Kubota Utility Vehicle RTV1140CPX Spare Parts Catalog EN FR
Language: French, English
Model: Kubota RTV1140CPX Utility Vehicle
Number of Pages: 243 Pages
Frequentl Y Used Items / Frequently Used Items
Pieces De Maintenance / Maintenance Parts
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Bride A Eau Et Thermostat / Water Flange And Th Ermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Couvercle De Silencieux / Muffler Cover
Pedale D'accelerateur / Acceler Ator Pedal
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Pompe D'alimentation (Mecanique ) / Fuel Pump (Mechanical)
Tuyau D'eau (Radia Teur) / Water Pipe (Radiator)
Tuyau D'eau (Moteu R) / Water Pipe (Engine)
Radiateur / Radiat Or
Reservoir Du Radia Teur / Reserve Tank
Covercle De Radiat Eur / Radiator Cover
Alternateur / Alternato R
Alternateur [Parties Co Mposantes] / Alternator [Component Parts]
Lanceur / Starter
Batterie / Battery
Contact A Huile Et Ther Mometre / Oil Switch And Thermometer
Interrupteur/Detecteur / Switch/Sensor
Tableau De Commutateur / Panel Switch
Frein De Commutateur / Brake Switch
Phare / Head Light
Feu D'arriere / Tail Li Ght
Faisceau Electrique / E Lectrical Wiring
Carter Avant / Front Case
Carter De Transmission / Transmissi On Case
Couvercle De Carter De Transmission / Transmission Case Cover
Hst / Hst
Hst 1 (Pompe De Charge) [Parties Co Mposantes] / Hst 1 (Charge Pump) [Component Parts]
Hst 2 (Piston) [Parties Composantes ] / Hst 2 (Piston) [Component Parts]
Hst 3 (Regulateur) [Parties Composa Ntes] / Hst 3 (Regulator) [Component Parts]
Hst 4 (Arbre De Moteur) [Parties Co Mposantes] / Hst 4 (Motor Shaft) [Component Parts]
Hst 5 (Couvercle) [Parties Composan Tes] / Hst 5 (Cover) [Component Parts]
Hst 6 (Soupapes) [Parties Composant Es] / Hst 6 (Valve) [Component Parts]
Arbre D'entree / Input Shaft
Arbre De Transmission / Propeller S Haft
Arbre De Changement De Gamme / Rang E Gear Shaft
Arbre De Marche Arriere / Reverse S Haft
Arbre De Marche / Idle Shaft
Arbre D'entrainement Avant / Front Wheel Propeller Shaft
Pignon Conique / Spiral Bevel Pinio N
Differentiel Arriere / Rear Differe Ntial
Jeu De Transmission / Transmission Kit
Bras De Changement De Gamme / Range Gear Arm
Bras De Traction Avant / Fr Ont Wheel Drive Arm
Fourchette De Blocage Diffe Rentiel / Differential Lock Shift Fork
Levier De Vittese-Changemen T / Speed Change Lever
Tige De Commande De Vitesse / Speed Change Rod
Levier De Changement De Vit Esses Principal / Main Gear Shift Lever
Levier De Tranission Aux Ro Ues Avant / Front Wheel Drive Lever
Essieu Arriere (Gauche) / Rear Axle (Left)
Essieu Arriere (Droite) / Rear Axle (Right)
Demi Arbre Arriere (Gauche) / Rear D Rive Shaft (Left)
Demi Arbre Arriere (Droite) / Rear D Rive Shaft (Right)
Suspension Arriere (Droite) / Rear S Uspension (Right)
Pedale De Verrouillage Du Differenti El / Differential Lock Pedal
Frein Avant (Gauche) / Front Brake (Left)
Frein Avant (Droite) / Front Brake (Right)
Frein Arriere (Gauche) / Rear Brake (Left)
Frein Arriere (Droite) / Rear Brake (Right)
Cylindre De Frein (Gauche) / Brake Cylinder (Left )
Cylindre De Frein (Droite) / Brake Cylinder (Righ T)
Maitre Cylindre De Frein [Parties Composantes] / Brake Master Cylinder [Component Parts]
Circuit D'huile Frein (Avant) / Brake Oil Line (F Ront)
Circuit D'huile Frein (Arriere) / Brake Oil Line (Rear)
Tige De Frein / Brake Rod
Cable De Frein De Stationnement / Parking Brake W Ire
Pedale De Frien / Brake Pedal
Levier De Relevage / Lif T Lever
Dechargee De Maillon / U Nload Link
Support Avant Droit / Hy Draulic Pump
Reservoir A Hydraulique / Hydraulic Tank
Circuit D'huile Hydrauli Que (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrauli Que (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydrauli Que (Refroidisseur) / Hydraulic Oil Line (Oil Coole R)
Circuit D'huile Hydrauli Que (Reservoir) / Hydraulic Oil Line (Tank)
Circuit D'huile Hydrauli Que (Distributeur) / Hydraulic Oil Line (Control Va Lve)
