652
1,893,758
Kubota Utility Vehicle RTV-X900TWEU Spare Parts Catalog EN FR
Language: French, English
Model: Kubota RTV-X900TWEU Utility Vehicle
Number of Pages: 327 Pages
Frequen Tly Used Items / Frequently Used Items
Pieces De Maintenance / Maintenance Parts
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear C Ase
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camsha Ft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Crankshaf T
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateu R / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / N Ozzle Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzl E Holder [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Couvercle De Silencieux / Muffler Cover
Essieu Arbre A Cames 1 [Option] / Camshaft Ki T 1 [Option]
Essieu Arbre A Cames 2 [Option] / Camshaft Ki T 2 [Option]
Pedale D'accelerateur / Accel Erator Pedal
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtlre A Essence / Fuel Filt Er
Filtre A Carburant [Parties C Omposantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel P Ump
Tuyau De Trop-Pl Ein / Air Bleeder Hose
Ventilateur (Rad Iateur) / Fan (Radiator)
Ventilateur (Mot Eur) / Fan (Engine)
Carter De Lanceu R / Fan Cover
Tuyau D'eau (Rad Iateur) / Water Pipe (Radiator)
Tuyau D'eau (Mot Eur) / Water Pipe (Engine)
Radiateur / Radi Ator
Joint De Radiate Ur / Radiator Shield
Reservoir Du Rad Iateur / Reserve Tank
Solenoide D'arret / S Top Solenoid
Alternateur Complet / Alternator
Alternateur [Parties Composantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Interrupteur/Detecteu R / Switch/Sensor
Avertisseur/Trembleur / Horn/Buzzer
Interrupteur/Relais / Switch/Relay
Tableau De Commutateu R / Panel Switch
Frein De Commutateur / Brake Switch
Phare / Head Light
Feux De Combinaison A Vant / Front Combination Light
Feux De Combinaison A Rriere / Rear Combination Light
Lamp Et Plaque D'imma Triculation / License Lamp
Prise De Remorque / T Railer Socket
Faisceau Electrique / Electrical Wiring
Carter Avant / Front Case
Carter De Transmission / Transmis Sion Case
Reniflard De Transmission / Trans Mission Breather
Couvercle De Carter De Transmissi On / Transmission Case Cover
Reniflard Demarreur/Volant Moteur / Starter Breather/Flywheelcase Breather
Hst / Hst
Hst 1 (Carter) [Parties Composant Es] / Hst 1 (Case) [Component Parts]
Hst 2 (Pompe) [Parties Composante S] / Hst 2 (Pump) [Component Parts]
Hst 3 (Piston) [Parties Composant Es] / Hst 3 (Piston) [Component Parts]
Hst 4 (Moteur) [Parties Composant Es] / Hst 4 (Motor) [Component Parts]
Hst 5 (Regulateur) [Parties Compo Santes] / Hst 5 (Regulator) [Component Parts]
Hst 6 (Pompe De Charge) [Parties Composantes] / Hst 6 (Charge Pump) [Component Parts ]
Hst 7 (Couvercle Du Orifice Bloc) [Parties Composantes] / Hst 7 (Port Block Cover) [ Component Parts]
Hst 8 (Soupape De Orifice Bloc) [ Parties Composantes] / Hst 8 (Port Block Valve) [Co Mponent Parts]
Hst 9 (Orifice Bloc) [Parties Com Posantes] / Hst 9 (Port Block) [Component Parts]
Arbre D'entree / Input Shaft
Arbre Principal De Changement / M Ain Gear Shaft
