Kubota Utility Tractors M5700DT Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5700DT Utility Tractors
Number of Pages: 235 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse [Excepte Type Cabine] / Cylinder Head [Rop S Type]
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames Dalimentation / Fuel Camshaft
Levier D Arret Du Moteur / Engine Stop Lever
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur Et Bougie De Prechauffage [Excepte Type Cabine] / Nozzle Holder And Glow Plug [Rops T Ype]
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Bride A Eau Et Thermostat [Excepte Type Cabine] / Water Flange And Thermostat [Rops Type]
Pompe A Eau / Water Pump
Collecteur D'echappement [Excepte Type Cabine] / E Xhaust Manifold [Rops Type]
Filtre A Air [Excepte Type Cabine] / Air Cleaner [ Rops Type]
Filtre A Air [Parties Composantes] / Air Cleaner [ Component Parts]
Silencieux [Excepte Type Cabine] / Muffler [Rops T Ype]
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur [Excepte Type Cabine] / Hand Accelerator Lever [Rops Type]
Solenoide D'arret/Cable D'arret Du Moteur [Excepte Type Cabine] / Stop Solenoid/Engine Stop Wire [Rop S Type]
Reservoir A Carburant [Excepte Typ E Cabine] / Fuel Tank [Rops Type]
Tuyau A Carburant [Excepte Type Ca Bine] / Fuel Pipe [Rops Type]
Filtre A Carburant [Parties Compos Antes] [Excepte Type Cabine] / Fuel Filter [Compone Nt Parts] [Rops Type]
Tuyau De Eau [Excepte Type Cabine] / Water Pipe [Rops Type]
Radiateur [Excepte Ty Pe Cabine] / Radiator [Rops Type]
Vase De Expansion [Ex Cepte Type Cabine] / Reserve Tank [Rops Type]
Alternateur [Excepte Type Cabine] / Alternator [Rops Type]
Alternateur [Parties Compo Santes] [Excepte Type Cabine] / Alternator [Compone Nt Parts] [Rops Type]
Lanceur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie [Excepte Type Cab Ine] / Battery [Rops Type]
Commutateur/Detector [Exce Pte Type Cabine] / Switch/Sensor [Rops Type]
Commutateur (Tableau De Bo Rd)[Excepte Type Cabine] / Switch (Panel Board) [Ro Ps Type]
Tableau De Bord [Excepte T Ype Cabine] / Panel Board [Rops Type]
Phare / Head Light
Feux De Detresse/Feux Arri Ere [Excepte Type Cabine] / Hazard Light/Tail Light [Rops Type]
Faisceau Electrique 1 [Exc Epte Type Cabine] / Electrical Wiring 1 [Rops Type]
Carter De Embrayage [ Excepte Type Cabine] / Clutch Housing [Rops Type]
Boite D'engrenage / S Huttle Gear Case
Carter De Transmissio N [Excepte Type Cabine] / Transmission Case [Rops T Ype]
Couvrcle De Carter De Boite Arriere / Transmission Case Rear Cover
Carter Entrainement / Front Drive Case
Embrayage / Clutch
Embrayage / Clutch
Fourchette De Embraya Ge [Excepte Type Cabine] / Clutch Release Fork [Rop S Type]
Pedale De Embrayage [ Excepte Type Cabine] / Clutch Pedal [Rops Type]
Arbre De Entree / Inp Ut Shaft
Premier Arbre / First Shaft
Deuxieme Arbre / Seco Nd Shaft
Troisiem Arbre [Excep T Type Cabine] / Third Shaft [Rops Type]
Arbre De Marche Arrie Re / Back Idle Shaft
Vitesse Rampante / Cr Eep Shaft
Engrenage Conique [Ty Pe Vieux] / Bevel Gear [Old Type]
