Kubota Utility Tractors M7040DTHNB-EC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M7040DTHNB-EC Utility Tractors
Number of Pages: 407 Pages
Frequently Use D Items / Frequently Used Items
Bloc Moteur [Vieux] / Crankcase [Old]
Bloc Moteur [Nouveau] / Crankcase [New]
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes D'admission Et Soupapes D'echappeme Nt / Inlet Valve And Exhaust Valve
Couvre-Culasse / Head Cover
Couverture / Front Cover
Pistons Et Vilebrequin / Piston And Cranksha Ft
Arbre A Cames Et Arbre De Pignon Fou / Camsh Aft And Idle Gear Shaft
Compensateur / Balancer
Volant Moteur / Flywheel
Unite De Pompe D'injection / Injection Pump Unit
Arbre A Cames De Carburant / Fuel Camshaft
Levier A Fourche (Regulateur De Vitesses) / Fork Lever (Governor)
Boulon D'ajustement De Restriction / Restric Tion Adjusting Bolt
Bride A Eau Et Thermostat / Water Flange And Thermostat
Pompe A Eau / Water Pump
Soupape D'egr / Egr Valve
Tuyauterie De L'eau D'egr / Egr Water Piping
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Cle Aner [Component Parts]
Tuyau D'admission / Inlet Pipe
Silencieux / Muffler
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (T Urbo Charger)
Refroidissement / Oil Cooler
Pieces Electriques De Moteur / Engine Electr Ical Parts
Levier D'accelerateur / Hand Accelerator Lev Er
Reservoir A Carburant Droite / Fuel Tank Rh
Reservoir A Carburant Gauche / Fuel Tank Lh
Tuyau A Carburant 1 (Arriere ) / Fuel Pipe 1 (Rear)
Separateur / Separator
Separateur [Parties Composan Tes] / Separator [Component Parts]
Ventilateur / F An
Ventilateur / F An
Ventilateur / F An
Tuyau D'eau / W Ater Pipe
Radiateur / Rad Iator
Reservoir Du Ra Diateur / Reserve Tank
Alternateur / Altern Ator
Alternateur [Parties Composantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Demarreur [Parties C Omposantes] / Starter [Component Parts]
Batterie [Vieux] / B Attery [Old]
Batterie [Nouveau] / Battery [New]
Commutateur/Detector (Moteur) / Switch/Sensor (Engine)
Commutateur/Detector (Avant) / Switch/Sensor (Front)
Commutateur/Detector (Arriere) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [S E]
Commutateur/Detector (Arriere) [Ita] [Pdf Proportionnelle A Lavancement ] / Switch/Sensor (Rear) [Ita] [G-Pto]
Commutateur (Tableau De Bord) / Switch (Panel Board)
Relais / Relay
Relais / Relay
Tableau De Bord / Pa Nel Board
Phare / Head Light
Phare / Head Light
Feux De Route [Parti Es Composantes] / Head Light [Component Parts]
Feux Avant / Front C Ombination Light
Feux De Combinaison Arriere / Rear Combination Light
Lamp Et Plaque D'imm Atriculation / License Lamp
Faisceau Electrique (Avant) [Ec] [Se] / Electrical Wiring (Front) [Ec] [Se]
Faisceau Electrique (Avant) [Ita] [Pdf Proportionnelle A Lavancement] / Electrical Wiring (Front) [Ita] [G-Pto]
Faisceau Electrique (Arriere) [Ec] [Se] / Electrical Wiring (Rear) [Ec] [Se]
Faisceau Electrique (Arriere) [Ita] [Pdf Proportionnelle A Lavancement] / Electrical Wiring (Rear) [Ita] [G-Pto]
Carter D'embray Age / Clutch Housing
Soupape D'inver Seur / Shuttle Valve
Boite D'engrena Ge / Shuttle Gear Case
Covercle De Cha Ngement / Shift Cover
Carter De Trans Mission [Ec] [Se] / Transmission Case [Ec] [Se]
Carter De Trans Mission [Ita] [Pdf Proportionnelle A Lavancement] / Transmission Case [Ita] [G-Pto]
Tuyau De Renifl Ard (Carter De Transmission) / Breather Hose (Trans Mission Case)
Couvercle De Ca Rter De Boite Arriere [Ec] [Ita] / Transmission Cas E Rear Cover [Ec] [Ita]
