Kubota Utility Vehicle RTV-X1140-AU Parts Catalog
Language: English, Japanese
Model: Kubota RTV-X1140-AU Utility Vehicle
Region: North America
Number of Pages: 521 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head
Engine Gear Case
Engine Head Cover
Engine Oil Filter
Engine Dipstick And Guide
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft
Engine Flywheel
Engine Fuel Camshaft And Governor Shaft
Engine Idle Apparatus
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner
Engine Inlet Pipe (Air Cleaner)
Engine Muffler ## S.No. =37222 S.No.; =37222
Engine Muffler ## S.No. =37223 S.No.; =37223
Engine Muffler Cover
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Fuel System Accelerator Pedal
Fuel System Fuel Tank
Fuel System Fuel Pipe
Fuel System Fuel Filter
Fuel System Fuel Filter [Component Parts]
Fuel System Fuel Pump
Cooling Water System Air Bleeder Hose
Cooling Water System Fan (Radiator)
Cooling Water System Fan (Engine)
Cooling Water System Water Pipe (Radiator)
Cooling Water System Water Pipe (Engine 1)
Cooling Water System Water Pipe (Engine 2)
Cooling Water System Radiator
Cooling Water System Radiator Shield
Cooling Water System Reserve Tank
Electrical System Stop Solenoid
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Oil Switch And Thermometer
Electrical System Switch Sensor
Electrical System Switch Relay
Electrical System Panel Switch
Electrical System Brake Switch
Electrical System Head Light
Electrical System Rear Lamp
Electrical System Electrical Wiring (Body)
Transmission Front Case
Transmission Transmission Case
Transmission Transmission Breather
Transmission Transmission Case Cover
Transmission Starter Breather Flywheelcase Breather
Transmission HST
Transmission HST 1 (Case) [Component Parts]
Transmission HST 2 (Pump) [Component Parts]
Transmission HST 3 (Piston) [Component Parts]
Transmission HST 4 (Motor) [Component Parts]
Transmission HST 5 (Regulator) [Component Parts]
Transmission HST 6 (Charge Pump) [Component Parts]
Transmission HST 7 (Port Block Cover) [Component Parts]
Transmission HST 8 (Port Block Valve) [Component Parts]
Transmission HST 9 (Port Block) [Component Parts]
Transmission Input Shaft
Transmission Main Gear Shaft
Transmission Range Gear Shaft
Transmission Reverse Shaft
Transmission Idle Shaft
Transmission 4wd Shaft
Transmission Spiral Bevel Pinion
Transmission Rear Differential
Transmission Rear Differential Gear
Transmission Rear Axle Gear (Left)
Transmission Rear Axle Gear (Right)
Speed Change Range Gear Shift Fork
Speed Change Range Gear Arm
Speed Change Front Wheel Drive Arm
Speed Change Rear Differential Lock Shift Fork
Speed Change Control Valve Arm
Speed Change Speed Change Lever
Speed Change Speed Change Rod
Speed Change Speed Change Cable
Speed Change Main Gear Shift Lever
Speed Change Front Wheel Drive Lever
Rear Axle Rear Axle (Left)
Rear Axle Rear Axle (Right)
Rear Axle Rear Drive Shaft (Left)
Rear Axle Rear Drive Shaft (Right)
Rear Axle Rear Drive Shaft [Component Parts]
Rear Axle Rear Suspension (Left)
Rear Axle Rear Suspension (Right)
Rear Axle Rear Suspension [Component Parts]
Rear Axle Rear Suspension Arm (Left Upper)
Rear Axle Rear Suspension Arm (Left Lower)
Rear Axle Rear Suspension Arm (Right Upper)
Rear Axle Rear Suspension Arm (Right Lower)
Rear Axle Rear Stabilizer
Rear Axle Differential Lock Pedal
Brake Front Brake (Left)
Brake Front Brake (Right)
Brake Rear Brake (Left)
Brake Rear Brake (Right)
Brake Brake Cylinder
Brake Brake Cylinder [Component Parts]
Brake Brake Master Cylinder
Brake Brake Master Cylinder [Component Parts]
Brake Brake Oil Line (Front)
Brake Brake Oil Line (Rear)
Brake Brake Rod
Brake Parking Brake Lever
Brake Parking Brake Wire
Brake Brake Pedal
Hydraulic System Lift Lever
Hydraulic System Unload Link
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Tank
Hydraulic System Oil Cooler (Body)