Engrenage Conique [Ty Pe Nouveau] / Bevel Gear [New Type]
Differentiel Arriere / Differential Rear
Arbre De Transmission Pdf [Excepte Type Cabine] / Pto Propeller Shaft [R Ops Type]
Pdf Embrayage / Pto C Lutch
Embrayage Pdf [Partie S Composantes] / Pto Clutch [Component Parts]
Soupape D'embrayage P Df / Pto Clutch Valve
Soupape D'embrayage P Df [Parties Composantes] / Pto Clutch Valve [Compo Nent Parts]
Arbre De Pdf / Pto Sh Aft
Fourchette De Change Ment De Vitesses / Main Gear Shift Fork
Fourchtte De Inverse Ur / Shuttle Gear Shift Fork
Fourchette De Change Ment De Vitesses [Excepte Type Cabine] / Range Gear Shift Fork [Rops Type]
Fourchtte De Pdf / P To Shift Fork
Fourchette De Blocag E Differentiel / Rear Differential Lock Shift Fork
Levier De Cahngement De Vitesses Principal [Excepte Type Cabine] / Main Gear Shift Lever [Rops Type]
Levier De Inverseur [Excepte Type Cabine] / Shuttle Shift Lever [Rops T Ype]
Levier De Changement De Vitesses [Excepte Type Cabine] / Range Gear Shi Ft Lever [Rops Type]
Levier De Commande D E Embrayage Pdf [Excepte Type Cabine] / Pto Clutch Lever [Rops Type]
Levier De Transmissi On Aux Roues Avant [Excepte Type Cabine] / Front Wh Eel Drive Lever [Rops Type]
Axe Arriere / Rear Axle
Frein / Brake
Tige De Frein [Except Type Ca Bine] / Brake Rod [Rops Type]
Pedale De Frein [Excepte Type Cabine] / Brake Pedal [Rops Type]
Pedale Bloc.Differentiel Arri Ere [Excepte Type Cabine] / Rear Differential Lock Pedal [Rops Type]
Chassis Avant [Excepte Typ E Cabine] / Front Axle Frame [Rops Type]
Support De Reducteur / Fro Nt Axle Bracket
Arbre De Transmission / Fr Ont Propeller Shaft
Avant Carter De Differenti El / Front Differential Case
Differentiel Avant / Diffe Rential Front
Carter Reducteur / Front A Xle Case
Demi Arbre De Pont Avant / Differential Gear Shaft
Pont Avant / Front Axle
Volant De Direction [Excepte Type Cabine] / S Teering Handle [Rops Type]
Servo Direction [Excepte Type Cabine] / Steer Ing Controller [Rops Type]
Servo Direction [Parties Composantes] / Steer Ing Controller [Component Parts]
Timoner De Direction / Stee Ring Linkage
Cylindre De Direction [Part Ies Composantes] / Steering Cylinder [Component Par Ts]
Support Avant Droit / Hydra Ulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydrauliqu E (Aspiration) [Excepte Type Cabine] / Hydraulic Pi Pe (Suction) [Rops Type]
Circuit De Huile Hydrauliqu E (Refoulement) [Excepte Type Cabine] / Hydraulic P Ipe (Delivery) [Rops Type]
Circuit D'huile Hydraulique (Refroidisseur) [Excepte Type Cabine] / Hydraulic Oil Line (Oil Cooler) [Rops Type]
Circuit D'huile Hydraulique (Direction/Pdf) [Excepte Type Cabine] / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Tuyau De Direction (Refoule Ment) [Excepte Type Cabine] / Steering Hose (Delive Ry) [Rops Type]
Cylindre Hydraulique [Excep Te Type Cabine] / Hydraulic Cylinder [Rops Type]
Bras De Relevage / Hydrauli C Lift Arm
Couvercle De Cylindre Hydra Ulique [Excepte Type Cabine] / Hydraulic Cylinder C Over [Rops Type]
Distributeur Hydraulique / Control Valve
