Kubota Utility Tractors M6040DTHNB-NEC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M6040DTHNB-NEC Utility Tractors
Number of Pages: 414 Pages
Frequently Us Ed Items / Frequently Used Items
Bloc Moteur [Vieux] / Crankcase [Old]
Bloc Moteur [Nouveau] / Crankcase [New]
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes D'admission Et Soupapes D'echappem Ent / Inlet Valve And Exhaust Valve
Couvre-Culasse / Head Cover
Couverture / Front Cover
Pistons Et Vilebrequin / Piston And Cranksh Aft
Arbre A Cames Et Arbre De Pignon Fou / Cams Haft And Idle Gear Shaft
Compensateur / Balancer
Volant Moteur / Flywheel
Unite De Pompe D'injection / Injection Pump Unit
Arbre A Cames De Carburant / Fuel Camshaft
Levier A Fourche (Regulateur De Vitesses) / Fork Lever (Governor)
Boulon D'ajustement De Restriction / Restri Ction Adjusting Bolt
Bride A Eau Et Thermostat / Water Flange An D Thermostat
Pompe A Eau / Water Pump
Soupape D'egr / Egr Valve
Tuyauterie De L'eau D'egr / Egr Water Pipin G
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Cl Eaner [Component Parts]
Tuyau D'admission / Inlet Pipe
Silencieux / Muffler
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe ( Turbo Charger)
Refroidissement / Oil Cooler
Pieces Electriques De Moteur / Engine Elect Rical Parts
Levier D'accelerateur / Hand Accelerator Le Ver
Reservoir A Carburant / Fue L Tank
Reservoir A Carburant Droit E / Fuel Tank Rh
Reservoir A Carburant Gauch E / Fuel Tank Lh
Tuyau A Carburant 1 (Arrier E) / Fuel Pipe 1 (Rear)
Tuyau A Carburant 2 (Avant) / Fuel Pipe 2 (Front)
Separateur / Separator
Separateur [Parties Composa Ntes] / Separator [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Ra Diator
Reservoir Du R Adiateur / Reserve Tank
Alternateur / Alter Nator
Alternateur [Partie S Composantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Demarreur [Parties Composantes] / Starter [Component Parts]
Batterie [Vieux] / Battery [Old]
Batterie [Nouveau] / Battery [New]
Commutateur/Detecto R (Moteur) / Switch/Sensor (Engine)
Commutateur/Detecto R (Avant) / Switch/Sensor (Front)
Commutateur/Detecto R (Arriere) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [ Se]
Commutateur (Tablea U De Bord) / Switch (Panel Board)
Relais / Relay
Relais / Relay
Tableau De Bord / P Anel Board
Phare / Head Light
Phare / Head Light
Feux De Route [Part Ies Composantes] / Head Light [Component Parts]
Feux Avant / Front Combination Light
Feux De Combinaison Arriere / Rear Combination Light
Lamp Et Plaque D'im Matriculation / License Lamp
Faisceau Electrique (Avant) [Ec] [Se] / Electrical Wiring (Front) [Ec] [Se]
Faisceau Electrique (Arriere) [Ec] [Se] / Electrical Wiring (Rear) [Ec ] [Se]
Carter D'embra Yage / Clutch Housing
Soupape D'inve Rseur / Shuttle Valve
Boite D'engren Age / Shuttle Gear Case
Covercle De Ch Angement / Shift Cover
Carter De Tran Smission [Ec] [Se] / Transmission Case [Ec] [Se]
Tuyau De Renif Lard (Carter De Transmission) / Breather Hose (Tran Smission Case)
Couvercle De C Arter De Boite Arriere [Se] / Transmission Case Rea R Cover [Se]
Carter Pont Ar Riere / Rear Axle Case
Amoritisseur D Isque / Damper Disk
Pedala D'embra Yage / Clutch Pedal
Levier De Soup Ape (Embrayage/Inverseur) / Valve Lever (Clutch/Shu Ttle)