Carter Pont Arr Iere / Rear Axle Case
Amoritisseur Di Sque / Damper Disk
Pedala D'embray Age / Clutch Pedal
Levier De Soupa Pe (Embrayage/Inverseur) / Valve Lever (Clutch/Shut Tle)
Arbre D'entree / Input Shaft
Embrayage D'inv Erseur [Parties Composantes] / Shuttle Clutch [Comp Onent Parts]
Arbre De Invers Eur / Shuttle Shaft
Demarreur / Starter
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Vitesse Rampant E / Creep Shaft
Engrenage Coniq Ue [Ec] [Se] / Bevel Gear [Ec] [Se]
Engrenage Coniq Ue [Ita] [Pdf Proportionnelle A Lavancement] / Beve L Gear [Ita] [G-Pto]
Differentiel Ar Riere / Differential Rear
Arbre De Transm Ission Pdf / Pto Propeller Shaft
Embrayage Pdf [ Ec] [Se] [Vieux] / Pto Clutch [Ec] [Se] [Old]
Embrayage Pdf [ Ec] [Se] [Nouveau] / Pto Clutch [Ec] [Se] [New]
Embrayage Pdf [ Ita] [Pdf Proportionnelle A Lavancement] [Vieux] / Pto Clutch [Ita] [G-Pto] [Old]
Embrayage Pdf [ Ita] [Pdf Proportionnelle A Lavancement] [Nouveau] / Pto Clutch [Ita] [G-Pto] [New]
Embrayage Pdf [ Parties Composantes] [Vieux] / Pto Clutch [Componen T Parts] [Old]
Embrayage Pdf [ Parties Composantes] [Nouveau] / Pto Clutch [Compon Ent Parts] [New]
Soupape D'embra Yage Pdf / Pto Clutch Valve
Arbre De Pdf / Pto Shaft
Embrayage Avant D'entrainement / Front Drive Clutch
Embrayage Avant D'entrainement [Parties Composantes] / Front Drive Clutch [Component Parts]
Arbre De Transm Ission (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Changement De Vitesses / Main Gear Shift Fork
Fourchette De Changement De Gamme Et Rampante / Range And Creep G Ear Shift Fork
Fourchette De Changement De Pdf Proportionnelle [Ita] [Pdf Propor Tionnelle A Lavancement] / Ground Pto Shift Fork [I Ta] [G-Pto]
Fourchette De Blocage Differentiel / Rear Differential Lock Shift Fork
Levier De Cahn Gement De Vitesses Principal / Main Gear Shift Leve R
Cable De Chang Ement De Vitesses Principal / Main Gear Shift Cable
Levier D'inver Seur / Shuttle Shift Lever
Cable De Inver Seur / Shuttle Cable
Levier De Chan Gement De Vitesses / Range Gear Shift Lever
Levier De Vite Sses Pdf / Pto Gear Shift Lever
Levier De Chan Gement De Pdf Proportionnelle [Ita] [Pdf Proportion Nelle A Lavancement] / Ground Pto Shift Lever [Ita] [G-Pto]
Pedale Bloc.Differentie L Arriere / Rear Differential Lock Pedal
Axe Arriere / Rear Axle
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Tige De Frein / Brake R Od
Levier De Frein Station Nement / Parking Brake Lever
Pedale De Frien / Brake Pedal
Cylindre De Frein / Bra Ke Master Cylinder
Cylindre De Frein [Part Ies Composantes] / Brake Master Cylinder [Component Parts]
Tuyau De Frein / Brake Pipe
Tuyau De Cylindre De Fr Ein / Brake Master Cylinder Pipe
Chassis Avant / Fron T Axle Frame
Arbre De Transmissio N / Front Propeller Shaft
Avant Carter De Diff Erentiel / Front Differential Case
Differentiel Avant / Differential Front
Carter Engrenage Con Ique Droite / Bevel Gear Case Rh
Carter Engrenage Con Ique Gauche / Bevel Gear Case Lh
Carter Reducteur Dro Ite / Front Axle Case Rh
Carter Reducteur Gau Che / Front Axle Case Lh
Demi Arbre De Pont A Vant Droite / Differential Gear Shaft Rh
Demi Arbre De Pont A Vant Gauche / Differential Gear Shaft Lh
Reducteur Droite / F Ront Axle Rh
Reducteur Gauche / F Ront Axle Lh
Levier De Inclinaison Du Volant De Dire Ction / Tilt Lever
Joint De Cardan De Direction / Steering Joint
