Kubota Utility Vehicle RTV-X900N5TWEU MR Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV-X900N5TWEU MR Utility Vehicle
Number of Pages: 283 Pages
Iten S Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel / Dipstick
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsh Aft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Plat E
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rocke R Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Cambota,Kit 1 [Opção] / Camshaft Kit 1 [O Ption]
Cambota,Kit 2 [Opção] / Camshaft Kit 2 [O Ption]
Deposito Combustive L / Fuel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fu El Filter
Filtro Gasoleo [Peç As Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fue L Pump
M Angueira Do Purgador De Ar / Air Bleeder Hose
V Entoinha (Radiador) / Fan (Radiator)
V Entoinha (Motor) / Fan (Engine)
R Esguardo Ventoinha / Fan Cover
T Ubo Agua (Radiador) / Water Pipe (Radiator)
T Ubo Agua (Motor) / Water Pipe (Engine)
R Adiador / Radiator
R Esguardo Do Radiador / Radiator Shield
D Eposito Reserva / Reserve Tank
Alternador / Alter Nator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / S Tarter
Motor Arranque [Pe Ças Componentes] / Starter [Component Parts]
Interruptor E Term Ómetro / Oil Switch And Thermometer
Interruptor/Sensor / Switch/Sensor
Buzina/Sirene / Ho Rn/Buzzer
Interruptor / Rele / Switch / Relay
Painel Interruptor / Panel Switch
Interruptor Travao / Brake Switch
Luzes Frente / Hea D Light
Luzes Frontais / F Ront Combination Lamp
Braco Traseiro / R Ear Combination Lamp
Ficha Reboque / Tr Ailer Socket
Cablagem Electrica / Electrical Wiring
Carter Frontal / Front Case
Caixa Da Transmissão / Transm Ission Case
Respiro Transmissão / Transmi Ssion Breather
Respirador Do Motor De Arranq Ue/Respirador Do Volante Motor / Starter Breather/F Lywheelcase Breather
Hst / Hst
Hst 1 (Carter) [Peças Compone Ntes] / Hst 1 (Case) [Component Parts]
Hst 3 (Pistão) [Peças Compone Ntes] / Hst 3 (Piston) [Component Parts]
Hst 4 (Motor) [Peças Componen Tes] / Hst 4 (Motor) [Component Parts]
Hst 5 (Regulador) [Peças Comp Onentes] / Hst 5 (Regulator) [Component Parts]
Hst 6 (Carga Bomba) [Peças Co Mponentes] / Hst 6 (Charge Pump) [Component Parts]
Hst 7 (Tampa Do Bloco De Aber Tura) [Peças Componentes] / Hst 7 (Port Block Cover ) [Component Parts]
Hst 8 (Válvula Do Bloco De Ab Ertura) [Peças Componentes] / Hst 8 (Port Block Val Ve) [Component Parts]
Hst 9 (Bloco De Abertura) [Pe Ças Componentes] / Hst 9 (Port Block) [Component Pa Rts]
Veio Primario / Input Shaft
Engrenagem Principal / Main G Ear Shaft
Veio Gamas Velocidades / Rang E Gear Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio De 4wd / 4wd Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear D Ifferential
Engrenagem Diferencial Trasei Ra / Rear Differential Gear
Engrenagem Do Eixo Traseiro ( Esquerdo) / Rear Axle Gear (Left)
Engrenagem Do Eixo Traseiro ( Direito) / Rear Axle Gear (Right)
Forqueta Velocidade S / Range Gear Shift Fork
Braço Carreto Gamas / Range Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Bloqueio Diferencia L De Forqueta / Differential Lock Shift Fork
Braço Da Válvula De Controlo / Control Valve Arm
Caixa Velocidades / Speed Change Lever
Caixa Velocidades / Speed Change Rod
Alavanca Velocidade S / Main Gear Shift Lever
Alavanca Dupla Trac Cao / Front Wheel Drive Lever
Eixo Traseiro (Esq) / Rear Axl E (Left)
Eixo Traseiro (Drt) / Rear Axl E (Right)
Veio De Transmissão Traseiro ( Esquerdo) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro ( Direito) / Rear Drive Shaft (Right)
Veio De Transmissão Traseiro [ Peças Componentes] / Rear Drive Shaft [Component Pa Rts]
Suspensão Traseiro (Esq) / Rea R Suspension (Left)