Distributeur Auxiliaire / Remote Control Valve
Controle Des Valves Aux. [Parties Composantes] / Remote Control Valve [Comp Onent Parts]
Cylindre De Relevage / L Ift Cylinder
Cylindre De Relevage [Pa Rties Composantes] / Lift Cylinder [Component Parts ]
Circuit D'huile Hydrauli Que (Cylindre De Relevage) / Hydraulic Oil Line (Li Ft Cylinder)
Chassis Transmission / Transmission Frame
Dessous Garde / Under Guard
Demi Arbre De Pont Avant / Differenti Al Gear Shaft
Differentiel Avant / Front Differenti Al
Demi Arbre Avant (Gauche) / Front Dri Ve Shaft (Left)
Demi Arbre Avant (Droite) / Front Dri Ve Shaft (Right)
Carter De Differentiel Avant (Gauche) / Front Axle Case (Left)
Carter De Differentiel Avant (Droite) / Front Axle Case (Right)
Carter Reducteur (Gauche) / Front Axl E (Left)
Essieu Avant (Droite) / Front Axle (R Ight)
Arbre De Transmission Avant / Front P Ropeller Shaft
Suspension Avant (Gauche) / Front Sus Pension (Left)
Suspension Avant (Droite) / Front Sus Pension (Right)
Suspension Avant [Parties Composantes ] / Front Suspension [Component Parts]
Bras De Suspension Avant (Gauche) / F Ront Suspension Arm (Left)
Bras De Suspension Avant (Droite) / F Ront Suspension Arm (Right)
Colonne De Direction / Steering Wheel
Cylindre De Direction / Steering Cylinder
Corps De Boite (Avant) / Box Ba Se (Front)
Corps De Boite (Arriere) / Box Base (Rear)
Plaque De Boite (Avant) / Box P Late (Front)
Plaque De Boite (Arriere) / Box Plate (Rear)
Grille De Boite / Box Gate
Capot (Superieur) / Bonnet (Upper)
Capot (Inferieur) / Bonnet (Lower)
Aile (Avant) / Fender (Front)
Aile (Arriere) / Fender (Rear)
Couvercle De Centre (Avant) / Center Cover (Front)
Couvercle De Centre (Lateral) / Center Cove R (Side)
Couvercle De Centre (Arriere) / Center Cove R (Rear)
Support De Siege (Arriere) / Seat Support ( Rear)
Siege (Avant) / Seat (Front)
Siege (Arriere) / Seat (Rear)
Ceinture De Maintien (Avant) / Seat Belt (F Ront)
Ceinture De Sécurité (Arrière) / Seat Belt (Rear)
Marchepied (Avant) / Step (Front)
Marchepied (Arriere) / Step (Rear)
Cadre Anti-Renversment (Avant) / Rops (Fron T)
Cadre Anti-Renversment (Arriere) / Rops (Re Ar)
Filet (Cadre Anti-Renversement) / Net (Rops )
Roue Avant (25*10-12) / Fr Ont Wheel (25*10-12)
Roue Avant (25*12-12) / Fr Ont Wheel (25*12-12)
Roue Arriere (25*11-12) / Rear Wheel (25*11-12)
Roue Arriere (25*10-12) / Rear Wheel (25*10-12)
Roue Arriere (25*12-12) / Rear Wheel (25*12-12)
Accessories Et Pieces De Service / Accessories An D Service Parts
Admission D'air D'haute Position (No.De M/E V44 71) [Option] / High Position Air Intake Kit (W/G No . V4471) [Option]
Alarme De Recul (No.De M/E V4232) [Option] / Ba Ckup Beeper Kit (W/G No.V4232) [Option]
Phares De Travail (Arriere) (No.De M/E V4453) [ Option] / Work Light Kit (Rear) (W/G No. V4453) [Op Tion]
Ens.Carter De Arriere Moteur [Option] / Rear Mo Tor Case Kit [Option]
Arbre De Entrainement Avec Graisseur [Option] / Front Propeller Shaft With Nipple [Option]
Ressort De Suspension Avant (No.De M/E V4219) [ Option] / Front Heavy Load Springs Kit (W/G No.V421 9) [Option]
Recouvrement De Benne (No.De M/E V4451) [Option ] / Bed Liner Kit (W/G No. V4451) [Option]
Boite De Rangement Avant (No.De M/E V4235) [Opt Ion] / Front Accessory Box Kit (W/G No.V4235) [Opti On]
Support De Gobelet (No.De M/E V4452) [Option] / Cup Holder Kit (W/G No. V4452) [Option]
Boite A Gant (No.De M/E V4234) [Option] / Glove Box Kit (W/G No.V4234) [Option]
Garde Boue Avant (No.De M/E V4236) [Option] / F Ront Mud Guard Kit (W/G No.V4236) [Option]
Protecteur (Siege Arriere) [Option] / Shield Ki T (Seat Rear) [Option]
Support De Appui Tete (No.De M/E V4443) [Option ] / Headrest Stay Kit (W/G No. V4443) [Option]
Appui Tete (No.De M/E V4231) [Option] / Headres T Kit (W/G No. V4231) [Option]
Kit De Auvent (No.De M/E V4441) [Option] / Cano Py Kit (W/G No. V4441) [Option]
Pare-Brise (No.De M/E V4442) [Option] / Polycar Bonate Windshield Kit (W/G No. V4442) [Option]