Servo Direction [Parties Composantes] / Steering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Direc Tion / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Composan Tes] [Vieux] / Steering Cylinder [Component Parts] [Old]
Pompe Hydraulique / H Ydraulic Pump
Pompe Hydraulique [Pa Rties Composantes] / Hydraulic Pump [Component Part S]
Circuit De Huile Hydr Aulique (Refoulement) / Hydraulic Pipe (Delivery)
Refroidisseur / Oil C Ooler
Circuit D'huile Hydra Ulique (Direction/Pdf) / Hydraulic Oil Line (Steeri Ng/Pto)
Circuit D'huile Hydra Ulique (Inverseu/Pdf) / Hydraulic Oil Line (Shuttle /Pto)
Circuit D'huile Hydra Ulique (Soupape D'embrayage Pdf) / Hydraulic Oil Li Ne (Pto Clutch Valve)
Tuyau De Direction (R Efoulement) / Steering Hose (Delivery)
Carter De Cylindre Hy Draulique / Hydraulic Cylinder Case
Bras De Relevage / Hy Draulic Lift Arm
Clapet De Surcharge/S Oupape De Securite / Safety Valve/Relief Valve
Levier De Verrouillag E / Lowering Lock Lever
Distributeur Controle [Vieux] / Control Valve [Old]
Distributeur Controle [Nouveau] / Control Valve [New]
Levier De Controle De Position Et D'effort / Draft And Position Control Lever
Position Et Arbre D'e Ffort [Vieux] / Position And Draft Shaft [Old]
Position Et Arbre D'e Ffort [Nouveau] / Position And Draft Shaft [New]
Levier De Controle De Position / Feed Back Lever
Valve Auxiliaire [Ec] [Vieux] / Auxiliary Control Valve [Ec] [Old]
Valve Auxiliaire [Ec] [Nouveau] / Auxiliary Control Valve [Ec] [New]
Valve Auxiliaire [Ita ] / Auxiliary Control Valve [Ita]
Valve Auxiliaire (Fd) [Parties Composantes] [Vieux] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valve Auxiliaire (Scd ) [Parties Composantes] [Nouveau] / Auxiliary Contr Ol Valve (Scd) [Component Parts] [New]
Valve Auxiliaire (S/D ) [Parties Composantes] / Auxiliary Control Valve ( S/D) [Component Parts]
Valve Prioritaire D'e Coulement [Parties Composantes] [Vieux] / Flow Prio Rity Valve [Component Parts] [Old]
Levier De Controle De Distributeur Auxiliaire (1eme) / Auxiliary Control Valve Lever (1st)
Levier De Controle De Distributeur Auxiliaire (2eme) / Auxiliary Control Valve Lever (2nd)
3-Pts Soulevez Le Cyl Indre D'aide Gauche [Ec] [Ita] [Vieux] / 3p-Lift As Sist Cylinder Lh [Ec] [Ita] [Old]
3-Pts Soulevez Le Cyl Indre D'aide Gauche [Ec] [Ita] [Nouveau] / 3p-Lift Assist Cylinder Lh [Ec] [Ita] [New]
3-Pts Soulevez Le Cyl Indre D'aide Droite [Ec] [Ita] [Vieux] / 3p-Lift As Sist Cylinder Rh [Ec] [Ita] [Old]
3-Pts Soulevez Le Cyl Indre D'aide Droite [Ec] [Ita] [Nouveau] / 3p-Lift Assist Cylinder Rh [Ec] [Ita] [New]
3-Pts Soulevez Le Cyl Indre D'aide [Parties Composantes] [Vieux] / 3p-Lif T Assist Cylinder [Component Parts] [Old]
3-Pts Soulevez Le Cyl Indre D'aide [Parties Composantes] [Nouveau] / 3p-L Ift Assist Cylinder [Component Parts] [New]
Support De Tirant Superieur / Top L Ink Bracket
Tirant Superieur [Vieux] / Top Link [Old]
Tirant Superieur [Nouveau] / Top Li Nk [New]
Tirant Inferieur [Vieux] / Lower Li Nk [Old]
Tirant Inferieur [Noveau]] / Lower Link [New]
Stabilisateur [Ec] [Vieux] / Stabil Izer [Ec] [Old]
Stabilisateur [Ec] [Nouveau] / Stab Ilizer [Ec] [New]
Stabilisateur [Ita] [Vieux] / Stabi Lizer [Ita] [Old]
Stabilisateur [Ita] [Nouveau] / Sta Bilizer [Ita] [New]
Barre De Relevage Droite [Vieux] / Lift Rod Rh [Old]
Barre De Relevage Droite [Nouveau] / Lift Rod Rh [New]
Barre De Relevage Gauche [Vieux] / Lift Rod Lh [Old]
Barre De Relevage Gauche [Nouveau] / Lift Rod Lh [New]
Protecteur Pdf [Ec] [Ita] / Pto Sha Ft Protector [Ec] [Ita]
