Kubota Utility Vehicle RTV-X900TWEU MC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV-X900TWEU MC Utility Vehicle
Number of Pages: 300 Pages
Itens Uso Freq Uente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaf T And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Gl Ow Plug
Suporte Bico [Peças Componentes] / Nozzle H Older [Component Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Cambota Kit 1 [Opção] / Camshaft Kit 1 [Opt Ion]
Cambota Kit 2 [Opção] / Camshaft Kit 2 [Opt Ion]
Acelarador Pedal / Ac Celerator Pedal
Tubo Combustivel / Fu El Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Man Gueira Do Purgador De Ar / Air Bleeder Hose
Ven Toinha (Radiador) / Fan (Radiator)
Ven Toinha (Motor) / Fan (Engine)
Res Guardo Ventoinha / Fan Cover
Tub O Agua (Radiador) / Water Pipe (Radiator)
Tub O Agua (Motor) / Water Pipe (Engine)
Rad Iador / Radiator
Rad Iador Protecção / Radiator Shield
Dep Osito Reserva / Reserve Tank
Alternador / Alterna Tor
Alternador [Peças Co Mponentes] / Alternator [Component Parts]
Motor Arranque / Sta Rter
Motor Arranque [Peça S Componentes] / Starter [Component Parts]
Interruptor E Termóm Etro / Oil Switch And Thermometer
Interruptor/Sensor / Switch/Sensor
Buzina/Sirene / Horn /Buzzer
Interruptor / Rele / Switch/Relay
Tampa Interruptor / Panel Switch
Interruptor Travao / Brake Switch
Luzes Frente / Head Light
Luzes Frontais / Fro Nt Combination Light
Braco Traseiro / Rea R Combination Light
Farol Matricula / Li Cense Lamp
Ficha Reboque / Trai Ler Socket
Cablagem Electrica / Electrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmissio N Case
Respiro Transmissão / Transmiss Ion Breather
Tampa Transmissão / Transmissio N Case Cover
Hst / Hst
Hst 1 (Carter) [Peças Component Es] / Hst 1 (Case) [Component Parts]
Hst 2 (Bomba) [Peças Componente S] / Hst 2 (Pump) [Component Parts]
Hst 3 (Pistão) [Peças Component Es] / Hst 3 (Piston) [Component Parts]
Hst 4 (Motor) [Peças Componente S] / Hst 4 (Motor) [Component Parts]
Hst 5 (Regulador) [Peças Compon Entes] / Hst 5 (Regulator) [Component Parts]
Hst 7 (Tampa Do Bloco De Abertu Ra) [Peças Componentes] / Hst 7 (Port Block Cover) [Component Parts]
Hst 8 (Válvula Do Bloco De Aber Tura) [Peças Componentes] / Hst 8 (Port Block Valve ) [Component Parts]
Hst 9 (Bloco De Abertura) [Peça S Componentes] / Hst 9 (Port Block) [Component Part S]
Veio Primario / Input Shaft
Engrenagem Principal / Main Gea R Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio De 4wd / 4wd Shaft
Pinhao Espiral / Spiral Bevel P Inion
Diferencial Traseiro / Rear Dif Ferential
Engrenagem Diferencial Traseira / Rear Differential Gear
Engrenagem Do Eixo Traseiro (Es Querdo) / Rear Axle Gear (Left)
Engrenagem Do Eixo Traseiro (Di Reito) / Rear Axle Gear (Right)
Forqueta Velocidades / Range Gear Shift Fork
Braço Carreto Gamas / Range Gear Arm
Braco Roda Frente / F Ront Wheel Drive Arm
Bloqueio Diferencial Forqueta / Differential Lock Shift Fork
Braço Da Válvula De C Ontrolo / Control Valve Arm
Caixa Velocidades / S Hift Lever
Tirante De Mudança De Velocidade / Speed Control Rod
Cabo De Mudança De Ve Locidade / Speed Change Cable
Alavanca Velocidades / Main Gear Shift Lever
Alavanca Dupla Tracca O / Front Wheel Drive Lever
Eixo Traseiro (Esq) / Rear Axle (Left)
Eixo Traseiro (Drt) / Rear Axle (Right)
Veio De Transmissão Traseiro (Es Q) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro (Dr T) / Rear Drive Shaft (Right)
Veio De Transmissão Traseiro [Pe Ças Componentes] / Rear Drive Shaft [Component Part S]
Suspensão Traseiro (Esq) / Rear Suspension (Left)
Suspensão Traseiro (Drt) / Rear Suspension (Right)
Suspensão Traseiro [Peças Compon Entes] / Rear Suspension [Component Parts]