Arbre D'entree / Input Shaft
Embrayage D'in Verseur [Parties Composantes] / Shuttle Clutch [Com Ponent Parts]
Arbre De Inver Seur / Shuttle Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbr E / Third Shaft
Vitesse Rampan Te / Creep Shaft
Engrenage Coni Que [Ec] [Se] / Bevel Gear [Ec] [Se]
Differentiel A Rriere / Differential Rear
Arbre De Trans Mission Pdf / Pto Propeller Shaft
Embrayage Pdf [Ec] [Se] [Vieux] / Pto Clutch [Ec] [Se] [Old]
Embrayage Pdf [Ec] [Se] [Nouveau] / Pto Clutch [Ec] [Se] [New]
Embrayage Pdf [Parties Composantes] [Vieux] / Pto Clutch [Compone Nt Parts] [Old]
Embrayage Pdf [Parties Composantes] [Nouveau] / Pto Clutch [Compo Nent Parts] [New]
Soupape D'embr Ayage Pdf / Pto Clutch Valve
Arbre De Pdf / Pto Shaft
Embrayage Avan T D'entrainement / Front Drive Clutch
Embrayage Avan T D'entrainement [Parties Composantes] / Front Driv E Clutch [Component Parts]
Arbre De Trans Mission (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Changement De Vitesses / Main Gear Shift Fork
Fourchette De Changement De Gamme Et Rampante / Range And Creep Gear Shift Fork
Fourchette De Blocage Differentiel / Rear Differential Lock Shif T Fork
Levier De Cah Ngement De Vitesses Principal / Main Gear Shift Lev Er
Cable De Chan Gement De Vitesses Principal / Main Gear Shift Cabl E
Levier D'inve Rseur / Shuttle Shift Lever
Cable De Inve Rseur / Shuttle Cable
Levier De Cha Ngement De Vitesses / Range Gear Shift Lever
Levier De Vit Esses Pdf / Pto Gear Shift Lever
Pedale Bloc.Differenti El Arriere / Rear Differential Lock Pedal
Axe Arriere / Rear Axl E
Frein Droite / Brake R H
Frein Gauche / Brake L H
Tige De Frein / Brake Rod
Levier De Frein Statio Nnement / Parking Brake Lever
Pedale De Frien / Brak E Pedal
Cylindre De Frein / Br Ake Master Cylinder
Cylindre De Frein [Par Ties Composantes] / Brake Master Cylinder [Componen T Parts]
Tuyau De Frein / Brake Pipe
Tuyau De Cylindre De F Rein / Brake Master Cylinder Pipe
Support De Reducteu R / Front Axle Bracket
Arbre De Transmissi On / Front Propeller Shaft
Avant Carter De Dif Ferentiel / Front Differential Case
Engrenage Conique ( Avant) / Bevel Gear (Front)
Differentiel Avant / Differential Front
Carter Engrenage Co Nique Droite / Bevel Gear Case Rh
Carter Engrenage Co Nique Gauche / Bevel Gear Case Lh
Carter Reducteur Dr Oite / Front Axle Case Rh
Carter Reducteur Ga Uche / Front Axle Case Lh
Demi Arbre De Pont Avant Droite / Differential Gear Shaft Rh
Demi Arbre De Pont Avant Gauche / Differential Gear Shaft Lh
Reducteur Droite / Front Axle Rh
Reducteur Gauche / Front Axle Lh
Levier De Inclinaison Du Volant De Dir Ection / Tilt Lever
Joint De Cardan De Direction / Steerin G Joint
Servo Direction [Parties Composantes] / Steering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Dire Ction / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Composa Ntes] [Vieux] / Steering Cylinder [Component Parts] [Old]
Cylindre De Direction [Parties Composa Ntes] [Nouveau] / Steering Cylinder [Component Part S] [New]
Pompe Hydraulique / Hydraulic Pump
Pompe Hydraulique [P Arties Composantes] / Hydraulic Pump [Component Par Ts]
Circuit De Huile Hyd Raulique (Refoulement) / Hydraulic Pipe (Delivery)
