Kubota Utility Tractors M7040DTHNBC(NEC) Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M7040DTHNBC(NEC) Utility Tractors
Number of Pages: 414 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes D'admission Et Soupapes D'echapp Ement / Inlet Valve And Exhaust Valve
Couvre-Culasse / Head Cover
Couverture / Front Cover
Pistons Et Vilebrequin / Piston And Crank Shaft
Arbre A Cames Et Arbre De Pignon Fou / Ca Mshaft And Idle Gear Shaft
Compensateur / Balancer
Volant Du Moteur / Flywheel
Unite De Pompe D'injection / Injection Pu Mp Unit
Arbre A Cames Dalimentation / Fuel Camsha Ft
Levier A Fourche (Regulateur De Vitesses) / Fork Lever (Governor)
Boulon D'ajustement De Restriction / Rest Riction Adjusting Bolt
Kit D'accouplements Rapides [Option] / Wa Ter Flange And Thermostat
Pompe A Eau / Water Pump
Collecteur D'echappement / Exhaust Manifo Ld
Soupape D'egr / Egr Valve
Tuyauterie De L'eau D'egr / Egr Water Pip Ing
Filter A Air / Air Cleaner
Tuyau D'admission / Inlet Pipe
Silencieux / Muffler
Refroidissement / Oil Cooler
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Ta Nk
Reservoir A Carburant Dro Ite / Fuel Tank Rh
Reservoir A Carburant Gau Che / Fuel Tank Lh
Tuyau A Carburant 1 (Arri Ere) [Ec] [Se] / Fuel Pipe 1 (Rear) [Ec] [Se]
Separateur / Separator
Separateur [Parties Compo Santes] / Separator [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Alternateur Compl Et / Alternator
Alternateur [Part Ies Composantes] / Alternator [Component Parts]
Lanceur / Starter
Lanceur / Starter
Lanceur / Starter
Demarreur [Partie S Composantes] / Starter [Component Parts]
Batterie [Vieux] / Battery [Old]
Batterie [Nouveau ] / Battery [New]
Commutateur/Detec Tor (Avant) / Switch/Sensor (Front)
Commutateur/Detec Tor (Arriere) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [Se]
Commutateur (Tabl Eau De Bord) / Switch (Panel Board)
Commutateur / Swi Tch
Relais / Relay
Relais / Relay
Relais / Relay
Tableau De Bord / Panel Board
Phare / Head Ligh T
Phare / Head Ligh T
Feux De Route [Pa Rties Composantes] / Head Light [Component Parts]
Feux De Combinais On Avant / Front Combination Light
Lumiere De Travai L/Lumiere De Balise / Working Light/Beacon Light
Feux De Combinais On Arriere / Rear Combination Light
Lamp Et Plaque D' Immatriculation / License Lamp
Plafonnier / Room Light
Radio-Orateur / R Adio Speaker
Cuve De Lavage / Washer Tank
Essuie-Glase Avan T / Front Wiper
Faisceau Electriq Ue (Moteur) [Ec] [Se] / Electrical Wiring (Engine) [Ec] [Se]
Faisceau Electriq Ue (Principal) [Ec] [Se] / Electrical Wiring (Main) [Ec] [Se]
Faisceau Electriq Ue (Cabine) / Electrical Wiring (Cab)
Carter De Em Brayage / Clutch Housing
Soupape D'in Verseur / Shuttle Valve
Boite D'engr Enage / Shuttle Gear Case
Carter De Tr Ansmission [Ec] [Se] / Transmission Case [Ec] [Se]
Tuyau De Ren Iflard (Carter De Transmission) / Breather Hose (Tr Ansmission Case)
Couvercle De Carter De Boite Arriere [Se] / Transmission Case R Ear Cover [Se]
Amoritisseur Disque / Damper Disk
Pedala D'emb Rayage / Clutch Pedal
Levier De So Upape (Embrayage) / Valve Lever (Clutch)
Arbre De Ent Ree / Input Shaft
Embrayage De Inverseur [Parties Composantes] / Shuttle Clutch [ Component Parts]
Arbre De Inv Erseur / Shuttle Shaft
Premier Arbr E / First Shaft
Deuxieme Arb Re / Second Shaft
Troisiem Arb Re / Third Shaft
Vitesse Ramp Ante / Creep Shaft
Engrenage Co Nique [Ec] [Se] / Bevel Gear [Ec] [Se]
Arbre De Tra Nsmission Pdf / Pto Propeller Shaft
Embrayage Pd F [Ec] [Se] [Vieux] / Pto Clutch [Ec] [Se] [Old]
Embrayage Pd F [Ec] [Se] [Nouveau] / Pto Clutch [Ec] [Se] [New]
Embrayage Pd F [Parties Composantes] / Pto Clutch [Component Par Ts]
Soupape D'em Brayage Pdf / Pto Clutch Valve
Arbre De Pdf / Pto Shaft
Embrayage Av Ant D'entrainement / Front Drive Clutch
Embrayage Av Ant D'entrainement [Parties Composantes] / Front Dr Ive Clutch [Component Parts]
Arbre De Tra Nsmission (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Changement De Vitesses / Main Gear Shift Fork
