Kubota Utility Tractors M5700DTN Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5700DTN Utility Tractors
Number of Pages: 249 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames Dalimentation / Fuel Camshaft
Levier D Arret Du Moteur / Engine Stop Lever
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Levier D'accelerateur / Hand Accelerator Lever
Solenoide D'arret/Cable D'arret Du Moteur / Stop Solenoid/Engine Stop Wire
Reservoir Carb. / Fuel Tank
Filtre A Carburant [Parties Compo Santes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Reservoir Du Radiate Ur / Reserve Tank
Alternateur Complet / Alt Ernator
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur/Detector / Sw Itch/Sensor
Commutateur (Tableau De B Ord)/Relais / Switch (Panel Board)/Relay
Tableau De Bord / Panel B Oard
Tableau De Bord (Pieces C Omposantes) / Panel Board [Component Parts]
Phare / Head Light
Feux Clignotant / Flasher Light
Feux Arriere / Tail Light
Faisceau Electrique / Ele Ctrical Wiring
Carter De Embrayage / Clutch Housing
Boite D'engrenage / Shuttle Gear Case
Carter De Transmissi On / Transmission Case
Couvrcle De Carter D E Boite Arriere / Transmission Case Rear Cover
Carter Entrainement / Front Drive Case
Embrayage / Clutch
Fourchette De Embray Age / Clutch Release Fork
Pedala D'embrayage / Clutch Pedal
Arbre De Entree / In Put Shaft
Premier Arbre / Firs T Shaft
Deuxieme Arbre / Sec Ond Shaft
Troisiem Arbre / Thi Rd Shaft
Arbre De Marche Arri Ere / Back Idle Shaft
Vitesse Rampante / C Reep Shaft
Engrenage Conique [O Ld Type] / Bevel Gear [Old Type]
Engrenage Conique [N Ew Type] / Bevel Gear [New Type]
Differentiel Arriere / Differential Rear
Arbre De Transmissio N Pdf / Pto Propeller Shaft
Pdf Embrayage / Pto Clutch
Embrayage Pdf [Parti Es Composantes] / Pto Clutch [Component Parts]
Soupape D'embrayage Pdf / Pto Clutch Valve
Soupape D'embrayage Pdf [Parties Composantes] / Pto Clutch Valve [Comp Onent Parts]
Arbre De Pdf / Pto S Haft
Arbre De Transmissio N (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Change Ment De Vitesses / Main Gear Shift Fork
Fourchtte De Inverse Ur / Shuttle Gear Shift Fork
Fourchette De Change Ment De Vitesses / Range Gear Shift Fork
Fourchette De Blocag E Differentiel / Rear Differential Lock Shift Fork
Axe Arriere / Rear A Xle
Frein / Brake
Tige De Frein / Brake Rod
Levier De Cahngement De Vite Sses Principal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift Lever
Levier De Changement De Vite Sses / Range Gear Shift Lever
Tige De Changement Vitesses / Range Gear Shift Rod
Levier De Commande De Embray Age Pdf / Pto Clutch Lever
Levier De Vitesses Pdf / Pto Gear Shift Lever
Levier De Tranission Aux Rou Es Avant / Front Wheel Drive Lever
Pedale De Frien / Brake Peda L
Pedale Bloc.Differentiel Arr Iere / Rear Differential Lock Pedal
Chassis Avant / Front Axl E Frame
Support De Reducteur / Fr Ont Axle Bracket
Arbre De Transmission / F Ront Propeller Shaft
Differentiel Avant / Diff Erential Front
Carter Engrenage Conique / Bevel Gear Case
Demi Arbre De Pont Avant / Differential Gear Shaft
Pont Avant / Front Axle
Servo Direction [Parties Composantes] / Stee Ring Controller [Component Parts]
Timoner De Direction / Steering Linkage
Support Avant Droit / Hydr Aulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydrauliq Ue (Aspiration) / Hydraulic Pipe (Suction)
Circuit De Huile Hydrauliq Ue (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hydrauliqu E (Direction/Pdf) / Hydraulic Oil Line (Steering/Pt O)
Tuyau De Direction (Refoul Ement) / Steering Hose (Delivery)
Cylindre Hydraulique / Hyd Raulic Cylinder
Bras De Relevage / Hydraul Ic Lift Arm
Couvercle De Cylindre Hydr Aulique / Hydraulic Cylinder Cover
Distributeur Hydraulique / Control Valve
Levier De Controle De Posi Tion Et D'effort / Draft And Position Control Lever
Support De Levier De Cont. De Position Et D'effort / Draft And Position Contro L Lever Bracket
Arbre De Controle De Posit Ion / Position Control Shaft
Arbre De Controle D'effort / Draft Control Shaft
Levier De Controle De Posi Tion / Feed Back Lever
Valve Auxiliaire / Auxilia Ry Control Valve
Valve Auxiliaire [Parties Composantes] / Auxiliary Control Valve [Component P Arts]
Support De Tirant Superieu R / Top Link Bracket
Tirant Superieur / Top Lin K
Bras Inferieurs / Lower Li Nk
Barre De Relevage / Lift R Od Lh
Barre De Attelage / Swingi Ng Drawbar
Protecteur Pdf / Pto Shaft Protector
Capot Avant / Hood(Bonnet) Front
Capot Superieur / Hood(Bonnet) Upper
Capot Lateral / Hood(Bonnet) Side
Capot De Couvercle Lateral / Hood(Bonnet) Sid E Cover
Capot Arriere / Hood(Bonnet) Rear
Retroviseur / Rearview Mirror
Aile / Fender
Plancher / Floor Seat
Marchpied / Step
Marchpied / Step
Siege / Seat
Boite Dutils / Tool Box
Cadre Anti-Renversement 1 (Ventrale) [Type Vi Eux] / Rops 1 (Mid) [Old Type]
Cadre Anti-Renversement 1 (Ventrale)[Type Nou Veau] / Rops 1 (Mid) [New Type]
Cadre Anti-Renversement 2 (Arriere) [Type Vie Ux] / Rops 2 (Rear) [Old Type]
Cadre Anti-Renversement 2 (Arriere) [Type Nou Veau] / Rops 2 (Rear) [New Type]
Roue Avant (8-16 ) / Front Wheel (8-16)
Roue Avant (9,5- 16) [Option] / Front Wheel (9.5-16) [Option]
Roue Arriere (12 ,4-24fl) / Rear Wheel (12.4-24fl)
Roue Arriere (14 ,9-24fl) [Option] / Rear Wheel (14.9-24fl) [Option]
Etiquette / Label
Accessories Et Piece De Service / Acces Sories And Service Parts
Eclairage De Travail [Option] / Working Light Kit [Option]
Kit D'accouplements Rapides [Option] / Trailer So Cket Kit [Option]
Fren De Stationnement [Option] / Paking Brake Lev Er Kit [Option] [Old Type]
Fren De Stationnement [Option] [New Type] / Pakin G Brake Lever Kit [Option] [New Type]
Support De Poids Avant [Option] / Front Weight Bu Mper Kit [Option]
Valve Auxiliaire [Option] / Auxiliary Control Val Ve Kit [Option]
Controle De La Valve Auxiliare [Parties Composant Es] [Option] / Auxiliary Control Valve [Component P Arts][Option]
Kit De Support Du Marche-Pied [Option] / Step Sup Port Kit [Option]
