702,019
Kubota Utility Vehicle RTV1140CPX Parts Catalog
Language: English, Japanese
Model: Kubota RTV1140CPX Utility Vehicle
Region: North America
Number of Pages: 449 Pages
Frequently Used Items Frequently Used Items
Engine Crank Case
Engine Oil Pan
Engine Cylinder Head ## S.No. =1cxz999 S.No.; =1cxz999
Engine Cylinder Head ## S.No. =1cy0001 S.No.; =1cy0001
Engine Gear Case ## S.No. =1dhz999 S.No.; =1dhz999
Engine Gear Case ## S.No. =1dj0001 S.No.; =1dj0001
Engine Head Cover
Engine Oil Filter
Engine Dipstick And Guide
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft ## S.No. =1cxz999 S.No.; =1cxz999
Engine Camshaft And Idle Gear Shaft ## S.No. =1cy0001 S.No.; =1cy0001
Engine Piston And Crankshaft ## S.No. =1cxz999 S.No.; =1cxz999
Engine Piston And Crankshaft ## S.No. =1cy0001 S.No.; =1cy0001
Engine Flywheel
Engine Fuel Camshaft And Governor Shaft
Engine Idle Apparatus
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug ## S.No. =1cxz999 S.No.; =1cxz999
Engine Nozzle Holder And Glow Plug ## S.No. =1cy0001 S.No.; =1cy0001
Engine Nozzle Holder [Component Parts] ## S.No. =1cxz999 S.No.; =1cxz999
Engine Nozzle Holder [Component Parts] ## S.No. =1cy0001 S.No.; =1cy0001
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner
Engine Inlet Pipe
Engine Muffler
Engine Muffler Cover
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Stop Solenoid
Fuel System Accelerator Pedal
Fuel System Fuel Tank
Fuel System Fuel Pipe
Fuel System Fuel Filter
Fuel System Fuel Pump (Mechanical)
Cooling Water System Water Pipe (Radiator)
Cooling Water System Water Pipe (Engine)
Cooling Water System Radiator
Cooling Water System Reserve Tank
Cooling Water System Radiator Cover
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Oil Switch And Thermometer
Electrical System Switch Sensor
Electrical System Panel Switch
Electrical System Brake Switch
Electrical System Head Light
Electrical System Tail Light ## S.No. =18960 S.No.; =18960
Electrical System Tail Light ## S.No.18961 To 31000 S.No.;18961 To 31000
Electrical System Tail Light ## S.No. =31001 S.No.; =31001
Electrical System Electrical Wiring
Transmission Front Case
Transmission Transmission Case
Transmission Transmission Case Cover
Transmission HST
Transmission HST 1 (Charge Pump) [Component Parts]
Transmission HST 2 (Piston) [Component Parts]
Transmission HST 3 (Regulator) [Component Parts]
Transmission HST 4 (Motor Shaft) [Component Parts] ## S.No. =26008 S.No.; =26008
Transmission HST 4 (Motor Shaft) [Component Parts] ## S.No. =30001 S.No.; =30001
Transmission HST 5 (Cover) [Component Parts] ## S.No. =26008 S.No.; =26008
Transmission HST 5 (Cover) [Component Parts] ## S.No. =30001 S.No.; =30001
Transmission HST 6 (Valve) [Component Parts]
Transmission Input Shaft
Transmission Propeller Shaft
Transmission Range Gear Shaft
Transmission Reverse Shaft
Transmission Idle Shaft
Transmission 4wd Shaft
Transmission Spiral Bevel Pinion
Transmission Rear Differential
Transmission Transmission Kit
Speed Change Range Gear Shift Fork
Speed Change Range Gear Arm
Speed Change Front Wheel Drive Arm
Speed Change Differential Lock Shift Fork
Speed Change Speed Change Lever
Speed Change Speed Change Rod
Speed Change Main Gear Shift Lever
Speed Change Front Wheel Drive Lever
Rear Axle Rear Axle (Left)
Rear Axle Rear Axle (Right)
Rear Axle Rear Drive Shaft (Left)
Rear Axle Rear Drive Shaft (Right)
Rear Axle Rear Suspension (Left)
Rear Axle Rear Suspension (Right)
Rear Axle Differential Lock Pedal
Brake Front Brake (Left)
Brake Front Brake (Right)
Brake Rear Brake (Left)
Brake Rear Brake (Right)
Brake Brake Cylinder (Left)
Brake Brake Cylinder (Right)
Brake Brake Master Cylinder
