Kubota Utility Vehicle RTV-X900MREU Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV-X900MREU Utility Vehicle
Number of Pages: 294 Pages
Itens Uso Frequen Te / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft A Nd Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Cambota,Kit 1 [Opção] / Camshaft Kit 1 [Option ]
Cambota,Kit 2 [Opção] / Camshaft Kit 2 [Option ]
Acelarador Pedal / Accel Erator Pedal
Deposito Combustivel / F Uel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Fi Lter
Filtro Gasoleo [Peças Co Mponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pum P
Mangue Ira Do Purgador De Ar / Air Bleeder Hose
Ventoi Nha (Radiador) / Fan (Radiator)
Ventoi Nha (Motor) / Fan (Engine)
Resgua Rdo Ventoinha / Fan Cover
Tubo A Gua (Radiador) / Water Pipe (Radiator)
Tubo A Gua (Motor) / Water Pipe (Engine)
Radiad Or / Radiator
Radiad Or Protecção / Radiator Shield
Deposi To Reserva / Reserve Tank
Valvula Solenoide / Sto P Solenoid
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Interruptor E Termómetr O / Oil Switch And Thermometer
Interruptor/Sensor / Sw Itch/Sensor
Buzina/Sirene / Horn/Bu Zzer
Interruptor/Rele / Swit Ch/Relay
Tampa Interruptor / Pan El Switch
Interruptor Travao / Br Ake Switch
Luzes Frente / Head Lig Ht
Farol Traseiro / Tail L Ight
Cablagem Electrica / El Ectrical Wiring
Carter Frontal / Front Case
Caixa Velocidades / Transmission C Ase
Respiro Transmissão / Transmission Breather
Tampa Transmissão / Transmission C Ase Cover
Hst / Hst
Hst 1 (Carter) [Peças Componentes] / Hst 1 (Case) [Component Parts]
Hst 2 (Bomba) [Peças Componentes] / Hst 2 (Pump) [Component Parts]
Hst 3 (Pistão) [Peças Componentes] / Hst 3 (Piston) [Component Parts]
Hst 4 (Motor) [Peças Componentes] / Hst 4 (Motor) [Component Parts]
Hst 5 (Regulador) [Peças Component Es] / Hst 5 (Regulator) [Component Parts]
Hst 6 (Carga Bomba) [Peças Compone Ntes] / Hst 6 (Charge Pump) [Component Parts]
Hst 7 (Tampa Do Bloco De Abertura) [Peças Componentes] / Hst 7 (Port Block Cover) [Co Mponent Parts]
Hst 8 (Válvula Do Bloco De Abertur A) [Peças Componentes] / Hst 8 (Port Block Valve) [ Component Parts]
Hst 9 (Bloco De Abertura) [Peças C Omponentes] / Hst 9 (Port Block) [Component Parts]
Veio Primario / Input Shaft
Engrenagem Principal / Main Gear S Haft
Veio Gamas Velocidades / Range Gea R Shaft
Inversor / Reverse Shaft
Veio De 4wd / 4wd Shaft
Pinhao Espiral / Spiral Bevel Pini On
Diferencial Traseiro / Rear Differ Ential
Engrenagem Diferencial Traseira / Rear Differential Gear
Engrenagem Do Eixo Traseiro (Esq) / Rear Axle Gear (Left)
Engrenagem Do Eixo Traseiro (Drt) / Rear Axle Gear (Right)
Forqueta Velocidades / R Ange Gear Shift Fork
Braço Carreto Gamas / Ra Nge Gear Arm
Braco Roda Frente / Fron T Wheel Drive Arm
Bloqueio Diferencial For Queta / Differential Lock Shift Fork
Braço Da Válvula De Cont Rolo / Control Valve Arm
Caixa Velocidades / Shif T Lever
Tirante De Mudança De Ve Locidade / Speed Change Rod
Cabo De Mudança De Veloc Idade / Speed Change Cable
Alavanca Velocidades / M Ain Gear Shift Lever
Eixo Traseiro (Esq) / Rear Axle (Le Ft)
Eixo Traseiro (Drt) / Rear Axle (Ri Ght)
Veio De Transmissão Traseiro (Esq) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro (Drt) / Rear Drive Shaft (Right)
Veio De Transmissão Traseiro [Peças Componentes] / Rear Drive Shaft [Component Parts]
Suspensão Traseiro (Esq) / Rear Sus Pension (Left)
Suspensão Traseiro (Drt) / Rear Sus Pension (Right)