Calandre Avant / Front Grille
Capot Superieur / Hood (Bonnet) Upper
Capot Superieur (Insonorisant/Isolateur) [Nouveau] / Hood (Bonnet) Upper (Sound Absorber/In Sulator) [New]
Capot De Couvercle Lateral / Hood (Bonne T) Side Cover
Support De Capot / Bonnet Support
Bouclier / Shield
Bouclier / Shield
Capot Arriere (Insonorisant) / Hood (Bon Net) Rear (Sound Absorber)
Retroviseur / Rearview Mirror
Aile / Fender
Marchepied / Step
Couverture Superieure De Marchepied / St Ep Upper Cover
Repose De Marchepied/Insonorisant / Step Mat/Sound Absorber
Marchepied Auxiliaire / Auxiliary Step
Support Du Siège [Ec] [Se] / Seat Bracke T [Ec] [Se]
Boite Dutils / Tool Box
Cadre Anti-Renversement 1 (Ve Ntrale) / Rops 1 (Mid)
Cadre Anti-Renversement 2 (Ar Riere) / Rops 2 (Rear)
Etiquette (Arriere) [Ec] [Se] / Label (R Ear) [Ec] [Se]
Etiquette (Arriere) [Ita] [Pdf Proportio Nnelle A Lavancement] / Label (Rear) [Ita] [G-Pto]
Accessories Et Piece De Service / Accessories And Service Parts
Alternateur 1 (Alternateur) [Option] / Alter Nator Kit 1 (Alternator) [Option]
Alternateur 2 (Harness) [Option] / Alternato R Kit 2 (Wire Harness) [Option]
Alternateur [Parties Composantes] [Option] / Alternator [Component Parts] [Option]
Sortie Hydraulique A Distance Avant (Support /Tuyau) [Option] / Front Remote Hydraulic Outlet (H Older/Pipe) [Option]
Sortie Hydraulique A Distance Avant (1eme So Upape) [Option] / Front Remote Hydraulic Outlet (1s T Valve) [Option]
Sortie Hydraulique A Distance Avant (2eme So Upape) [Option] / Front Remote Hydraulic Outlet (2n D Valve) [Option]
Valve Auxiliaire (Fc) [Parties Composantes] [Option] / Front Remote Hydraulic Outlet (Fc) [Comp Onent Parts] [Option]
Valve Auxiliaire (Scd) [Parties Composantes] [Option] [Vieux] / Front Remote Hydraulic Outlet ( Scd) [Component Parts] [Option] [Old]
Valve Auxiliaire (Scd) [Parties Composantes] [Option] [Nouveau] / Front Remote Hydraulic Outlet (Scd) [Component Parts] [Option] [New]
Sortie Hydraulique A Distance Avant (Couverc Le De Soupape) [Option] / Front Remote Hydraulic Ou Tlet (Valve Cover) [Option]
Sortie Hydraulique A Distance Avant (Levier De Commande) [Option] / Front Remote Hydraulic Outl Et (Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Levier De 1eme) [Option] / Front Remote Hydraulic Outlet ( 1st Valve Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Levier De 2eme) [Option] / Front Remote Hydraulic Outlet ( 2nd Valve Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Parenth Ese De Garde) [Option] / Front Remote Hydraulic Out Let (Guard Bracket) [Option]
Kit Levier De Soupape De Contrôle De L'auxil Iaire (3eme) [Option] / Auxiliary Control Valve Lev Er Kit (3rd) [Option]
Valve De Frein Remorque 1 (Soupape/Tuyau) [O Ption] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Op Tion]
Valve De Frein Remorque 2 (Tuyau) [Option] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Valve De Frein Remorque 3 (Couvercle) [Optio N] / Trailer Brake Valve Kit 3 (Cover) [Option]
Support De La Barre D'attelage [Ec] [Option] [Vieux] / Drawbar Bracket Kit [Ec] [Option] [Old]
Kit De Support Du Marche-Pied [Option] [Vieu X] / Step Support Kit [Option] [Old]
Ventilateur / F An
Ventilateur / F An
Ventilateur / F An
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Relais / Relay
Relais / Relay
Phare / Head Light
Phare / Head Light
Demarreur / Starter
Bouclier / Shield
Bouclier / Shield
Aile / Fender
Marchepied / Step
