Kubota Utility Vehicle RTV1140CPX Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV1140CPX Utility Vehicle
Number of Pages: 244 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Pl Ug
Suporte Bico[Peças Componentes] / Nozzle Holder [Component Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Acelarador Pedal / Accelerato R Pedal
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo (Mecânica) / Fu El Pump (Mechanical)
Tubo Agua (Rad Iador) / Water Pipe (Radiator)
Tubo Agua (Mot Or) / Water Pipe (Engine)
Radiador / Rad Iator
Deposito Reser Va / Reserve Tank
Tampa Do Radia Dor / Radiator Cover
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor E Termómetro Do Óleo / Oil Switch And Thermometer
Interruptor/Sensor / Swit Ch/Sensor
Tampa Interruptor / Panel Switch
Interruptor Travao / Brak E Switch
Luzes Frente / Head Light
Farol Traseiro / Tail Lig Ht
Cablagem Electrica / Elec Trical Wiring
Carter Frontal / Front Case
Tampa Transmissao / Transmission Case Cover
Hst / Hst
Hst 1 (Bomba) [Peças Componentes] / H St 1 (Charge Pump) [Component Parts]
Hst 2 (Piston) [Peças Componentes] / Hst 2 (Piston) [Component Parts]
Hst 3 (Regulador) [Peças Componentes] / Hst 3 (Regulator) [Component Parts]
Hst 4 (Veio Motor) [Peças Componentes ] / Hst 4 (Motor Shaft) [Component Parts]
Hst 5 (Resguardo) [Peças Componentes] / Hst 5 (Cover) [Component Parts]
Hst 6 (Valvula) [Peças Componentes] / Hst 6 (Valve) [Component Parts]
Veio Primario / Input Shaft
Veio Gamas Velocidades / Range Gear S Haft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio Tracao Dianteira / Front Wheel P Ropeller Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear Different Ial
Kit Transmissao / Transmission Kit
Forqueta Velocidades / Range G Ear Shift Fork
Braço Carreto Gamas / Range Ge Ar Arm
Braco Roda Frente / Front Whee L Drive Arm
Alavanca / Differential Lock S Hift Fork
Caixa Velocidades / Speed Chan Ge Lever
Tirante De Mudança De Velocida De / Speed Change Rod
Alavanca Velocidades / Main Ge Ar Shift Lever
Eixo Traseiro (Esq) / Rear Axle (Left )
Eixo Traseiro (Drt) / Rear Axle (Righ T)
Veio De Transmissão Traseiro (Esq) / Rear Drive Shaft (Left)
Suspensão Traseiro (Esq) / Rear Suspe Nsion (Left)
Suspensão Traseiro (Drt) / Rear Suspe Nsion (Right)
Bloqueio Diferencial / Differential L Ock Pedal
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao (Esq) / Brake Cylinder (Left)
Cilindro Travao (Drt) / Brake Cylinder (Right)
Cilindro Travao Principal / Brake Master Cylind Er
Cilnidro Principal Travao [Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Line (Fr Ont)
Tubo Oleo Travoes (Traseira) / Brake Oil Line ( Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lever
Elo De Descarregamento / Unload Link
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Deposito Oleo Hidraulico / Hydraulic Tank
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hydraul Ic Oil Line (Hst)
Tubo Oleo (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Tubo Oleo (Deposito) / Hy Draulic Oil Line (Tank)
Distribuidor Auxiliar / R Emote Control Valve
Distribuidor Auxiliar [Pe Ças Componentes] / Remote Control Valve [Component Parts]
Cilndro Eleveção / Lift C Ylinder
Cilndro Eleveção [Peças C Omponentes] / Lift Cylinder [Component Parts]
Linha De Óleo Hidráulico (Cilindro Esquerdo) / Hydraulic Oil Line (Lift Cyli Nder)
Estrutura Transmissao / Transmission Frame
Protecção Inferior / Under Guard