Suspensão Traseiro [Peças Component Es] / Rear Suspension [Component Parts]
Braço Da Suspensão Traseira (Superi Or Esquerdo) / Rear Suspension Arm (Left Upper)
Braço Da Suspensão Traseira (Inferi Or Esquerdo) / Rear Suspension Arm (Left Lower)
Braço Da Suspensão Traseira (Superi Or Direito) / Rear Suspension Arm (Right Upper)
Braço Da Suspensão Traseira (Inferi Or Direito) / Rear Suspension Arm (Right Lower)
Pedal Bloqueio Diferencial / Differ Ential Lock Pedal
Travao Frontal (Esq) / Front Brake (Left)
Travao Frontal (Drt) / Front Brake (Right)
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Cilindro Travao / Brake Cylinder
Cilindro Do Travão [Peças Componentes] / Brake Cylinder [Component Parts]
Cilindro Travao Principal / Brake Master Cylin Der
Cilnidro Principal Travao [Peças Componentes] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frontal) / Brake Oil Line ( Front)
Tubo Oleo Travoes (Traseiro) / Brake Oil Line (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Levante A Alavanca / Li Ft Lever
Bomba Hidraulico / Hydr Aulic Pump
Deposito Oleo Hidraulic O / Hydraulic Tank
Radiador Oleo / Oil Coo Ler
Linha De Óleo Hidráulic O (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulic O (Bomba) / Hydraulic Oil Line (Pump)
Linha De Óleo Hidráulic O (Hst) / Hydraulic Oil Line (Hst)
Linha De Óleo Hidráulic O (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Linha De Óleo Hidráulic O (Deposito) / Hydraulic Oil Line (Tank)
Linha De Óleo Hidráulic O (Válvula De Controlo) / Hydraulic Oil Line (Contr Ol Valve)
Valvula Control / Contr Ol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Valvula Descarga / Reie F Valve
Linha De Óleo Hidráulic O (Cilindro Esquerdo) / Hydraulic Oil Line (Lift Cy Linder)
Estrutura Transmissão / Transmission Frame
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Suporte Da Transmissão / Transmission Brack Et
Carter Eixo Frente / Front Axle C Ase
Veio De Transmissão Dianteiro (Es Q) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro [Pe Ças Componentes] / Front Drive Shaft [Component Par Ts]
Carter Eixo Frente (Esq) / Front Axle Case (Left)
Carter Eixo Frente (Drt) / Front Axle Case (Right)
Tubo Do Respiradouro / Breather P Ipe
Eixo Dianteiro (Esq) / Front Axle (Left)
Eixo Dianteiro (Drt) / Front Axle (Right)
Veio Tracao Dianteira / Front Whe El Propeller Shaft
Veio Tracao Dianteira [Peças Comp Onentes] / Front Wheel Propeller Shaft [Component Parts]
Suspensao Frontal (Esq) / Front S Uspension (Left)
Suspensao Frontal (Drt) / Front S Uspension (Right)
Suspensao Frontal [Peças Componen Tes] / Front Suspension [Component Parts]
Braço Da Suspensão Dianteira (Sup Erior Esquerdo) / Front Suspension Arm (Left Upper)
Braço Da Suspensão Dianteira (Inf Erior Esquerdo) / Front Suspension Arm (Left Lower)
Braço Da Suspensão Dianteira (Sup Erior Direito) / Front Suspension Arm (Right Upper)
Braço Da Suspensão Dianteira (Inf Erior Direito) / Front Suspension Arm (Right Lower)
Estabilizador Dianteiro / Front S Tabilizer
Alavanca Inclinacao / Tilt Lever
Direcção Controlador / Steering Controlle R
Cilindro Direcção [Peças Componentes] / S Teering Cylinder [Component Parts]
Caixa Base / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Proteccao Frontal / Front Guard
Pára-Choques Dianteiro / Front Bumper
Capot / Hood (Bonnet)
Painel Lateral / Side Cover
Porta-Luvas / Glove Box
Estrutura Do Painel / Panel Frame
Guarda Lamas (Frente) / Fender (Front)
Guarda Lamas (Traseira) / Fender (Rear)