Arbre De Changement De Gamme / Ra Nge Gear Shaft
Arbre De Marche Arriere / Reverse Shaft
Arbre De 4rm / 4wd Shaft
Pignon Conique / Spiral Bevel Pin Ion
Differentiel Arriere / Rear Diffe Rential
Engrenages De Differentiel Arrier E / Rear Differential Gear
Engrenages De Essieu Arriere (Gau Che) / Rear Axle Gear (Left)
Engrenages De Essieu Arriere (Dro Ite) / Rear Axle Gear (Right)
Bras De Changement De Gam Me / Range Gear Arm
Bras De Traction Avant / Front Wheel Drive Arm
Fourchette De Blocage Dif Ferentiel / Differential Lock Shift Fork
Bras Controle Des Valve / Control Valve Arm
Levier De Vittese-Changem Ent / Shift Lever
Tige De Commande De Vitte Sse / Speed Control Rod
Cable De Vittese-Changeme Nt / Speed Change Cable
Levier De Changement De V Itesses Principal / Main Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Essieu Arriere (Gauche) / Rear Axl E (Left)
Essieu Arriere (Droite) / Rear Axl E (Right)
Demi Arbre Arriere (Gauche) / Rear Drive Shaft (Left)
Demi Arbre Arriere (Droite) / Rear Drive Shaft (Right)
Demi Arbre Arriere [Parties Compos Antes] / Rear Drive Shaft [Component Parts]
Suspension Arriere (Gauche) / Rear Suspension (Left)
Suspension Arriere (Droite) / Rear Suspension (Right)
Suspension Arriere [Parties Compos Antes] / Rear Suspension [Component Parts]
Bras De Suspension Arriere (Superi Eur G.) / Rear Suspension Arm (Left Upper)
Bras De Suspension Arriere (Inferi Eur G.) / Rear Suspension Arm (Left Lower)
Bras De Suspension Arriere (Superi Eur D.) / Rear Suspension Arm (Right Upper)
Bras De Suspension Arriere (Inferi Eur D.) / Rear Suspension Arm (Right Lower)
Stabilisation Arriere / Rear Stabi Lizer
Pedale De Verrouillage Du Differen Tiel / Differential Lock Pedal
Frein Avant (Gauche) / Front Brake (Left)
Frein Avant (Droite) / Front Brake (Right)
Frein Arriere (Gauche) / Rear Brake (Left)
Frein Arriere (Droite) / Rear Brake (Right)
Cylindre De Frein / Brake Cylinder
Cylindre De Frein [Parties Composantes] / Brake Cylinder [Component Parts]
Maitre Cylindre De Frein / Brake Master Cylinde R
Maitre Cylindre De Frein [Parties Composantes] / Brake Master Cylinder [Component Parts]
Circuit D'huile Frein (Avant) / Brake Oil Line (Front)
Circuit D'huile Frein (Arriere) / Brake Oil Lin E (Rear)
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Brak E Lever
Cable De Frein De Stationnement / Parking Brake Wire
Pedale De Frien / Brake Pedal
Levier De Relevage / L Ift Lever
Dechargee De Maillon / Unload Link
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Reservoir A Hydrauliqu E / Hydraulic Tank
Refroidissement / Oil Cooler
Circuit D'huile Hydrau Lique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrau Lique (Pompe) / Hydraulic Oil Line (Pump)
Circuit D'huile Hydrau Lique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydrau Lique (Refroidissement) / Hydraulic Oil Line (Oil C Ooler)
Circuit D'huile Hydrau Lique (Reservoir) / Hydraulic Oil Line (Tank)
Conduite D'huile Hydra Ulique (Vanne De Commande) / Hydraulic Oil Line (Co Ntrol Valve)