Levier De Controle De Posit Ion Et D'effort [Excepte Type Cabine] / Draft And P Osition Control Lever [Rops Type]
Arbre De Controle De Positi On / Position Control Shaft
Arbre De Controle D'effort / Draft Control Shaft
Levier De Controle De Posit Ion / Feed Back Lever
Valve Auxiliaire [Excepte T Ype Cabine] / Auxiliary Control Valve [Rops Type]
Valve Auxiliaire [Parties C Omposantes] [Excepte Type Cabine] / Auxiliary Contr Ol Valve [Component Parts] [Rops Type]
Support De Tirant Superieur [Excepte Type Cabine] / Top Link Bracket [Rops Type]
Tirant Superieur [Excepte Type Cabine] / Top Link [Rops Type]
Bras Inferieurs [Excepte Type Cabine] [Ty Pe Vieux] / Lower Link [Rops Type] [Old Type]
Bras Inferieurs [Excepte Type Cabine] [Ty Pe Nouveau] / Lower Link [Rops Type] [New Type]
Barre De Attelage [Excepte Type Cabine] / Swinging Drawbar [Rops Type]
Protecteur Pdf / Pto Shaft Protector
Capot Avant [Excepte Type Cabine] / Hood(Bonne T) Front [Rops Type]
Capot Superieur [Excepte Type Cabine] / Hood(B Onnet) Upper [Rops Type]
Capot Lateral [Excepte Type Cabine] / Hood(Bon Net) Side [Rops Type]
Capot Arriere [Excepte Type Cabine] / Hood(Bon Net) Rear [Rops Type]
Retroviseur [Excepte Type Cabine] / Rearview M Irror [Rops Type]
Aile [Excepte Type Cabine] / Fender [Rops Type ]
Plancher [Excepte Type Cabine] / Floor Seat [R Ops Type]
Marchpied [Excepte Type Cabine] / Step [Rops T Ype]
Cadre Anti-Renversement [Excepte Ty Pe Cabine] [Type Vieux] / Rops [Rops Type] [Old Typ E]
Cadre Anti-Renversement [Excepte Ty Pe Cabine] [Type Nouveau] / Rops [Rops Type] [New T Ype]
Si Ege [Excepte Type Cabine] / Seat [Rops Type]
Bo Ite Outils [Excepte Type Cabine] / Tool Box [Rops T Ype]
Roue Avant (9,5-22) [Option] / Front Wheel (9.5-22) [Option]
Roue Avant (8,3-24) [Option] / Front Wheel (8.3-24) [Option]
Roue Arriere (16,9-28) [Optio N] / Rear Wheel (16.9-28) [Option]
Roue Arriere (14,9-28) [Optio N] / Rear Wheel (14.9-28) [Option]
Etiquette [Excepte Type Cabine] / Label [Rops Type]
Accessories Et Piece De Service / Access Ories And Service Parts
Eclairage De Travail [Except Type Cabine][Option] / Working Light Kit [Rops Type] [Option]
Prise De Remorque [Except Type Cabine] [Option] / Trailer Socket Kit [Rops Type] [Option]
Levier De Frein Stationnement[Excepte Type Cabine] [Option] [Type Vieux] / Paking Brake Lever Kit [Ro Ps Type] [Option] [Old Type]
Levier De Frein Stationnement[Excepte Type Cabine] [Option] [Type Nouveau] / Paking Brake Lever Kit [ Rops Type] [Option] [New Type]
Valve Auxiliaire (Scd) [Excepte Type Cabine] [Opti On] / Auxiliary Control Valve Kit (Scd) [Rops Type] [Option]
Valve Auxiliaire (Fd)[Excepte Type Cabine] [Option ] / Auxiliary Control Valve Kit(Fd)[Rops Type] [Opt Ion]
Valve Auxiliaire(Scd)[Parties Composantes][Excepte Type Cabine][Option] / Auxiliary Control Valve(Scd )[Component Parts][Rops Type][Option]
Valve Auxiliaire(Fd)[Parties Composantes][Excepte Type Cabine][Option] / Auxiliary Control Valve(Fd)[ Component Parts][Rops Type][Option]
Kit De Support Du Marche-Pied [Option] / Step Supp Ort Kit [Option]