Braço Da Suspensão Traseira (Sup Erior Esquerdo) / Rear Suspension Arm (Left Upper)
Braço Da Suspensão Traseira (Inf Erior Esquerdo) / Rear Suspension Arm (Left Lower)
Braço Da Suspensão Traseira (Sup Erior Direito) / Rear Suspension Arm (Right Upper)
Braço Da Suspensão Traseira (Inf Erior Direito) / Rear Suspension Arm (Right Lower)
Estabilizador Traseiro / Rear St Abilizer
Pedal Bloqueio Diferencial / Dif Ferential Lock Pedal
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao / Brake Cylinder
Cilindro Do Travão [Peças Componentes] / Br Ake Cylinder [Component Parts]
Cilnidro Principal Travao [Peças Componente S] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frontal) / Brake Oil Lin E (Front)
Tubo Oleo Travoes (Traseiro) / Brake Oil Li Ne (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Levante A Alavanca / Lift Lever
Elo De Descarregamen To / Unload Link
Bomba Hidraulico / H Ydraulic Pump
Bomba Hidraulico [Pe Ças Componentes] / Hydraulic Pump [Component Parts]
Deposito Oleo Hidrau Lico / Hydraulic Tank
Radiador Oleo / Oil Cooler
Linha De Óleo Hidráu Lico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráu Lico (Bomba) / Hydraulic Oil Line (Pump)
Linha De Óleo Hidráu Lico (Hst) / Hydraulic Oil Line (Hst)
Linha De Óleo Hidráu Lico (Deposito) / Hydraulic Oil Line (Tank)
Linha De Óleo Hidráu Lico (Válvula De Controlo) / Hydraulic Oil Line (Co Ntrol Valve)
Valvula Control / Co Ntrol Valve
Valvula Control [Peç As Componentes] / Control Valve [Component Parts]
Valvula Descarga / R Elief Valve
Cilndro Eleveção / L Ift Cylinder
Linha De Óleo Hidráu Lico (Cilindro Esquerdo) / Hydraulic Oil Line (Lift Cylinder)
Estrutura Transmissão / Transmission Fra Me
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Suporte Da Transmissão / Transmission Br Acket
Carter Eixo Frente / Front Axl E Case
Grupo Conico / Differential Ge Ar Shaft
Diferencial Dianteiro / Front Differential
Veio De Transmissão Dianteiro (Esq) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Drt) / Front Drive Shaft (Right)
Veio De Transmissão Dianteiro [Peças Componentes] / Front Drive Shaft [Component Parts]
Carter Eixo Frente (Esq) / Fro Nt Axle Case (Left)
Carter Eixo Frente (Drt) / Fro Nt Axle Case (Right)
Tubo Do Respiradouro / Breathe R Pipe
Eixo Dianteiro (Esq) / Front A Xle (Left)
Eixo Dianteiro (Drt) / Front A Xle (Right)
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Veio Tracao Dianteira [Peças C Omponentes] / Front Wheel Propeller Shaft [Componen T Parts]
Suspensao Frontal (Esq) / Fron T Suspension (Left)
Suspensao Frontal (Drt) / Fron T Suspension (Right)
Suspensao Frontal [Peças Compo Nentes] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira ( Superior Esquerdo) / Front Suspension Arm (Left Upp Er)
Braço Da Suspensão Dianteira ( Inferior Esquerdo) / Front Suspension Arm (Left Low Er)
Braço Da Suspensão Dianteira ( Superior Direito) / Front Suspension Arm (Right Upp Er)
Braço Da Suspensão Dianteira ( Inferior Direito) / Front Suspension Arm (Right Low Er)
Estabilizador Dianteiro / Fron T Stabilizer
Alavanca Inclinacao / Tilt Lever
Direcção Controlador / Steering Contro Ller
Tirante / Tie Rod
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Caixa Base / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Proteccao Frontal / Front Guard
Grelha Frontal / Front Grille
Pára-Choques Dianteiro / Front Bumper
Capot / Hood (Bonnet)
Painel Lateral / Side Cover
Tampa Painel / Panel Cover
Estrutura Do Painel / Panel Under Cove R
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear )
Cobertura Central (Lado) / Center Cove R (Side)
Cobertura Central (Traseira) / Center Cover (Rear)
Suporte Do Assento (Operação) / Seat S Upport (Operation)