Distributeur Hydrauliq Ue / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Soupape De Surete / Re Lief Valve
Circuit D'huile Hydrau Lique (Cylindre De Relevage) / Hydraulic Oil Line ( Lift Cylinder)
Chassis Transmission / Transmission Frame
Dessous Garde / Under Guard
Console De Moteur / Engine Bracket
Support De Transmission / Transmission Bracke T
Demi Arbre De Pont Avant / Differen Tial Gear Shaft
Differentiel Avant / Front Differen Tial
Demi Arbre Avant (Gauche) / Front D Rive Shaft (Left)
Demi Arbre Avant (Droite) / Front D Rive Shaft (Right)
Demi Arbre Avant [Parties Composant Es] / Front Drive Shaft [Component Parts]
Carter De Differentiel Avant (Gauch E) / Front Axle Case (Left)
Carter De Differentiel Avant (Droit E) / Front Axle Case (Right)
Tuyau Reniflard / Breather Pipe
Essieu Avant (Gauche) / Front Axle (Left)
Essieu Avant (Droite) / Front Axle (Right)
Arbre D'entrainement Avant / Front Wheel Propeller Shaft
Arbre D'entrainement Avant [Parties Composantes] / Front Wheel Propeller Shaft [Compon Ent Parts]
Suspension Avant (Gauche) / Front S Uspension (Left)
Suspension Avant (Droite) / Front S Uspension (Right)
Suspension Avant [Parties Composant Es] / Front Suspension [Component Parts]
Bras De Suspension Avant (Inferieur G.) / Front Suspension Arm (Left Lower)
Bras De Suspension Avant (Supérieur D.) / Front Suspension Arm (Right Upper)
Bras De Suspension Avant (Inferieur D.) / Front Suspension Arm (Right Lower)
Stabilisation Avant / Front Stabili Zer
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direct Ion / Steering Cylinder
Cylindre De Direction [Parties Composant Es] / Steering Cylinder [Component Parts]
Corps De Boite / Box Base
Plaque De Boite / Box Plate
Grille De Boite / Box Gate
Couverture De Boite / Box Cov Er
Pare-Choc Avant / Front Bumper
Capot Superieur / Hood (Bonnet)
Couvercle Lateral / Side Cover
Boite A Gant / Glove Box
Couverle De Panneau Sous / Panel Under Co Ver
Aile (Avant) / Fender (Front)
Aile (Arriere) / Fender (Rear)
Couvercle De Centre (Lateral) / Center Co Ver (Side)
Couvercle De Centre (Arriere) / Center Co Ver (Rear)
Support De Siege (Opération) / Seat Suppo Rt (Operation)
Support De Siege (Passager) / Seat Suppor T (Passenger)
Siege / Seat
Marchepied / Step
Plaque D'isolation / Insulation Plate
Retroviseur / Rearview Mirror
Cadre Anti-Renversment / Rops
Attelage / Front Hitch
Barre D'attelage / Drawbar
Roue Avant (25*10-12) / Front Wheel (25*10-12)
Roue Arriere (25*10-12) / Rear Wheel (25*10-12)
Etiquettes (Panneau) / Label (Panel)
Jauge Huile (No.De M/E V5202) [Option] / Oil Gauge Kit (W/G No.V5202) [Option]
Alarme De Recul (No.De M/E V5236) [Option] / Backup Beeper Kit (W/G No.V5236) [Option]
Phares De Travail (Avant) (Sans Toit) (No.De M/E V5222) [Option] / Work Light Kit (Front) (Witho Ut Roof) (W/G No.V5222) [Option]
Phares De Travail (Avant) (Avec Toit) (No.De M/E V5222) [Option] / Work Light Kit (Front) (With Roof) (W/G No.V5222) [Option]
Phares De Travail (Arriere) (No.De M/E V5223) [Option] / Work Light Kit (Rear) (W/G No.V5223) [O Ption]
Kit D'accouplements Rapides [Option] / Traile R Socket Kit [Option]