Brake Brake Master Cylinder [Component Parts] ## Note Order By Ref.No.140,150 New Parts And Fig
Brake Brake Oil Line (Front)
Brake Brake Oil Line (Rear)
Brake Brake Rod
Brake Parking Brake Lever
Brake Parking Brake Wire
Brake Brake Pedal
Hydraulic System Lift Lever
Hydraulic System Unload Link
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Tank
Hydraulic System Hydraulic Oil Line (Steering)
Hydraulic System Hydraulic Oil Line (HST)
Hydraulic System Hydraulic Oil Line (Oil Cooler)
Hydraulic System Hydraulic Oil Line (Tank)
Hydraulic System Hydraulic Oil Line (Control Valve)
Hydraulic System Remote Control Valve
Hydraulic System Remote Control Valve [Component Parts]
Hydraulic System Lift Cylinder
Hydraulic System Lift Cylinder [Component Parts]
Hydraulic System Hydraulic Oil Line (Lift Cylinder)
Frame Main Frame
Frame Transmission Frame
Frame Under Guard
Front Axle Front Axle Case
Front Axle Differential Gear Shaft
Front Axle Front Differential
Front Axle Front Drive Shaft (Left)
Front Axle Front Drive Shaft (Right)
Front Axle Front Axle Case (Left)
Front Axle Front Axle Case (Right)
Front Axle Front Axle (Left)
Front Axle Front Axle (Right)
Front Axle Front Propeller Shaft
Front Axle Front Suspension (Left)
Front Axle Front Suspension (Right)
Front Axle Front Suspension [Component Parts]
Front Axle Front Suspension Arm (Left)
Front Axle Front Suspension Arm (Right)
Steering Steering Handle
Steering Steering Controller
Steering Steering Cylinder
Steering Steering Cylinder [Component Parts]
Cargo Bed Box Base (Front)
Cargo Bed Box Base (Rear)
Cargo Bed Box Plate (Front)
Cargo Bed Box Plate (Rear)
Cargo Bed Box Gate
Hood Bonnet Front Guard
Hood Bonnet Front Grille
Hood Bonnet Bonnet (Upper)
Hood Bonnet Bonnet (Lower)
Hood Bonnet Panel Cover
Hood Bonnet Fender (Front)
Hood Bonnet Fender (Rear)
Hood Bonnet Center Cover
Hood Bonnet Center Cover (Side)
Hood Bonnet Center Cover (Rear)
Hood Bonnet Seat Support (Rear)
Hood Bonnet Seat (Front)
Hood Bonnet Seat (Rear)
Hood Bonnet Seat Belt (Front) ## S.No. =20356 S.No.; =20356
Hood Bonnet Seat Belt (Front) ## S.No. =20357 S.No.; =20357
Hood Bonnet Seat Belt (Rear)
Hood Bonnet Step (Front)
Hood Bonnet Step (Rear)
Hood Bonnet Rops (Front)
Hood Bonnet Rops (Rear)
Hood Bonnet Net (Rops)
Front Rear Tire Front Wheel (250-12)
Front Rear Tire Rear Wheel (250-12)
Labels Label (Front)
Labels Label (Rear)
Accessories And Service Parts Accessories And Service Parts
Option High Position Air Intake Kit (W G. No. V4471) [Option]
Option Fan Kit [Option]
Option Backup Beeper Kit (W G No.V4232) [Option]
Option Overheat Alarm Kit [Option]
Option Turn Signal Light Hazard Light Kit (W G. No. V4447) [Option]
Option Work Light Kit (Front) (W G. No. V4222a) [Option]
Option Work Light Kit (Front) (W G. No. V4222a) [Option] Work Light Kit (Front) (W G. No Work Light Kit (Front) (W G. No
Option Work Light Kit (Rear) (W G. No. V4453) [Option]
Option Rear Motor Case Kit [Option] ## S.No. =26008 S.No.; =26008
Option Front Propeller Shaft With Nipple [Option]
Option Front Heavy Load Strut Kit (W G No.V4209) [Option]
Option Ressort De Suspension Avant (No.De M E V4219) [Option]
Option Bed Liner Kit (W G. No. V4451) [Option]
Option Winch Mounting Kit (W G No.V4254) [Option]
Option Front Accessory Box Kit (W G No.V4235) [Option]
Option Cup Holder Kit (W G. No. V4452) [Option]
Option Glove Box Kit (W G No.V4234) [Option]
Option Front Mud Guard Kit (W G No.V4236) [Option]
Option Headrest Stay Kit (W G. No. V4443) [Option]
Option Headrest Kit (W G. No. V4231) [Option]
Option Tail Lamp Guards Kit (W G No.V4227) [Option]
Option Canopy Kit (W G. No. V4441) [Option]
Option Polycarbonate Windshield Kit (W G. No. V4442) [Option]
Option 5-Spoke Aluminum Alloy Wheel (W G. No. V4301) [Option]
