Kubota Utility Vehicle RTV-X1110TWEU MR Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota RTV-X1110TWEU MR Utility Vehicle
Number of Pages: 284 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel / Dipstick
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsha Ft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Bomba Agua E Termostacto / Water Flange An D Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tampa Do Silenciador / Muffler Cover
Pedal Acelarador / A Ccelerator Pedal
Tubo Combustivel / F Uel Pipe
Filtro Gasoleo / Fue L Filter
Filtro Gasoleo [Peça S Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ma Ngueira Do Purgador De Ar / Air Bleeder Hose
Ve Ntoinha (Radiador) / Fan (Radiator)
Ve Ntoinha (Motor) / Fan (Engine)
Tu Bo Agua (Radiador) / Water Pipe (Radiator)
Tu Bo Agua 1 (Motor) / Water Pipe 1 (Engine)
Tu Bo Agua 2 (Motor) / Water Pipe 2 (Engine)
Ra Diador / Radiator
Re Sguardo Do Radiador / Radiator Shield
De Posito Reserva / Reserve Tank
Alternador / Altern Ator
Alternador [Peças C Omponentes] / Alternator [Component Parts]
Motor Arranque / St Arter
Motor Arranque [Peç As Componentes] / Starter [Component Parts]
Interruptor E Termó Metro / Oil Switch And Thermometer
Interruptor/Sensor / Switch/Sensor
Buzina/Sirene / Hor N/Buzzer
Interruptor/Rele / Switch / Relay
Painel Interruptor / Panel Switch
Interruptor Travao / Brake Switch
Luzes Frente / Head Light
Luzes Frontais / Fr Ont Combination Lamp
Braco Traseiro / Re Ar Combination Lamp
Farol Matricula / L Icense Lamp
Ficha Reboque / Tra Iler Socket
Cablagem Electrica / Electrical Wiring
Carter Frontal / Front Case
Caixa Da Transmissão / Transmi Ssion Case
Respiro Transmissão / Transmis Sion Breather
Tampa Da Transmissão / Transmi Ssion Case Cover
Respirador Do Motor De Arranqu E/Respirador Do Volante Motor / Starter Breather/Fl Ywheelcase Breather
Hst / Hst
Hst (Carter) [Peças Componente S] / Hst (Case) [Component Parts]
Hst (Bomba) [Peças Componentes ] / Hst (Pump) [Component Parts]
Hst (Pistão) [Peças Componente S] / Hst (Piston) [Component Parts]
Hst (Motor) [Peças Componentes ] / Hst (Motor) [Component Parts]
Hst (Regulador) [Peças Compone Ntes] / Hst (Regulator) [Component Parts]
Hst (Carga Bomba) [Peças Compo Nentes] / Hst (Charge Pump) [Component Parts]
Hst (Tampa Do Bloco De Abertur A) [Peças Componentes] / Hst (Port Block Cover) [Co Mponent Parts]
Hst (Válvula Do Bloco De Abert Ura) [Peças Componentes] / Hst (Port Block Valve) [ Component Parts]
Hst (Bloco De Abertura) [Peças Componentes] / Hst (Port Block) [Component Parts]
Veio Primario / Input Shaft
Engrenagem Principal / Main Ge Ar Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Veio Ponto Morto / Idle Shaft
Veio De 4wd / 4wd Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Traseiro / Rear Di Fferential
Engrenagem Diferencial Traseir A / Rear Differential Gear
Engrenagem Do Eixo Traseiro (D Ireita) / Rear Axle Gear (Right)
Forqueta Velocidades / Range Gear Shift Fork
Braço Carreto Gamas / Range Gear Arm
Braco Roda Frente / Front Wheel Drive Arm
Bloqueio Diferencial De Forqueta / Differential Lock Shift Fork
Braço Da Válvula De Controlo / Control Valve Arm
Caixa Velocidades / Speed Change Lever
Caixa Velocidades / Speed Change Rod
Cabo De Mudança De V Elocidade / Speed Change Cable
Alavanca Velocidades / Main Gear Shift Lever
Alavanca Dupla Tracc Ao / Front Wheel Drive Lever
Eixo Traseiro(Esq) / Rear Axle (Left)
Eixo Traseiro(Drt) / Rear Axle (Right)
Veio De Transmissão Traseiro (E Squerdo) / Rear Drive Shaft (Left)
Veio De Transmissão Traseiro [P Eças Componentes] / Rear Drive Shaft [Component Par Ts]
Suspensão Traseiro(Esq) / Rear Suspension (Left)
Suspensão Traseiro(Drt) / Rear Suspension (Right)