Suspensão Traseiro (Drt) / Rea R Suspension (Right)
Braço Da Suspensão Traseira (S Uperior Esquerdo) / Rear Suspension Arm (Left Upper )
Braço Da Suspensão Traseira (S Uperior Direito) / Rear Suspension Arm (Right Upper )
Braço Da Suspensão Traseira (I Nferior Direito) / Rear Suspension Arm (Right Lower )
Bloqueio Diferencial Pedal / D Ifferential Lock Pedal
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right )
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right )
Cilindro Do Travão [Peças Componentes] / Brake Cylinder [Component Parts]
Cilindro Travao Principal [Peças Componen Tes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Li Ne (Front)
Tubo Oleo Travoes (Traseira) / Brake Oil Line (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Le Ver
Elo De Descarregam Ento / Unload Link
Bomba Hidraulico [ Peças Componentes] / Hydraulic Pump [Component Part S]
Deposito Oleo Hidr Aulico / Hydraulic Tank
Radiador Oleo / Oi L Cooler
Circuito Oleo (Dir Ecção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidr Áulico (Bomba) / Hydraulic Oil Line (Pump)
Tubo Oleo (Hst) / Hydraulic Oil Line (Hst)
Tubo Oleo (Radiad Or Oleo) / Hydraulic Oil Line (Oil Cooler)
Tubo Oleo (Deposit O) / Hydraulic Oil Line (Tank)
Linha De Óleo Hidr Áulico (Válvula De Controlo) / Hydraulic Oil Line ( Control Valve)
Valvula Control [P Eças Componentes] / Control Valve [Component Parts]
Valvula Descarga / Relief Valve
Linha De Óleo Hidr Áulico (Cilindro Esquerdo) / Hydraulic Oil Line (Li Ft Cylinder)
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Suporte Da Transmissão / Transmission Bracket
Carter Eixo Frente / Front A Xle Case
Grupo Conico / Bevel Gear
Diferencial Dianteiro / Fron T Differential
Veio De Transmissão Dianteir O (Esquerdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteir O (Direito) / Front Drive Shaft (Right)
Veio De Accionamento Diantei Ro [Peças Componentes] / Front Drive Shaft [Compone Nt Parts]
Carter Eixo Frente (Esq) / F Ront Axle Case (Left)
Carter Eixo Frente (Drt) / F Ront Axle Case (Right)
Tubo Do Respiradouro / Breat Her Pipe
Eixo Dianteiro (Esq) / Front Axle (Left)
Eixo Dianteiro (Drt) / Front Axle (Right)
Veio Tracao Dianteira / Fron T Wheel Propeller Shaft
Veio Cardan Da Roda Dianteir A [Peças Componentes] / Front Wheel Propeller Shaft [Component Parts]
Suspensao Frontal (Esq) / Fr Ont Suspension (Left)
Suspensão Frontal [Peças Com Ponentes] / Front Suspension [Component Parts]
Braço Da Suspensão Frontal ( Superior Esquerdo) / Front Suspension Arm (Left Upp Er)
Braço Da Suspensão Frontal ( Inferior Esquerdo) / Front Suspension Arm (Left Low Er)
Braço Da Suspensão Frontal ( Superior Direito) / Front Suspension Arm (Right Upp Er)
Braço Da Suspensão Frontal ( Inferior Direito) / Front Suspension Arm (Right Low Er)
Estabilizador Dianteiro / Fr Ont Stabilizer
Coluna Direcção / Column,Steering
Alavanca / Tilt Lever
Direcção / Steering
Direcção Assistida / Tie Rod
Cilindro Direcção / Steering Cylinde R
Cilindro Direcção [Peças Componentes ] / Steering Cylinder [Component Parts]
Caixa / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Distribuidor Auxiliar / Front Guard
Grelha Frontal / Front Grille
Pára-Choques Dianteiro / Front Bumpe R
Painel Lateral / Side Cover
Porta-Luvas / Glove Box
Tampa Painel / Panel Cover
Painel Estrutura / Panel Frame
Guarda Lamas (Frente) / Fender (Fron T)
Guarda Lamas (Traseira) / Fender (Re Ar)
Cobertura Central (Lado) / Center Co Ver (Side)
Cobertura Central (Traseira) / Cente R Cover (Rear)
Suporte Do Assento (Operação) / Seat Support (Operation)
Suporte Assento (Passageiro) / Seat Support (Passenger)
Banco / Seat
Cinto Segurança / Seat Belt
Degrau / Step