Papillon A Main (No.De M/E V5241) [Option] / Hand Throttle Kit (W/G No.V5241) [Option]
Support De Suspension Avant (No.De M/E V5219) [Option] / Front Heavy Load Strut Kit (W/G No.V521 9) [Option]
Ressort De Suspension Avant (No.De M/E V5218) [Option] / Front Heavy Load Springs Kit (W/G No.V5 218) [Option]
Avant Garde Cv-J (No.De M/E V5238) [Option] / Front Cv-J Guard Kit (W/G No.V5238) [Option]
Arrière Garde Cv-J (No.De M/E V5239) [Option] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hydraulique De Sortie Coupleur (No.De M/E V52 76) [Option] / Hydraulic Outlet Coupler Kit (W/G No .V5276) [Option]
Double Pompe Hydraulique (Pompe) (No.De M/E V 5271) [Option] / Double Hyd. Pump Kit (Pump) (W/G.N O.V5271) [Option]
Double Pompe Hydraulique (Circuit D'huile) (N O.De M/E V5271) [Option] / Double Hyd. Pump Kit (Oi L Line) (W/G.No.V5271) [Option]
Simple Soupape Hydraulique (Levier) (No.De M/ E V5273) [Option] / Hyd.Single Valve Kit (Lever) (W /G No.V5273) [Option]
Simple Soupape Hydraulique (Arbre) (No.De M/E V5273) [Option] / Hyd.Single Valve Kit (Shaft) (W/ G No.V5273) [Option]
Simple Soupape Hydraulique (Soupape) (No.De M /E V5273) [Option] / Hyd.Single Valve Kit (Valve) ( W/G No.V5273) [Option]
Simple Soupape Hydraulique [Parties Comp.] (N O.De M/E V5273) [Option] / Hyd.Single Valve [Comp.P Arts] (W/G No.V5273) [Option]
Simple Soupape Hydraulique (Circuit D'huile) (No.De M/E V5273) [Option] / Hyd.Single Valve Kit ( Oil Line) (W/G No.V5273) [Option]
Double Soupape Hydraulique (Levier) (No.De M/ E V5274) [Option] / Hyd.Double Valve Kit (Lever) (W /G No.V5274) [Option]
Double Soupape Hydraulique (Arbre) (No.De M/E V5274) [Option] / Hyd.Double Valve Kit (Shaft) (W/ G No.V5274) [Option]
Double Soupape Hydraulique (Soupape) (No.De M /E V5274) [Option] / Hyd.Double Valve Kit (Valve) ( W/G No.V5274) [Option]
Double Soupape Hydraulique [Parties Comp.] (N O.De M/E V5274) [Option] / Hyd.Double Valve [Comp.P Arts] (W/G No.V5274) [Option]
Double Soupape Hydraulique (Circuit D'huile) 1 (No.De M/E V5274) [Option] / Hyd.Double Valve Kit (Oil Line) 1 (W/G No.V5274) [Option]
Double Soupape Hydraulique (Circuit D'huile) 2 (No.De M/E V5274) [Option] / Hyd.Double Valve Kit (Oil Line) 2 (W/G No.V5274) [Option]
Barre D'attelage Arriere [Option] / Drawbar K It Rear [Option]
Garde Boue Avant (No.De M/E V5225) [Option] / Front Mud Guard Kit (W/G No.V5225) [Option]
Garde Boue Arriere (No.De M/E V5226) [Option] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Support De Appui Tete (No.De M/E V5230) [Opti On] / Headrest Stay Kit (W/G No.V5230) [Option]
Appui Tete (No.De M/E V4231xt) [Option] / Hea Drest Kit (W/G No.V4231xt) [Option]
Feux Stroboscopique (No.De M/E V5227) [Option ] / Tail Lamp Guards Kit (W/G No.V5227) [Option]
Kit De Auvent (No.De M/E V5221) [Option] / Ca Nopy Kit (W/G No.V5221) [Option]
Roue De Alloy D'aluminium [Option] / Aluminum Alloy Wheel Kit [Option]
Materiel Alloy Wheel (No.De M/E V5205) [Optio N] / Alloy Wheel Hardware Kit (W/G No.V5205) [Optio N]
Kit Articulation Arrière [Option] / Rear Knuc Kle Kit [Option]