Fourchette De Changement De Gamme Et Rampante / Range And Cree P Gear Shift Fork
Fourchette De Blocage Differentiel / Rear Differential Lock Sh Ift Fork
Levier De C Ahngement De Vitesses Principal / Main Gear Shift L Ever
Tige De Cha Ngement De Vitesses Principal / Main Gear Shift Rod
Levier D'in Verseur / Shuttle Shift Lever
Cable De In Verseur / Shuttle Cable
Levier De C Hangement De Vitesses / Range Gear Shift Lever
Levier De V Itesses Pdf / Pto Gear Shift Lever
Axe Arriere / Rear A Xle
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Tige De Frein (Pedal De Frein) / Brake Rod (Brake Pedal)
Tige De Frein (Came De Frein) / Brake Rod (Brake Cam)
Pedale De Frien / Br Ake Pedal
Cylindre De Frein [P Arties Composantes] / Brake Master Cylinder [Compon Ent Parts]
Tuyau De Frein / Bra Ke Pipe
Chassis Avant / F Ront Axle Frame
Support De Reduct Eur / Front Axle Bracket
Arbre De Transmis Sion / Front Propeller Shaft
Avant Carter De D Ifferentiel / Front Differential Case
Differentiel Avan T / Differential Front
Carter Engrenage Conique Droite / Bevel Gear Case Rh
Demi Arbre De Pon T Avant Droite / Differential Gear Shaft Rh
Demi Arbre De Pon T Avant Gauche / Differential Gear Shaft Lh
Reducteur Droite / Front Axle Rh
Reducteur Gauche / Front Axle Lh
Volant De Direction / Steering Handl E
Pedale De Inclinaison Du Volant De D Irection / Tilt Pedal
Servo Direction / Steering Controlle R
Servo Direction [Parties Composantes ] [Vieux] / Steering Controller [Component Parts] [ Old]
Servo Direction [Parties Composantes ] [Nouveau] / Steering Controller [Component Parts] [New]
Barrd De Accouplement/Cylindre De Di Rection / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Compo Santes] [Vieux] / Steering Cylinder [Component Part S] [Old]
Cylindre De Direction [Parties Compo Santes] [Nouveau] / Steering Cylinder [Component Pa Rts] [New]
Support Avant Droi T / Hydraulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component P Arts]
Circuit De Huile H Ydraulique (Refoulement) / Hydraulic Pipe (Delivery )
Refroidisseur / Oi L Cooler
Circuit D'huile Hy Draulique (Direction) / Hydraulic Oil Line (Steerin G)
Circuit D'huile Hy Draulique (Inverseu/Pdf) / Hydraulic Oil Line (Shut Tle/Pto)
Circuit D'huile Hy Draulique (Soupape D'embrayage Pdf) / Hydraulic Oil Line (Pto Clutch Valve)
Tuyau De Direction (Refoulement) / Steering Hose (Delivery)
Cylindre Hydrauliq Ue / Hydraulic Cylinder
Bras De Relevage / Hydraulic Lift Arm
Clapet De Surcharg E/Soupape De Securite / Safety Valve/Relief Valve
Distributeur Hydra Ulique [Vieux] / Control Valve [Old]
Distributeur Contr Ole [Nouveau] / Control Valve [New]
Levier De Controle De Position Et D'effort / Draft And Position Contr Ol Lever
Position Et Arbre D'effort [Vieux] / Position And Draft Shaft [Old] # # No.S.<=83572 S.No.;<=83572 / S.No.<=83572 S.No.;< =83572
Position Et Arbre D'effort [Nouveau] / Position And Draft Shaft [New]
Levier De Controle De Position / Feed Back Lever
Valve Auxiliaire [ Se] [Vieux] / Auxiliary Control Valve [Se] [Old]
Valve Auxiliaire [ Se] [Nouveau] / Auxiliary Control Valve [Se] [New]
Valve Auxiliaire ( Fd) [Parties Composantes] [Vieux] / Auxiliary Contr Ol Valve (Fd) [Component Parts] [Old]
Valve Auxiliaire ( Scd) [Parties Composantes] [Nouveau] / Auxiliary Co Ntrol Valve (Scd) [Component Parts] [New]
Valve Prioritaire D'ecoulement [Parties Composantes] / Flow Priority Valve [Component Parts]
Levier De Controle De Distributeur Auxiliaire (1eme) / Auxiliary Cont Rol Valve Lever (1st)
Levier De Controle De Distributeur Auxiliaire (2eme) / Auxiliary Cont Rol Valve Lever (2nd)
3-Pts Soulevez Le Cylindre D'aide Gauche [Se] [Vieux] / 3p-Lift Assis T Cylinder Lh [Se] [Old]
3-Pts Soulevez Le Cylindre D'aide Gauche [Se] [Nouveau] / 3p-Lift Ass Ist Cylinder Lh [Se] [New]
3-Pts Soulevez Le Cylindre D'aide Droite [Se] [Vieux] / 3p-Lift Assis T Cylinder Rh [Se] [Old]