Refroidisseur / Oil Cooler
Circuit D'huile Hydr Aulique (Direction/Pdf) / Hydraulic Oil Line (Steer Ing/Pto)
Circuit D'huile Hydr Aulique (Inverseu/Pdf) / Hydraulic Oil Line (Shuttl E/Pto)
Circuit D'huile Hydr Aulique (Soupape D'embrayage Pdf) / Hydraulic Oil L Ine (Pto Clutch Valve)
Tuyau De Direction ( Refoulement) / Steering Hose (Delivery)
Carter De Cylindre H Ydraulique / Hydraulic Cylinder Case
Bras De Relevage / H Ydraulic Lift Arm
Clapet De Surcharge/ Soupape De Securite / Safety Valve/Relief Valve
Levier De Verrouilla Ge / Lowering Lock Lever
Distributeur Control E [Vieux] / Control Valve [Old]
Distributeur Control E [Nouveau] / Control Valve [New]
Levier De Controle D E Position Et D'effort / Draft And Position Control Lever
Position Et Arbre D' Effort [Vieux] / Position And Draft Shaft [Old]
Position Et Arbre D' Effort [Nouveau] / Position And Draft Shaft [New] # # No.S.>=83349 S.No.;>=83349 / S.No.>=83349 S.No.;> =83349
Levier De Controle D E Position / Feed Back Lever
Valve Auxiliaire [Se ] [Vieux] / Auxiliary Control Valve [Se] [Old]
Valve Auxiliaire [Se ] [Nouveau] / Auxiliary Control Valve [Se] [New]
Valve Auxiliaire (Fd ) [Parties Composantes] [Vieux] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valve Auxiliaire (Sc D) [Parties Composantes] [Nouveau] / Auxiliary Cont Rol Valve (Scd) [Component Parts] [New]
Valve Auxiliaire (S/ D) [Parties Composantes] / Auxiliary Control Valve (S/D) [Component Parts]
Valve Prioritaire D' Ecoulement [Parties Composantes] [Vieux] / Flow Pri Ority Valve [Component Parts] [Old]
Levier De Controle D E Distributeur Auxiliaire (1eme) / Auxiliary Contro L Valve Lever (1st)
Levier De Controle D E Distributeur Auxiliaire (2eme) / Auxiliary Contro L Valve Lever (2nd)
3-Pts Soulevez Le Cy Lindre D'aide Gauche [Se] [Vieux] / 3p-Lift Assist Cylinder Lh [Se] [Old]
3-Pts Soulevez Le Cy Lindre D'aide Gauche [Se] [Nouveau] / 3p-Lift Assis T Cylinder Lh [Se] [New]
3-Pts Soulevez Le Cy Lindre D'aide Droite [Se] [Vieux] / 3p-Lift Assist Cylinder Rh [Se] [Old]
3-Pts Soulevez Le Cy Lindre D'aide Droite [Se] [Nouveau] / 3p-Lift Assis T Cylinder Rh [Se] [New]
3-Pts Soulevez Le Cy Lindre D'aide [Parties Composantes] [Vieux] / 3p-Li Ft Assist Cylinder [Component Parts] [Old]
3-Pts Soulevez Le Cy Lindre D'aide [Parties Composantes] [Nouveau] / 3p- Lift Assist Cylinder [Component Parts] [New]
Tuyau De Reniflard ( 3-Pts Cylindre) / Breather Hose (3p Cylinder)
Tirant Superieur [Vieux] / Top Lin K [Old]
Tirant Superieur [Nouveau] / Top L Ink [New]
Tirant Inferieur [Noveau]] / Lower Link [New]
Stabilisateur [Se] [Vieux] / Stabi Lizer [Se] [Old]
Stabilisateur [Se] [Nouveau] / Sta Bilizer [Se] [New]
Barre De Relevage Droite [Vieux] / Lift Rod Rh [Old]
Barre De Relevage Droite [Nouveau] / Lift Rod Rh [New]
Barre De Relevage Gauche [Vieux] / Lift Rod Lh [Old]
Barre De Relevage Gauche [Nouveau] / Lift Rod Lh [New]
Support De La Barre D'attelage [Se ] / Drawbar Bracket [Se]
Protecteur Pdf [Se] / Pto Shaft Pr Otector [Se]
Calandre Avant / Front Grille
Capot Superieur / Hood (Bonnet) Upper
Capot Superieur (Insonorisant/Isolateur ) [Vieux] / Hood (Bonnet) Upper (Sound Absorber/Ins Ulator) [Old]
Capot Superieur (Insonorisant/Isolateur ) [Nouveau] / Hood (Bonnet) Upper (Sound Absorber/I Nsulator) [New]
