702,019
Kubota Utility Vehicle RTV-X1120DR-AU Parts Catalog
Language: English, Japanese
Model: Kubota RTV-X1120DR-AU Utility Vehicle
Region: North America
Number of Pages: 538 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head
Engine Gear Case
Engine Head Cover
Engine Oil Filter
Engine Dipstick And Guide
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft
Engine Flywheel
Engine Fuel Camshaft And Governor Shaft
Engine Idle Apparatus
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner
Engine Inlet Pipe
Engine Muffler
Engine Muffler Cover
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Fuel System Accelerator Pedal
Fuel System Fuel Tank
Fuel System Fuel Pipe
Fuel System Fuel Filter
Fuel System Fuel Filter[Component Parts]
Fuel System Fuel Pump
Cooling Water System Air Bleeder Hose
Cooling Water System Fan (Front Radiator)
Cooling Water System Fan (Engine)
Cooling Water System Water Pipe (Radiator)
Cooling Water System Water Pipe (Engine 1)
Cooling Water System Water Pipe (Engine 2)
Cooling Water System Radiator
Cooling Water System Radiator Shield (Front)
Cooling Water System Reserve Tank
Electrical System Stop Solenoid
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Oil Switch And Thermometer
Electrical System Switch Sensor
Electrical System Switch Relay
Electrical System Panel Switch
Electrical System Brake Switch
Electrical System Head Light
Electrical System Tail Light
Electrical System Electrical Wiring
Transmission Front Case
Transmission Transmission Case
Transmission Transmission Breather
Transmission Transmission Case Cover
Transmission Starter Breather Flywheelcase Breather
Transmission HST
Transmission HST 1 (Case) [Component Parts]
Transmission HST 2 (Pump) [Component Parts]
Transmission HST 3 (Piston) [Component Parts]
Transmission HST 4 (Motor) [Component Parts]
Transmission HST 5 (Regulator) [Component Parts]
Transmission HST 6 (Charge Pump) [Component Parts]
Transmission HST 7 (Port Block Cover) [Component Parts]
Transmission HST 8 (Port Block Valve) [Component Parts]
Transmission HST 9 (Port Block) [Component Parts]
Transmission Input Shaft
Transmission Main Gear Shaft
Transmission Range Gear Shaft
Transmission Reverse Shaft
Transmission Idle Shaft
Transmission Front Wheel Propeller Shaft
Transmission Spiral Bevel Pinion
Transmission Rear Differential
Transmission Rear Differential Gear Shaft
Transmission Rear Axle Gear (Left)
Transmission Rear Axle Gear (Right)
Speed Change Range Gear Shift Fork
Speed Change Range Gear Arm
Speed Change Front Wheel Drive Arm
Speed Change Differential Lock Shift Fork
Speed Change Control Valve Arm
Speed Change Shift Lever
Speed Change Speed Change Rod
Speed Change Speed Change Cable
Speed Change Main Gear Shift Lever
Speed Change Front Wheel Drive Lever
Rear Axle Rear Axle (Left)
Rear Axle Rear Axle (Right)
Rear Axle Rear Drive Shaft (Left)
Rear Axle Rear Drive Shaft (Right)
Rear Axle Rear Drive Shaft [Component Parts]
Rear Axle Rear Suspension (Left)
Rear Axle Rear Suspension (Right)
Rear Axle Rear Suspension [Component Parts]
Rear Axle Rear Suspension Arm (Left Upper)
Rear Axle Rear Suspension Arm (Left Lower)
Rear Axle Rear Suspension Arm (Right Upper)
Rear Axle Rear Suspension Arm (Right Lower)
Rear Axle Rear Stabilizer
Rear Axle Differential Lock Pedal
Brake Front Brake (Left)
Brake Front Brake (Right)
Brake Rear Brake (Left)
Brake Rear Brake (Right)
Brake Brake Cylinder
Brake Brake Cylinder [Component Parts]
Brake Brake Master Cylinder
Brake Brake Master Cylinder [Component Parts]
Brake Brake Oil Line (Front)
Brake Brake Oil Line (Rear)
Brake Brake Rod
Brake Parking Brake Lever
Brake Parking Brake Wire
Brake Brake Pedal
Hydraulic System Lift Lever
Hydraulic System Unload Link
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Tank ## Note Order By Ref.No.120,125 And 130 New Parts
Hydraulic System Oil Cooler (Front)
Hydraulic System Oil Cooler (Engine)
Hydraulic System Hydraulic Oil Line (Engine Oil)
Hydraulic System Hydraulic Oil Line (Steering)
Hydraulic System Hydraulic Oil Line (Pump)
Hydraulic System Hydraulic Oil Line (HST)
Hydraulic System Hydraulic Oil Line (Oil Cooler)
Hydraulic System Hydraulic Oil Line (Tank)
Hydraulic System Hydraulic Oil Line (Control Valve)
Hydraulic System Control Valve
Hydraulic System Control Valve [Component Parts]
Hydraulic System Reief Valve
Hydraulic System Lift Cylinder
Hydraulic System Hydraulic Oil Line (Lift Cylinder)
Frame Main Frame
Frame Transmission Frame
Frame Under Guard
Frame Engine Bracket
Frame Transmission Bracket
Front Axle Front Axle Case
Front Axle Differential Gear Shaft
Front Axle Front Differential
Front Axle Front Drive Shaft (Left)
Front Axle Front Drive Shaft (Right)
Front Axle Front Drive Shaft [Component Parts]
Front Axle Front Axle Case (Left)
Front Axle Front Axle Case (Right)
Front Axle Breather Pipe
Front Axle Front Axle (Left)
Front Axle Front Axle (Right)
Front Axle Front Wheel Propeller Shaft
Front Axle Front Wheel Propeller Shaft [Component Parts]
Front Axle Front Suspension (Left)
Front Axle Front Suspension (Right)
Front Axle Front Suspension [Component Parts]
Front Axle Front Suspension Arm (Left Upper)
Front Axle Front Suspension Arm (Left Lower)
Front Axle Front Suspension Arm (Right Upper)
Front Axle Front Suspension Arm (Right Lower)
Front Axle Front Stabilizer
Steering Steering Wheel
Steering Steering Post
Steering Tilt Lever
Steering Steering Controller
Steering Tie Rod
Steering Steering Cylinder
Steering Steering Cylinder [Component Parts] ## S.No. =18425 S.No.; =18425
Steering Steering Cylinder [Component Parts] ## S.No. =18426 S.No.; =18426
Cargo Bed Box Base
Cargo Bed Box Plate
Cargo Bed Box Gate
Cargo Bed Box Cover ## Note Order By Ref.No.010 And 030 New Parts.