Cobertura Central (Lado) / Center Cover ( Side)
Cobertura Central (Traseira) / Center Cov Er (Rear)
Suporte Do Assento (Operação) / Seat Supp Ort (Operation)
Banco / Seat
Cinto Segurança / Seat Belt
Placa De Isolamento / Insulation Plate
Banco Caixa / Seat Box
Roda Frente (25*10-12) / Front Wheel (25*10-12)
Roda Traseira (25*10-1 2) / Rear Wheel (25*10-12)
Etiqueta (Painel) / Label (Panel)
Ac Essorios E Peças Serviço / Accessories And Service Parts
Vareta Nivel Oleo (W/G V5202) [Opção] / Oil Ga Uge Kit (W/G No.V5202) [Option]
Kit Sonoro Mancha Atras (W/G V5236) [Opção] / Backup Beeper Kit (W/G No.V5236) [Option]
Kit Acelarador Mao (W/G V5241) [Opção] / Hand Throttle Kit (W/G No.V5241) [Option]
Kit Estrutura Elevacao Frontal (W/G V5219) [Op Ção] / Front Heavy Load Strut Kit (W/G No.V5219) [O Ption]
Kit Estrutura Elevação (W/G V5218) [Opção] / F Ront Heavy Load Springs Kit (W/G No.V5218) [Option]
Kit Guarda Cv-J Traseira (W/G V5239) [Opção] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hidráulico Tomada Acoplamento Kit (W/G V5276) [Opção] / Hydraulic Outlet Coupler Kit (W/G No.V527 6) [Option]
Duplo Bomba Hidraulico Kit (Bomba) (W/G V5271) [Opção] / Double Hyd. Pump Kit (Pump) (W/G.No.V527 1) [Option]
Bomba Hidraulico [Peças Componentes] (W/G V527 1) [Opção] / Hydraulic Pump [Component Parts] (W/G No.V5271) [Option]
Unico Válvula De Hidraulico Kit (Alavanca) (W/ G V5273) [Opção] / Hyd.Single Valve Kit (Lever) (W/ G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Veio) (W/G V5 273) [Opção] / Hyd.Single Valve Kit (Shaft) (W/G.No .V5273) [Option]
Unico Válvula De Hidraulico Kit (Válvula) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Valve) (W/G .No.V5273) [Option]
Unico Válvula De Hidraulico [Peças Componentes ] (W/G V5273) [Opção] / Hyd.Single Valve [Comp.Part S] (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Tubo) (W/G V5 273) [Opção] / Hyd.Single Valve Kit (Oil Line) (W/G .No.V5273) [Option]
Duplo Válvula De Hidraulico Kit (Alavanca) (W/ G V5274) [Opção] / Hyd.Double Valve Kit (Lever) (W/ G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Veio) (W/G V5 274) [Opção] / Hyd.Double Valve Kit (Shaft) (W/G.No .V5274) [Option]
Duplo Válvula De Hidraulico Kit (Válvula) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Valve) (W/G .No.V5274) [Option]
Duplo Válvula De Hidraulico [Peças Componentes ] (W/G V5274) [Opção] / Hyd.Double Valve [Comp.Part S] (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 1 (W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line) 1 (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 2 (W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line) 2 (W/G.No.V5274) [Option]
Kit Camisa (W/G V5229) [Opção] / Bed Liner Kit (W/G. No. V5229) [Option]
Kit Barra Reboque [Opcao] / Drawbar Kit Front [Option]
Kit Barra Reboque [Opcao] / Drawbar Kit Rear [ Option]
Kit Guarda Lamas Frontais (W/G V5225) [Opção] / Front Mud Guard Kit (W/G No.V5225) [Option]
Kit Guarda Lamas Traseira (W/G V5226) [Opção] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Kitproteccaoluzes (W/G V5227) [Opção] / Tail L Amp Guards Kit (W/G No.V5227) [Option]
Kit De Roda De Aluminio [Opção] / Aluminum All Oy Wheel Kit [Option]
Kit De Roda De Aluminio (W/G Artv5213) [Opção] / Aluminum Alloy Wheel Kit (W/G No.Artv5213) [Opti On]
Aluminum Kit Parafuso Da Roda (W/G V5205) [Opç Ão] / Alloy Wheel Hardware Kit (W/G No.V5205) [Opti On]
Carreto / Gear Case
Escpae / Muffler
Hst / Hst
Banco / Seat