Capot De Couvercle Lateral / Hood (Bonn Et) Side Cover
Support De Capot / Bonnet Support
Bouclier / Shield
Capot Arriere (Insonorisant) / Hood (Bo Nnet) Rear (Sound Absorber)
Retroviseur / Rearview Mirror
Aile / Fender
Plancher / Floor Sheet
Marchepied / Step
Couverture Superieure De Marchepied / S Tep Upper Cover
Repose De Marchepied/Insonorisant / Ste P Mat/Sound Absorber
Marchepied Auxiliaire / Auxiliary Step
Support Du Siège [Ec] [Se] / Seat Brack Et [Ec] [Se]
Boite Dutils / Tool Box
Cadre Anti-Renversement 1 (V Entrale) / Rops 1 (Mid)
Cadre Anti-Renversement 2 (A Rriere) / Rops 2 (Rear)
Etiquette (Arriere) [Ec] [Se] / Label ( Rear) [Ec] [Se]
Accessories Et Piece De Service / Accessories And Service Parts
Alternateur 1 (Alternateur) [Option] / Alte Rnator Kit 1 (Alternator) [Option]
Alternateur 2 (Harness) [Option] / Alternat Or Kit 2 (Wire Harness) [Option]
Alternateur [Parties Composantes] [Option] / Alternator [Component Parts] [Option]
Sortie Hydraulique A Distance Avant (Suppor T/Tuyau) [Option] / Front Remote Hydraulic Outlet ( Holder/Pipe) [Option]
Sortie Hydraulique A Distance Avant (1eme S Oupape) [Option] / Front Remote Hydraulic Outlet (1 St Valve) [Option]
Sortie Hydraulique A Distance Avant (2eme S Oupape) [Option] / Front Remote Hydraulic Outlet (2 Nd Valve) [Option]
Valve Auxiliaire (Fc) [Parties Composantes] [Option] / Front Remote Hydraulic Outlet (Fc) [Com Ponent Parts] [Option]
Valve Auxiliaire (Scd) [Parties Composantes ] [Option] [Vieux] / Front Remote Hydraulic Outlet (Scd) [Component Parts] [Option] [Old]
Valve Auxiliaire (Scd) [Parties Composantes ] [Option] [Nouveau] / Front Remote Hydraulic Outle T (Scd) [Component Parts] [Option] [New]
Sortie Hydraulique A Distance Avant (Couver Cle De Soupape) [Option] / Front Remote Hydraulic O Utlet (Valve Cover) [Option]
Sortie Hydraulique A Distance Avant (Levier De Commande) [Option] / Front Remote Hydraulic Out Let (Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Levier De 1eme) [Option] / Front Remote Hydraulic Outlet (1st Valve Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Levier De 2eme) [Option] / Front Remote Hydraulic Outlet (2nd Valve Control Lever) [Option]
Sortie Hydraulique A Distance Avant (Parent Hese De Garde) [Option] / Front Remote Hydraulic Ou Tlet (Guard Bracket) [Option]
Kit Levier De Soupape De Contrôle De L'auxi Liaire (3eme) [Option] / Auxiliary Control Valve Le Ver Kit (3rd) [Option]
Valve De Frein Remorque 1 (Soupape/Tuyau) [ Option] / Trailer Brake Valve Kit 1 (Valve/Pipe) [O Ption]
Valve De Frein Remorque 2 (Tuyau) [Option] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Valve De Frein Remorque 3 (Couvercle) [Opti On] / Trailer Brake Valve Kit 3 (Cover) [Option]
Support De La Barre D'attelage [Se] [Option ] [Vieux] / Drawbar Bracket Kit [Se] [Option] [Old]
Protecteur D'axe De Pdf [Se] [Option] [Vieu X] / Pto Shaft Protector Kit [Se] [Option] [Old]
Kit De Support Du Marche-Pied [Option] [Vie Ux] / Step Support Kit [Option] [Old]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Demarreur / Starter
Relais / Relay
Relais / Relay
Phare / Head Light
Phare / Head Light
Bouclier / Shield
Aile / Fender
Marchepied / Step