Carter Eixo Frente / Front Axle Cas E
Grupo Conico / Differential Gear Sh Aft
Diferencial Dianteiro / Front Diffe Rential
Veio De Transmissão Dianteiro (Esq) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Drt) / Front Drive Shaft (Right)
Carter Eixo Frente (Esq) / Front Ax Le Case (Left)
Carter Eixo Frente (Drt) / Front Ax Le Case (Right)
Eixo Dianteiro (Esq) / Front Axle ( Left)
Eixo Dianteiro (Drt) / Front Axle ( Right)
Veio Frontal / Front Propeller Shaf T
Suspensao Frontal (Esq) / Front Sus Pension (Left)
Suspensao Frontal (Drt) / Front Sus Pension (Right)
Suspensao Frontal [Peças Componente S] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Esq) / Front Suspension Arm (Left)
Braço Da Suspensão Dianteira (Drt) / Front Suspension Arm (Right)
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Base Caixa (Frente) / Box Base (Front)
Base Caixa (Traseira) / Box Base (Rear )
Chapa Caixa (Frente) / Box Plate (Fron T)
Estrutura Caixa / Box Gate
Proteccao Frontal / Front Guard
Capot (Superior) / Bonnet (Upper)
Capot (Inferior) / Bonnet (Lower)
Tampa Painel / Panel Cover
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear)
Cobertura Central (Frente) / Center Cover ( Front)
Cobertura Central (Lado) / Center Cover (Si De)
Cobertura Central (Traseira) / Center Cover (Rear)
Suporte Assento (Traseira) / Seat Support ( Rear)
Banco (Frente) / Seat (Front)
Banco (Traseira) / Seat (Rear)
Cinto Segurança (Frente) / Seat Belt (Front )
Cinto Segurança (Traseira) / Seat Belt (Rea R)
Degrau (Frente) / Step (Front)
Arco (Frente) / Rops (Front)
Arco (Traseira) / Rops (Rear)
Rede (Arco) / Net (Rops)
Roda Frente (25*10-12 ) / Front Wheel (25*10-12)
Roda Frente (25*12-12 ) / Front Wheel (25*12-12)
Roda Traseira (25*11- 12) / Rear Wheel (25*11-12)
Roda Traseira (25*10- 12) / Rear Wheel (25*10-12)
Roda Traseira (25*12- 12) / Rear Wheel (25*12-12)
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Kit De Admissão De Ar Em Posição Elevada (W/G No . V4471) [Opcao] / High Position Air Intake Kit (W/ G No. V4471) [Option]
Kit Sonoro Mancha Atras (W/G No.V4232) [Opcao] / Backup Beeper Kit (W/G No.V4232) [Option]
Kit Luzes Trabalho (W/G No. V4453) [Opcao] / Wor K Light Kit (Rear) (W/G No. V4453) [Option]
Kit Da Caixa Do Motor Traseiro [Opcao] / Rear Mo Tor Case Kit [Option]
Veio Frontal [Opcao] / Front Propeller Shaft Wit H Nipple [Option]
Kit Estrutura Elevação (W/G No. V4219) [Opcao] / Front Heavy Load Springs Kit (W/G No.V4219) [Optio N]
Kit Camisa (W/G No. V4451) [Opcao] / Bed Liner K It (W/G No. V4451) [Option]
Kit Caixa Acessorios (W/G No. V4235) [Opcao] / F Ront Accessory Box Kit (W/G No.V4235) [Option]
Kit Do Suporte Para Copos (W/G No. V4452) [Opcao ] / Cup Holder Kit (W/G No. V4452) [Option]
Kit Porta Luvas (W/G No. V4234) [Opcao] / Glove Box Kit (W/G No.V4234) [Option]
Kit Guarda Lamas Frontais (W/G No. V4236) [Opcao ] / Front Mud Guard Kit (W/G No.V4236) [Option]
Protecção,Kit (Banco Traseira) [Opcao] / Shield Kit (Seat Rear) [Option]
Kit Do Suporte Do Encosto Para A Cabeça (W/G No. V4443) [Opcao] / Headrest Stay Kit (W/G No. V4443) [Option]
Kit Encosto Cabeça (W/G No. V4231) [Opcao] / Hea Drest Kit (W/G No. V4231) [Option]
Kit Tecto Lona (W/G No. V4441) [Opcao] / Canopy Kit (W/G No. V4441) [Option]
Kit De Pára-Brisas Em Policarbonato (W/G No. V44 42) [Opcao] / Polycarbonate Windshield Kit (W/G No. V4442) [Option]
Carreto / Gear Case
Escpae / Muffler
Hst / Hst