Placa De Isolamento / Insulation Pla Te
Puxo Dianteiro / Front Hitch
Barra Reboque / Drawbar
Roda Frente (25*1 0-12) / Front Wheel (25*10-12)
Etiqueta (Frente) [Ingles] / Label (F Ront) [English]
Etiqueta (Frente) [Frances] [Alemanha ] / Label (Front) [French] [German]
Etiqueta (Painel) [Ingles] / Label (P Anel) [English]
Etiqueta (Painel) [Frances] [Alemanha ] / Label (Panel) [French] [German]
Etiqueta (Traseira) [Frances] [Aleman Ha] / Label (Rear) [French] [German]
Acessorios E Peças Serviço / Accessories And Ser Vice Parts
Vareta Nivel Oleo (W/G V5202) [Opção] / O Il Gauge Kit (W/G No.V5202) [Option]
Kit Sonoro Mancha Atras (W/G V5236) [Opçã O] / Backup Beeper Kit (W/G No.V5236) [Option]
Kit Acelarador Mao (W/G V5241) [Opção] / Hand Throttle Kit (W/G No.V5241) [Option]
Kit Estrutura Elevacao Frontal (W/G V5219 ) [Opção] / Front Heavy Load Strut Kit (W/G No.V521 9) [Option]
Kit Estrutura Elevação (W/G V5218) [Opção ] / Front Heavy Load Springs Kit (W/G No.V5218) [Op Tion]
Kit Guarda Cv-J Frontal (W/G V5238) [Opçã O] / Front Cv-J Guard Kit (W/G No.V5238) [Option]
Kit Guarda Cv-J Traseira (W/G V5239) [Opç Ão] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hidráulico Tomada Acoplamento Kit (W/G V5 276) [Opção] / Hydraulic Outlet Coupler Kit (W/G No .V5276) [Option]
Duplo Bomba Hidraulico Kit (Bomba) (W/G V 5271) [Opção] / Double Hyd. Pump Kit (Pump) (W/G.No .V5271) [Option]
Bomba Hidraulico [Peças Componentes] (W/G V5271) [Opção] / Hydraulic Pump [Comp.Parts] (W/G No.V5271) [Option]
Duplo Bomba Hidraulico Kit (Tubo) (W/G V5 271) [Opção] / Double Hyd. Pump Kit (Oil Line) (W/G .No.V5271) [Option]
Unico Válvula De Hidraulico Kit (Alavanca ) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Lever ) (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Veio) (W /G V5273) [Opção] / Hyd.Single Valve Kit (Shaft) (W /G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Válvula) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Valve) (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico [Peças Compon Entes] (W/G V5273) [Opção] / Hyd.Single Valve [Comp .Parts] (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Tubo) (W /G V5273) [Opção] / Hyd.Single Valve Kit (Oil Line) (W/G.No.V5273) [Option]
Duplo Válvula De Hidraulico Kit (Alavanca ) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Lever ) (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Veio) (W /G V5274) [Opção] / Hyd.Double Valve Kit (Shaft) (W /G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Válvula) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Valve) (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico [Peças Compon Entes] (W/G V5274) [Opção] / Hyd.Double Valve [Comp .Parts] (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 1 (W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Lin E) 1 (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 2 (W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Lin E) 2 (W/G.No.V5274) [Option]
Kit Camisa (W/G V5229) [Opção] / Bed Line R Kit (W/G. No.V5229) [Option]
Kit Guarda Lamas Frontais (W/G V5225) [Op Ção] / Front Mud Guard Kit (W/G No.V5225) [Option]
Kit Guarda Lamas Traseira (W/G V5226) [Op Ção] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Kitproteccaoluzes (W/G V5227) [Opção] / T Ail Lamp Guards Kit (W/G No.V5227) [Option]
Kit De Roda De Aluminio [Opção] / Aluminu M Alloy Wheel Kit [Option]
Kit De Roda De Aluminio (W/G Artv5213) [O Pção] / Aluminum Alloy Wheel Kit (W/G No.Artv5213) [Option]
Aluminum Kit Parafuso Da Roda (W/G V5205) [Opção] / Alloy Wheel Hardware Kit (W/G No.V5205) [Option]
Carreto / Gear Case
Escpae / Muffler
Hst / Hst
Direcção / Steering
Caixa / Box Base
Banco / Seat
Degrau / Step