3-Pts Soulevez Le Cylindre D'aide Droite [Se] [Nouveau] / 3p-Lift Ass Ist Cylinder Rh [Se] [New]
3-Pts Soulevez Le Cylindre D'aide [Parties Composantes] [Vieux] / 3p- Lift Assist Cylinder [Component Parts] [Old]
3-Pts Soulevez Le Cylindre D'aide [Parties Composantes] [Nouveau] / 3 P-Lift Assist Cylinder [Component Parts] [New]
Tuyau De Reniflard (3-Pts Cylindre) / Breather Hose (3p Cylinder)
Support De Tirant Superieur / To P Link Bracket
Tirant Superieur [Vieux] / Top L Ink [Old]
Tirant Superieur [Nouveau] / Top Link [New]
Bras Inferieurs [Vieux] / Lower Link [Old]
Bras Inferieurs [Nouveau] / Lowe R Link [New]
Stabilisateur [Se] [Vieux] / Sta Bilizer [Se] [Old]
Stabilisateur [Vieux] / Stabiliz Er [Old]
Stabilisateur [Nouveau] / Stabil Izer [New]
Barre De Relevage Droite [Vieux] / Lift Rod Rh [Old]
Barre De Relevage Droite [Nouvea U] / Lift Rod Rh [New]
Barre De Relevage Gauche [Vieux] / Lift Rod Lh [Old]
Barre De Relevage Gauche [Nouvea U] / Lift Rod Lh [New]
Support De La Barre D'attelage [ Se] / Drawbar Bracket [Se]
Protecteur Pdf [Se] / Pto Shaft Protector [Se]
Damper De Capot / Hood(Bonnet) Damper
Capot De Couvercle Lateral / Hood(Bon Net) Side Cover
Support De Capot / Bonnet Support
Armature De Cabine / Cab Frame
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Vitre Arriere (Superieur) / Rear Window (Upp Er)
Retroviseur [Vieux] / Rearview Mirror [Old]
Retroviseur [Nouveau] / Rearview Mirror [New ]
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Tapis / Floor Mat
Couvercle De Viste / Inspection Plate
Couvercle De Aile Droite / Fender Cover Rh # # Note:Order By Ref.No.030,125 And 130 New Parts. / Note:Order By Ref.No.030,125 And 130 New Parts.
Aile / Fender
Boite Outils / Tool Box
Air Conditionneur / A Ir Conditioner
Conduit De Air / Air Conditioner Duct
Condensateur / Conden Ser
Tuyau De Air Conditio Nneur Ens Condensateur / Air Conditioner Hose / Con Denser Hose
Compresseur / Compres Sor
Tuyau De Drainage / D Rain Hose
Etiquette (Armature De Cabine) / Labe L (Cab Frame)
Etiquette (Arriere) [Ec] [Se] / Label (Rear) [Ec] [Se]
Accessories Et Piece De Service / Accessories And Service Parts
Alternateur (Alternateur) [Option] / Alte Rnator Kit (Alternator) [Option]
Alternateur [Parties Composantes] [Option ] / Alternator [Component Parts] [Option]
Sortie Hyd. A Distance Avant (Support/Tuy Au) [Option] / Front Remote Hydraulic Outlet (Holde R/Pipe) [Option]
Sortie Hydraulique A Distance Avant (1eme Soupape) [Option] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Sortie Hydraulique A Distance Avant (2eme Soupape) [Option] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Valve Auxiliaire (Fc) [Parties Composante S] [Option] / Auxiliary Control Valve (Fc) [Compone Nt Parts] [Option]
Valve Auxiliaire (Scd) [Parties Composant Es] [Option] [Vieux] / Auxiliary Control Valve (Scd ) [Component Parts] [Option] [Old]
Valve Auxiliaire (Scd) [Parties Composant Es] [Option] [Nouveau] / Auxiliary Control Valve (S Cd) [Component Parts] [Option] [New]
Sortie Hyd. A Distance Avant (Couvercle D E Soupape) [Option] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Sortie Hyd. A Distance Avant (Levier De C Ommande) [Option] / Front Remote Hydraulic Outlet ( Control Lever) [Option]
Sortie Hyd. A Distance Avant (Levier De 1 Eme) [Option] / Front Remote Hyd. Outlet (1st Valve Control Lever) [Option]
Sortie Hyd. A Distance Avant (Levier De 2 Eme) [Option] / Front Remote Hyd. Outlet (2nd Valve Control Lever) [Option]
Sortie Hyd. A Distance Avant (Couvercle) [Option] / Front Remote Hydraulic Outlet (Cover) [O Ption]
Valve De Frein Remorque 1 (Soupape/Tuyau) [Vieux] [Option] / Trailer Brake Valve Kit 1 (Valv E/Pipe) [Old] [Option]
Valve De Frein Remorque 1 (Soupape/Tuyau) [Nouveau] [Option] / Trailer Brake Valve Kit 1 (Va Lve/Pipe) [New] [Option]
Valve De Frein Remorque 2 (Tuyau) [Option ] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Support De La Barre D'attelage [Se] [Vieu X] [Option] / Drawbar Bracket Kit [Se] [Old] [Optio N]