Suspensão Traseiro [Peças Compo Nentes] / Rear Suspension [Component Parts]
Braço Da Suspensão Traseira (Su Perior Esquerdo) / Rear Suspension Arm (Left Upper)
Braço Da Suspensão Traseira (In Ferior Esquerdo) / Rear Suspension Arm (Left Lower)
Braço Da Suspensão Traseira (Su Perior Direito) / Rear Suspension Arm (Right Upper)
Bloqueio Diferencial Pedal / Di Fferential Lock Pedal
Travao Frontal(Esq) / Front Brake (Left)
Travao Frontal(Drt) / Front Brake (Right)
Travao Traseiro(Esq) / Rear Brake (Left)
Travao Traseiro(Drt) / Rear Brake (Right)
Cilindro Travao / Brake Cylinder
Cilindro Do Travão [Peças Componentes] / B Rake Cylinder [Component Parts]
Cilindro Travao Principal [Peças Component Es] / Brake Master Cylinder [Component Parts]
Tubo Oleo Travoes (Frente) / Brake Oil Lin E (Front)
Tubo Oleo Travoes (Traseira) / Brake Oil L Ine (Rear)
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavanca / Lift Lev Er
Elo De Descarregame Nto / Unload Link
Bomba Hidraulico [P Eças Componentes] / Hydraulic Pump [Component Parts ]
Deposito Oleo Hidra Ulico / Hydraulic Tank
Radiador Oleo / Oil Cooler
Radiador Oleo (Moto R) / Oil Cooler (Engine)
Circuito Oleo (Moto R Oleo) / Hydraulic Oil Line (Engine Oil Filler)
Circuito Oleo (Dire Cção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidrá Ulico (Bomba) / Hydraulic Oil Line (Pump)
Tubo Oleo (Hst) / H Ydraulic Oil Line (Hst)
Tubo Oleo (Radiado R Oleo) / Hydraulic Oil Line (Oil Cooler)
Tubo Oleo (Deposito ) / Hydraulic Oil Line (Tank)
Linha De Óleo Hidrá Ulico (Válvula De Controlo) / Hydraulic Oil Line (C Ontrol Valve)
Valvula Control / C Ontrol Valve
Valvula Control [Pe Ças Componentes] / Control Valve [Component Parts]
Valvula Descarga / Relief Valve
Linha De Óleo Hidrá Ulico (Cilindro Esquerdo) / Hydraulic Oil Line (Lif T Cylinder)
Transmissao / Transmission Frame
Protecção Inferior / Under Guard
Suporte Do Motor / Engine Bracket
Suporte Da Transmissão / Transmission B Racket
Carter Eixo Frente / Front Ax Le Case
Grupo Conico / Bevel Gear
Diferencial Dianteiro / Front Differential
Veio De Transmissão Dianteiro (Esquerdo) / Front Drive Shaft (Left)
Veio De Transmissão Dianteiro (Direito) / Front Drive Shaft (Right)
Veio De Accionamento Dianteir O [Peças Componentes] / Front Drive Shaft [Componen T Parts]
Carter Eixo Frente (Esq) / Fr Ont Axle Case (Left)
Carter Eixo Frente (Drt) / Fr Ont Axle Case (Right)
Tubo Do Respiradouro / Breath Er Pipe
Eixo Dianteiro (Esq) / Front Axle (Left)
Eixo Dianteiro (Drt) / Front Axle (Right)
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Veio Cardan Da Roda Dianteira [Peças Componentes] / Front Wheel Propeller Shaft [Component Parts]
Suspensão Frontal(Esq) / Fron T Suspension (Left)
Suspensão Frontal(Drt) / Fron T Suspension (Right)
Suspensão Frontal [Peças Comp Onentes] / Front Suspension [Component Parts]
Braço Da Suspensão Frontal (S Uperior Esquerdo) / Front Suspension Arm (Left Uppe R)
Braço Da Suspensão Frontal (I Nferior Esquerdo) / Front Suspension Arm (Left Lowe R)
Braço Da Suspensão Frontal (S Uperior Direito) / Front Suspension Arm (Right Uppe R)
Braço Da Suspensão Frontal (I Nferior Direito) / Front Suspension Arm (Right Lowe R)
Estabilizador Dianteiro / Fro Nt Stabilizer
Coluna Direcção / Column,Steering
Alavanca / Tilt Lever
Direcção / Steering
Direcção Assistida / Tie Rod
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Caixa / Box Base
Chapa Caixa / Box Plate
Estrutura Caixa / Box Gate
Tampa Caixa / Box Cover
Distribuidor Auxiliar / Front Guard
Grelha Frontal / Front Grille
Pára-Choques Dianteiro / Front Bumper
Painel Lateral / Side Cover
Porta-Luvas / Glove Box
Tampa Painel / Panel Cover
Painel Estrutura / Panel Frame
