmission Frame
Dessous Garde / Under Guard
Demi Arbre De Pont Avant / Different Ial Gear Shaft
Differentiel Avant / Front Different Ial
Demi Arbre Avant (Gauche) / Front Dr Ive Shaft (Left)
Demi Arbre Avant (Droite) / Front Dr Ive Shaft (Right)
Carter De Differentiel Avant (Gauche ) / Front Axle Case (Left)
Carter De Differentiel Avant (Droite ) / Front Axle Case (Right)
Carter Reducteur (Gauche) / Front Ax Le (Left)
Essieu Avant (Droite) / Front Axle ( Right)
Arbre De Transmission Avant / Front Propeller Shaft
Suspension Avant (Gauche) / Front Su Spension (Left)
Suspension Avant (Droite) / Front Su Spension (Right)
Suspension Avant [Parties Composante S] / Front Suspension [Component Parts]
Bras De Suspension Avant (Gauche) / Front Suspension Arm (Left)
Bras De Suspension Avant (Droite) / Front Suspension Arm (Right)
Colonne De Direction / Steering Wheel
Cylindre De Direction / Steering Cylinder
Cylindre De Direction [Parties Composante S] / Steering Cylinder [Component Parts]
Corps De Boite (Avant) / Box B Ase (Front)
Corps De Boite (Arriere) / Box Base (Rear)
Plaque De Boite (Avant) / Box Plate (Front)
Plaque De Boite (Arriere) / Bo X Plate (Rear)
Grille De Boite / Box Gate
Capot (Superieur) / Bonnet (Upper)
Capot (Inferieur) / Bonnet (Lower)
Aile (Avant) / Fender (Front)
Aile (Arriere) / Fender (Rear)
Couvercle De Centre (Avant) / Center Cover (Front)
Couvercle De Centre (Lateral) / Center Cov Er (Side)
Couvercle De Centre (Arriere) / Center Cov Er (Rear)
Support De Siege (Arriere) / Seat Support (Rear)
Siege (Avant) / Seat (Front)
Siege (Arriere) / Seat (Rear)
Ceinture De Maintien (Avant) / Seat Belt ( Front)
Ceinture De Sécurité (Arrière) / Seat Belt (Rear)
Marchepied (Avant) / Step (Front)
Marchepied (Arriere) / Step (Rear)
Cadre Anti-Renversment (Avant) / Rops (Fro Nt)
Cadre Anti-Renversment (Arriere) / Rops (R Ear)
Filet (Cadre Anti-Renversement) / Net (Rop S)
Roue Avant (25*10-12) / F Ront Wheel (25*10-12)
Roue Arriere (25*11-12) / Rear Wheel (25*11-12)
Roue Arriere (25*10-12) / Rear Wheel (25*10-12)
Accessories Et Pieces De Service / Accessories A Nd Service Parts
Admission D'air D'haute Position (No.De M/E V4 471) [Option] / High Position Air Intake Kit (W/G N O. V4471) [Option]
Alarme De Recul (No.De M/E V4232) [Option] / B Ackup Beeper Kit (W/G No.V4232) [Option]
Phares De Travail (Arriere) (No.De M/E V4453) [Option] / Work Light Kit (Rear) (W/G No. V4453) [O Ption]
Ens.Carter De Arriere Moteur [Option] / Rear M Otor Case Kit [Option]
Ressort De Suspension Avant (No.De M/E V4219) [Option] / Front Heavy Load Springs Kit (W/G No.V42 19) [Option]
Recouvrement De Benne (No.De M/E V4451) [Optio N] / Bed Liner Kit (W/G No. V4451) [Option]
Boite De Rangement Avant (No.De M/E V4235) [Op Tion] / Front Accessory Box Kit (W/G No.V4235) [Opt Ion]
Support De Gobelet (No.De M/E V4452) [Option] / Cup Holder Kit (W/G No. V4452) [Option]
Boite A Gant (No.De M/E V4234) [Option] / Glov E Box Kit (W/G No.V4234) [Option]
Garde Boue Avant (No.De M/E V4236) [Option] / Front Mud Guard Kit (W/G No.V4236) [Option]
Protecteur (Siege Arriere) [Option] / Shield K It (Seat Rear) [Option]
Support De Appui Tete (No.De M/E V4443) [Optio N] / Headrest Stay Kit (W/G No. V4443) [Option]
Appui Tete (No.De M/E V4231) [Option] / Headre St Kit (W/G No. V4231) [Option]
Pare-Brise (No.De M/E V4442) [Option] / Polyca Rbonate Windshield Kit (W/G No. V4442) [Option]