Hydraulic System Oil Cooler (Engine)
Hydraulic System Hydraulic Oil Line (Steering)
Hydraulic System Hydraulic Oil Line (Pump)
Hydraulic System Hydraulic Oil Line (HST)
Hydraulic System Hydraulic Oil Line (Tank)
Hydraulic System Hydraulic Oil Line (Control Valve)
Hydraulic System Control Valve
Hydraulic System Control Valve [Component Parts]
Hydraulic System Relief Valve
Hydraulic System Lift Cylinder
Hydraulic System Hydraulic Oil Line (Lift Cylinder)
Frame Main Frame
Frame Transmission Frame
Frame Under Guard
Frame Engine Bracket
Frame Transmission Bracket
Front Axle Front Axle Case
Front Axle Bevel Gear
Front Axle Front Differential
Front Axle Front Drive Shaft (Left)
Front Axle Front Drive Shaft (Right)
Front Axle Front Drive Shaft [Component Parts]
Front Axle Front Axle Case (Left)
Front Axle Front Axle Case (Right)
Front Axle Breather Pipe
Front Axle Front Axle (Left)
Front Axle Front Axle (Right)
Front Axle Front Wheel Propeller Shaft
Front Axle Front Wheel Propeller Shaft [Component Parts]
Front Axle Front Suspension (Left)
Front Axle Front Suspension (Right)
Front Axle Front Suspension [Component Parts]
Front Axle Front Suspension Arm (Left Upper)
Front Axle Front Suspension Arm (Left Lower)
Front Axle Front Suspension Arm (Right Upper)
Front Axle Front Suspension Arm (Right Lower)
Front Axle Front Stabilizer
Steering Steering Handle
Steering Steering Column
Steering Tilt Lever
Steering Steering Controller
Steering Tie Rod
Steering Steering Cylinder
Steering Steering Cylinder [Component Parts]
Cargo Bed Box Base (Front)
Cargo Bed Box Base (Rear)
Cargo Bed Box Plate (Front)
Cargo Bed Box Plate (Front) (Left)
Cargo Bed Box Plate (Front) (Right)
Cargo Bed Box Plate (Rear)
Cargo Bed Box Gate
Cargo Bed Box Cover (Front)
Cargo Bed Box Cover (Rear)
Hood Bonnet Front Guard
Hood Bonnet Front Grille
Hood Bonnet Front Bumper
Hood Bonnet Hood (Bonnet) Upper
Hood Bonnet Side Cover
Hood Bonnet Glove Box
Hood Bonnet Panel Cover
Hood Bonnet Panel Frame
Hood Bonnet Fender (Front)
Hood Bonnet Fender (Rear)
Hood Bonnet Center Cover (Front)
Hood Bonnet Center Cover (Side)
Hood Bonnet Center Cover (Rear)
Hood Bonnet Step (Front)
Hood Bonnet Step (Rear)
Hood Bonnet Seat Support (Operation)
Hood Bonnet Seat Support (Passenger)
Hood Bonnet Seat Support (Rear)
Hood Bonnet Seat Support (Backrest)
Hood Bonnet Handrail
Hood Bonnet Seat (Front)
Hood Bonnet Seat (Rear)
Hood Bonnet Seat Belt (Front)
Hood Bonnet Seat Belt (Rear)
Hood Bonnet Insulation Plate
Hood Bonnet Rearview Mirror
Hood Bonnet Seat Box
Hood Bonnet Rops (Front)
Hood Bonnet Rops (Rear)
Front Rear Tire Front Wheel (250-12)
Front Rear Tire Rear Wheel (250-12)
Labels Label (Front)
Labels Label (Panel)
Labels Label (Rear)
Accessories And Service Parts Accessories And Service Parts
Option Oil Gauge Kit (W G No.V5202a) [Option]
Option Backup Beeper Kit (W G No.V5236) [Option]
Option Turn Signal Light Hazard Light Kit (W G No.V5237) [Option]
Option Breather Kit [Option] ## S.No. =24491 S.No.; =24491
Option Front Cv-J Guard Kit (W G No.V5238) [Option]
Option Rear Cv-J Guard Kit (W G No.V5239) [Option]
Option Hydraulic Outlet Coupler Kit (W G No.V5276) [Option]
Option Front Mud Guard Kit (W G No.V5225) [Option]
Option Rear Mud Guard Kit (W G No.V5226) [Option]
Option Tail Lamp Guards Kit (W G No.V5227) [Option]
Option Aluminum Alloy Wheel Kit (Black) [Option]
Option Aluminum Alloy Wheel Kit (Black Smoke) [Option]
Option Aluminum Alloy Wheel Kit (Silver) (W G No.Artv5213) [Option]
Option Aluminum Alloy Wheel Kit (Black) (W G No.Artv5214) [Option]
Option Aluminum Alloy Wheel Kit (Black Smoke) (W G No.Artv5214) [Option]
Option Alloy Wheel Hardware Kit (Black) (W G No.V5203) [Option]
Option Alloy Wheel Hardware Kit (Silver) (W G No.V5205) [Option]
Option Rear Knuckle Campaign Kit [Option]
Option Rear Wheel Stud Bolts Campaign Kit [Option]
Option Rear Suspension Arms Campaign Kit [Option]