Suporte Assento (Passageiro) / Seat Su Pport (Passenger)
Banco / Seat
Cinto Segurança / Seat Belt
Degrau / Step
Placa De Isolamento / Insulation Plate
Barra Reboque / Drawbar
Roda Frente (25*10- 12) / Front Wheel (25*10-12)
Roda Traseira (25*1 0-12) / Rear Wheel (25*10-12)
Etiqueta (Frente) [Ingles] / Label (Fro Nt) [English]
Etiqueta (Frente) [Frances] [Alemanha] / Label (Front) [French] [German]
Etiqueta (Painel) [Ingles] / Label (Pan El) [English]
Etiqueta (Painel) [Frances] [Alemanha] / Label (Panel) [French] [German]
Etiqueta (Traseira) [Ingles] / Label (R Ear) [English]
Etiqueta (Traseira) [Frances] [Alemanha ] / Label (Rear) [French] [German]
Acessorios E Peças Serviço / Accessories And Servi Ce Parts
Vareta Nivel Oleo (W/G V5202) [Opção] / Oil Gauge Kit (W/G No.V5202) [Option]
Kit Sonoro Mancha Atras (W/G V5236) [Opção] / Backup Beeper Kit (W/G No.V5236) [Option]
Kit Acelarador Mao (W/G V5241) [Opção] / Ha Nd Throttle Kit (W/G No.V5241) [Option]
Kit Estrutura Elevacao Frontal (W/G V5219) [Opção] / Front Heavy Load Strut Kit (W/G No.V5219) [Option]
Kit Estrutura Elevação (W/G V5218) [Opção] / Front Heavy Load Springs Kit (W/G No.V5218) [Opti On]
Kit Guarda Cv-J Frontal (W/G V5238) [Opção] / Front Cv-J Guard Kit (W/G No.V5238) [Option]
Kit Guarda Cv-J Traseira (W/G V5239) [Opção ] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hidráulico Tomada Acoplamento Kit (W/G V527 6) [Opção] / Hydraulic Outlet Coupler Kit (W/G No.V 5276) [Option]
Duplo Bomba Hidraulico Kit (Bomba) (W/G V52 71) [Opção] / Double Hyd. Pump Kit (Pump) (W/G.No.V 5271) [Option]
Bomba Hidraulico [Peças Componentes] (W/G V 5271) [Opção] / Hydraulic Pump [Comp.Parts] (W/G No .V5271) [Option]
Duplo Bomba Hidraulico Kit (Tubo) (W/G V527 1) [Opção] / Double Hyd. Pump Kit (Oil Line) (W/G.N O.V5271) [Option]
Unico Válvula De Hidraulico Kit (Veio) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Shaft) (W/G .No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Válvula) ( W/G V5273) [Opção] / Hyd.Single Valve Kit (Valve) ( W/G.No.V5273) [Option]
Unico Válvula De Hidraulico [Peças Componen Tes] (W/G V5273) [Opção] / Hyd.Single Valve [Comp.Parts] (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Tubo) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Oil Line) ( W/G.No.V5273) [Option]
Duplo Válvula De Hidraulico Kit (Alavanca) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Lever) (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Veio) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Shaft) (W/G .No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Válvula) ( W/G V5274) [Opção] / Hyd.Double Valve Kit (Valve) ( W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico [Peças Componen Tes] (W/G V5274) [Opção] / Hyd.Double Valve [Comp.Parts] (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 1 (W /G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line) 1 (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 2 (W /G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line) 2 (W/G.No.V5274) [Option]
Kit Camisa (W/G V5229) [Opção] / Bed Liner Kit (W/G. No.V5229) [Option]
Kit Guarda Lamas Frontais (W/G V5225) [Opçã O] / Front Mud Guard Kit (W/G No.V5225) [Option]
Kit Guarda Lamas Traseira (W/G V5226) [Opçã O] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Kitproteccaoluzes (W/G V5227) [Opção] / Tai L Lamp Guards Kit (W/G No.V5227) [Option]
Kit De Roda De Aluminio [Opção] / Aluminum Alloy Wheel Kit [Option]
Kit De Roda De Aluminio (W/G Artv5213) [Opç Ão] / Aluminum Alloy Wheel Kit (W/G No.Artv5213) [O Ption]
Aluminum Kit Parafuso Da Roda (W/G V5205) [ Opção] / Alloy Wheel Hardware Kit (W/G No.V5205) [O Ption]
Kit De Junta Traseira [Opção] / Rear Knuckl E Kit [Option]
