Kubota Utility Tractors M7040DTHNBC(EC) Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M7040DTHNBC(EC) Utility Tractors
Number of Pages: 409 Pages
Frequently U Sed Items / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes D'admission Et Soupapes D'echappe Ment / Inlet Valve And Exhaust Valve
Couvre-Culasse / Head Cover
Couverture / Front Cover
Pistons Et Vilebrequin / Piston And Cranks Haft
Arbre A Cames Et Arbre De Pignon Fou / Cam Shaft And Idle Gear Shaft
Compensateur / Balancer
Volant Du Moteur / Flywheel
Unite De Pompe D'injection / Injection Pum P Unit
Arbre A Cames Dalimentation / Fuel Camshaf T
Levier A Fourche (Regulateur De Vitesses) / Fork Lever (Governor)
Boulon D'ajustement De Restriction / Restr Iction Adjusting Bolt
Kit D'accouplements Rapides [Option] / Wat Er Flange And Thermostat
Pompe A Eau / Water Pump
Collecteur D'echappement / Exhaust Manifol D
Soupape D'egr / Egr Valve
Tuyauterie De L'eau D'egr / Egr Water Pipi Ng
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air C Leaner [Component Parts]
Tuyau D'admission / Inlet Pipe
Silencieux / Muffler
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe( Turbo Charger)
Refroidissement / Oil Cooler
Levier D'accelerateur / Hand Accelerator L Ever
Reservoir Carb. / Fuel Tan K
Reservoir A Carburant Droi Te / Fuel Tank Rh
Reservoir A Carburant Gauc He / Fuel Tank Lh
Tuyau A Carburant 1 (Arrie Re) [Ec] [Se] / Fuel Pipe 1 (Rear) [Ec] [Se]
Tuyau A Carburant 1 (Arrie Re) [Ita] [Pdf Proportionnelle A Lavancement] / Fue L Pipe 1 (Rear) [Ita] [G-Pto]
Tuyau A Carburant 2 (Avant ) / Fuel Pipe 2 (Front)
Separateur / Separator
Separateur [Parties Compos Antes] / Separator [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / R Adiator
Reservoir Du Radiateur / Reserve Tank
Alternateur Comple T / Alternator
Alternateur [Parti Es Composantes] / Alternator [Component Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Component Parts]
Batterie [Vieux] / Battery [Old]
Batterie [Nouveau] / Battery [New]
Commutateur/Detect Or (Avant) / Switch/Sensor (Front)
Commutateur/Detect Or (Arriere) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [Se]
Commutateur/Detect Or (Arriere) [Ita] [Pdf Proportionnelle A Lavanceme Nt] / Switch/Sensor (Rear) [Ita] [G-Pto]
Commutateur (Table Au De Bord) / Switch (Panel Board)
Commutateur / Swit Ch
Relais / Relay
Relais / Relay
Tableau De Bord / Panel Board
Phare / Head Light
Phare / Head Light
Feux De Route [Par Ties Composantes] / Head Light [Component Parts]
Feux De Combinaiso N Avant / Front Combination Light
Lumiere De Travail /Lumiere De Balise / Working Light/Beacon Light
Feux De Combinaiso N Arriere / Rear Combination Light
Lamp Et Plaque D'i Mmatriculation / License Lamp
Plafonnier / Room Light
Radio-Orateur / Ra Dio Speaker
Cuve De Lavage / W Asher Tank
Essuie-Glase Avant / Front Wiper
Faisceau Electriqu E (Moteur) [Ec] [Se] / Electrical Wiring (Engine) [ Ec] [Se]
Faisceau Electriqu E (Moteur) [Ita] [Pdf Proportionnelle A Lavancement ] / Electrical Wiring (Engine) [Ita] [G-Pto]
Faisceau Electriqu E (Principal) [Ec] [Se] / Electrical Wiring (Main) [Ec] [Se]
Faisceau Electriqu E (Principal) [Ita] [Pdf Proportionnelle A Lavancem Ent] / Electrical Wiring (Main) [Ita] [G-Pto]
Faisceau Electriqu E (Cabine) / Electrical Wiring (Cab)
Carter De Emb Rayage / Clutch Housing
Soupape D'inv Erseur / Shuttle Valve