Guarda Lamas(Frente) / Fender (Front)
Guarda Lamas(Traseira) / Fender (Rear )
Cobertura Central (Lado) / Center Cov Er (Side)
Cobertura Central (Traseira) / Center Cover (Rear)
Suporte Do Assento (Operação) / Seat Support (Operation)
Suporte Assento (Passageiro) / Seat S Upport (Passenger)
Banco / Seat
Cinto Segurança / Seat Belt
Degrau / Step
Placa De Isolamento / Insulation Plat E
Puxo Dianteiro / Front Hitch
Barra Reboque / Drawbar
Roda Frente (25*10 -12) / Front Wheel (25*10-12)
Roda Traseira (25* 10-12) / Rear Wheel (25*10-12)
Etiqueta (Frente) [Ingles] / Label (Fr Ont) [English]
Etiqueta (Painel) [Ingles] / Label (Pa Nel) [English]
Etiqueta (Painel) [Frances] [Alemanha] / Label (Panel) [French] [German]
Etiqueta (Traseira) [Ingles] / Label ( Rear) [English]
Etiqueta (Traseira) [Frances] [Alemanh A]) / Label (Rear) [French] [German]
Acessorios E Peças Serviço / Accessories And Serv Ice Parts
Vareta Nivel Oleo (W/G V5204) [Opção] / Oi L Gauge Kit (W/G No.V5204) [Option]
Kit Sonoro Mancha Atras (W/G V5236) [Opção ] / Backup Beeper Kit (W/G No.V5236) [Option]
Kit Acelarador Mao (W/G V5243) [Opção] / H And Throttle Kit (W/G No.V5243) [Option]
Kit Estrutura Elevacao Frontal (W/G V5219) [Opção] / Front Heavy Load Strut Kit (W/G No.V5219 ) [Option]
Kit Estrutura Elevação (W/G V5218) [Opção] / Front Heavy Load Springs Kit (W/G No.V5218) [Opt Ion]
Kit Guarda Cv-J Frontal (W/G V5238) [Opção ] / Front Cv-J Guard Kit (W/G No.V5238) [Option]
Kit Guarda Cv-J Traseira (W/G V5239) [Opçã O] / Rear Cv-J Guard Kit (W/G No.V5239) [Option]
Hidráulico Tomada Acoplamento Kit (W/G V52 76) [Opção] / Hydraulic Outlet Coupler Kit (W/G No. V5276) [Option]
Duplo Bomba Hidraulico Kit (Bomba) (W/G V5 272) [Opção] / Double Hyd. Pump Kit (Pump) (W/G.No. V5272) [Option]
Bomba Hidraulico [Peças Componentes] (W/G V5272) [Opção] / Hydraulic Pump [Comp.Parts] (W/G N O.V5272) [Option]
Duplo Bomba Hidraulico Kit (Tubo) (W/G V52 72) [Opção] / Double Hyd. Pump Kit (Oil Line) (W/G. No.V5272) [Option]
Unico Válvula De Hidraulico Kit (Veio) (W/ G V5273) [Opção] / Hyd.Single Valve Kit (Shaft) (W/ G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Válvula) (W/G V5273) [Opção] / Hyd.Single Valve Kit (Valve) (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico [Peças Compone Ntes] (W/G V5273) [Opção] / Hyd.Single Valve [Comp. Parts] (W/G.No.V5273) [Option]
Unico Válvula De Hidraulico Kit (Tubo) (W/ G V5273) [Opção] / Hyd.Single Valve Kit (Oil Line) (W/G.No.V5273) [Option]
Duplo Válvula De Hidraulico Kit (Alavanca) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Lever) (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Veio) (W/ G V5274) [Opção] / Hyd.Double Valve Kit (Shaft) (W/ G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Válvula) (W/G V5274) [Opção] / Hyd.Double Valve Kit (Valve) (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico [Peças Compone Ntes] (W/G V5274) [Opção] / Hyd.Double Valve [Comp. Parts] (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 1 ( W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line ) 1 (W/G.No.V5274) [Option]
Duplo Válvula De Hidraulico Kit (Tubo) 2 ( W/G V5274) [Opção] / Hyd.Double Valve Kit (Oil Line ) 2 (W/G.No.V5274) [Option]
Kit Camisa (W/G V5229) [Opção] / Bed Liner Kit (W/G. No.V5229) [Option]
Kit Guarda Lamas Frontais (W/G V5225) [Opç Ão] / Front Mud Guard Kit (W/G No.V5225) [Option]
Kit Guarda Lamas Traseira (W/G V5226) [Opç Ão] / Rear Mud Guard Kit (W/G No.V5226) [Option]
Kitproteccaoluzes (W/G V5227) [Opção] / Ta Il Lamp Guards Kit (W/G No.V5227) [Option]
Kit De Roda De Aluminio [Opção] / Aluminum Alloy Wheel Kit [Option]
Aluminum Kit Parafuso Da Roda (W/G V5205) [Opção] / Alloy Wheel Hardware Kit (W/G No.V5205) [ Option]