Hood Bonnet Front Guard
Hood Bonnet Front Grille
Hood Bonnet Front Bumper
Hood Bonnet Bonnet
Hood Bonnet Side Cover
Hood Bonnet Glove Box
Hood Bonnet Door (Left)
Hood Bonnet Door (Right)
Hood Bonnet Panel Cover
Hood Bonnet Panel Frame
Hood Bonnet Fender (Front)
Hood Bonnet Fender (Rear)
Hood Bonnet Center Cover (Side)
Hood Bonnet Center Cover (Rear)
Hood Bonnet Seat Support (Operation)
Hood Bonnet Seat Support (Passenger)
Hood Bonnet Seat
Hood Bonnet Seat Belt
Hood Bonnet Step
Hood Bonnet Insulation Plate
Hood Bonnet Seat Box
Hood Bonnet Rops
Front Rear Tire Front Wheel (250-12)
Front Rear Tire Rear Wheel (250-12)
Labels Label (Front)
Labels Label (Panel)
Labels Label (Rear)
Accessories And Service Parts Accessories And Service Parts
Option Oil Gauge Kit (W G No.V5204) [Option]
Option Backup Beeper Kit (W G No.V5236) [Option]
Option Turn Signal Light Hazard Light Kit (W G No.V5257) [Option]
Option Work Light Kit (Front) (Without Roof Or Windshield) (W G No
Option Work Light Kit (Front) (With Roof Or Windshield) (W G No.V5222) [Option]
Option Work Light Kit (Rear) (W G No.V5223) [Option]
Option Breather Kit [Option] ## S.No. =21313 S.No.; =21313
Option Hand Throttle Kit (W G No.V5243) [Option]
Option Front Heavy Load Strut Kit (W G No.V5219) [Option]
Option Front Heavy Load Springs Kit (W G No.V5218) [Option]
Option Front Cv-J Guard Kit (W G No.V5238) [Option]
Option Rear Cv-J Guard Kit (W G No.V5239) [Option]
Option Hydraulic Outlet Coupler Kit (W G No.V5276) [Option]
Option Double Hyd. Pump Kit (Pump) (W G No.V5272) [Option]
Option Hydraulic Pump [Component Parts] (W G No.V5272) [Option]
Option Double Hyd. Pump Kit (Oil Line) (W G No.V5272) [Option]
Option Hyd.Single Valve Kit (Lever) (W G No.V5273) [Option]
Option Hyd.Single Valve Kit (Shaft) (W G No.V5273) [Option]
Option Hyd.Single Valve Kit (Valve) (W G No.V5273) [Option]
Option Hyd.Single Valve [Comp.Parts] (W G No.V5273) [Option]
Option Hyd.Single Valve Kit (Oil Line) (W G No.V5273) [Option]
Option Hyd.Double Valve Kit (Lever) (W G No.V5274) [Option]
Option Hyd.Double Valve Kit (Shaft) (W G No.V5274) [Option]
Option Hyd.Double Valve Kit (Valve) (W G No.V5274) [Option]
Option Hyd.Double Valve [Comp.Parts] (W G No.V5274) [Option]
Option Hyd.Double Valve Kit (Oil Line) 1 (W G No.V5274) [Option]
Option Hyd.Double Valve Kit (Oil Line) 2 (W G No.V5274) [Option]
Option Bed Liner Kit (W G No.V5229) [Option]
Option Front Mud Guard Kit (W G No.V5225) [Option]
Option Rear Mud Guard Kit (W G No.V5226) [Option]
Option Headrest Stay Kit (W G No.V5230) [Option]
Option Headrest Kit (W G No.V5231) [Option]
Option Tail Lamp Guards Kit (W G No.V5227) [Option]
Option Canopy Kit (W G No.V5221) [Option]
Option Clear Windshield Kit (W G No.V5258) [Option]
Option Tinted Windshield Kit (W G No.V5259) [Option]
Option Aluminum Alloy Wheel Kit [Option]
Option Aluminum Alloy Wheel Kit (Black) (W G No.Artv5214) [Option]
Option Aluminum Alloy Wheel Kit (Black Smoke) [Option]
Option Aluminum Alloy Wheel Kit (W G No.Artv5213) [Option]
Option Alloy Wheel Hardware Kit (W G No.V5205) [Option]
Option Rear Knuckle Kit [Option]