Boite D'engre Nage / Shuttle Gear Case
Covercle De C Hangement / Shift Cover
Carter De Tra Nsmission [Ec] [Se] / Transmission Case [Ec] [Se]
Carter De Tra Nsmission [Ita] [Pdf Proportionnelle A Lavancement] / Transmission Cas [Ita] [G-Pto]
Tuyau De Reni Flard (Carter De Transmission) / Breather Hose (Tra Nsmission Case)
Couvercle De Carter De Boite Arriere [Ec] [Ita] / Transmission C Ase Rear Cover [Ec] [Ita]
Carter Pont A Rriere / Rear Axle Case
Amoritisseur Disque / Damper Disk
Pedala D'embr Ayage / Clutch Pedal
Levier De Sou Pape (Embrayage) / Valve Lever (Clutch)
Arbre De Entr Ee / Input Shaft
Embrayage De Inverseur [Parties Composantes] / Shuttle Clutch [C Omponent Parts]
Arbre De Inve Rseur / Shuttle Shaft
Premier Arbre / First Shaft
Deuxieme Arbr E / Second Shaft
Troisiem Arbr E / Third Shaft
Vitesse Rampa Nte / Creep Shaft
Engrenage Con Ique [Ec] [Se] / Bevel Gear [Ec] [Se]
Engrenage Con Ique [Ita] [Pdf Proportionnelle A Lavancement] / Be Vel Gear [Ita] [G-Pto]
Differentiel Arriere / Differential Rear
Arbre De Tran Smission Pdf / Pto Propeller Shaft
Embrayage Pdf [Ec] [Se] [Vieux] / Pto Clutch [Ec] [Se] [Old]
Embrayage Pdf [Ec] [Se] [Nouveau] / Pto Clutch [Ec] [Se] [New] # # No.S.>=96106 S.No.;>=96106 / S.No.>=96106 S.No.;> =96106
Embrayage Pdf [Ita] [Pdf Proportionnelle A Lavancement] [Vieux] / Pto Clutch [Ita] [G-Pto] [Old]
Embrayage Pdf [Ita] [Pdf Proportionnelle A Lavancement] [Nouveau ] / Pto Clutch [Ita] [G-Pto] [New]
Embrayage Pdf [Parties Composantes] / Pto Clutch [Component Part S]
Soupape D'emb Rayage Pdf / Pto Clutch Valve
Arbre De Pdf / Pto Shaft
Embrayage Ava Nt D'entrainement / Front Drive Clutch
Embrayage Ava Nt D'entrainement [Parties Composantes] / Front Dri Ve Clutch [Component Parts]
Arbre De Tran Smission (Arriere) / Front Propeller Shaft (Rear)
Fourchette D E Changement De Vitesses / Main Gear Shift Fork
Fourchette D E Changement De Gamme Et Rampante / Range And Creep Gear Shift Fork
Fourchette D E Changement De Pdf Proportionnelle [Ita] [Pdf Prop Ortionnelle A Lavancement] / Ground Pto Shift Fork [Ita] [G-Pto]
Fourchette D E Blocage Differentiel / Rear Differential Lock Shi Ft Fork
Levier De Ca Hngement De Vitesses Principal / Main Gear Shift Le Ver
Tige De Chan Gement De Vitesses Principal / Main Gear Shift Rod
Levier D'inv Erseur / Shuttle Shift Lever
Cable De Inv Erseur / Shuttle Cable
Levier De Ch Angement De Vitesses / Range Gear Shift Lever
Levier De Vi Tesses Pdf / Pto Gear Shift Lever
Fourchette D E Changement De Pdf Proportionnelle [Ita] [Pdf Prop Ortionnelle A Lavancement] / Ground Pto Shift Lever [Ita] [G-Pto]
Axe Arriere / Rear Ax Le
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Tige De Frein (Pedal De Frein) / Brake Rod (Brake Pedal)
Tige De Frein (Came D E Frein) / Brake Rod (Brake Cam)
Levier De Frein Stati Onnement / Parking Brake Lever
Pedale De Frien / Bra Ke Pedal
Cylindre De Frein / B Rake Master Cylinder
Cylindre De Frein [Pa Rties Composantes] / Brake Master Cylinder [Compone Nt Parts]
Tuyau De Frein / Brak E Pipe
Chassis Avant / Fr Ont Axle Frame
Support De Reducte Ur / Front Axle Bracket
Arbre De Transmiss Ion / Front Propeller Shaft
Avant Carter De Di Fferentiel / Front Differential Case
Differentiel Avant / Differential Front
Carter Engrenage C Onique Droite / Bevel Gear Case Rh
Carter Engrenage C Onique Gauche / Bevel Gear Case Lh
Carter Reducteur D Roite / Front Axle Case Rh
Carter Reducteur G Auche / Front Axle Case Lh
Demi Arbre De Pont Avant Droite / Differential Gear Shaft Rh
Demi Arbre De Pont Avant Gauche / Differential Gear Shaft Lh
Reducteur Droite / Front Axle Rh
Reducteur Gauche / Front Axle Lh
Pedale De Inclinaison Du Volant De Di Rection / Tilt Pedal
Joint De Cardan De Direction / Steeri Ng Joint
Servo Direction [Parties Composantes] [Vieux] / Steering Controller [Component Parts] [O Ld]
Servo Direction [Parties Composantes] [Nouveau] / Steering Controller [Component Parts] [New]
Barrd De Accouplement/Cylindre De Dir Ection / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Compos Antes] [Vieux] / Steering Cylinder [Component Parts ] [Old]
Cylindre De Direction [Parties Compos Antes] [Nouveau] / Steering Cylinder [Component Par Ts] [New]
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [ Parties Composantes] / Hydraulic Pump [Component Pa Rts]
Circuit De Huile Hy Draulique (Refoulement) / Hydraulic Pipe (Delivery)
Refroidisseur / Oil Cooler
Circuit D'huile Hyd Raulique (Direction) / Hydraulic Oil Line (Steering )
Circuit D'huile Hyd Raulique (Inverseu/Pdf) / Hydraulic Oil Line (Shutt Le/Pto)
Circuit D'huile Hyd Raulique (Soupape D'embrayage Pdf) / Hydraulic Oil Line (Pto Clutch Valve)
Tuyau De Direction (Refoulement) / Steering Hose (Delivery)
Cylindre Hydrauliqu E / Hydraulic Cylinder
Clapet De Surcharge /Soupape De Securite / Safety Valve/Relief Valve
Levier De Verrouill Age / Lowering Lock Lever
Distributeur Hydrau Lique [Vieux] / Control Valve [Old]
Distributeur Contro Le [Nouveau] / Control Valve [New]
Levier De Controle De Position Et D'effort / Draft And Position Contro L Lever
Position Et Arbre D 'Effort [Vieux] / Position And Draft Shaft [Old]
Position Et Arbre D 'Effort [Nouveau] / Position And Draft Shaft [New]
Levier De Controle De Position / Feed Back Lever
Valve Auxiliaire [E C] [Ita] [Vieux] / Auxiliary Control Valve [Ec] [It A] [Old]
Valve Auxiliaire [E C] [Ita] [Nouveau] / Auxiliary Control Valve [Ec] [ Ita] [New]
Valve Auxiliaire (F D) [Parties Composantes] [Vieux] / Auxiliary Contro L Valve (Fd) [Component Parts] [Old]
Valve Auxiliaire (S Cd) [Parties Composantes] [Nouveau] / Auxiliary Con Trol Valve (Scd) [Component Parts] [New]
Valve Prioritaire D 'Ecoulement [Parties Composantes] / Flow Priority V Alve [Component Parts]
Levier De Controle De Distributeur Auxiliaire (1eme) / Auxiliary Contr Ol Valve Lever (1st)
Levier De Controle De Distributeur Auxiliaire (2eme) / Auxiliary Contr Ol Valve Lever (2nd)
3-Pts Soulevez Le C Ylindre D'aide Gauche [Ec] [Ita] [Vieux] / 3p-Lift Assist Cylinder Lh [Ec] [Ita] [Old]
3-Pts Soulevez Le C Ylindre D'aide Gauche [Ec] [Ita] [Nouveau] / 3p-Lif T Assist Cylinder Lh [Ec] [Ita] [New]
3-Pts Soulevez Le C Ylindre D'aide Droite [Ec] [Ita] [Vieux] / 3p-Lift Assist Cylinder Rh [Ec] [Ita] [Old]
3-Pts Soulevez Le C Ylindre D'aide Droite [Ec] [Ita] [Nouveau] / 3p-Lif T Assist Cylinder Rh [Ec] [Ita] [New]
3-Pts Soulevez Le C Ylindre D'aide [Parties Composantes] [Vieux] / 3p-L Ift Assist Cylinder [Component Parts] [Old]
Tuyau De Reniflard (3-Pts Cylindre) / Breather Hose (3p Cylinder)
Tirant Superieur [Vieux] / Top Li Nk [Old]
Bras Inferieurs [Vieux] / Lower L Ink [Old]
Bras Inferieurs [Nouveau] / Lower Link [New]
Stabilisateur [Ec] [Vieux] / Stab Ilizer [Ec] [Old]
Stabilisateur [Vieux] / Stabilize R [Old]
Stabilisateur [Nouveau] / Stabili Zer [New]
Barre De Relevage Droite [Vieux] / Lift Rod Rh [Old]
Barre De Relevage Droite [Nouveau ] / Lift Rod Rh [New]
Barre De Relevage Gauche [Vieux] / Lift Rod Lh [Old]
Barre De Relevage Gauche [Nouveau ] / Lift Rod Lh [New]
Protecteur Pdf [Ec] [Ita] / Pto S Haft Protector [Ec] [Ita]
Capot Superieur / Hood(Bonnet) Upper
Damper De Capot / Hood(Bonnet) Damper
Capot De Couvercle Lateral / Hood(Bonn Et) Side Cover
Support De Capot / Bonnet Support
Armature De Cabine / Cab Frame
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Vitre Arriere (Superieur) / Rear Window (Uppe R)
Retroviseur [Vieux] / Rearview Mirror [Old] # # No.S.<=84922 S.No.;A:<=84922 / S.No.<=84922 S.No. ;A:<=84922
Retroviseur [Nouveau] / Rearview Mirror [New]
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Tapis / Floor Mat
Tapis / Floor Mat
Couvercle De Viste / Inspection Plate
Couvercle De Aile Droite / Fender Cover Rh
Aile / Fender
Boite Outils / Tool Box
Air Conditionneur / Ai R Conditioner
Conduit De Air / Air C Onditioner Duct
Tuyau De Chauffage / H Eater Hose
Condensateur / Condens Er
Tuyau De Air Condition Neur Ens Condensateur / Air Conditioner Hose / Cond Enser Hose
Compresseur / Compress Or
Tuyau De Drainage / Dr Ain Hose
Etiquette (Armature De Cabine) / Label (Cab Frame)
Etiquette (Arriere) [Ec] [Se] / Label (Rear) [Ec] [Se]
Etiquette (Arriere) [Ita] [Pdf Proport Ionnelle A Lavancement] / Label (Rear) [Ita] [G-Pto ]
Accessories Et Piece De Service / Accessories And Service Parts
Alternateur (Alternateur) [Option] / Alter Nator Kit (Alternator) [Option]
Alternateur [Parties Composantes] [Option] / Alternator [Component Parts] [Option]
Sortie Hyd. A Distance Avant (Support/Tuya U) [Option] / Front Remote Hydraulic Outlet (Holder /Pipe) [Option]
Sortie Hydraulique A Distance Avant (1eme Soupape) [Option] / Front Remote Hydraulic Outlet ( 1st Valve) [Option]
Valve Auxiliaire (Fc) [Parties Composantes ] [Option] / Auxiliary Control Valve (Fc) [Componen T Parts] [Option]
Valve Auxiliaire (Scd) [Parties Composante S] [Option] [Vieux] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Old]
Valve Auxiliaire (Scd) [Parties Composante S] [Option] [Nouveau] / Auxiliary Control Valve (Sc D) [Component Parts] [Option] [New]
Sortie Hyd. A Distance Avant (Couvercle De Soupape) [Option] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Sortie Hyd. A Distance Avant (Levier De Co Mmande) [Option] / Front Remote Hydraulic Outlet (C Ontrol Lever) [Option]
Sortie Hyd. A Distance Avant (Levier De 2e Me) [Option] / Front Remote Hyd. Outlet (2nd Valve Control Lever) [Option]
Sortie Hyd. A Distance Avant (Couvercle) [ Option] / Front Remote Hydraulic Outlet (Cover) [Op Tion]
Valve De Frein Remorque 1 (Soupape/Tuyau) [Vieux] [Option] / Trailer Brake Valve Kit 1 (Valve /Pipe) [Old] [Option]
Valve De Frein Remorque 1 (Soupape/Tuyau) [Nouveau] [Option] / Trailer Brake Valve Kit 1 (Val Ve/Pipe) [New] [Option]
Valve De Frein Remorque 2 (Tuyau) [Option] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Support De La Barre D'attelage [Ec] [Vieux ] [Option] / Drawbar Bracket Kit [Ec] [Old] [Option ]
Ventilateur / Fan
Ventilateur / Fan
Lanceur / Starter
Lanceur / Starter
Relais / Relay
Relais / Relay
Phare / Head Light
Phare / Head Light
Tapis / Floor Mat
Tapis / Floor Mat
Aile / Fender
